ayush
21 April 2021 07:13
1
I am on the linux kernel 5.11.14
CPU : AMD Ryzen 7 4700U
Manjaro Gnome fully updated
lm-sensors doesnt show tctl or k10temp
i have tried running sensors-detect but no success
iwlwifi_1-virtual-0
Adapter: Virtual device
temp1: +57.0°C
nvme-pci-0100
Adapter: PCI adapter
Composite: +36.9°C (low = -273.1°C, high = +81.8°C)
(crit = +84.8°C)
Sensor 1: +36.9°C (low = -273.1°C, high = +65261.8°C)
amdgpu-pci-0400
vddgfx: 724.00 mV
vddnb: 806.00 mV
edge: +47.0°C
power1: 5.00 W
BAT1-acpi-0
Adapter: ACPI interface
in0: 11.85 V
acpitz-acpi-0
temp1: +47.0°C (crit = +125.0°C)
linub
21 April 2021 08:54
2
i run “sensors” and see cpu temps,but only 5 cores out of 12.
@ayush - output of:
sensors -u
inxi -v 8 -z
@linub - CPU temps are only for the physical cores (or do you have a 12 core processor?)
linub
21 April 2021 20:46
4
“lscpu”
CPU(s): 12
On-line CPU(s) list: 0-11
Thread(s) per core: 2
Core(s) per socket: 6
Socket(s): 1
Fabby
21 April 2021 21:26
5
1 Socket = 1 CPU
6 cores = 6 ALUs with each 2 pipelines bringing the total to 12, but you should see 6 T° numbered from 0-5. (1 per core)
E.G. on my system:
fab-user@fab-manjaro:~
$ lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
Address sizes: 39 bits physical, 48 bits virtual
CPU(s): 8
On-line CPU(s) list: 0-7
Core(s) per socket: 4
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 158
Model name: Intel(R) Core(TM) i7-7700HQ CPU @ 2.80GHz
Stepping: 9
CPU MHz: 3450.472
CPU max MHz: 3800.0000
CPU min MHz: 800.0000
BogoMIPS: 5599.85
Virtualization: VT-x
L1d cache: 128 KiB
L1i cache: 128 KiB
L2 cache: 1 MiB
L3 cache: 6 MiB
NUMA node0 CPU(s): 0-7
and then the T°:
$ sensors
coretemp-isa-0000
Adapter: ISA adapter
Package id 0: +65.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +60.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +61.0°C (high = +100.0°C, crit = +100.0°C)
Core 2: +65.0°C (high = +100.0°C, crit = +100.0°C)
Core 3: +65.0°C (high = +100.0°C, crit = +100.0°C)
Hi, hddtemp is EOL and drivetemp is now a kernel feature (from Linux 5.6 on)
echo "drivetemp" | sudo tee -a /etc/modules-load.d/modules.conf
sudo pacman -R hddtemp
[Note] removing hddtemp might break some conkys, but as said by @merlock below, this package is not even maintained…
Then
sudo systemctl status systemd-modules-load.service
or
sudo modprobe drivetemp
and
sensors
Source
nam1962:
Hi, hddtemp is EOL
I think it’s orphaned/unmaintained rather than EOL.
Personally, I don’t care for it:
drivetemp-scsi-2-0
Adapter: SCSI adapter
temp1: +36.0°C (low = +0.0°C, high = +70.0°C)
(crit low = +0.0°C, crit = +70.0°C)
(lowest = +30.0°C, highest = +40.0°C)
drivetemp-scsi-4-0
temp1: +41.0°C (low = +0.0°C, high = +60.0°C)
(crit low = -40.0°C, crit = +70.0°C)
(lowest = +39.0°C, highest = +47.0°C)
drivetemp-scsi-0-0
temp1: +35.0°C (low = +0.0°C, high = +70.0°C)
vs
sudo hddtemp /dev/sd[a-c]
/dev/sda: Samsung SSD 860 EVO 500G B @: 35°C
/dev/sdb: Samsung SSD 860 EVO 500G B @: 36°C
/dev/sdc: Hitachi HDS723020BLA642: 41°C
Oh, and recommending to remove hddtemp might break a lot of peoples’ conky setups.
Fabby
23 April 2021 12:59
8
@merlock
Nam1962 never said to remove hddtemp: those commands just activate drivetemp
@nam1962 :Thanks! Didn’t know about that and I’ve got both hddtemp
and drivetemp
active now and will drop the former once Conky supports the latter!
moson
23 April 2021 14:53
9
Strange that k10temp is missing.
Please try
sudo rmmod k10temp
sudo modprobe k10temp force=1
Does it show up in sensors
afterwards?
Edit: @Yochanan ninja’d me.
No problem, I added a note.
Anyhow, no pity for such outdated package
Fabby
23 April 2021 18:03
14
So is your problem solved now with all the benter in-between? If not, try 5.10 LTS or if that doesn’t work, 5.12 stable as these things are built into the kernel!
Hi !
Small reminder : drivetemp is in the kernel from 5.6 on !
ayush
30 April 2021 14:45
17
Thank you so much , sorry I didn’t check earlier
This works , I wasn’t sure why k10temp was not probed earlier.
moson
30 April 2021 14:52
18
Ok, cool.
If you want to make it persistent across reboots, create a file /etc/modprobe.d/k10temp.conf
sudo nano /etc/modprobe.d/k10temp.conf
and paste the following text
options k10temp force=1
(save with CTRL+S, exit nano with CTRL+X)
system
Closed
15 May 2021 14:52
19
