Can't change default audio device
Hello, I’m having trouble selecting the default devices in the volume control tray and the system settings.
When I try to select the default device in the system tray, it doesn’t change the default device but adds the mark that is the default device without removing it from the other device
Screenshot_20250301_110659
If I try to change it from the system settings, it adds a line showing that it noticed that I clicked on the device, but it doesn’t do anything, so far, the only temporary solution I found is running systemctl --user restart pipewire, but I will have the same problem after a restart.
I would appreciate any advice on how to fix this
  Kernel: 6.12.12-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=e25eb414-7401-4086-851c-0725906b306f rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.10.0
  Type: Desktop System: Gigabyte product: X570 AORUS ELITE v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: X570 AORUS ELITE serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: F40d
    date: 09/02/2024
  System RAM: total: 32 GiB available: 31.27 GiB used: 3.71 GiB (11.9%)
    (unregistered) size: 8 GiB speed: 3600 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Corsair
    part-no: CMK16GX4M2D3600C18 serial: N/A
  Device-3: Channel-B DIMM 0 type: DDR4 detail: synchronous unbuffered
  Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 0 microcode: 0xA20102D
    desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3246 min/max: 550/3701 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3246 2: 3246 3: 3246
    4: 3246 5: 3246 6: 3246 7: 3246 8: 3246 9: 3246 10: 3246 11: 3246 12: 3246
    bogomips: 88844
    cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip user_shstk v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT / 7800
    XT] vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-3 code: Navi-3x
    process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 16
    ports: active: DP-2,HDMI-A-2 empty: DP-1,HDMI-A-1,Writeback-1
    bus-ID: 0c:00.0 chip-ID: 1002:747e class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.15 with: Xwayland v: 24.1.5
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu d-rect: 4480x2520 display-ID: 0
  Monitor-1: DP-2 pos: top-right model: Gigabyte M27Q X serial: <filter>
    built: 2022 res: mode: 2560x1440 hz: 240 scale: 100% (1) dpi: 109 gamma: 1.2
    size: 596x335mm (23.46x13.19") diag: 684mm (26.9") ratio: 16:9 modes:
    max: 2560x1440 min: 640x480
  Monitor-2: HDMI-A-2 pos: bottom-l model: BenQ RL2455 serial: <filter>
    built: 2015 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 92 gamma: 1.2
    size: 531x298mm (20.91x11.73") diag: 609mm (24") ratio: 16:9 modes:
    max: 1920x1080 min: 720x400
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
    navi32 LLVM 19.1.7 DRM 3.59 6.12.12-2-MANJARO) device-ID: 1002:747e
    memory: 15.62 GiB unified: no display-ID: :1.0
  API: Vulkan v: 1.4.303 layers: 15 device: 0 type: discrete-gpu name: AMD
    Radeon RX 7800 XT (RADV NAVI32) driver: N/A device-ID: 1002:747e
    surfaces: xcb,xlib,wayland
    de: kscreen-console,kscreen-doctor gpu: radeontop wl: wayland-info,wlr-randr
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 0c:00.1 chip-ID: 1002:ab30 class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Audio-Technica AT2020USB+
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 5-4:3 chip-ID: 0909:001c class-ID: 0300
  API: ALSA v: k6.12.12-2-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet 10-Gigabit X540-AT2 driver: ixgbe v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8 port: N/A bus-ID: 05:00.0
    chip-ID: 8086:1528 class-ID: 0200
  IF: enp5s0f0 state: down mac: <filter>
  Device-2: Intel Ethernet 10-Gigabit X540-AT2 driver: ixgbe v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 4 link-max: lanes: 8 port: N/A bus-ID: 05:00.1
  IF: enp5s0f1 state: up speed: 10000 Mbps duplex: full mac: <filter>
  Device-3: Intel I211 Gigabit Network vendor: Gigabyte driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
  IF: enp6s0 state: down mac: <filter>
  IF-ID-1: mullvpn state: unknown speed: 10000 Mbps duplex: full mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  Device-1: TP-Link UB500 Adapter driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 2357:0604
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.1
    lmp-v: 10 status: discoverable: no pairing: no class-ID: 6c0104
  Local Storage: total: 6.37 TiB used: 162.96 GiB (2.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung
    model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 48.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO with
    Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
    speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7
    temp: 43.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 162.96 GiB (8.9%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:7 label: N/A
    uuid: e25eb414-7401-4086-851c-0725906b306f
    used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6 label: N/A
    uuid: BA92-28E0
  ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 100 MiB fs: vfat label: N/A
    uuid: D28E-B11A
  ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 1.82 TiB fs: ntfs label: N/A
    uuid: FAF89128F890E3E3
  ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 546 MiB fs: ntfs label: N/A
    uuid: 12BE8106BE80E417
  ID-5: /dev/sda1 maj-min: 8:1 size: 931.51 GiB fs: ntfs label: SSD 860 EVO
    uuid: 38088F12088ECDF6
  ID-6: /dev/sdb1 maj-min: 8:17 size: 1.82 TiB fs: ntfs label: Hard drive
    uuid: 8432ABCC32ABC192
  Hub-2: 1-2:2 info: VIA Labs Hub ports: 4 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2210
  Hub-3: 1-3:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 1-3.4:5 info: Ducky One 3 RGB type: HID,keyboard,mouse
    driver: hid-generic,usbhid interfaces: 5 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 3233:1311 class-ID: 0300
    serial: <filter>
  Device-2: 1-4:4 info: Integrated Express IT8297 RGB LED Controller
    type: keyboard driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    chip-ID: 048d:8297 class-ID: 0301
  Hub-4: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-5: 2-2:2 info: VIA Labs Hub ports: 1 rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0210
  Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-4:2 info: TP-Link UB500 Adapter type: bluetooth driver: btusb
    interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
    power: 500mA chip-ID: 2357:0604 class-ID: e001 serial: <filter>
  Hub-7: 3-6:3 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-8: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-9: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-2:2 info: Logitech USB Receiver type: mouse,keyboard,HID
    lanes: 1 mode: 1.1 power: 98mA chip-ID: 046d:c547 class-ID: 0300
  Device-2: 5-4:3 info: Audio-Technica AT2020USB+ type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Hub-10: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 37.6 C mobo: 31.0 C gpu: amdgpu temp: 44.0 C
    mem: 63.0 C
  Fan Speeds (rpm): N/A gpu: amdgpu fan: 23
  Processes: 354 Power: uptime: 1m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: 1966 pm: pacman pkgs: 1945 libs: 511 tools: pamac,yay pm: flatpak
    pkgs: 21 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.37
Check names of audio playback sinks
pactl list sinks short | cut -f2
and name of the default sink
pactl get-default-sink
To change the default sink use this command with sink name from first command
pactl set-default-sink [name]
Or install Qt version of PulseAudio Volume Control – pavucontrol-qt
using pavucontrol-qt does let me change the default device now, but the volume control and settings aren’t getting updated, it islike nothing has changed, I think because of that I can’t use the buttons or something to increase or reduce the volume, I need to open either the settings or pavucontrol-qt
Restoring PipeWire and Wireplumber settings to default
delete any custom configuration folders
sudo rm -r /etc/pipewire /etc/wireplumber
or
rm -r ~/.config/pipewire ~/.config/wireplumber
and restart pipewire and wireplumber services to load default configurations
systemctl --user restart pipewire pipewire-pulse wireplumber
I did sudo rm -r /etc/pipewire /etc/wireplumber, it deleted the pipewire but the wireplumber folder didn’t exist, and I don’t have either of them in the .config.
After I restarted the services, and restarted the computer it still had the same problem
Do you have any more ideas ?
something else I found is that it’s only happening on my user, I created a new user to test this and it didn’t have any problems, so I’m not sure what is causing the problem but it is a user specific bug
