I am getting this error when using this command:
⋊> ~ sudo xrandr --output eDP-1 --mode 1920x1080 --rate 60.01
xrandr: Configure crtc 0 failed
now here are the available refresh rates
⋊> ~ xrandr --query
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP-1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
1920x1080 144.00*+ 60.01 59.97 59.96 59.93
i tried it without sudo and that didn’t work and even lxappearance can’t change it. how do i fix this
also if its necessary, i am using qtile on manjaro xfce and the laptop is a dell g3 3590. Is the xfce setting blocking the xrandr function or is it something else?
let me know if there is other info i need to provide
also here are a few red lines i found in dmesg, let me know if there is an issue here:
[ 5879.125878] wlp0s20f3: authenticated
[ 5879.126880] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[ 5879.130010] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[ 5879.136559] wlp0s20f3: associated
[ 5932.176824] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[ 5932.225328] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[ 5932.225340] wlp0s20f3: 80 MHz not supported, disabling VHT
[ 5932.228262] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[ 5932.260753] wlp0s20f3: authenticated
[ 5932.260948] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[ 5932.263150] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[ 5932.271627] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[ 5932.276441] wlp0s20f3: associated
[ 5932.446245] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[ 5953.469957] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[ 5953.528258] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[ 5953.531453] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[ 5953.555115] wlp0s20f3: authenticated
[ 5953.556281] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[ 5953.559185] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[ 5953.562813] wlp0s20f3: associated
[ 6065.205792] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[ 6065.247319] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[ 6065.247330] wlp0s20f3: 80 MHz not supported, disabling VHT
[ 6065.248840] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[ 6065.286169] wlp0s20f3: authenticated
[ 6065.286320] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[ 6065.288852] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[ 6065.306798] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[ 6065.310954] wlp0s20f3: associated
[ 6065.358999] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[ 6096.625551] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[ 6096.676172] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[ 6096.679272] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[ 6096.702833] wlp0s20f3: authenticated
[ 6096.705226] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[ 6096.706951] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[ 6096.712241] wlp0s20f3: associated
[ 6143.745285] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[ 6143.791348] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[ 6143.791371] wlp0s20f3: 80 MHz not supported, disabling VHT
[ 6143.794802] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[ 6143.832043] wlp0s20f3: authenticated
[ 6143.832191] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[ 6143.834919] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[ 6143.839681] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[ 6143.843818] wlp0s20f3: associated
[ 6143.898417] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[ 6448.029276] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[ 6448.068120] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[ 6448.073409] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[ 6448.097915] wlp0s20f3: authenticated
[ 6448.098745] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[ 6448.102640] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[ 6448.106498] wlp0s20f3: associated
[ 6494.371875] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[ 6494.420027] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[ 6494.420038] wlp0s20f3: 80 MHz not supported, disabling VHT
[ 6494.421876] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[ 6494.449300] wlp0s20f3: authenticated
[ 6494.449450] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[ 6494.451520] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[ 6494.457934] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[ 6494.463949] wlp0s20f3: associated
[ 6494.509650] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[ 6795.589315] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[ 6795.649655] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[ 6795.653393] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[ 6795.709982] wlp0s20f3: authenticated
[ 6795.715033] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[ 6795.718205] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[ 6795.723356] wlp0s20f3: associated
[ 6842.822229] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[ 6842.859810] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[ 6842.859825] wlp0s20f3: 80 MHz not supported, disabling VHT
[ 6842.861649] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[ 6842.894465] wlp0s20f3: authenticated
[ 6842.894647] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[ 6842.895256] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[ 6842.900160] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[ 6842.907248] wlp0s20f3: associated
[ 6842.969165] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[ 7144.151671] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[ 7144.190227] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[ 7144.193359] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[ 7144.218487] wlp0s20f3: authenticated
[ 7144.219517] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[ 7144.222364] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[ 7144.227781] wlp0s20f3: associated
[ 7191.389515] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[ 7191.435755] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[ 7191.435790] wlp0s20f3: 80 MHz not supported, disabling VHT
[ 7191.439398] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[ 7191.475066] wlp0s20f3: authenticated
[ 7191.475230] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[ 7191.479161] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[ 7191.487525] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[ 7191.491567] wlp0s20f3: associated
[ 7191.635656] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[ 7432.821799] device vboxnet0 left promiscuous mode
[ 7432.847347] vboxnetflt: 139 out of 214 packets were not sent (directed to host)
[ 7492.744515] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[ 7492.836341] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[ 7492.839196] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[ 7492.863586] wlp0s20f3: authenticated
[ 7492.866857] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[ 7492.870126] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[ 7492.874753] wlp0s20f3: associated
[ 7540.120122] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[ 7540.168953] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[ 7540.168969] wlp0s20f3: 80 MHz not supported, disabling VHT
[ 7540.171358] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[ 7540.205365] wlp0s20f3: authenticated
[ 7540.205548] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[ 7540.206502] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[ 7540.216925] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[ 7540.221102] wlp0s20f3: associated
[ 7540.299687] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[ 7841.404712] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[ 7841.445645] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[ 7841.450188] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[ 7841.474651] wlp0s20f3: authenticated
[ 7841.477604] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[ 7841.481540] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[ 7841.486667] wlp0s20f3: associated
[ 7888.637929] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[ 7888.675817] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[ 7888.675839] wlp0s20f3: 80 MHz not supported, disabling VHT
[ 7888.679096] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[ 7888.717013] wlp0s20f3: authenticated
[ 7888.717218] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[ 7888.717245] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[ 7888.724124] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[ 7888.728417] wlp0s20f3: associated
[ 7888.760045] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[ 8189.975601] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[ 8190.045441] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[ 8190.050513] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[ 8190.075459] wlp0s20f3: authenticated
[ 8190.078405] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[ 8190.081756] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[ 8190.087086] wlp0s20f3: associated
[ 8237.201991] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[ 8237.253224] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[ 8237.253238] wlp0s20f3: 80 MHz not supported, disabling VHT
[ 8237.254734] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[ 8237.284784] wlp0s20f3: authenticated
[ 8237.284964] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[ 8237.288014] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[ 8237.293222] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[ 8237.297328] wlp0s20f3: associated
[ 8237.323192] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[ 8538.755848] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[ 8538.806618] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[ 8538.809457] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[ 8538.834782] wlp0s20f3: authenticated
[ 8538.835574] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[ 8538.838871] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[ 8538.844078] wlp0s20f3: associated
[ 8585.672279] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[ 8585.719934] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[ 8585.719951] wlp0s20f3: 80 MHz not supported, disabling VHT
[ 8585.721782] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[ 8585.839649] wlp0s20f3: authenticated
[ 8585.839843] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[ 8585.841886] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[ 8585.852848] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[ 8585.857174] wlp0s20f3: associated
[ 8585.885868] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[ 8887.003512] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[ 8887.046431] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[ 8887.051229] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[ 8887.074833] wlp0s20f3: authenticated
[ 8887.076251] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[ 8887.079538] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[ 8887.085253] wlp0s20f3: associated
[ 8934.249612] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[ 8934.288071] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[ 8934.288084] wlp0s20f3: 80 MHz not supported, disabling VHT
[ 8934.290435] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[ 8934.324594] wlp0s20f3: authenticated
[ 8934.324721] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[ 8934.325873] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[ 8934.330720] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[ 8934.335556] wlp0s20f3: associated
[ 8934.347544] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[ 9235.795906] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[ 9235.836628] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[ 9235.842931] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[ 9235.867367] wlp0s20f3: authenticated
[ 9235.870328] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[ 9235.874411] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[ 9235.879847] wlp0s20f3: associated
[ 9282.823747] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[ 9282.861758] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[ 9282.861770] wlp0s20f3: 80 MHz not supported, disabling VHT
[ 9282.863873] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[ 9282.895869] wlp0s20f3: authenticated
[ 9282.896033] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[ 9282.899917] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[ 9282.904702] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[ 9282.907249] wlp0s20f3: associated
[ 9282.915931] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[ 9584.264771] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[ 9584.318243] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[ 9584.323101] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[ 9584.347927] wlp0s20f3: authenticated
[ 9584.351055] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[ 9584.353866] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[ 9584.360200] wlp0s20f3: associated
[ 9631.580944] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[ 9631.618782] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[ 9631.618812] wlp0s20f3: 80 MHz not supported, disabling VHT
[ 9631.620596] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[ 9631.655953] wlp0s20f3: authenticated
[ 9631.656072] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[ 9631.657315] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[ 9631.687822] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[ 9631.694126] wlp0s20f3: associated
[ 9631.881993] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[ 9679.295412] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[ 9679.345679] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[ 9679.350028] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[ 9679.373240] wlp0s20f3: authenticated
[ 9679.373631] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[ 9679.377844] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[ 9679.381599] wlp0s20f3: associated
[ 9726.206985] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[ 9726.265821] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[ 9726.265832] wlp0s20f3: 80 MHz not supported, disabling VHT
[ 9726.268404] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[ 9726.300048] wlp0s20f3: authenticated
[ 9726.300206] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[ 9726.303321] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[ 9726.308196] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[ 9726.315892] wlp0s20f3: associated
[ 9726.394922] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[10027.696608] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[10027.767556] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[10027.771819] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[10027.795606] wlp0s20f3: authenticated
[10027.799417] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[10027.802369] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[10027.805935] wlp0s20f3: associated
[10081.597587] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[10081.649931] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[10081.649946] wlp0s20f3: 80 MHz not supported, disabling VHT
[10081.652074] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[10081.687704] wlp0s20f3: authenticated
[10081.687928] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[10081.690681] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[10081.700462] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[10081.703477] wlp0s20f3: associated
[10081.715841] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[10327.806057] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[10327.842259] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[10327.845381] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[10327.869804] wlp0s20f3: authenticated
[10327.870583] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[10327.873670] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[10327.878895] wlp0s20f3: associated
[10379.220627] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[10379.291311] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[10379.291324] wlp0s20f3: 80 MHz not supported, disabling VHT
[10379.294120] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[10379.324368] wlp0s20f3: authenticated
[10379.324599] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[10379.325991] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[10379.331925] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[10379.339041] wlp0s20f3: associated
[10379.388097] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[10382.499715] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[10382.544502] iwlwifi 0000:00:14.3: Unhandled alg: 0x71b
[10382.545212] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[10382.550462] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[10382.574224] wlp0s20f3: authenticated
[10382.576021] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[10382.578427] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[10382.582002] wlp0s20f3: associated
[10526.263199] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[10526.324268] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[10526.324280] wlp0s20f3: 80 MHz not supported, disabling VHT
[10526.325810] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[10526.361595] wlp0s20f3: authenticated
[10526.361718] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[10526.362733] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[10526.368350] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[10526.372747] wlp0s20f3: associated
[10526.430199] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[10827.617762] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[10827.667180] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[10827.674140] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[10827.698187] wlp0s20f3: authenticated
[10827.700715] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[10827.702367] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[10827.705842] wlp0s20f3: associated
[10874.757205] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[10874.831527] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[10874.831539] wlp0s20f3: 80 MHz not supported, disabling VHT
[10874.833030] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[10874.867607] wlp0s20f3: authenticated
[10874.867805] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[10874.873446] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[10874.880338] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[10874.883026] wlp0s20f3: associated
[10874.892391] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[11176.256348] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[11176.297430] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[11176.301741] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[11176.326151] wlp0s20f3: authenticated
[11176.332527] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[11176.336426] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[11176.340188] wlp0s20f3: associated
[11223.289007] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[11223.337681] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[11223.337698] wlp0s20f3: 80 MHz not supported, disabling VHT
[11223.340276] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[11223.382096] wlp0s20f3: authenticated
[11223.382378] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[11223.385321] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[11223.392479] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[11223.397002] wlp0s20f3: associated
[11223.453493] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[11524.532085] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[11524.580093] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[11524.584746] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[11524.610345] wlp0s20f3: authenticated
[11524.611702] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[11524.614355] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[11524.619276] wlp0s20f3: associated
[11571.811610] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[11571.858970] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[11571.858985] wlp0s20f3: 80 MHz not supported, disabling VHT
[11571.860487] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[11571.896503] wlp0s20f3: authenticated
[11571.896693] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[11571.897887] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[11571.905009] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[11571.908995] wlp0s20f3: associated
[11571.914127] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[11873.204927] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[11873.256495] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[11873.261285] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[11873.288477] wlp0s20f3: authenticated
[11873.291279] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[11873.294707] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[11873.298618] wlp0s20f3: associated
[11920.431130] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[11920.494931] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[11920.494947] wlp0s20f3: 80 MHz not supported, disabling VHT
[11920.496767] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[11920.531077] wlp0s20f3: authenticated
[11920.531443] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[11920.534147] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[11920.541461] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[11920.545769] wlp0s20f3: associated
[11920.579812] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[12224.261704] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[12224.304220] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[12224.307931] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[12224.331906] wlp0s20f3: authenticated
[12224.334344] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[12224.336532] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[12224.341870] wlp0s20f3: associated
[12271.124103] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[12271.172843] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[12271.172871] wlp0s20f3: 80 MHz not supported, disabling VHT
[12271.175773] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[12271.212175] wlp0s20f3: authenticated
[12271.212353] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[12271.213873] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[12271.228660] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[12271.231211] wlp0s20f3: associated
[12271.292203] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[12571.841943] iwlwifi 0000:00:14.3: Unhandled alg: 0x703
[12571.933080] iwlwifi 0000:00:14.3: Unhandled alg: 0x703
[12574.658954] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[12574.719605] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[12574.725089] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[12574.750432] wlp0s20f3: authenticated
[12574.751915] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[12574.754173] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[12574.759949] wlp0s20f3: associated
[12627.728633] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[12627.769801] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[12627.769823] wlp0s20f3: 80 MHz not supported, disabling VHT
[12627.771943] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[12627.811838] wlp0s20f3: authenticated
[12627.812220] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[12627.814943] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[12627.829165] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[12627.833255] wlp0s20f3: associated
[12627.842465] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[12740.944543] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[12741.001815] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[12741.005248] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[12741.028625] wlp0s20f3: authenticated
[12741.030779] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[12741.033347] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[12741.038715] wlp0s20f3: associated
[12786.944188] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[12786.982724] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[12786.982738] wlp0s20f3: 80 MHz not supported, disabling VHT
[12786.984752] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[12787.023540] wlp0s20f3: authenticated
[12787.023838] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[12787.030367] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[12787.040391] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[12787.044453] wlp0s20f3: associated
[12787.071010] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[12790.254527] ACPI Error: Thread 703856640 cannot release Mutex [ECMX] acquired by thread 148701184 (20220331/exmutex-378)
[12790.254538] ACPI Error: Aborting method \_SB.PCI0.LPCB.ECDV._Q66 due to previous error (AE_AML_NOT_OWNER) (20220331/psparse-529)
[12816.330836] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[12816.381401] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[12816.386565] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[12816.411419] wlp0s20f3: authenticated
[12816.413542] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[12816.417631] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[12816.423884] wlp0s20f3: associated
[12852.789879] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[12852.790606] sd 0:0:0:0: [sda] Stopping disk
[12863.473576] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[12863.516880] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[12863.516896] wlp0s20f3: 80 MHz not supported, disabling VHT
[12863.520006] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[12863.549730] wlp0s20f3: authenticated
[12863.549969] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[12863.553241] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[12863.568724] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[12863.572853] wlp0s20f3: associated
[12863.664991] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[12897.509893] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[12897.516123] ata1.00: configured for UDMA/100
[12897.516992] sd 0:0:0:0: [sda] Starting disk
[12902.063352] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[12902.104007] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[12902.109081] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[12902.132368] wlp0s20f3: authenticated
[12902.132818] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[12902.134739] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[12902.141849] wlp0s20f3: associated
[12917.720364] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[12917.721103] sd 0:0:0:0: [sda] Stopping disk
[12948.059639] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[12948.129113] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[12948.129142] wlp0s20f3: 80 MHz not supported, disabling VHT
[12948.132643] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[12948.161692] wlp0s20f3: authenticated
[12948.161909] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[12948.162445] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[12948.167652] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[12948.175515] wlp0s20f3: associated
[12948.347955] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[12953.442990] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[12953.449271] ata1.00: configured for UDMA/100
[12953.450217] sd 0:0:0:0: [sda] Starting disk
[12981.972820] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[12982.025458] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[12982.030607] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[12982.053760] wlp0s20f3: authenticated
[12982.055586] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[12982.058573] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[12982.064729] wlp0s20f3: associated
[13005.729897] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[13005.730613] sd 0:0:0:0: [sda] Stopping disk
[13028.635559] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[13028.687569] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[13028.687585] wlp0s20f3: 80 MHz not supported, disabling VHT
[13028.690650] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[13028.726730] wlp0s20f3: authenticated
[13028.726934] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[13028.728522] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[13028.738705] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[13028.743707] wlp0s20f3: associated
[13028.834268] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[13062.191990] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[13062.231343] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[13062.238135] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[13062.262945] wlp0s20f3: authenticated
[13062.264874] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[13062.267383] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[13062.273444] wlp0s20f3: associated
[13068.182198] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[13068.188390] ata1.00: configured for UDMA/100
[13068.189240] sd 0:0:0:0: [sda] Starting disk
[13093.954352] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[13093.955065] sd 0:0:0:0: [sda] Stopping disk
[13109.231614] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[13109.271033] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[13109.271049] wlp0s20f3: 80 MHz not supported, disabling VHT
[13109.274850] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[13109.305714] wlp0s20f3: authenticated
[13109.306065] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[13109.307818] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[13109.313791] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[13109.317277] wlp0s20f3: associated
[13109.526315] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[13125.158252] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[13125.203249] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[13125.209491] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[13125.233471] wlp0s20f3: authenticated
[13125.234340] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[13125.238117] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[13125.244352] wlp0s20f3: associated
[13163.237949] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[13163.244102] ata1.00: configured for UDMA/100
[13163.245023] sd 0:0:0:0: [sda] Starting disk
[13183.600557] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[13183.664866] sd 0:0:0:0: [sda] Stopping disk
[13232.000337] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[13232.006826] ata1.00: configured for UDMA/100
[13232.007728] sd 0:0:0:0: [sda] Starting disk
[13236.167028] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[13236.203741] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[13236.203769] wlp0s20f3: 80 MHz not supported, disabling VHT
[13236.206349] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[13236.234587] wlp0s20f3: authenticated
[13236.234796] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[13236.236784] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[13236.244714] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[13236.248171] wlp0s20f3: associated
[13236.291538] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[13243.127195] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[13243.183362] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[13243.188867] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[13243.213049] wlp0s20f3: authenticated
[13243.213351] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[13243.214957] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[13243.220593] wlp0s20f3: associated
[13282.039810] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[13282.040523] sd 0:0:0:0: [sda] Stopping disk
[13345.423135] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[13345.429480] ata1.00: configured for UDMA/100
[13345.430397] sd 0:0:0:0: [sda] Starting disk
[13374.162290] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[13374.163046] sd 0:0:0:0: [sda] Stopping disk
[13414.288668] r8169 0000:04:00.0 enp4s0: Link is Down
[13414.354604] wlp0s20f3: deauthenticating from 5c:8c:30:fd:c9:ad by local choice (Reason: 3=DEAUTH_LEAVING)
[13414.583135] ACPI: button: The lid device is not compliant to SW_LID.
[13419.584784] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[13419.588167] ata1.00: configured for UDMA/100
[13419.589049] sd 0:0:0:0: [sda] Starting disk
[13421.208027] PM: suspend entry (s2idle)
[13421.212762] Filesystems sync: 0.004 seconds
[13423.240620] Freezing user space processes
[13423.241898] Freezing user space processes completed (elapsed 0.001 seconds)
[13423.241902] OOM killer disabled.
[13423.241903] Freezing remaining freezable tasks
[13423.243040] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
[13423.243042] printk: Suspending console(s) (use no_console_suspend to debug)
[13423.268856] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[13423.269593] sd 0:0:0:0: [sda] Stopping disk
[13424.202865] ACPI: EC: interrupt blocked
[13424.203983] intel_pch_thermal 0000:00:12.0: CPU-PCH is cool [47C]
[17939.710034] intel-hid INT33D5:00: unknown event 0xca
[17939.714847] ACPI: EC: interrupt unblocked
[17940.965637] sd 0:0:0:0: [sda] Starting disk
[17941.116908] nvme nvme0: 8/0/0 default/read/poll queues
[17941.279015] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[17941.325900] ata1.00: configured for UDMA/100
[17943.018040] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[17943.018344] OOM killer enabled.
[17943.018348] Restarting tasks ... done.
[17943.023527] random: crng reseeded on system resumption
[17943.168293] PM: suspend exit
[17943.575005] Generic FE-GE Realtek PHY r8169-0-400:00: attached PHY driver (mii_bus:phy_addr=r8169-0-400:00, irq=MAC)
[17943.765097] r8169 0000:04:00.0 enp4s0: Link is Down
[17952.778954] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[17952.784008] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[17952.807188] wlp0s20f3: authenticated
[17952.808259] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[17952.811416] wlp0s20f3: RX AssocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[17952.815132] wlp0s20f3: associated
[17952.992274] IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f3: link becomes ready
[17999.420949] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[17999.479270] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[17999.479307] wlp0s20f3: 80 MHz not supported, disabling VHT
[17999.481914] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[17999.512859] wlp0s20f3: authenticated
[17999.513028] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[17999.513743] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[17999.562173] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[17999.572451] wlp0s20f3: associated
[17999.655618] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[18034.043918] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[18034.082473] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[18034.088837] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[18034.114605] wlp0s20f3: authenticated
[18034.116681] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[18034.118299] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[18034.122351] wlp0s20f3: associated
[18080.049693] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[18080.088261] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[18080.088288] wlp0s20f3: 80 MHz not supported, disabling VHT
[18080.090911] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[18080.121255] wlp0s20f3: authenticated
[18080.121451] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[18080.122473] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[18080.128666] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[18080.132686] wlp0s20f3: associated
[18080.139144] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[18095.981551] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[18096.045938] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[18096.050803] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[18096.075127] wlp0s20f3: authenticated
[18096.077795] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[18096.079418] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[18096.082930] wlp0s20f3: associated
[18206.925881] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[18206.982949] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[18206.982973] wlp0s20f3: 80 MHz not supported, disabling VHT
[18206.986455] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[18207.019874] wlp0s20f3: authenticated
[18207.020281] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[18207.022205] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[18207.029183] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[18207.033913] wlp0s20f3: associated
[18207.112914] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[18235.154640] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[18235.196792] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[18235.203441] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[18235.228405] wlp0s20f3: authenticated
[18235.231124] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[18235.234159] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[18235.237776] wlp0s20f3: associated
[18281.589300] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[18281.628745] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[18281.628771] wlp0s20f3: 80 MHz not supported, disabling VHT
[18281.631938] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[18281.664163] wlp0s20f3: authenticated
[18281.664395] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[18281.665411] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[18281.671337] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[18281.677561] wlp0s20f3: associated
[18281.762934] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[18352.698294] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[18352.749960] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[18352.754463] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[18352.778278] wlp0s20f3: authenticated
[18352.781284] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[18352.784556] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[18352.787771] wlp0s20f3: associated
[18394.698092] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[18394.698803] sd 0:0:0:0: [sda] Stopping disk
[18394.820390] sd 0:0:0:0: [sda] Starting disk
[18400.438671] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[18400.480905] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[18400.480923] wlp0s20f3: 80 MHz not supported, disabling VHT
[18400.484422] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[18400.514839] wlp0s20f3: authenticated
[18400.515065] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[18400.517940] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[18400.522836] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[18400.529465] wlp0s20f3: associated
[18400.543428] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[18410.241314] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[18410.280737] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[18410.286973] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[18410.311929] wlp0s20f3: authenticated
[18410.314200] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[18410.316191] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[18410.319536] wlp0s20f3: associated
[18521.293276] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[18521.350499] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[18521.350514] wlp0s20f3: 80 MHz not supported, disabling VHT
[18521.352888] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[18521.384727] wlp0s20f3: authenticated
[18521.384873] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[18521.386194] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[18521.395259] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[18521.400247] wlp0s20f3: associated
[18521.582779] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[18552.987022] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[18553.035679] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[18553.040451] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[18553.065930] wlp0s20f3: authenticated
[18553.066645] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[18553.070664] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[18553.073889] wlp0s20f3: associated
[18599.942217] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[18599.986903] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[18599.986922] wlp0s20f3: 80 MHz not supported, disabling VHT
[18599.989267] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[18600.020825] wlp0s20f3: authenticated
[18600.020994] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[18600.021852] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[18600.029521] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[18600.032895] wlp0s20f3: associated
[18600.224311] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[18631.274268] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[18631.313277] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[18631.320007] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[18631.342936] wlp0s20f3: authenticated
[18631.343785] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[18631.345625] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[18631.350659] wlp0s20f3: associated
[18678.528510] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[18678.564859] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[18678.564883] wlp0s20f3: 80 MHz not supported, disabling VHT
[18678.569039] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[18678.595510] wlp0s20f3: authenticated
[18678.595721] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[18678.598396] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[18678.603221] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[18678.610131] wlp0s20f3: associated
[18678.656738] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[18724.838757] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[18724.904584] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[18724.910934] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[18724.936393] wlp0s20f3: authenticated
[18724.938118] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[18724.940816] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[18724.944708] wlp0s20f3: associated
[18771.267317] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[18771.313534] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[18771.313569] wlp0s20f3: 80 MHz not supported, disabling VHT
[18771.317036] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[18771.346168] wlp0s20f3: authenticated
[18771.346412] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[18771.346936] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[18771.352297] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[18771.358802] wlp0s20f3: associated
[18771.429584] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[18835.907921] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[18835.946461] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[18835.952179] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[18835.976660] wlp0s20f3: authenticated
[18835.980836] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[18835.983737] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[18835.989889] wlp0s20f3: associated
[18882.048867] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[18882.088285] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[18882.088332] wlp0s20f3: 80 MHz not supported, disabling VHT
[18882.091551] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[18882.123844] wlp0s20f3: authenticated
[18882.124049] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[18882.128368] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[18882.138230] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[18882.143342] wlp0s20f3: associated
[18882.224624] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[18915.600202] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[18915.658473] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[18915.664046] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[18915.688758] wlp0s20f3: authenticated
[18915.692989] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[18915.695430] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[18915.701245] wlp0s20f3: associated
[18962.644035] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[18962.689466] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[18962.689485] wlp0s20f3: 80 MHz not supported, disabling VHT
[18962.692727] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[18962.728032] wlp0s20f3: authenticated
[18962.728206] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[18962.730071] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[18962.737401] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[18962.742353] wlp0s20f3: associated
[18962.814184] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[18996.108518] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[18996.174272] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[18996.181053] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[18996.206908] wlp0s20f3: authenticated
[18996.211169] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[18996.213185] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[18996.218677] wlp0s20f3: associated
[19047.291466] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[19047.382778] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[19047.382799] wlp0s20f3: 80 MHz not supported, disabling VHT
[19047.386022] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[19047.420091] wlp0s20f3: authenticated
[19047.420444] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[19047.424395] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[19047.429239] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[19047.436515] wlp0s20f3: associated
[19047.495326] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[19078.615972] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[19078.696818] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[19078.703034] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[19078.728316] wlp0s20f3: authenticated
[19078.728800] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[19078.732414] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[19078.738618] wlp0s20f3: associated
[19125.835832] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[19125.878190] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[19125.878209] wlp0s20f3: 80 MHz not supported, disabling VHT
[19125.881234] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[19125.917290] wlp0s20f3: authenticated
[19125.917509] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[19125.918826] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[19125.924425] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[19125.933890] wlp0s20f3: associated
[19125.933943] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[19157.283930] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[19157.328649] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[19157.335621] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[19157.362416] wlp0s20f3: authenticated
[19157.363204] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[19157.364950] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[19157.370822] wlp0s20f3: associated
[19204.463503] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[19204.515318] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[19204.515335] wlp0s20f3: 80 MHz not supported, disabling VHT
[19204.518011] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[19204.550699] wlp0s20f3: authenticated
[19204.550857] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[19204.553120] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[19204.558952] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[19204.563089] wlp0s20f3: associated
[19204.574101] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[19210.096543] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[19210.140671] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[19210.144831] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[19210.168056] wlp0s20f3: authenticated
[19210.172727] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[19210.174543] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[19210.178082] wlp0s20f3: associated
[19327.381220] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[19327.423254] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[19327.423272] wlp0s20f3: 80 MHz not supported, disabling VHT
[19327.426421] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[19327.460478] wlp0s20f3: authenticated
[19327.460680] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[19327.460805] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[19327.466959] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[19327.473457] wlp0s20f3: associated
[19327.656366] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[19393.713137] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[19393.774121] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[19393.780312] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[19393.805173] wlp0s20f3: authenticated
[19393.805937] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[19393.809235] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[19393.813321] wlp0s20f3: associated
[19440.199593] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[19440.241173] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[19440.241196] wlp0s20f3: 80 MHz not supported, disabling VHT
[19440.244101] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[19440.281086] wlp0s20f3: authenticated
[19440.281493] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[19440.282550] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[19440.287479] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[19440.296998] wlp0s20f3: associated
[19440.297063] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[19471.527740] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[19471.602990] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[19471.608724] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[19471.632078] wlp0s20f3: authenticated
[19471.633536] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[19471.636647] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[19471.640138] wlp0s20f3: associated
[19518.727218] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[19518.782955] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[19518.782974] wlp0s20f3: 80 MHz not supported, disabling VHT
[19518.786411] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[19518.826390] wlp0s20f3: authenticated
[19518.826630] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[19518.826720] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[19518.831539] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[19518.840195] wlp0s20f3: associated
[19518.840243] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[19552.441585] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[19552.482877] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[19552.488992] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[19552.513993] wlp0s20f3: authenticated
[19552.520682] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[19552.522757] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[19552.526222] wlp0s20f3: associated
[19596.554402] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[19596.555371] sd 0:0:0:0: [sda] Stopping disk
[19598.521216] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[19598.527339] ata1.00: configured for UDMA/100
[19598.528258] sd 0:0:0:0: [sda] Starting disk
[19599.637920] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[19599.679785] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[19599.679802] wlp0s20f3: 80 MHz not supported, disabling VHT
[19599.682810] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[19599.714960] wlp0s20f3: authenticated
[19599.715161] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[19599.717491] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[19599.722399] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[19599.730276] wlp0s20f3: associated
[19599.730343] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[19628.548656] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[19628.549399] sd 0:0:0:0: [sda] Stopping disk
[19630.969038] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[19631.004695] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[19631.009972] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[19631.035672] wlp0s20f3: authenticated
[19631.041895] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[19631.044819] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[19631.048563] wlp0s20f3: associated
[19677.968787] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[19678.028023] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[19678.028043] wlp0s20f3: 80 MHz not supported, disabling VHT
[19678.031477] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[19678.069446] wlp0s20f3: authenticated
[19678.069634] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[19678.075005] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[19678.095449] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[19678.100834] wlp0s20f3: associated
[19678.165207] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[19679.508223] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[19679.514199] ata1.00: configured for UDMA/100
[19679.515069] sd 0:0:0:0: [sda] Starting disk
[19709.410059] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[19709.452101] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[19709.457709] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[19709.483388] wlp0s20f3: authenticated
[19709.486070] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[19709.488808] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[19709.492483] wlp0s20f3: associated
[19714.515641] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[19714.516339] sd 0:0:0:0: [sda] Stopping disk
[19747.267260] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[19747.273393] ata1.00: configured for UDMA/100
[19747.274261] sd 0:0:0:0: [sda] Starting disk
[19756.506353] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[19756.549344] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[19756.549363] wlp0s20f3: 80 MHz not supported, disabling VHT
[19756.552317] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[19756.585813] wlp0s20f3: authenticated
[19756.586035] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[19756.589291] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[19756.595200] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[19756.598149] wlp0s20f3: associated
[19756.602099] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[19777.311036] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[19777.311723] sd 0:0:0:0: [sda] Stopping disk
[19788.084164] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[19788.129549] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[19788.136572] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[19788.161178] wlp0s20f3: authenticated
[19788.163517] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[19788.166647] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=2)
[19788.171857] wlp0s20f3: associated
[19829.447000] wlp0s20f3: Connection to AP 5c:8c:30:fd:c9:ad lost
[19829.755513] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[19829.755544] wlp0s20f3: 80 MHz not supported, disabling VHT
[19829.759675] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[19829.787996] wlp0s20f3: authenticated
[19829.788344] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[19829.790494] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[19829.802642] wlp0s20f3: RX AssocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[19829.809823] wlp0s20f3: associated
[19829.816772] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[19861.168532] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[19861.217459] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[19861.223071] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[19861.246889] wlp0s20f3: authenticated
[19861.248101] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[19861.251318] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[19861.255435] wlp0s20f3: associated
[19885.103304] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[19885.109728] ata1.00: configured for UDMA/100
[19885.110599] sd 0:0:0:0: [sda] Starting disk
[19905.498215] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[19905.498888] sd 0:0:0:0: [sda] Stopping disk
[19907.591760] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[19907.647366] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[19907.647385] wlp0s20f3: 80 MHz not supported, disabling VHT
[19907.650583] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[19907.685588] wlp0s20f3: authenticated
[19907.685959] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[19907.688106] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[19907.692973] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[19907.697095] wlp0s20f3: associated
[19907.741801] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[19913.621168] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[19913.627139] ata1.00: configured for UDMA/100
[19913.627982] sd 0:0:0:0: [sda] Starting disk
[19938.896062] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[19938.952123] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[19938.958487] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[19938.985077] wlp0s20f3: authenticated
[19938.989045] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[19938.991222] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[19938.995568] wlp0s20f3: associated
[19971.564256] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[19971.564933] sd 0:0:0:0: [sda] Stopping disk
[19973.003646] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[19973.009881] ata1.00: configured for UDMA/100
[19973.010774] sd 0:0:0:0: [sda] Starting disk
[19992.125602] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[19992.171205] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[19992.171226] wlp0s20f3: 80 MHz not supported, disabling VHT
[19992.174377] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[19992.207559] wlp0s20f3: authenticated
[19992.207879] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[19992.208435] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[19992.215825] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[19992.224633] wlp0s20f3: associated
[19992.224707] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[20025.536473] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[20025.584551] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[20025.590330] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[20025.615882] wlp0s20f3: authenticated
[20025.619291] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[20025.623411] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[20025.627014] wlp0s20f3: associated
[20029.810040] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[20029.810740] sd 0:0:0:0: [sda] Stopping disk
[20034.642374] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[20034.648448] ata1.00: configured for UDMA/100
[20034.649364] sd 0:0:0:0: [sda] Starting disk
[20064.283227] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[20064.283940] sd 0:0:0:0: [sda] Stopping disk
[20072.656233] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[20072.698307] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[20072.698323] wlp0s20f3: 80 MHz not supported, disabling VHT
[20072.701757] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[20072.732620] wlp0s20f3: authenticated
[20072.732806] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[20072.735852] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[20072.740802] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[20072.746296] wlp0s20f3: associated
[20072.807939] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[20077.599169] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[20077.605467] ata1.00: configured for UDMA/100
[20077.606326] sd 0:0:0:0: [sda] Starting disk
[20104.164306] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[20104.209457] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[20104.214242] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[20104.239402] wlp0s20f3: authenticated
[20104.240446] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[20104.243886] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[20104.249616] wlp0s20f3: associated
[20114.918541] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[20114.919229] sd 0:0:0:0: [sda] Stopping disk
[20121.415191] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[20121.421162] ata1.00: configured for UDMA/100
[20121.421979] sd 0:0:0:0: [sda] Starting disk
[20151.183736] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[20151.223355] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[20151.223397] wlp0s20f3: 80 MHz not supported, disabling VHT
[20151.226358] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[20151.257618] wlp0s20f3: authenticated
[20151.257968] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[20151.259927] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[20151.271454] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[20151.276285] wlp0s20f3: associated
[20151.347123] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[20151.630054] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[20151.630774] sd 0:0:0:0: [sda] Stopping disk
[20154.281169] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[20154.287359] ata1.00: configured for UDMA/100
[20154.288180] sd 0:0:0:0: [sda] Starting disk
[20182.508140] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[20182.576770] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[20182.582690] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[20182.609412] wlp0s20f3: authenticated
[20182.610952] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[20182.612718] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[20182.616353] wlp0s20f3: associated
[20197.509103] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[20197.509823] sd 0:0:0:0: [sda] Stopping disk
[20211.536908] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[20211.543349] ata1.00: configured for UDMA/100
[20211.544228] sd 0:0:0:0: [sda] Starting disk
[20230.319240] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[20230.371481] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[20230.371500] wlp0s20f3: 80 MHz not supported, disabling VHT
[20230.375053] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[20230.411133] wlp0s20f3: authenticated
[20230.411404] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[20230.414198] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[20230.419304] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[20230.425656] wlp0s20f3: associated
[20230.502106] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[20241.650624] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[20241.651316] sd 0:0:0:0: [sda] Stopping disk
[20261.860530] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[20261.927923] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[20261.933905] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[20261.958136] wlp0s20f3: authenticated
[20261.960068] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[20261.962219] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[20261.965698] wlp0s20f3: associated
[20308.447132] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[20308.492579] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[20308.492598] wlp0s20f3: 80 MHz not supported, disabling VHT
[20308.495459] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[20308.523759] wlp0s20f3: authenticated
[20308.523968] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[20308.526801] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[20308.542786] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[20308.546323] wlp0s20f3: associated
[20308.737116] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[20320.315972] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[20320.321980] ata1.00: configured for UDMA/100
[20320.322787] sd 0:0:0:0: [sda] Starting disk
[20339.799538] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[20339.851137] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[20339.857050] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[20339.881744] wlp0s20f3: authenticated
[20339.885899] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[20339.888037] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[20339.891747] wlp0s20f3: associated
[20373.784622] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[20373.785341] sd 0:0:0:0: [sda] Stopping disk
[20376.625484] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[20376.631556] ata1.00: configured for UDMA/100
[20376.632419] sd 0:0:0:0: [sda] Starting disk
[20395.488081] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[20395.534157] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[20395.534179] wlp0s20f3: 80 MHz not supported, disabling VHT
[20395.537783] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[20395.572691] wlp0s20f3: authenticated
[20395.572940] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[20395.574336] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[20395.579356] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[20395.586537] wlp0s20f3: associated
[20395.668832] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[20404.695593] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[20404.696261] sd 0:0:0:0: [sda] Stopping disk
[20411.033634] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[20411.039878] ata1.00: configured for UDMA/100
[20411.040801] sd 0:0:0:0: [sda] Starting disk
[20429.072415] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[20429.111088] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[20429.114515] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[20429.141297] wlp0s20f3: authenticated
[20429.145200] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[20429.148219] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[20429.152535] wlp0s20f3: associated
[20431.380994] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[20431.381693] sd 0:0:0:0: [sda] Stopping disk
[20449.217591] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[20449.223813] ata1.00: configured for UDMA/100
[20449.224626] sd 0:0:0:0: [sda] Starting disk
[20476.027321] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[20476.072223] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[20476.072248] wlp0s20f3: 80 MHz not supported, disabling VHT
[20476.075189] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[20476.105681] wlp0s20f3: authenticated
[20476.106015] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[20476.106833] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[20476.112053] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[20476.117977] wlp0s20f3: associated
[20476.155814] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[20479.971011] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[20480.011525] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[20480.015493] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[20480.039167] wlp0s20f3: authenticated
[20480.040498] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[20480.044405] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[20480.049807] wlp0s20f3: associated
[20622.920464] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[20622.962559] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[20622.962598] wlp0s20f3: 80 MHz not supported, disabling VHT
[20622.965548] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[20622.998612] wlp0s20f3: authenticated
[20622.998775] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[20623.000142] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[20623.007197] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[20623.010832] wlp0s20f3: associated
[20623.198525] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[20640.828286] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[20640.917348] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[20640.923825] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[20640.949556] wlp0s20f3: authenticated
[20640.950977] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[20640.954349] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[20640.958078] wlp0s20f3: associated
[20880.863506] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[20880.913011] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[20880.913027] wlp0s20f3: 80 MHz not supported, disabling VHT
[20880.915282] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[20880.950419] wlp0s20f3: authenticated
[20880.950639] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[20880.952926] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[20880.963895] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[20880.968681] wlp0s20f3: associated
[20881.036129] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[20903.296869] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[20903.336482] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[20903.341181] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[20903.365780] wlp0s20f3: authenticated
[20903.366774] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[20903.369623] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[20903.373452] wlp0s20f3: associated
[21368.332234] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[21368.373415] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[21368.373440] wlp0s20f3: 80 MHz not supported, disabling VHT
[21368.376068] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[21368.400918] wlp0s20f3: authenticated
[21368.401133] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[21368.405092] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[21368.410443] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[21368.414427] wlp0s20f3: associated
[21368.450710] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[21399.614633] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[21399.657264] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[21399.662954] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[21399.688436] wlp0s20f3: authenticated
[21399.690856] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[21399.692547] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[21399.696586] wlp0s20f3: associated
[21446.923277] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[21446.974583] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[21446.974601] wlp0s20f3: 80 MHz not supported, disabling VHT
[21446.976952] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[21447.011144] wlp0s20f3: authenticated
[21447.011360] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[21447.012935] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[21447.019948] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[21447.026124] wlp0s20f3: associated
[21447.092767] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[21476.622435] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[21476.666461] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[21476.670173] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[21476.694110] wlp0s20f3: authenticated
[21476.695385] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[21476.698268] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[21476.701562] wlp0s20f3: associated
[21523.571389] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[21523.629958] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[21523.629988] wlp0s20f3: 80 MHz not supported, disabling VHT
[21523.633185] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[21523.661400] wlp0s20f3: authenticated
[21523.661872] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[21523.664191] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[21523.671880] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[21523.676412] wlp0s20f3: associated
[21523.686441] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[21555.057064] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[21555.104871] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[21555.109681] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[21555.133717] wlp0s20f3: authenticated
[21555.136703] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[21555.139986] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[21555.143228] wlp0s20f3: associated
[21602.069526] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[21602.127971] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[21602.127987] wlp0s20f3: 80 MHz not supported, disabling VHT
[21602.131163] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[21602.163555] wlp0s20f3: authenticated
[21602.163740] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[21602.168877] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[21602.181849] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[21602.185998] wlp0s20f3: associated
[21602.225921] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[21635.562098] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[21635.614871] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[21635.620900] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[21635.647052] wlp0s20f3: authenticated
[21635.648052] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[21635.650435] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[21635.654090] wlp0s20f3: associated
[21682.554421] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[21682.595467] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[21682.595504] wlp0s20f3: 80 MHz not supported, disabling VHT
[21682.600103] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[21682.633895] wlp0s20f3: authenticated
[21682.634269] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[21682.636990] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[21682.648950] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[21682.653809] wlp0s20f3: associated
[21682.710957] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[21715.359899] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[21715.411277] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[21715.416154] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[21715.441254] wlp0s20f3: authenticated
[21715.446154] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[21715.449380] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[21715.454790] wlp0s20f3: associated
[21761.222460] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[21761.271821] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[21761.271861] wlp0s20f3: 80 MHz not supported, disabling VHT
[21761.275524] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[21761.305098] wlp0s20f3: authenticated
[21761.305430] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[21761.308507] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[21761.313762] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[21761.320415] wlp0s20f3: associated
[21761.352221] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[21763.779073] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[21763.849266] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[21763.856559] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[21763.880564] wlp0s20f3: authenticated
[21763.881712] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[21763.884685] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[21763.891513] wlp0s20f3: associated
[21825.503658] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[21825.504327] sd 0:0:0:0: [sda] Stopping disk
[21826.076830] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[21826.082754] ata1.00: configured for UDMA/100
[21826.083581] sd 0:0:0:0: [sda] Starting disk
[21906.292721] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[21906.345293] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[21906.345310] wlp0s20f3: 80 MHz not supported, disabling VHT
[21906.348230] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[21906.376663] wlp0s20f3: authenticated
[21906.376825] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[21906.378628] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[21906.391779] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[21906.399802] wlp0s20f3: associated
[21906.451973] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[21938.265316] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[21938.317638] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[21938.326238] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[21938.351223] wlp0s20f3: authenticated
[21938.354558] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[21938.357991] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[21938.361619] wlp0s20f3: associated
[21985.023880] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[21985.077653] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[21985.077686] wlp0s20f3: 80 MHz not supported, disabling VHT
[21985.081628] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[21985.118020] wlp0s20f3: authenticated
[21985.118360] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[21985.120339] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[21985.133713] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[21985.138722] wlp0s20f3: associated
[21985.197116] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[22016.389882] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[22016.442503] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[22016.448311] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[22016.472638] wlp0s20f3: authenticated
[22016.472905] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[22016.477220] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[22016.484129] wlp0s20f3: associated
[22063.752663] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[22063.821261] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[22063.821299] wlp0s20f3: 80 MHz not supported, disabling VHT
[22063.824364] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[22063.879079] wlp0s20f3: authenticated
[22063.879336] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[22063.881932] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[22063.887221] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[22063.891505] wlp0s20f3: associated
[22063.939177] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[22095.248582] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[22095.300259] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[22095.305743] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[22095.330674] wlp0s20f3: authenticated
[22095.334640] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[22095.337999] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[22095.342172] wlp0s20f3: associated
[22120.991866] ACPI Error: Thread 828506112 cannot release Mutex [ECMX] acquired by thread 450118272 (20220331/exmutex-378)
[22120.991876] ACPI Error: Aborting method \_SB.PCI0.LPCB.ECDV._Q66 due to previous error (AE_AML_NOT_OWNER) (20220331/psparse-529)
[22123.677519] r8169 0000:04:00.0 enp4s0: Link is Down
[22148.160863] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[22148.207355] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[22148.207391] wlp0s20f3: 80 MHz not supported, disabling VHT
[22148.212525] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[22148.256537] wlp0s20f3: authenticated
[22148.256776] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[22148.256898] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[22148.262250] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[22148.267488] wlp0s20f3: associated
[22148.315260] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[22154.524222] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[22154.570153] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[22154.575931] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[22154.600593] wlp0s20f3: authenticated
[22154.603515] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[22154.606419] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[22154.611741] wlp0s20f3: associated
[22297.254841] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[22297.299768] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[22297.299801] wlp0s20f3: 80 MHz not supported, disabling VHT
[22297.305297] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[22297.336284] wlp0s20f3: authenticated
[22297.336668] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[22297.337395] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[22297.347103] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[22297.352991] wlp0s20f3: associated
[22297.406554] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[22330.657595] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[22330.714852] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[22330.720709] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[22330.746765] wlp0s20f3: authenticated
[22330.750033] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[22330.752475] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[22330.755857] wlp0s20f3: associated
[22383.849414] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[22383.894366] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[22383.894403] wlp0s20f3: 80 MHz not supported, disabling VHT
[22383.898000] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[22383.937136] wlp0s20f3: authenticated
[22383.937332] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[22383.939044] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[22383.944335] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[22383.951679] wlp0s20f3: associated
[22384.035242] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[22417.489099] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[22417.534680] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[22417.542569] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[22417.566166] wlp0s20f3: authenticated
[22417.568386] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[22417.572035] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[22417.577475] wlp0s20f3: associated
[22464.371194] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[22464.416333] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[22464.416369] wlp0s20f3: 80 MHz not supported, disabling VHT
[22464.420077] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[22464.449705] wlp0s20f3: authenticated
[22464.450085] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[22464.450823] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[22464.455705] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[22464.466559] wlp0s20f3: associated
[22464.520071] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[22471.451566] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[22471.522061] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[22471.531148] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[22471.554124] wlp0s20f3: authenticated
[22471.557468] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[22471.561057] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[22471.566369] wlp0s20f3: associated
[22593.315508] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[22593.372496] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[22593.372506] wlp0s20f3: 80 MHz not supported, disabling VHT
[22593.374015] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[22593.402732] wlp0s20f3: authenticated
[22593.402906] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[22593.405199] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[22593.410068] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[22593.418059] wlp0s20f3: associated
[22593.439164] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[22624.762814] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[22624.869411] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[22624.873014] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[22624.897949] wlp0s20f3: authenticated
[22624.901198] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[22624.903894] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[22624.907233] wlp0s20f3: associated
[22671.927010] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[22671.968439] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[22671.968453] wlp0s20f3: 80 MHz not supported, disabling VHT
[22671.969972] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[22671.999958] wlp0s20f3: authenticated
[22672.000066] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[22672.003643] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[22672.012859] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[22672.018650] wlp0s20f3: associated
[22672.080436] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[22707.157170] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[22707.214953] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[22707.218629] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[22707.247654] wlp0s20f3: authenticated
[22707.249697] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[22707.252051] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[22707.257744] wlp0s20f3: associated
[22754.572888] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[22754.624058] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[22754.624089] wlp0s20f3: 80 MHz not supported, disabling VHT
[22754.626417] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[22754.672026] wlp0s20f3: authenticated
[22754.672376] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[22754.675550] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[22754.680712] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[22754.685809] wlp0s20f3: associated
[22754.715958] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[22761.046436] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[22761.132122] iwlwifi 0000:00:14.3: Unhandled alg: 0x71b
[22761.133020] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[22761.141412] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[22761.165741] wlp0s20f3: authenticated
[22761.168708] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[22761.170561] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[22761.178789] wlp0s20f3: associated
[22903.463428] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[22903.514117] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[22903.514150] wlp0s20f3: 80 MHz not supported, disabling VHT
[22903.517852] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[22903.549335] wlp0s20f3: authenticated
[22903.549750] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[22903.552771] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[22903.561634] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[22903.565910] wlp0s20f3: associated
[22903.602624] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[22918.632739] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[22918.693537] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[22918.700045] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[22918.723305] wlp0s20f3: authenticated
[22918.725888] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[22918.728037] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[22918.735556] wlp0s20f3: associated
[23159.258729] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[23159.305473] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[23159.305508] wlp0s20f3: 80 MHz not supported, disabling VHT
[23159.308781] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[23159.342375] wlp0s20f3: authenticated
[23159.342746] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[23159.344938] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[23159.359292] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[23159.365109] wlp0s20f3: associated
[23159.392905] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[23202.489265] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[23202.531405] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[23202.536976] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[23202.562458] wlp0s20f3: authenticated
[23202.567169] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[23202.570461] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[23202.575298] wlp0s20f3: associated
[23255.923979] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[23255.968507] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[23255.968540] wlp0s20f3: 80 MHz not supported, disabling VHT
[23255.972999] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[23256.007623] wlp0s20f3: authenticated
[23256.007987] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[23256.009917] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[23256.023627] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[23256.029424] wlp0s20f3: associated
[23256.056571] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[23268.523626] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[23268.565753] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[23268.571834] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[23268.596807] wlp0s20f3: authenticated
[23268.599672] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[23268.603243] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[23268.608979] wlp0s20f3: associated
[23378.811692] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[23378.851663] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[23378.851675] wlp0s20f3: 80 MHz not supported, disabling VHT
[23378.854864] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[23378.883662] wlp0s20f3: authenticated
[23378.883807] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[23378.887680] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[23378.892674] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[23378.903680] wlp0s20f3: associated
[23378.933865] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[23410.054856] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[23410.096185] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[23410.106165] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[23410.129733] wlp0s20f3: authenticated
[23410.130465] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[23410.133788] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[23410.139319] wlp0s20f3: associated
[23457.447093] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[23457.488603] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[23457.488636] wlp0s20f3: 80 MHz not supported, disabling VHT
[23457.492439] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[23457.523507] wlp0s20f3: authenticated
[23457.523874] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[23457.526346] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[23457.532929] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[23457.539828] wlp0s20f3: associated
[23457.576394] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[23490.839511] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[23490.898521] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[23490.905544] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[23490.933619] wlp0s20f3: authenticated
[23490.939022] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[23490.949438] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[23490.952080] wlp0s20f3: associated
[23542.038790] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[23542.084196] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[23542.084232] wlp0s20f3: 80 MHz not supported, disabling VHT
[23542.087578] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[23542.123675] wlp0s20f3: authenticated
[23542.124029] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[23542.124750] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[23542.133668] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[23542.138326] wlp0s20f3: associated
[23542.158290] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[23557.222074] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[23557.265582] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[23557.272723] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[23557.297018] wlp0s20f3: authenticated
[23557.301245] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[23557.303326] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[23557.310710] wlp0s20f3: associated
[23668.916686] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[23668.953679] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[23668.953715] wlp0s20f3: 80 MHz not supported, disabling VHT
[23668.957517] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[23668.986059] wlp0s20f3: authenticated
[23668.986455] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[23668.989197] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[23668.996458] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[23669.003312] wlp0s20f3: associated
[23669.029780] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[23700.479631] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[23700.567089] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[23700.575123] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[23700.599807] wlp0s20f3: authenticated
[23700.602051] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[23700.604241] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[23700.608044] wlp0s20f3: associated
[23747.558654] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[23747.620746] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[23747.620782] wlp0s20f3: 80 MHz not supported, disabling VHT
[23747.626573] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[23747.658694] wlp0s20f3: authenticated
[23747.659064] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[23747.661170] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[23747.666119] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[23747.672022] wlp0s20f3: associated
[23747.673372] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[23778.901267] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[23778.965940] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[23778.973517] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[23778.998496] wlp0s20f3: authenticated
[23779.000625] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[23779.002592] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[23779.010509] wlp0s20f3: associated
[23830.200038] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[23830.281871] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[23830.281890] wlp0s20f3: 80 MHz not supported, disabling VHT
[23830.285948] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[23830.318716] wlp0s20f3: authenticated
[23830.319087] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[23830.321014] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[23830.328259] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[23830.332813] wlp0s20f3: associated
[23830.406450] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[23892.799420] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[23892.839867] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[23892.848090] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[23892.873475] wlp0s20f3: authenticated
[23892.875328] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[23892.877898] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[23892.884523] wlp0s20f3: associated
[23940.902128] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[23940.943236] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[23940.943271] wlp0s20f3: 80 MHz not supported, disabling VHT
[23940.947633] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[23940.981705] wlp0s20f3: authenticated
[23940.982086] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[23940.984505] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[23940.989961] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[23940.994499] wlp0s20f3: associated
[23940.997079] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[23972.224218] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[23972.289367] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[23972.295852] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[23972.319381] wlp0s20f3: authenticated
[23972.320529] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[23972.324620] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[23972.332253] wlp0s20f3: associated
[24023.609696] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[24023.660681] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[24023.660694] wlp0s20f3: 80 MHz not supported, disabling VHT
[24023.661911] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[24023.690881] wlp0s20f3: authenticated
[24023.691062] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[24023.692942] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[24023.697806] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[24023.702054] wlp0s20f3: associated
[24023.733749] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[24054.959387] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[24055.014845] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[24055.019230] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[24055.043658] wlp0s20f3: authenticated
[24055.045849] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[24055.047840] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[24055.053229] wlp0s20f3: associated
[24108.095280] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[24108.145063] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[24108.145078] wlp0s20f3: 80 MHz not supported, disabling VHT
[24108.147631] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[24108.178606] wlp0s20f3: authenticated
[24108.178906] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[24108.181483] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[24108.189213] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[24108.197876] wlp0s20f3: associated
[24108.213140] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[24139.438410] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[24139.486957] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[24139.490991] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[24139.514291] wlp0s20f3: authenticated
[24139.517595] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[24139.519049] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[24139.522520] wlp0s20f3: associated
[24186.717136] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[24186.754515] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[24186.754530] wlp0s20f3: 80 MHz not supported, disabling VHT
[24186.756043] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[24186.784252] wlp0s20f3: authenticated
[24186.784369] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[24186.786774] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[24186.791754] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[24186.797935] wlp0s20f3: associated
[24186.855411] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[24218.093637] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[24218.184896] iwlwifi 0000:00:14.3: Unhandled alg: 0x71b
[24218.185841] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[24218.195562] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[24218.219940] wlp0s20f3: authenticated
[24218.223000] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[24218.226303] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[24218.231562] wlp0s20f3: associated
[24265.279404] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[24265.323393] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[24265.323428] wlp0s20f3: 80 MHz not supported, disabling VHT
[24265.327805] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[24265.360367] wlp0s20f3: authenticated
[24265.360728] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[24265.362066] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[24265.368907] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[24265.379681] wlp0s20f3: associated
[24265.393644] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[24298.778959] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[24298.843983] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[24298.848399] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[24298.871715] wlp0s20f3: authenticated
[24298.874871] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[24298.878854] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[24298.886732] wlp0s20f3: associated
[24345.884696] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[24345.929425] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[24345.929458] wlp0s20f3: 80 MHz not supported, disabling VHT
[24345.933222] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[24345.964283] wlp0s20f3: authenticated
[24345.964646] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[24345.967436] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[24345.972865] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[24345.976628] wlp0s20f3: associated
[24345.980387] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[24348.961598] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[24349.000890] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[24349.007056] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[24349.030046] wlp0s20f3: authenticated
[24349.030592] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[24349.032259] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[24349.036019] wlp0s20f3: associated
[24492.915591] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[24492.967949] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[24492.967984] wlp0s20f3: 80 MHz not supported, disabling VHT
[24492.973053] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[24493.006985] wlp0s20f3: authenticated
[24493.007368] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[24493.011476] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[24493.020266] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[24493.026895] wlp0s20f3: associated
[24493.026932] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[24501.555133] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[24501.613799] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[24501.619983] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[24501.646211] wlp0s20f3: authenticated
[24501.647961] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[24501.651486] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[24501.659387] wlp0s20f3: associated
[24740.731165] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[24740.781080] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[24740.781115] wlp0s20f3: 80 MHz not supported, disabling VHT
[24740.786148] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[24740.815025] wlp0s20f3: authenticated
[24740.815151] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[24740.820422] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[24740.837268] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[24740.841549] wlp0s20f3: associated
[24740.929559] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[24772.203921] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[24772.250788] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[24772.255848] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[24772.281529] wlp0s20f3: authenticated
[24772.283201] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[24772.285948] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[24772.289562] wlp0s20f3: associated
[24819.276512] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[24819.331335] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[24819.331369] wlp0s20f3: 80 MHz not supported, disabling VHT
[24819.336415] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[24819.371955] wlp0s20f3: authenticated
[24819.372223] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[24819.372382] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[24819.377573] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[24819.383941] wlp0s20f3: associated
[24819.469135] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[24843.360747] usb 1-1: USB disconnect, device number 2
[24843.694139] usb 1-3: USB disconnect, device number 3
[24850.638931] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[24850.686791] iwlwifi 0000:00:14.3: Unhandled alg: 0x71b
[24850.687813] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[24850.699405] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[24850.723858] wlp0s20f3: authenticated
[24850.725176] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[24850.728697] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=1)
[24850.736343] wlp0s20f3: associated
[24897.855113] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[24897.897843] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[24897.897873] wlp0s20f3: 80 MHz not supported, disabling VHT
[24897.903578] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[24897.939449] wlp0s20f3: authenticated
[24897.939747] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[24897.941013] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[24897.946540] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1c11 status=0 aid=3)
[24897.953359] wlp0s20f3: associated
[24898.010572] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[24900.217963] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[24900.218655] sd 0:0:0:0: [sda] Stopping disk
[24934.284131] r8169 0000:04:00.0 enp4s0: Link is Down
[24934.342261] wlp0s20f3: deauthenticating from 5c:8c:30:fd:c9:a9 by local choice (Reason: 3=DEAUTH_LEAVING)
[24939.483962] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[24939.489859] ata1.00: configured for UDMA/100
[24939.490729] sd 0:0:0:0: [sda] Starting disk
[24941.164829] PM: suspend entry (s2idle)
[24941.170646] Filesystems sync: 0.005 seconds
[24943.016107] Freezing user space processes
[24943.017688] Freezing user space processes completed (elapsed 0.001 seconds)
[24943.017691] OOM killer disabled.
[24943.017692] Freezing remaining freezable tasks
[24943.018867] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
[24943.018869] printk: Suspending console(s) (use no_console_suspend to debug)
[24943.040557] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[24943.041236] sd 0:0:0:0: [sda] Stopping disk
[24943.943412] ACPI: EC: interrupt blocked
[24943.944648] intel_pch_thermal 0000:00:12.0: CPU-PCH is cool [51C]
[32545.642724] intel-hid INT33D5:00: unknown event 0xca
[32545.647978] ACPI: EC: interrupt unblocked
[32546.892132] sd 0:0:0:0: [sda] Starting disk
[32547.053063] nvme nvme0: 8/0/0 default/read/poll queues
[32547.209248] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[32547.255863] ata1.00: configured for UDMA/100
[32548.958021] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[32548.958913] OOM killer enabled.
[32548.958917] Restarting tasks ... done.
[32548.964917] random: crng reseeded on system resumption
[32549.104234] PM: suspend exit
[32549.488598] Generic FE-GE Realtek PHY r8169-0-400:00: attached PHY driver (mii_bus:phy_addr=r8169-0-400:00, irq=MAC)
[32549.685344] r8169 0000:04:00.0 enp4s0: Link is Down
[32553.875162] usb 1-3: new low-speed USB device number 7 using xhci_hcd
[32554.020204] usb 1-3: New USB device found, idVendor=1a2c, idProduct=4c5e, bcdDevice= 1.10
[32554.020207] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[32554.020208] usb 1-3: Product: USB Keyboard
[32554.020210] usb 1-3: Manufacturer: SEMICO
[32554.024792] input: SEMICO USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/0003:1A2C:4C5E.0006/input/input35
[32554.078653] hid-generic 0003:1A2C:4C5E.0006: input,hidraw0: USB HID v1.10 Keyboard [SEMICO USB Keyboard] on usb-0000:00:14.0-3/input0
[32554.085000] input: SEMICO USB Keyboard Consumer Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:1A2C:4C5E.0007/input/input36
[32554.138567] input: SEMICO USB Keyboard System Control as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:1A2C:4C5E.0007/input/input37
[32554.138632] input: SEMICO USB Keyboard as /devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.1/0003:1A2C:4C5E.0007/input/input39
[32554.138730] hid-generic 0003:1A2C:4C5E.0007: input,hiddev96,hidraw1: USB HID v1.10 Keyboard [SEMICO USB Keyboard] on usb-0000:00:14.0-3/input1
[32558.328708] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[32558.340773] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[32558.364656] wlp0s20f3: authenticated
[32558.365160] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[32558.369041] wlp0s20f3: RX AssocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=3)
[32558.373185] wlp0s20f3: associated
[32558.526364] IPv6: ADDRCONF(NETDEV_CHANGE): wlp0s20f3: link becomes ready
[32579.448385] usb 1-1: new full-speed USB device number 8 using xhci_hcd
[32579.600469] usb 1-1: New USB device found, idVendor=1b1c, idProduct=1b3c, bcdDevice= 3.08
[32579.600481] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[32579.600485] usb 1-1: Product: Corsair Gaming HARPOON RGB Mouse
[32579.600488] usb 1-1: Manufacturer: Corsair
[32579.600491] usb 1-1: SerialNumber: 0601A034AF6BA4E85E78BB78F5001C00
[32579.611782] input: Corsair Corsair Gaming HARPOON RGB Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:1B1C:1B3C.0008/input/input40
[32579.612246] input: Corsair Corsair Gaming HARPOON RGB Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:1B1C:1B3C.0008/input/input41
[32579.612438] input: Corsair Corsair Gaming HARPOON RGB Mouse as /devices/pci0000:00/0000:00:14.0/usb1/1-1/1-1:1.0/0003:1B1C:1B3C.0008/input/input42
[32579.612816] hid-generic 0003:1B1C:1B3C.0008: input,hiddev97,hidraw2: USB HID v1.11 Mouse [Corsair Corsair Gaming HARPOON RGB Mouse] on usb-0000:00:14.0-1/input0
[32579.616028] hid-generic 0003:1B1C:1B3C.0009: hiddev98,hidraw3: USB HID v1.11 Device [Corsair Corsair Gaming HARPOON RGB Mouse] on usb-0000:00:14.0-1/input1
[32603.858143] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[32603.900201] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[32603.900280] wlp0s20f3: 80 MHz not supported, disabling VHT
[32603.904455] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[32603.929363] wlp0s20f3: authenticated
[32603.929742] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[32603.930680] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[32603.935750] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1811 status=0 aid=4)
[32603.945043] wlp0s20f3: associated
[32603.986646] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[32621.613283] iwlwifi 0000:00:14.3: Unhandled alg: 0x703
[32621.619849] iwlwifi 0000:00:14.3: Unhandled alg: 0x703
[32622.197402] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[32622.259684] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[32622.268664] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[32622.295567] wlp0s20f3: authenticated
[32622.296608] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[32622.299698] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=3)
[32622.308355] wlp0s20f3: associated
[32861.787442] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[32861.839815] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[32861.839881] wlp0s20f3: 80 MHz not supported, disabling VHT
[32861.843048] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[32861.877877] wlp0s20f3: authenticated
[32861.878050] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[32861.880290] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[32861.888489] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1811 status=0 aid=4)
[32861.897735] wlp0s20f3: associated
[32861.928000] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[32895.387009] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[32895.430040] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[32895.436002] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[32895.460045] wlp0s20f3: authenticated
[32895.462777] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[32895.464875] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=3)
[32895.471261] wlp0s20f3: associated
[32942.299469] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:ad for new auth to 5c:8c:30:fd:c9:a9
[32942.324203] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:a9
[32942.324235] wlp0s20f3: 80 MHz not supported, disabling VHT
[32942.327600] wlp0s20f3: send auth to 5c:8c:30:fd:c9:a9 (try 1/3)
[32942.400770] wlp0s20f3: authenticated
[32942.401138] wlp0s20f3: associating to AP 5c:8c:30:fd:c9:a9 with corrupt probe response
[32942.401972] wlp0s20f3: associate with 5c:8c:30:fd:c9:a9 (try 1/3)
[32942.426106] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:a9 (capab=0x1811 status=0 aid=4)
[32942.435215] wlp0s20f3: associated
[32942.516086] wlp0s20f3: Limiting TX power to 20 (20 - 0) dBm as advertised by 5c:8c:30:fd:c9:a9
[32975.785318] wlp0s20f3: disconnect from AP 5c:8c:30:fd:c9:a9 for new auth to 5c:8c:30:fd:c9:ad
[32975.856986] wlp0s20f3: authenticate with 5c:8c:30:fd:c9:ad
[32975.863173] wlp0s20f3: send auth to 5c:8c:30:fd:c9:ad (try 1/3)
[32975.888953] wlp0s20f3: authenticated
[32975.891387] wlp0s20f3: associate with 5c:8c:30:fd:c9:ad (try 1/3)
[32975.894167] wlp0s20f3: RX ReassocResp from 5c:8c:30:fd:c9:ad (capab=0x1911 status=0 aid=3)
[32975.899405] wlp0s20f3: associated
