Can't change system language to English
After install I had English as system language and still in system settings I can see only English
But at you can see system language now Russian and I don’t know how to switch it back, because I didn’t switch it at all.
So how to change language back? And how to delete language pack?
cat locale.conf         ✔
LANG=en_US.UTF-8
locale         ✔
LANG=ru_RU.UTF-8
And I already did sudo locale-gen
Just to be clear:
  1. that is /etc/locale.conf?
  2. en_US.UTF8 line in /etc/locale.gen is uncommented?
Please post the output of that command.
  1. Yep
# /etc/locale.conf
LANG=en_US.UTF-8
LC_ADDRESS=ru_RU.UTF-8
LC_IDENTIFICATION=ru_RU.UTF-8
LC_MEASUREMENT=ru_RU.UTF-8
LC_MONETARY=ru_RU.UTF-8
LC_NAME=ru_RU.UTF-8
LC_NUMERIC=ru_RU.UTF-8
LC_PAPER=ru_RU.UTF-8
LC_TELEPHONE=ru_RU.UTF-8
LC_TIME=ru_RU.UTF-8
# /etc/locale.gen
# Locales enabled by Calamares
en_US.UTF-8 UTF-8
ru_RU.UTF-8 UTF-8
sudo locale-gen         ✔
Generating locales...
  en_US.UTF-8... done
  ru_RU.UTF-8... done
Generation complete.
Copying saved locales...
Copying complete.
Even if I comment RU string in locale.gen and run locale-gen nothing changes (
So I changed it back to English. I’m manually add russian here:
And after that switched it back and forth couple times and after relogin I have English system language. But I still don’t know where this settings stored.
Hi , thanks very much for your contribution. As a newbie to Manjaro, I’ve struggled with setting up the correct language/locale for over 1 hour. I originally chose uk_… - turns out that was ukranian?! Having followed the advice before your post, was STILL left with a job half done. The duplication of a setting foir a user profile should ideally be made CLEAR in the setup - not everyone is a linux guru. Thanks again. Joe.
It’s unclear whether you still have a problem and are asking for assistance or whether you just wanted to vent some frustration :wink:
