Hello, noob here.
I got a new laptop and installed Manjaro (coming from Ubuntu). One of the first things I wanted to do was switching to the LTS Kernel. So I installed it, rebooted and selected it. But then: nothing. First only the manufactors logo for a long time and then a black screen. Uninstalled it, reinstalled it, tried other Kernels. Everytime the same.
So I can only boot from the Kernel that was installed in the beginning.
Also (dont know if it has something to do with it) I tried to boot POP OS via USB and again it wouldnt boot (booted normally on my other pc). But the Manjaro USB is booting normally into Live OS.
In between (after my first attemt of switching to other Kernel) I also had an Error, I dont remember what it exactly was (I had so many problems, so I dont remember everything now…) but I had to deactivate secure booting. (also dont know, if it could have something to do with it…)
I have no idea what information I can give you other then:
uname -r
5.9.16-1-MANJARO
Post the output of this
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
root=UUID=ccd8070b-1862-4ef6-9058-f9aea870dedc ro quiet apparmor=1
security=apparmor resume=UUID=40acc7cf-e697-4752-8654-6a1bacc294eb
udev.log_priority=3
Desktop: KDE Plasma 5.21.1 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: Schenker product: XMG CORE 17(M20, RTX 2060)
v: Standard serial: <filter>
Mobo: Schenker model: GK7NxxR M20 v: Standard serial: <filter>
UEFI: American Megatrends v: N.1.16.A01 date: 09/02/2020
ID-1: BAT0 charge: 26.2 Wh condition: 62.3/62.3 Wh (100%) volts: 16.1/15.2
model: standard type: Li-ion serial: <filter> status: Charging
RAM: total: 15.12 GiB used: 3.05 GiB (20.2%)
Info: 8-Core model: AMD Ryzen 7 4800H with Radeon Graphics bits: 64
type: MT MCP arch: Zen 2 family: 17 (23) model-id: 60 (96) stepping: 1
microcode: 8600103 L2 cache: 4 MiB bogomips: 92663
Speed: 1591 MHz min/max: 1400/2900 MHz boost: enabled Core speeds (MHz):
1: 1591 2: 1707 3: 1454 4: 1588 5: 3342 6: 2367 7: 1642 8: 1555 9: 1912
10: 2022 11: 1725 12: 1899 13: 1592 14: 1449 15: 1533 16: 1570
fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs irperf lahf_lm
lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Tongfang Hongkong Limited driver: nvidia v: 460.39
alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:1f15
class ID: 0300
Device-2: AMD Renoir vendor: Tongfang Hongkong Limited driver: amdgpu
v: kernel bus ID: 05:00.0 chip ID: 1002:1636 class ID: 0300
Device-3: Chicony HD Webcam type: USB driver: uvcvideo bus ID: 3-4:4
chip ID: 04f2:b641 class ID: 0e02
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: modesetting,nvidia display ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.9x11.2")
s-diag: 581mm (22.9")
Monitor-1: HDMI-0 res: 1920x1080 dpi: 48 size: 1020x570mm (40.2x22.4")
diag: 1168mm (46")
OpenGL: renderer: GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 460.39
direct render: Yes
Device-1: AMD Family 17h HD Audio vendor: Tongfang Hongkong Limited
driver: snd_hda_intel v: kernel bus ID: 05:00.6 chip ID: 1022:15e3
class ID: 0403
Sound Server: ALSA v: k5.9.16-1-MANJARO
vendor: Tongfang Hongkong Limited driver: r8169 v: kernel port: e000
bus ID: 02:00.0 chip ID: 10ec:8168 class ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: e000
bus ID: 03:00.0 chip ID: 8086:2723 class ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus ID: 5-4:3
chip ID: 8087:0029 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 465.76 GiB used: 206.47 GiB (44.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M8500G
size: 465.76 GiB block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 rotation: SSD serial: <filter> rev: S5Z42105 temp: 25.9 C
scheme: GPT
ID-1: / raw size: 292.65 GiB size: 287.05 GiB (98.09%)
used: 206.46 GiB (71.9%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: ccd8070b-1862-4ef6-9058-f9aea870dedc
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%)
used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 0662-C784
ID-3: /run/timeshift/backup raw size: 292.65 GiB size: <superuser required>
used: <superuser required> fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: partition size: 16.64 GiB used: 2.5 MiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A
uuid: 40acc7cf-e697-4752-8654-6a1bacc294eb
ID-1: /dev/nvme0n1p4 maj-min: 259:4 size: 156.18 GiB fs: ext4 label: N/A
uuid: 6a3644b6-cf80-4778-829b-2a9e48764ded
Hub-1: 3-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Device-1: 3-1:2 info: Realtek RTS5129 Card Reader Controller
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:0129 class ID: ff00
serial: <filter>
Hub-2: 3-2:3 info: Genesys Logic Hub ports: 2 rev: 2.1 speed: 480 Mb/s
chip ID: 05e3:0610 class ID: 0900
Device-1: 3-2.1:7 info: Microsoft Natural Ergonomic Keyboard 4000 V1.0
type: Keyboard,HID driver: microsoft,usbhid interfaces: 2 rev: 2.0
speed: 1.5 Mb/s chip ID: 045e:00db class ID: 0300
Device-2: 3-2.2:6 info: MosArt 2.4G Keyboard Mouse type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 062a:4182 class ID: 0301
Device-3: 3-4:4 info: Chicony HD Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 04f2:b641 class ID: 0e02
Hub-3: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
chip ID: 1d6b:0003 class ID: 0900
Hub-4: 4-2:2 info: Genesys Logic USB3.2 Hub ports: 2 rev: 3.2 speed: 5 Gb/s
chip ID: 05e3:0620 class ID: 0900
Hub-5: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Hub-6: 5-3:2 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 05e3:0608 class ID: 0900
Device-1: 5-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s chip ID: 8087:0029 class ID: e001
Hub-7: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 49.4 C mobo: N/A
GPU: device: nvidia screen: :0.0 temp: 41 C device: amdgpu temp: 38.0 C
Processes: 354 Uptime: 6h 43m wakeups: 10 Init: systemd v: 247 Compilers:
gcc: 10.2.0 Packages: pacman: 1411 lib: 411 flatpak: 0 Shell: Bash v: 5.1.0
running in: konsole inxi: 3.3.01
In [Morsezeichen](https://de.wikipedia.org/wiki/Morsezeichen) wird J *kurz, lang, lang, lang*, also **· − − −** geschrieben/gesprochen.``
Have u tried installing Linux 5.11 and 5.10 LTS kernels?
And yes u need to disable secure boot to use Manjaro
hmm no, its not showing the tls flag…? The latests LTS I see is the 5.4
But ok, Ill try and report
5.10 is the latest LTS kernel
For amd CPUs there is a performance improvement with kernel 5.11…so u might want to use that and keep the 5.10 LTS kernel as a fallback
Thank you! That indeed worked!
Why wasnt it working with the others and now it did??
Nonetheless, Thanks a lot!
Welcome.Glad it worked… sometimes old kernels don’t work with newer hardware…
https://www.kernel.org/
U can check kernel development status here
Some hardware won’t boot with specific kernels as there is no support for them in those older kernels. For example, I cannot boot into Kernel 5.4 with my Radeon RX 5700XT, but I can in Kernel 5.6 and onward (but much much better with Kernel 5.10 and 5.11 now)
Some stuff are backported to some LTS kernels, but not everything.
If you want to learn more about each kernel changes, you can check it out here:
Phoronix has some good outlines as well
Ok, thank you! I will check out the links
system
Closed
20 March 2021 17:43
12
