Hi, you’re spot on there haven’t been any drives plugged into the card.
I’ve included the lspci results below with and without a drive plugged into the card and also ran inxi again from ubuntu with the card installed and a drive plugged in. I completely forgot about running lspci without the card plugged in. I’ll do that one a bit later and update. For some reason today I couldn’t get ubuntu to boot at all with the card plugged in in ‘no boot’ mode. Normally no boot is the one that works with ubuntu. Today I had to use it in AHCI mode to get ubuntu to boot, and once booted even though the card appeared in the results from lspci I couldn’t see the drive in the file manager, whereas all the other drives I have plugged into the motherboard did appear there. Also because they’re easier to access in my case I initially tried booting with one of my blu ray drives plugged into the card but that resulted in a kernel panic whenever I tried to boot.
LSPCI WITH CARD PLUGGED IN AND NO HDD:
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Starship/Matisse IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:03.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse GPP Bridge
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:05.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Internal PCIe GPP Bridge 0 to bus[E:B]
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 61)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Matisse Device 24: Function 7
01:00.0 Non-Volatile memory controller: Sandisk Corp WD Black 2018/PC SN720 NVMe SSD
02:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse Switch Upstream
03:01.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
03:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
03:03.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
03:05.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
03:08.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
03:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
03:0a.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Matisse PCIe GPP Bridge
04:00.0 Non-Volatile memory controller: Phison Electronics Corporation E12 NVMe Controller (rev 01)
05:00.0 Multimedia video controller: Conexant Systems, Inc. CX23887/8 PCIe Broadcast Audio and Video Decoder with 3D Comb (rev 04)
06:00.0 Network controller: Intel Corporation Wireless 8260 (rev 3a)
07:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
08:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
08:00.1 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
08:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
09:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
0a:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
0b:00.0 VGA compatible controller: NVIDIA Corporation TU106 [GeForce RTX 2060 SUPER] (rev a1)
0b:00.1 Audio device: NVIDIA Corporation TU106 High Definition Audio Controller (rev a1)
0b:00.2 USB controller: NVIDIA Corporation TU106 USB 3.1 Host Controller (rev a1)
0b:00.3 Serial bus controller [0c80]: NVIDIA Corporation TU106 USB Type-C UCSI Controller (rev a1)
0c:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
0d:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse PCIe Dummy Function
0e:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Reserved SPP
0e:00.1 Encryption controller: Advanced Micro Devices, Inc. [AMD] Starship/Matisse Cryptographic Coprocessor PSPCPP
0e:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Matisse USB 3.0 Host Controller
0e:00.4 Audio device: Advanced Micro Devices, Inc. [AMD] Starship/Matisse HD Audio Controller
LSPCI WITH HDD PLUGGED INTO CARD:
INXI WITH CARD PLUGGED IN AND HDD ATTACHED:
Kernel: 5.4.0-42-generic x86_64 bits: 64 compiler: gcc v: 9.3.0
parameters: BOOT_IMAGE=/casper/vmlinuz file=/cdrom/preseed/ubuntu.seed
maybe-ubiquity quiet splash ---
Desktop: N/A wm: gnome-shell dm: GDM3 3.34.1
Distro: Ubuntu 20.04.1 LTS (Focal Fossa)
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
serial: <filter> UEFI: American Megatrends v: 2606 date: 08/13/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
status: Discharging
RAM: total: 31.33 GiB used: 1.91 GiB (6.1%)
RAM Report:
Info: 6-Core model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 71 (113) stepping: N/A microcode: 8701021
L2 cache: 3072 KiB bogomips: 96007
Speed: 4032 MHz min/max: 2200/4000 MHz boost: enabled Core speeds (MHz):
1: 3999 2: 4000 3: 3987 4: 3995 5: 4001 6: 4005 7: 4001 8: 4003 9: 3999
10: 4000 11: 4000 12: 3993
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rdpid rdrand rdseed rdt_a rdtscp
rep_good sep sev sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext tsc
tsc_scale umip v_vmsave_vmload vgif vmcb_clean vme vmmcall wbnoinvd wdt
conditional, RSB filling
Device-1: Conexant Systems CX23887/8 PCIe Broadcast Audio and Video
vendor: Hauppauge works driver: cx23885 v: 0.0.4 bus ID: 05:00.0
chip ID: 14f1:8880
Device-2: NVIDIA TU106 [GeForce RTX 2060 SUPER] vendor: Gigabyte
driver: nouveau v: kernel alternate: nvidiafb bus ID: 0b:00.0
chip ID: 10de:1f06
Display: x11 server: X.Org 1.20.8 compositor: gnome-shell
driver: modesetting unloaded: fbdev,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-3 res: 1920x1080 hz: 60 dpi: 93
size: 527x296mm (20.7x11.7") diag: 604mm (23.8")
chip ID: 14f1:8880
Device-2: NVIDIA TU106 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus ID: 0b:00.1 chip ID: 10de:10f9
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus ID: 0e:00.4 chip ID: 1022:1487
Device-4: SteelSeries ApS SteelSeries Arctis 7 type: USB
driver: hid-generic,snd-usb-audio,usbhid bus ID: 7-1:2 chip ID: 1038:1260
Device-5: Logitech Logitech StreamCam type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus ID: 2-4:2
chip ID: 046d:0893 serial: <filter>
Sound Server: ALSA v: k5.4.0-42-generic
Device-1: Intel Wireless 8260 driver: iwlwifi v: kernel bus ID: 06:00.0
chip ID: 8086:24f3
IF: wlp6s0 state: down mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb
v: 5.6.0-k port: f000 bus ID: 07:00.0 chip ID: 8086:1539
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 6.36 TiB used: 837.68 GiB (12.9%)
ID-1: /dev/nvme0n1 vendor: SanDisk model: Extreme Pro 500GB
size: 465.76 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 101200RL scheme: GPT
ID-2: /dev/nvme1n1 vendor: Corsair model: Force MP510 size: 447.13 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4
serial: <filter> rev: ECFM22.5 scheme: GPT
ID-3: /dev/sda vendor: Samsung model: SSD 860 EVO 1TB size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: 3B6Q scheme: MBR
ID-4: /dev/sdb vendor: Seagate model: ST5000DM000-1FK178 size: 4.55 TiB
block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
rotation: 5980 rpm serial: <filter> rev: CC49 scheme: GPT
ID-5: /dev/sdc type: USB vendor: SanDisk model: Ultra Fit size: 14.32 GiB
block size: physical: 512 B logical: 512 B serial: <filter> rev: 1.00
scheme: MBR
Optical-1: /dev/sr0 vendor: PIONEER model: BD-RW BDR-211M rev: 1.52
dev-links: cdrom
Features: speed: 125 multisession: yes audio: yes dvd: yes
Optical-2: /dev/sr1 vendor: PIONEER model: BD-RW BDR-209D rev: 1.51
dev-links: cdrw,dvd,dvdrw
rw: cd-r,cd-rw,dvd-r state: running
ID-1: / raw size: N/A size: 15.67 GiB used: 133.6 MiB (0.8%) fs: overlay
source: ERR-102 label: N/A uuid: N/A
ID-2: /cdrom raw size: 2.59 GiB size: <superuser/root required>
used: <superuser/root required> fs: iso9660 dev: /dev/sdc1
label: Ubuntu 20.04.1 LTS amd64 uuid: 2020-07-31-16-51-12-00
ID-3: /media/ubuntu/Samsung 860 EVO raw size: 931.51 GiB
size: 931.51 GiB (100.00%) used: 837.51 GiB (89.9%) fs: ntfs
dev: /dev/sda1 label: Samsung 860 EVO uuid: 4268466468465737
ID-4: /var/crash raw size: 11.73 GiB size: <superuser/root required>
used: <superuser/root required> fs: ext4 dev: /dev/sdc3 label: writable
uuid: dce83d6c-2803-42c6-82ba-89003ab428c9
ID-5: /var/log raw size: 11.73 GiB size: 11.48 GiB (97.90%)
used: 42.9 MiB (0.4%) fs: ext4 dev: /dev/sdc3 label: writable
ID-1: /dev/nvme0n1p1 size: 464.26 GiB fs: ntfs label: N/A
uuid: 86860F96860F85C1
ID-2: /dev/nvme0n1p2 size: 535.0 MiB fs: ntfs label: N/A
uuid: C690CEB590CEAB6F
ID-3: /dev/nvme0n1p4 size: 701.0 MiB fs: vfat label: N/A uuid: DC38-75AA
ID-4: /dev/nvme1n1p1 size: 300.0 MiB fs: vfat label: N/A uuid: D54B-FAA6
ID-5: /dev/nvme1n1p2 size: 446.83 GiB fs: ext4 label: N/A
uuid: 4b7a9f9d-3c82-4fb9-b087-bc0184f55d56
ID-6: /dev/sdb1 size: 128.0 MiB fs: <superuser/root required> label: N/A
uuid: N/A
ID-7: /dev/sdb2 size: 4.55 TiB fs: ntfs label: Seagate Expansion Drive
uuid: 2E2E59192E58DC01
ID-8: /dev/sdc2 size: 3.9 MiB fs: vfat label: N/A uuid: C26E-047E
Hub: 1-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-2:2
info: Corsair CORSAIR K70 RGB MK.2 LOW PROFILE Mechanical Gaming Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s chip ID: 1b1c:1b55 serial: <filter>
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Device-1: 2-4:2 info: Logitech Logitech StreamCam type: Video,Audio,HID
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo interfaces: 6 rev: 3.2
speed: 5 Gb/s chip ID: 046d:0893 serial: <filter>
Hub: 3-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Device-1: 3-4:2 info: ASUSTek AURA LED Controller type: <vendor specific>
chip ID: 0b05:18f3 serial: <filter>
Device-2: 3-6:3 info: Intel type: Bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s chip ID: 8087:0a2b
Hub: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Device-1: 4-1:2 info: SanDisk Ultra Fit type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s
chip ID: 0781:5583 serial: <filter>
Hub: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Hub: 7-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 7-1:2 info: SteelSeries ApS SteelSeries Arctis 7 type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 1.1
speed: 12 Mb/s chip ID: 1038:1260
Device-2: 7-3:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID
chip ID: 046d:c52b
Hub: 8-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003
Missing: Required tool sensors not installed. Check --recommends
Processes: 352 Uptime: 5m Init: systemd v: 245 runlevel: 5 Compilers:
gcc: N/A Packages: 1791 apt: 1785 lib: 805 snap: 6 Shell: Bash v: 5.0.17
running in: gnome-terminal inxi: 3.1.06
