Hello there! I have my laptop with Manjaro 26.0.4 and hybrid graphics.
I’m using xrandr and X11 (not Wayland) to create custom screen resolution to switch from 1920x1080 to 3840x2160. On intel integrated gpu or hybrid mode I get the message “Configure crtc 0 failed”. If I use NVIDIA GPU mode and do the same, I will get the message “Configure crtc 0 failed” and X error:
# envycontrol, Intel Integrated GPU mode
$ cvt 3840 2160 60
# 3840x2160 59.98 Hz (CVT 8.29M9) hsync: 134.18 kHz; pclk: 712.75 MHz
Modeline "3840x2160_60.00" 712.75 3840 4152 4576 5312 2160 2163 2168 2237 -hsync +vsync
$ xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 382mm x 215mm
1920x1080 144.03 + 60.01* 59.97 59.96 60.01 59.93
1680x1050 59.95 59.88
1400x1050 74.76 59.98
320x200 85.27
320x180 59.84 59.32
320x175 85.27
$ xrandr --newmode "3840x2160_60.00" 712.75 3840 4152 4576 5312 2160 2163 2168 2237 -hsync +vsync
$ xrandr --addmode eDP-1 "3840x2160_60.00"
$ xrandr --output eDP-1 --mode "3840x2160_60.00"
xrandr: Configure crtc 0 failed
# envycontrol, Hybrid Mode
$ cvt 3840 2160 60
$ xrandr
320x200 85.27
320x180 59.84 59.32
320x175 85.27
HDMI-1-0 disconnected (normal left inverted right x axis y axis)
# envycontrol, NVIDIA GPU mode
$ cvt 3840 2160 60
$ xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
HDMI-0 disconnected (normal left inverted right x axis y axis)
eDP-1-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 382mm x 215mm
320x200 85.27
320x180 59.84 59.32
320x175 85.27
$ xrandr --addmode eDP-1-1 "3840x2160_60.00"
$ xrandr --output eDP-1-1 --mode "3840x2160_60.00"
X Error of failed request: BadMatch (invalid parameter attributes)
Major opcode of failed request: 140 (RANDR)
Minor opcode of failed request: 7 (RRSetScreenSize)
Serial number of failed request: 50
Current serial number in output stream: 51
On Intel Integrated GPU mode or Hybrid mode if I change from 1920x1080 to 3840x2160 via GUI display settings, nothing changes, but doing the same on NVIDIA GPU mode gives me a black screen and a cursor. Also if I enable NVIDIA GPU mode via envycontrol to get “X Screen Display Configuration” on NVIDIA X Server Settings (it doesn’t work on Intel Integrated GPU or Hybrid Mode), I can’t create a custom resolution. Here is the screenshot:
I would be interested to know if it is possible to set custom screen resolution 3840x2160 on a display 1920x1080 with proprietary NVIDIA drivers (screenshot hardware configuration below)? Any help will be appreciated.
Mod edit: Tidied up formatting (removing all those zsh-generated junk characters) and also removed the unneeded screenshots.
Welcome to the forum.
Please post the result of inxi -zv8 so we get more info about your system.
When posting the info, either put three backticks ( ` -sign) on an empty line before and after it, or paint over the text and then press “preformatted text” </> from the post toolbar. With long entries, you might also want to use “hide details” on it from behind the + -button on the toolbar to make the post more manageable.
Here is the result of inxi -zv8:
Kernel: 6.18.18-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=6cda8aed-a4fe-4cb7-abdc-52a111290da0 rw quiet splash
resume=UUID=03b53ee8-b2df-4747-86b5-c5513edcaac5 udev.log_priority=3
Desktop: KDE Plasma v: 6.5.6 tk: Qt v: N/A info: frameworks v: 6.24.0
Type: Laptop System: Micro-Star product: GF75 Thin 10UEK v: REV:1.0
Mobo: Micro-Star model: MS-17F5 v: REV:1.0 serial: <superuser required>
part-nu: 17F5.1 uuid: <superuser required> Firmware: UEFI
vendor: American Megatrends v: E17F5IMS.101 date: 12/15/2020
ID-1: BAT1 charge: 42.7 Wh (100%) condition: 42.7/51.3 Wh (83.3%)
volts: 12.85 min: 11.4 model: MSI BIF0_9 type: Li-ion serial: N/A charging:
status: full cycles: N/A
System RAM: total: 8 GiB available: 7.57 GiB used: 2.71 GiB (35.8%)
Array-1: capacity: 32 GiB slots: 2 modules: 1 EC: None
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 8 GiB speed:
spec: 3200 MT/s actual: 2933 MT/s volts: note: check curr: 1 min: 1 max: 1
width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M471A1G44AB0-CWE serial: <filter>
Device-2: ChannelB-DIMM0 type: no module installed
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0x100
Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62399
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
vme vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology
xtpr
Type: indirect_target_selection mitigation: Aligned branch/return thunks
Type: retbleed mitigation: Enhanced IBRS
conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q]
vendor: Micro-Star MSI driver: nvidia v: 590.48.01
alternate: nouveau,nova_core,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-11; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: none
empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Display: x11 server: X.Org v: 21.1.21 with: Xwayland v: 24.1.9
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia
alternate: fbdev,nouveau,nv,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x978f built: 2020 res: N/A dpi: 128
gamma: 1.2 chroma: red: x: 0.576 y: 0.345 green: x: 0.353 y: 0.580 blue:
x: 0.161 y: 0.125 white: x: 0.314 y: 0.329 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: 1920x1080
drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 26.0.2-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
device-ID: 8086:9bc4 memory: 7.39 GiB unified: yes
API: Vulkan v: 1.4.341 layers: 7 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Laptop GPU driver: nvidia v: 590.48.01
device-ID: 10de:2520 surfaces: N/A
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
API: ALSA v: k6.18.18-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.6.2 status: active with: 1: pipewire-pulse
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 8087:0026
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 2 state: down bt-service: enabled,running
Local Storage: total: 476.94 GiB used: 86.77 GiB (18.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PCP3512F-AI1
lanes: 4 tech: SSD serial: <filter> fw-rev: ECFK52.8 temp: 25.9 C
scheme: GPT
ID-1: / raw-size: 50 GiB size: 48.91 GiB (97.83%) used: 13.8 GiB (28.2%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 6cda8aed-a4fe-4cb7-abdc-52a111290da0
used: 328 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 5288-8D80
ID-3: /home raw-size: 423.44 GiB size: 415.72 GiB (98.18%)
used: 72.97 GiB (17.6%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
label: N/A uuid: 8162e923-fc81-4404-b1e7-4d06096a8943
ID-1: swap-1 type: partition size: 3 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 03b53ee8-b2df-4747-86b5-c5513edcaac5
Device-1: 1-5:2 info: SHARKOON GmbH 2.4GHz Wireless rechargeable vertical
mouse [More&Better] type: mouse driver: hid-generic,usbhid interfaces: 1
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
chip-ID: 1ea7:0064 class-ID: 0301
Device-2: 1-7:3 info: SteelSeries ApS KLC type: HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 1038:1122 class-ID: 0300
Device-3: 1-14:4 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-2: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
System Temperatures: cpu: 31.0 C pch: 40.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1328 libs: 358 tools: pamac pm: flatpak pkgs: 0
1: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
2: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
3: https://mirror.bakertelekom.fr/manjaro/stable/$repo/$arch
4: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
5: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
6: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
7: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
8: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
9: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
10: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
11: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
12: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
13: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
14: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
15: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
16: https://manjaro.grena.ge/stable/$repo/$arch
17: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
18: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
19: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
20: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
21: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
22: https://muug.ca/mirror/manjaro/stable/$repo/$arch
23: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
24: https://ftp.yz.yamagata-u.ac.jp/pub/linux/manjaro/stable/$repo/$arch
25: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
26: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
27: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
28: https://manjaro.ynh.ovh/stable/$repo/$arch
29: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
30: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
31: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
32: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
33: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
34: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
35: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
36: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
37: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
38: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
39: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
40: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
41: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
42: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
43: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
44: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
45: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
46: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
47: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
48: https://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
49: https://manjaro.mirror-services.net/pub/stable/$repo/$arch
50: https://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
51: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
52: https://mirror.fcix.net/manjaro/stable/$repo/$arch
53: https://mirror.init7.net/manjaro/stable/$repo/$arch
54: https://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
55: https://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
56: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
57: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
58: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
59: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
60: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
61: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
62: https://mirror.easyname.at/manjaro/stable/$repo/$arch
63: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
64: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
65: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
66: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
67: https://mirror.rabisu.com/mirrors/manjaro/stable/$repo/$arch
68: https://mirrors.manjaro.org/repo/stable/$repo/$arch
69: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
70: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
71: https://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
72: https://linorg.usp.br/manjaro/stable/$repo/$arch
73: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
74: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
75: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
76: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
77: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
78: https://mirrors2.manjaro.org/stable/$repo/$arch
79: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
80: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
81: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
82: https://mirror.23m.com/manjaro/stable/$repo/$arch
83: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
84: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
85: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
86: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
87: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
88: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
89: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
90: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
91: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
92: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
93: https://mirror.dc.uz/manjaro/stable/$repo/$arch
94: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
95: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
96: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
97: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
98: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
99: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
100: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
101: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
102: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
Processes:
CPU top: 5 of 343
1: cpu: 8.9% command: Can't started-by: firefox pid: 6138
mem: 681.5 MiB (8.7%)
2: cpu: 5.6% command: konsole pid: 7265 mem: 229.0 MiB (2.9%)
3: cpu: 4.9% command: zsh pid: 7283 mem: 10.4 MiB (0.1%)
4: cpu: 4.2% command: kwin_x11 pid: 990 mem: 180.6 MiB (2.3%)
5: cpu: 4.1% command: Xorg pid: 806 mem: 133.0 MiB (1.7%)
Memory top: 5 of 343
1: mem: 681.5 MiB (8.7%) command: Can't started-by: firefox pid: 6138
cpu: 8.9%
2: mem: 460.0 MiB (5.9%) command: plasmashell pid: 1035 cpu: 0.8%
3: mem: 274.1 MiB (3.5%) command: firefox pid: 6551 cpu: 0.3%
4: mem: 264.0 MiB (3.4%) command: dolphin pid: 3006 cpu: 0.1%
5: mem: 229.0 MiB (2.9%) command: konsole pid: 7265 cpu: 5.6%
Processes: 343 Power: uptime: 1h 42m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 2.96 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 259 default: graphical
tool: systemctl
Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.40
dmt
26 April 2026 12:23
4
kondrakov67:
GF75 Thin 10UEK
Is this your laptop?
https://www.msi.com/Laptop/GF75-Thin-10UX/Specification
It has a 1920x1080 screen so why would you try to set it to 3840x2160? You can’t exceed the native resolution.
Ben
26 April 2026 12:34
5
You cannot display more pixels than you have - this is a weird idea.
Yes, it is MSI GF75. Thanks for the answers, it was interesting to find out. I have an older laptop with AMD drivers, and I can use xrandr to set custom resolution 1920x1080 on a display 1366x768 using the commands listed above in the question (envycontrol was not used in this case). I remember exactly that it works with open-source drivers.
BG405
26 April 2026 17:48
7
Were you actually using something like newrez? I can’t find it now, but I was using it on my netbook when I was running it with Mint.
It utilized the VGA circuitry and used interpolation to display whatever crazy source resolution you wanted on that 1024x600 screen, worked quite well but had a downside: it tied up the VGA output so couldn’t use a second monitor.
dmt
26 April 2026 19:50
8
Sometimes a resolution isn’t detected properly, in that case you can add it in. However you can’t add arbitrary resolutions, only ones supported by the hardware.
