Sorry for the late reply,
here’s the output
[ 22.450] (--) Log file renamed from "/var/log/Xorg.pid-776.log" to "/var/log/Xorg.0.log"
[ 22.467]
X.Org X Server 1.20.10
[ 22.467] Build Operating System: Linux Manjaro Linux
[ 22.467] Current Operating System: Linux bakpao-ux303ub 5.4.89-1-MANJARO #1 SMP PREEMPT Tue Jan 12 23:39:44 UTC 2021 x86_64
[ 22.467] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=4c146c72-0f30-43dd-b73b-cc5b7fa348c8 ro quiet apparmor=1 security=apparmor resume=UUID=35db88b3-632a-4554-aed6-3bad2e394023 udev.log_priority=3 sysrq_always_enabled=1
[ 22.467] Build Date: 16 December 2020 10:33:32PM
[ 22.467]
[ 22.467] Current version of pixman: 0.40.0
[ 22.467] Before reporting problems, check http://wiki.x.org
[ 22.467] Markers: (--) probed, (**) from config file, (==) default setting,
[ 22.468] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Feb 12 01:14:51 2021
[ 22.508] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 22.508] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 22.563] (==) ServerLayout "layout"
[ 22.563] (==) No screen section available. Using defaults.
[ 22.563] (**) |-->Screen "Default Screen Section" (0)
[ 22.563] (**) | |-->Monitor "<default monitor>"
[ 22.564] (==) No monitor specified for screen "Default Screen Section".
[ 22.564] (==) Automatically adding devices
[ 22.564] (==) Automatically enabling devices
[ 22.564] (==) Automatically adding GPU devices
[ 22.564] (==) Automatically binding GPU devices
[ 22.564] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 22.582] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 22.582] Entry deleted from font path.
[ 22.582] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 22.582] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 22.582] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 22.582] (==) FontPath set to:
/usr/share/fonts/misc,
/usr/share/fonts/TTF
[ 22.582] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 22.582] (II) The server relies on udev to provide the list of input devices.
[ 22.582] (II) Module ABI versions:
[ 22.582] X.Org ANSI C Emulation: 0.4
[ 22.582] X.Org Video Driver: 24.1
[ 22.582] X.Org XInput driver : 24.1
[ 22.582] X.Org Server Extension : 10.0
[ 22.584] (++) using VT number 1
[ 22.584] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 22.586] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 22.604] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 22.606] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 22.606] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[ 22.926] (--) PCI:*(0@0:2:0) 8086:1916:1043:1b1d rev 7, Mem @ 0xdd000000/16777216, 0xb0000000/268435456, I/O @ 0x0000f000/64, BIOS @ 0x????????/131072
[ 22.926] (--) PCI: (1@0:0:0) 10de:1347:1043:1b1d rev 162, Mem @ 0xde000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000e000/128, BIOS @ 0x????????/524288
[ 22.927] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 22.927] (II) LoadModule: "glx"
[ 22.999] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 23.092] (II) Module glx: vendor="X.Org Foundation"
[ 23.092] compiled for 1.20.10, module version = 1.0.0
[ 23.092] ABI class: X.Org Server Extension, version 10.0
[ 23.092] (II) Applying OutputClass "intel" to /dev/dri/card1
[ 23.092] loading driver: modesetting
[ 23.092] (II) Applying OutputClass "nvidia" to /dev/dri/card0
[ 23.092] loading driver: nvidia
[ 23.093] (II) Applying OutputClass "nvidia" to /dev/dri/card0
[ 23.093] loading driver: nvidia
[ 23.093] (==) Matched modesetting as autoconfigured driver 0
[ 23.093] (==) Matched intel as autoconfigured driver 1
[ 23.093] (==) Matched nvidia as autoconfigured driver 2
[ 23.093] (==) Matched nouveau as autoconfigured driver 3
[ 23.093] (==) Matched nv as autoconfigured driver 4
[ 23.093] (==) Matched fbdev as autoconfigured driver 5
[ 23.093] (==) Matched vesa as autoconfigured driver 6
[ 23.093] (==) Assigned the driver to the xf86ConfigLayout
[ 23.093] (II) LoadModule: "modesetting"
[ 23.093] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 23.150] (II) Module modesetting: vendor="X.Org Foundation"
[ 23.150] compiled for 1.20.10, module version = 1.20.10
[ 23.150] Module class: X.Org Video Driver
[ 23.150] ABI class: X.Org Video Driver, version 24.1
[ 23.150] (II) LoadModule: "intel"
[ 23.150] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 23.192] (II) Module intel: vendor="X.Org Foundation"
[ 23.192] compiled for 1.20.10, module version = 2.99.917
[ 23.192] Module class: X.Org Video Driver
[ 23.192] ABI class: X.Org Video Driver, version 24.1
[ 23.192] (II) LoadModule: "nvidia"
[ 23.192] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[ 23.251] (II) Module nvidia: vendor="NVIDIA Corporation"
[ 23.251] compiled for 1.6.99.901, module version = 1.0.0
[ 23.251] Module class: X.Org Video Driver
[ 23.265] (II) LoadModule: "nouveau"
[ 23.265] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 23.281] (II) Module nouveau: vendor="X.Org Foundation"
[ 23.281] compiled for 1.20.8, module version = 1.0.16
[ 23.281] Module class: X.Org Video Driver
[ 23.281] ABI class: X.Org Video Driver, version 24.1
[ 23.281] (II) LoadModule: "nv"
[ 23.283] (WW) Warning, couldn't open module nv
[ 23.283] (EE) Failed to load module "nv" (module does not exist, 0)
[ 23.283] (II) LoadModule: "fbdev"
[ 23.285] (WW) Warning, couldn't open module fbdev
[ 23.285] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 23.285] (II) LoadModule: "vesa"
[ 23.286] (WW) Warning, couldn't open module vesa
[ 23.286] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 23.286] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 23.286] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 23.287] (II) intel: Driver for Intel(R) HD Graphics
[ 23.287] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[ 23.287] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[ 23.287] (II) NVIDIA dlloader X Driver 460.32.03 Sun Dec 27 18:56:00 UTC 2020
[ 23.287] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[ 23.289] (II) NOUVEAU driver
[ 23.289] (II) NOUVEAU driver for NVIDIA chipset families :
[ 23.289] RIVA TNT (NV04)
[ 23.289] RIVA TNT2 (NV05)
[ 23.289] GeForce 256 (NV10)
[ 23.289] GeForce 2 (NV11, NV15)
[ 23.289] GeForce 4MX (NV17, NV18)
[ 23.289] GeForce 3 (NV20)
[ 23.289] GeForce 4Ti (NV25, NV28)
[ 23.289] GeForce FX (NV3x)
[ 23.290] GeForce 6 (NV4x)
[ 23.290] GeForce 7 (G7x)
[ 23.290] GeForce 8 (G8x)
[ 23.290] GeForce 9 (G9x)
[ 23.290] GeForce GTX 2xx/3xx (GT2xx)
[ 23.290] GeForce GTX 4xx/5xx (GFxxx)
[ 23.290] GeForce GTX 6xx/7xx (GKxxx)
[ 23.290] GeForce GTX 9xx (GMxxx)
[ 23.290] GeForce GTX 10xx (GPxxx)
[ 23.304] (II) modeset(0): using drv /dev/dri/card1
[ 23.315] (II) Loading sub module "fb"
[ 23.315] (II) LoadModule: "fb"
[ 23.316] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 23.332] (II) Module fb: vendor="X.Org Foundation"
[ 23.332] compiled for 1.20.10, module version = 1.0.0
[ 23.332] ABI class: X.Org ANSI C Emulation, version 0.4
[ 23.332] (II) Loading sub module "wfb"
[ 23.332] (II) LoadModule: "wfb"
[ 23.332] (II) Loading /usr/lib/xorg/modules/libwfb.so
[ 23.335] (II) Module wfb: vendor="X.Org Foundation"
[ 23.335] compiled for 1.20.10, module version = 1.0.0
[ 23.335] ABI class: X.Org ANSI C Emulation, version 0.4
[ 23.335] (II) Loading sub module "ramdac"
[ 23.335] (II) LoadModule: "ramdac"
[ 23.335] (II) Module "ramdac" already built-in
[ 23.339] (II) modeset(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 23.339] (==) modeset(0): Depth 24, (==) framebuffer bpp 32
[ 23.339] (==) modeset(0): RGB weight 888
[ 23.339] (==) modeset(0): Default visual is TrueColor
[ 23.339] (II) Loading sub module "glamoregl"
[ 23.339] (II) LoadModule: "glamoregl"
[ 23.340] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 23.421] (II) Module glamoregl: vendor="X.Org Foundation"
[ 23.421] compiled for 1.20.10, module version = 1.0.1
[ 23.421] ABI class: X.Org ANSI C Emulation, version 0.4
[ 25.361] (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) HD Graphics 520 (SKL GT2)
[ 25.361] (II) modeset(0): glamor initialized
[ 25.362] (II) modeset(0): Output eDP-1 has no monitor section
[ 25.362] (II) modeset(0): Output DP-1 has no monitor section
[ 25.368] (II) modeset(0): Output HDMI-1 has no monitor section
[ 25.373] (II) modeset(0): Output HDMI-2 has no monitor section
[ 25.379] (II) modeset(0): EDID for output eDP-1
[ 25.379] (II) modeset(0): Manufacturer: CMN Model: 1361 Serial#: 0
[ 25.379] (II) modeset(0): Year: 2014 Week: 7
[ 25.379] (II) modeset(0): EDID Version: 1.4
[ 25.379] (II) modeset(0): Digital Display Input
[ 25.379] (II) modeset(0): 8 bits per channel
[ 25.379] (II) modeset(0): Digital interface is DisplayPort
[ 25.379] (II) modeset(0): Max Image Size [cm]: horiz.: 29 vert.: 17
[ 25.379] (II) modeset(0): Gamma: 2.20
[ 25.379] (II) modeset(0): No DPMS capabilities specified
[ 25.379] (II) modeset(0): Supported color encodings: RGB 4:4:4
[ 25.379] (II) modeset(0): First detailed timing is preferred mode
[ 25.379] (II) modeset(0): Preferred mode is native pixel format and refresh rate
[ 25.379] (II) modeset(0): redX: 0.640 redY: 0.340 greenX: 0.308 greenY: 0.615
[ 25.379] (II) modeset(0): blueX: 0.150 blueY: 0.070 whiteX: 0.313 whiteY: 0.329
[ 25.379] (II) modeset(0): Manufacturer's mask: 0
[ 25.379] (II) modeset(0): Supported detailed timing:
[ 25.379] (II) modeset(0): clock: 138.8 MHz Image Size: 293 x 165 mm
[ 25.379] (II) modeset(0): h_active: 1920 h_sync: 1966 h_sync_end 1996 h_blank_end 2080 h_border: 0
[ 25.379] (II) modeset(0): v_active: 1080 v_sync: 1082 v_sync_end 1086 v_blanking: 1112 v_border: 0
[ 25.379] (II) modeset(0): clock: 92.5 MHz Image Size: 293 x 165 mm
[ 25.379] (II) modeset(0): CMN
[ 25.379] (II) modeset(0): N133HSE-EA3
[ 25.379] (II) modeset(0): EDID (in hex):
[ 25.379] (II) modeset(0): 00ffffffffffff000dae611300000000
[ 25.379] (II) modeset(0): 07180104a51d117802ce85a3574e9d26
[ 25.379] (II) modeset(0): 12505400000001010101010101010101
[ 25.379] (II) modeset(0): 010101010101363680a0703820402e1e
[ 25.379] (II) modeset(0): 240025a510000018242480a070382040
[ 25.379] (II) modeset(0): 2e1e240025a510000018000000fe0043
[ 25.379] (II) modeset(0): 4d4e0a202020202020202020000000fe
[ 25.379] (II) modeset(0): 004e3133334853452d4541330a2000a1
[ 25.380] (II) modeset(0): Printing probed modes for output eDP-1
[ 25.380] (II) modeset(0): Modeline "1920x1080"x60.0 138.78 1920 1966 1996 2080 1080 1082 1086 1112 -hsync -vsync (66.7 kHz eP)
[ 25.380] (II) modeset(0): Modeline "1920x1080"x119.9 266.50 1920 1944 1960 2000 1080 1081 1084 1111 doublescan +hsync -vsync (133.2 kHz d)
[ 25.380] (II) modeset(0): Modeline "1920x1080"x60.0 173.00 1920 2048 2248 2576 1080 1083 1088 1120 -hsync +vsync (67.2 kHz d)
[ 25.380] (II) modeset(0): Modeline "1920x1080"x59.9 138.50 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync (66.6 kHz d)
[ 25.380] (II) modeset(0): Modeline "1920x1080"x40.0 92.52 1920 1966 1996 2080 1080 1082 1086 1112 -hsync -vsync (44.5 kHz e)
[ 25.380] (II) modeset(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz d)
[ 25.380] (II) modeset(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz d)
[ 25.380] (II) modeset(0): Modeline "1400x1050"x60.0 122.00 1400 1488 1640 1880 1050 1052 1064 1082 +hsync +vsync (64.9 kHz d)
[ 25.380] (II) modeset(0): Modeline "1600x900"x120.0 246.00 1600 1728 1900 2200 900 901 904 932 doublescan -hsync +vsync (111.8 kHz d)
[ 25.380] (II) modeset(0): Modeline "1600x900"x119.9 186.50 1600 1624 1640 1680 900 901 904 926 doublescan +hsync -vsync (111.0 kHz d)
[ 25.380] (II) modeset(0): Modeline "1600x900"x59.9 118.25 1600 1696 1856 2112 900 903 908 934 -hsync +vsync (56.0 kHz d)
[ 25.380] (II) modeset(0): Modeline "1600x900"x59.8 97.50 1600 1648 1680 1760 900 903 908 926 +hsync -vsync (55.4 kHz d)
[ 25.380] (II) modeset(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz d)
[ 25.380] (II) modeset(0): Modeline "1400x900"x60.0 103.50 1400 1480 1624 1848 900 903 913 934 -hsync +vsync (56.0 kHz d)
[ 25.380] (II) modeset(0): Modeline "1400x900"x59.9 86.50 1400 1448 1480 1560 900 903 913 926 +hsync -vsync (55.4 kHz d)
[ 25.380] (II) modeset(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz d)
[ 25.380] (II) modeset(0): Modeline "1440x810"x120.0 198.12 1440 1548 1704 1968 810 811 814 839 doublescan -hsync +vsync (100.7 kHz d)
[ 25.380] (II) modeset(0): Modeline "1440x810"x119.9 151.88 1440 1464 1480 1520 810 811 814 833 doublescan +hsync -vsync (99.9 kHz d)
[ 25.380] (II) modeset(0): Modeline "1368x768"x59.9 85.25 1368 1440 1576 1784 768 771 781 798 -hsync +vsync (47.8 kHz d)
[ 25.380] (II) modeset(0): Modeline "1368x768"x59.9 72.25 1368 1416 1448 1528 768 771 781 790 +hsync -vsync (47.3 kHz d)
[ 25.380] (II) modeset(0): Modeline "1280x800"x120.0 174.25 1280 1380 1516 1752 800 801 804 829 doublescan -hsync +vsync (99.5 kHz d)
[ 25.380] (II) modeset(0): Modeline "1280x800"x119.9 134.25 1280 1304 1320 1360 800 801 804 823 doublescan +hsync -vsync (98.7 kHz d)
[ 25.380] (II) modeset(0): Modeline "1280x800"x59.8 83.50 1280 1352 1480 1680 800 803 809 831 -hsync +vsync (49.7 kHz d)
[ 25.380] (II) modeset(0): Modeline "1280x800"x59.9 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz d)
[ 25.381] (II) modeset(0): Modeline "1280x720"x120.0 156.12 1280 1376 1512 1744 720 721 724 746 doublescan -hsync +vsync (89.5 kHz d)
[ 25.381] (II) modeset(0): Modeline "1280x720"x120.0 120.75 1280 1304 1320 1360 720 721 724 740 doublescan +hsync -vsync (88.8 kHz d)
[ 25.381] (II) modeset(0): Modeline "1280x720"x59.9 74.50 1280 1344 1472 1664 720 723 728 748 -hsync +vsync (44.8 kHz d)
[ 25.381] (II) modeset(0): Modeline "1280x720"x59.7 63.75 1280 1328 1360 1440 720 723 728 741 +hsync -vsync (44.3 kHz d)
[ 25.381] (II) modeset(0): Modeline "1024x768"x120.1 133.47 1024 1100 1212 1400 768 768 770 794 doublescan -hsync +vsync (95.3 kHz d)
[ 25.381] (II) modeset(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz d)
[ 25.381] (II) modeset(0): Modeline "960x720"x120.0 117.00 960 1024 1128 1300 720 720 722 750 doublescan -hsync +vsync (90.0 kHz d)
[ 25.381] (II) modeset(0): Modeline "928x696"x120.1 109.15 928 976 1088 1264 696 696 698 719 doublescan -hsync +vsync (86.4 kHz d)
[ 25.381] (II) modeset(0): Modeline "896x672"x120.0 102.40 896 960 1060 1224 672 672 674 697 doublescan -hsync +vsync (83.7 kHz d)
[ 25.381] (II) modeset(0): Modeline "1024x576"x119.9 98.50 1024 1092 1200 1376 576 577 580 597 doublescan -hsync +vsync (71.6 kHz d)
[ 25.381] (II) modeset(0): Modeline "1024x576"x119.9 78.38 1024 1048 1064 1104 576 577 580 592 doublescan +hsync -vsync (71.0 kHz d)
[ 25.381] (II) modeset(0): Modeline "1024x576"x59.9 46.50 1024 1064 1160 1296 576 579 584 599 -hsync +vsync (35.9 kHz d)
[ 25.381] (II) modeset(0): Modeline "1024x576"x59.8 42.00 1024 1072 1104 1184 576 579 584 593 +hsync -vsync (35.5 kHz d)
[ 25.381] (II) modeset(0): Modeline "960x600"x119.9 96.62 960 1028 1128 1296 600 601 604 622 doublescan -hsync +vsync (74.6 kHz d)
[ 25.381] (II) modeset(0): Modeline "960x600"x120.0 77.00 960 984 1000 1040 600 601 604 617 doublescan +hsync -vsync (74.0 kHz d)
[ 25.381] (II) modeset(0): Modeline "960x540"x119.9 86.50 960 1024 1124 1288 540 541 544 560 doublescan -hsync +vsync (67.2 kHz d)
[ 25.381] (II) modeset(0): Modeline "960x540"x120.0 69.25 960 984 1000 1040 540 541 544 555 doublescan +hsync -vsync (66.6 kHz d)
[ 25.381] (II) modeset(0): Modeline "960x540"x59.6 40.75 960 992 1088 1216 540 543 548 562 -hsync +vsync (33.5 kHz d)
[ 25.381] (II) modeset(0): Modeline "960x540"x59.8 37.25 960 1008 1040 1120 540 543 548 556 +hsync -vsync (33.3 kHz d)
[ 25.381] (II) modeset(0): Modeline "800x600"x120.0 81.00 800 832 928 1080 600 600 602 625 doublescan +hsync +vsync (75.0 kHz d)
[ 25.381] (II) modeset(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz d)
[ 25.381] (II) modeset(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz d)
[ 25.381] (II) modeset(0): Modeline "840x525"x120.0 73.12 840 892 980 1120 525 526 529 544 doublescan -hsync +vsync (65.3 kHz d)
[ 25.381] (II) modeset(0): Modeline "840x525"x119.8 59.50 840 864 880 920 525 526 529 540 doublescan +hsync -vsync (64.7 kHz d)
[ 25.381] (II) modeset(0): Modeline "864x486"x59.9 32.50 864 888 968 1072 486 489 494 506 -hsync +vsync (30.3 kHz d)
[ 25.381] (II) modeset(0): Modeline "864x486"x59.6 30.50 864 912 944 1024 486 489 494 500 +hsync -vsync (29.8 kHz d)
[ 25.381] (II) modeset(0): Modeline "700x525"x120.0 61.00 700 744 820 940 525 526 532 541 doublescan +hsync +vsync (64.9 kHz d)
[ 25.381] (II) modeset(0): Modeline "800x450"x119.9 59.12 800 848 928 1056 450 451 454 467 doublescan -hsync +vsync (56.0 kHz d)
[ 25.381] (II) modeset(0): Modeline "800x450"x119.6 48.75 800 824 840 880 450 451 454 463 doublescan +hsync -vsync (55.4 kHz d)
[ 25.381] (II) modeset(0): Modeline "640x512"x120.0 54.00 640 664 720 844 512 512 514 533 doublescan +hsync +vsync (64.0 kHz d)
[ 25.381] (II) modeset(0): Modeline "700x450"x119.9 51.75 700 740 812 924 450 451 456 467 doublescan -hsync +vsync (56.0 kHz d)
[ 25.381] (II) modeset(0): Modeline "700x450"x119.8 43.25 700 724 740 780 450 451 456 463 doublescan +hsync -vsync (55.4 kHz d)
[ 25.381] (II) modeset(0): Modeline "640x480"x120.0 54.00 640 688 744 900 480 480 482 500 doublescan +hsync +vsync (60.0 kHz d)
[ 25.381] (II) modeset(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz d)
[ 25.381] (II) modeset(0): Modeline "720x405"x59.5 22.50 720 744 808 896 405 408 413 422 -hsync +vsync (25.1 kHz d)
[ 25.381] (II) modeset(0): Modeline "720x405"x59.0 21.75 720 768 800 880 405 408 413 419 +hsync -vsync (24.7 kHz d)
[ 25.381] (II) modeset(0): Modeline "684x384"x119.8 42.62 684 720 788 892 384 385 390 399 doublescan -hsync +vsync (47.8 kHz d)
[ 25.381] (II) modeset(0): Modeline "684x384"x119.7 36.12 684 708 724 764 384 385 390 395 doublescan +hsync -vsync (47.3 kHz d)
[ 25.381] (II) modeset(0): Modeline "640x400"x119.8 41.75 640 676 740 840 400 401 404 415 doublescan -hsync +vsync (49.7 kHz d)
[ 25.381] (II) modeset(0): Modeline "640x400"x120.0 35.50 640 664 680 720 400 401 404 411 doublescan +hsync -vsync (49.3 kHz d)
[ 25.381] (II) modeset(0): Modeline "640x360"x119.7 37.25 640 672 736 832 360 361 364 374 doublescan -hsync +vsync (44.8 kHz d)
[ 25.381] (II) modeset(0): Modeline "640x360"x119.7 31.88 640 664 680 720 360 361 364 370 doublescan +hsync -vsync (44.3 kHz d)
[ 25.381] (II) modeset(0): Modeline "640x360"x59.8 18.00 640 664 720 800 360 363 368 376 -hsync +vsync (22.5 kHz d)
[ 25.381] (II) modeset(0): Modeline "640x360"x59.3 17.75 640 688 720 800 360 363 368 374 +hsync -vsync (22.2 kHz d)
[ 25.382] (II) modeset(0): Modeline "512x384"x120.0 32.50 512 524 592 672 384 385 388 403 doublescan -hsync -vsync (48.4 kHz d)
[ 25.382] (II) modeset(0): Modeline "512x288"x120.0 23.25 512 532 580 648 288 289 292 299 doublescan -hsync +vsync (35.9 kHz d)
[ 25.382] (II) modeset(0): Modeline "512x288"x119.8 21.00 512 536 552 592 288 289 292 296 doublescan +hsync -vsync (35.5 kHz d)
[ 25.382] (II) modeset(0): Modeline "480x270"x119.3 20.38 480 496 544 608 270 271 274 281 doublescan -hsync +vsync (33.5 kHz d)
[ 25.382] (II) modeset(0): Modeline "480x270"x119.6 18.62 480 504 520 560 270 271 274 278 doublescan +hsync -vsync (33.3 kHz d)
[ 25.382] (II) modeset(0): Modeline "400x300"x120.6 20.00 400 420 484 528 300 300 302 314 doublescan +hsync +vsync (37.9 kHz d)
[ 25.382] (II) modeset(0): Modeline "400x300"x112.7 18.00 400 412 448 512 300 300 301 312 doublescan +hsync +vsync (35.2 kHz d)
[ 25.382] (II) modeset(0): Modeline "432x243"x119.8 16.25 432 444 484 536 243 244 247 253 doublescan -hsync +vsync (30.3 kHz d)
[ 25.382] (II) modeset(0): Modeline "432x243"x119.1 15.25 432 456 472 512 243 244 247 250 doublescan +hsync -vsync (29.8 kHz d)
[ 25.382] (II) modeset(0): Modeline "320x240"x120.1 12.59 320 328 376 400 240 245 246 262 doublescan -hsync -vsync (31.5 kHz d)
[ 25.382] (II) modeset(0): Modeline "360x202"x119.0 11.25 360 372 404 448 202 204 206 211 doublescan -hsync +vsync (25.1 kHz d)
[ 25.382] (II) modeset(0): Modeline "360x202"x118.3 10.88 360 384 400 440 202 204 206 209 doublescan +hsync -vsync (24.7 kHz d)
[ 25.382] (II) modeset(0): Modeline "320x180"x119.7 9.00 320 332 360 400 180 181 184 188 doublescan -hsync +vsync (22.5 kHz d)
[ 25.382] (II) modeset(0): Modeline "320x180"x118.6 8.88 320 344 360 400 180 181 184 187 doublescan +hsync -vsync (22.2 kHz d)
[ 25.382] (II) modeset(0): EDID for output DP-1
[ 25.387] (II) modeset(0): EDID for output HDMI-1
[ 25.392] (II) modeset(0): EDID for output HDMI-2
[ 25.392] (II) modeset(0): Output eDP-1 connected
[ 25.392] (II) modeset(0): Output DP-1 disconnected
[ 25.392] (II) modeset(0): Output HDMI-1 disconnected
[ 25.392] (II) modeset(0): Output HDMI-2 disconnected
[ 25.392] (II) modeset(0): Using exact sizes for initial modes
[ 25.392] (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
[ 25.392] (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
[ 25.392] (==) modeset(0): DPI set to (96, 96)
[ 25.392] (II) Loading sub module "fb"
[ 25.392] (II) LoadModule: "fb"
[ 25.392] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 25.392] (II) Module fb: vendor="X.Org Foundation"
[ 25.393] compiled for 1.20.10, module version = 1.0.0
[ 25.393] ABI class: X.Org ANSI C Emulation, version 0.4
[ 25.393] (==) NVIDIA(G0): Depth 24, (==) framebuffer bpp 32
[ 25.393] (==) NVIDIA(G0): RGB weight 888
[ 25.393] (==) NVIDIA(G0): Default visual is TrueColor
[ 25.393] (==) NVIDIA(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 25.405] (**) Option "AllowNVIDIAGpuScreens"
[ 25.405] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[ 25.405] (**) NVIDIA(G0): Option "AllowEmptyInitialConfiguration"
[ 25.405] (**) NVIDIA(G0): Enabling 2D acceleration
[ 25.405] (II) Loading sub module "glxserver_nvidia"
[ 25.405] (II) LoadModule: "glxserver_nvidia"
[ 25.405] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[ 25.824] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[ 25.824] compiled for 1.6.99.901, module version = 1.0.0
[ 25.824] Module class: X.Org Server Extension
[ 25.824] (II) NVIDIA GLX Module 460.32.03 Sun Dec 27 18:53:34 UTC 2020
[ 25.848] (II) NVIDIA: The X server supports PRIME Render Offload.
[ 26.581] (II) NVIDIA(G0): NVIDIA GPU GeForce 940M (GM108-A) at PCI:1:0:0 (GPU-0)
[ 26.581] (--) NVIDIA(G0): Memory: 2097152 kBytes
[ 26.581] (--) NVIDIA(G0): VideoBIOS: 82.08.3b.00.4b
[ 26.581] (II) NVIDIA(G0): Detected PCI Express Link width: 4X
[ 26.581] (II) NVIDIA(G0): Validated MetaModes:
[ 26.581] (II) NVIDIA(G0): "NULL"
[ 26.581] (II) NVIDIA(G0): Virtual screen size determined to be 640 x 480
[ 26.581] (WW) NVIDIA(G0): Unable to get display device for DPI computation.
[ 26.581] (==) NVIDIA(G0): DPI set to (75, 75); computed from built-in default
[ 26.581] (II) UnloadModule: "intel"
[ 26.581] (II) Unloading intel
[ 26.581] (II) UnloadModule: "nouveau"
[ 26.581] (II) Unloading nouveau
[ 27.120] (==) modeset(0): Backing store enabled
[ 27.121] (==) modeset(0): Silken mouse disabled
[ 27.188] (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
[ 27.188] (==) modeset(0): DPMS enabled
[ 27.188] (II) modeset(0): [DRI2] Setup complete
[ 27.188] (II) modeset(0): [DRI2] DRI driver: iris
[ 27.188] (II) modeset(0): [DRI2] VDPAU driver: va_gl
[ 27.189] (II) NVIDIA: Using 6144.00 MB of virtual memory for indirect memory
[ 27.189] (II) NVIDIA: access.
[ 27.196] (II) NVIDIA(G0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 27.196] (II) NVIDIA(G0): may not be running or the "AcpidSocketPath" X
[ 27.196] (II) NVIDIA(G0): configuration option may not be set correctly. When the
[ 27.196] (II) NVIDIA(G0): ACPI event daemon is available, the NVIDIA X driver will
[ 27.196] (II) NVIDIA(G0): try to use it to receive ACPI event notifications. For
[ 27.196] (II) NVIDIA(G0): details, please see the "ConnectToAcpid" and
[ 27.197] (II) NVIDIA(G0): "AcpidSocketPath" X configuration options in Appendix B: X
[ 27.197] (II) NVIDIA(G0): Config Options in the README.
[ 27.262] (II) NVIDIA(G0): Setting mode "NULL"
[ 27.272] (==) NVIDIA(G0): Disabling shared memory pixmaps
[ 27.272] (==) NVIDIA(G0): Backing store enabled
[ 27.272] (==) NVIDIA(G0): Silken mouse disabled
[ 27.272] (==) NVIDIA(G0): DPMS enabled
[ 27.342] (II) Loading sub module "dri2"
[ 27.342] (II) LoadModule: "dri2"
[ 27.342] (II) Module "dri2" already built-in
[ 27.342] (II) NVIDIA(G0): [DRI2] Setup complete
[ 27.342] (II) NVIDIA(G0): [DRI2] VDPAU driver: nvidia
[ 27.342] (II) Initializing extension Generic Event Extension
[ 27.342] (II) Initializing extension SHAPE
[ 27.343] (II) Initializing extension MIT-SHM
[ 27.343] (II) Initializing extension XInputExtension
[ 27.344] (II) Initializing extension XTEST
[ 27.344] (II) Initializing extension BIG-REQUESTS
[ 27.345] (II) Initializing extension SYNC
[ 27.345] (II) Initializing extension XKEYBOARD
[ 27.346] (II) Initializing extension XC-MISC
[ 27.346] (II) Initializing extension SECURITY
[ 27.347] (II) Initializing extension XFIXES
[ 27.347] (II) Initializing extension RENDER
[ 27.348] (II) Initializing extension RANDR
[ 27.349] (II) Initializing extension COMPOSITE
[ 27.349] (II) Initializing extension DAMAGE
[ 27.350] (II) Initializing extension MIT-SCREEN-SAVER
[ 27.350] (II) Initializing extension DOUBLE-BUFFER
[ 27.351] (II) Initializing extension RECORD
[ 27.351] (II) Initializing extension DPMS
[ 27.352] (II) Initializing extension Present
[ 27.352] (II) Initializing extension DRI3
[ 27.353] (II) Initializing extension X-Resource
[ 27.353] (II) Initializing extension XVideo
[ 27.354] (II) Initializing extension XVideo-MotionCompensation
[ 27.354] (II) Initializing extension GLX
[ 27.355] (II) Initializing extension GLX
[ 27.355] (II) Indirect GLX disabled.
[ 27.390] (II) AIGLX: Loaded and initialized iris
[ 27.390] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 27.390] (II) Initializing extension XFree86-VidModeExtension
[ 27.390] (II) Initializing extension XFree86-DGA
[ 27.391] (II) Initializing extension XFree86-DRI
[ 27.391] (II) Initializing extension DRI2
[ 27.391] (II) Initializing extension NV-GLX
[ 27.391] (II) Initializing extension NV-CONTROL
[ 27.560] (II) modeset(0): Damage tracking initialized
[ 27.561] (II) modeset(0): Setting screen physical size to 508 x 285
[ 28.041] (II) config/udev: Adding input device Power Button (/dev/input/event2)
[ 28.041] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 28.041] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 28.041] (**) Power Button: Applying InputClass "system-keyboard"
[ 28.041] (II) LoadModule: "libinput"
[ 28.041] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 28.074] (II) Module libinput: vendor="X.Org Foundation"
[ 28.074] compiled for 1.20.8, module version = 0.30.0
[ 28.074] Module class: X.Org XInput Driver
[ 28.074] ABI class: X.Org XInput driver, version 24.1
[ 28.074] (II) Using input driver 'libinput' for 'Power Button'
[ 28.074] (**) Power Button: always reports core events
[ 28.074] (**) Option "Device" "/dev/input/event2"
[ 28.075] (**) Option "_source" "server/udev"
[ 28.109] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 28.109] (II) event2 - Power Button: device is a keyboard
[ 28.110] (II) event2 - Power Button: device removed
[ 28.139] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input2/event2"
[ 28.139] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 28.139] (**) Option "xkb_layout" "us"
[ 28.139] (**) Option "xkb_variant" "dvorak"
[ 28.197] (II) event2 - Power Button: is tagged by udev as: Keyboard
[ 28.197] (II) event2 - Power Button: device is a keyboard
[ 28.199] (II) config/udev: Adding input device Asus Wireless Radio Control (/dev/input/event6)
[ 28.199] (**) Asus Wireless Radio Control: Applying InputClass "evdev keyboard catchall"
[ 28.199] (**) Asus Wireless Radio Control: Applying InputClass "libinput keyboard catchall"
[ 28.199] (**) Asus Wireless Radio Control: Applying InputClass "system-keyboard"
[ 28.199] (II) Using input driver 'libinput' for 'Asus Wireless Radio Control'
[ 28.199] (**) Asus Wireless Radio Control: always reports core events
[ 28.199] (**) Option "Device" "/dev/input/event6"
[ 28.199] (**) Option "_source" "server/udev"
[ 28.201] (II) event6 - Asus Wireless Radio Control: is tagged by udev as: Keyboard
[ 28.201] (II) event6 - Asus Wireless Radio Control: device is a keyboard
[ 28.201] (II) event6 - Asus Wireless Radio Control: device removed
[ 28.259] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/ATK4002:00/input/input23/event6"
[ 28.259] (II) XINPUT: Adding extended input device "Asus Wireless Radio Control" (type: KEYBOARD, id 7)
[ 28.259] (**) Option "xkb_layout" "us"
[ 28.259] (**) Option "xkb_variant" "dvorak"
[ 28.261] (II) event6 - Asus Wireless Radio Control: is tagged by udev as: Keyboard
[ 28.261] (II) event6 - Asus Wireless Radio Control: device is a keyboard
[ 28.263] (II) config/udev: Adding input device Video Bus (/dev/input/event10)
[ 28.263] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 28.263] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 28.263] (**) Video Bus: Applying InputClass "system-keyboard"
[ 28.263] (II) Using input driver 'libinput' for 'Video Bus'
[ 28.263] (**) Video Bus: always reports core events
[ 28.263] (**) Option "Device" "/dev/input/event10"
[ 28.263] (**) Option "_source" "server/udev"
[ 28.265] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[ 28.266] (II) event10 - Video Bus: device is a keyboard
[ 28.266] (II) event10 - Video Bus: device removed
[ 28.312] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input26/event10"
[ 28.312] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 8)
[ 28.312] (**) Option "xkb_layout" "us"
[ 28.312] (**) Option "xkb_variant" "dvorak"
[ 28.315] (II) event10 - Video Bus: is tagged by udev as: Keyboard
[ 28.315] (II) event10 - Video Bus: device is a keyboard
[ 28.317] (II) config/udev: Adding input device Video Bus (/dev/input/event11)
[ 28.317] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 28.317] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 28.317] (**) Video Bus: Applying InputClass "system-keyboard"
[ 28.317] (II) Using input driver 'libinput' for 'Video Bus'
[ 28.317] (**) Video Bus: always reports core events
[ 28.317] (**) Option "Device" "/dev/input/event11"
[ 28.317] (**) Option "_source" "server/udev"
[ 28.320] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[ 28.320] (II) event11 - Video Bus: device is a keyboard
[ 28.320] (II) event11 - Video Bus: device removed
[ 28.365] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:22/LNXVIDEO:01/input/input27/event11"
[ 28.365] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 9)
[ 28.365] (**) Option "xkb_layout" "us"
[ 28.365] (**) Option "xkb_variant" "dvorak"
[ 28.369] (II) event11 - Video Bus: is tagged by udev as: Keyboard
[ 28.369] (II) event11 - Video Bus: device is a keyboard
[ 28.370] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 28.370] (II) No input driver specified, ignoring this device.
[ 28.370] (II) This device may have been added with another device file.
[ 28.371] (II) config/udev: Adding input device Sleep Button (/dev/input/event1)
[ 28.371] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 28.371] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 28.372] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 28.372] (II) Using input driver 'libinput' for 'Sleep Button'
[ 28.372] (**) Sleep Button: always reports core events
[ 28.372] (**) Option "Device" "/dev/input/event1"
[ 28.372] (**) Option "_source" "server/udev"
[ 28.374] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 28.374] (II) event1 - Sleep Button: device is a keyboard
[ 28.374] (II) event1 - Sleep Button: device removed
[ 28.389] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1/event1"
[ 28.389] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 10)
[ 28.389] (**) Option "xkb_layout" "us"
[ 28.389] (**) Option "xkb_variant" "dvorak"
[ 28.391] (II) event1 - Sleep Button: is tagged by udev as: Keyboard
[ 28.391] (II) event1 - Sleep Button: device is a keyboard
[ 28.395] (II) config/udev: Adding input device Logitech B330/M330/M331 (/dev/input/event4)
[ 28.395] (**) Logitech B330/M330/M331: Applying InputClass "evdev pointer catchall"
[ 28.395] (**) Logitech B330/M330/M331: Applying InputClass "evdev keyboard catchall"
[ 28.395] (**) Logitech B330/M330/M331: Applying InputClass "libinput pointer catchall"
[ 28.395] (**) Logitech B330/M330/M331: Applying InputClass "libinput keyboard catchall"
[ 28.395] (**) Logitech B330/M330/M331: Applying InputClass "system-keyboard"
[ 28.395] (II) Using input driver 'libinput' for 'Logitech B330/M330/M331'
[ 28.395] (**) Logitech B330/M330/M331: always reports core events
[ 28.395] (**) Option "Device" "/dev/input/event4"
[ 28.395] (**) Option "_source" "server/udev"
[ 28.399] (II) event4 - Logitech B330/M330/M331: is tagged by udev as: Keyboard Mouse
[ 28.400] (II) event4 - Logitech B330/M330/M331: device is a pointer
[ 28.400] (II) event4 - Logitech B330/M330/M331: device is a keyboard
[ 28.400] (II) event4 - Logitech B330/M330/M331: device removed
[ 28.419] (II) libinput: Logitech B330/M330/M331: needs a virtual subdevice
[ 28.419] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2.1/1-2.1:1.1/0003:046D:C52F.0002/0003:046D:4057.0003/input/input17/event4"
[ 28.419] (II) XINPUT: Adding extended input device "Logitech B330/M330/M331" (type: MOUSE, id 11)
[ 28.419] (**) Option "AccelerationScheme" "none"
[ 28.419] (**) Logitech B330/M330/M331: (accel) selected scheme none/0
[ 28.419] (**) Logitech B330/M330/M331: (accel) acceleration factor: 2.000
[ 28.419] (**) Logitech B330/M330/M331: (accel) acceleration threshold: 4
[ 28.424] (II) event4 - Logitech B330/M330/M331: is tagged by udev as: Keyboard Mouse
[ 28.424] (II) event4 - Logitech B330/M330/M331: device is a pointer
[ 28.424] (II) event4 - Logitech B330/M330/M331: device is a keyboard
[ 28.426] (II) config/udev: Adding input device Logitech B330/M330/M331 (/dev/input/mouse0)
[ 28.426] (**) Logitech B330/M330/M331: Applying InputClass "system-keyboard"
[ 28.426] (II) No input driver specified, ignoring this device.
[ 28.426] (II) This device may have been added with another device file.
[ 28.428] (II) config/udev: Adding input device GeneralPlus USB Audio Device (/dev/input/event5)
[ 28.428] (**) GeneralPlus USB Audio Device: Applying InputClass "evdev keyboard catchall"
[ 28.428] (**) GeneralPlus USB Audio Device: Applying InputClass "libinput keyboard catchall"
[ 28.428] (**) GeneralPlus USB Audio Device: Applying InputClass "system-keyboard"
[ 28.429] (II) Using input driver 'libinput' for 'GeneralPlus USB Audio Device'
[ 28.429] (**) GeneralPlus USB Audio Device: always reports core events
[ 28.429] (**) Option "Device" "/dev/input/event5"
[ 28.429] (**) Option "_source" "server/udev"
[ 28.433] (II) event5 - GeneralPlus USB Audio Device: is tagged by udev as: Keyboard
[ 28.433] (II) event5 - GeneralPlus USB Audio Device: device is a keyboard
[ 28.433] (II) event5 - GeneralPlus USB Audio Device: device removed
[ 28.485] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2.3/1-2.3:1.3/0003:1B3F:2007.0004/input/input18/event5"
[ 28.485] (II) XINPUT: Adding extended input device "GeneralPlus USB Audio Device" (type: KEYBOARD, id 12)
[ 28.485] (**) Option "xkb_layout" "us"
[ 28.485] (**) Option "xkb_variant" "dvorak"
[ 28.490] (II) event5 - GeneralPlus USB Audio Device: is tagged by udev as: Keyboard
[ 28.490] (II) event5 - GeneralPlus USB Audio Device: device is a keyboard
[ 28.492] (II) config/udev: Adding input device USB2.0 HD UVC WebCam: USB2.0 HD (/dev/input/event19)
[ 28.492] (**) USB2.0 HD UVC WebCam: USB2.0 HD: Applying InputClass "evdev keyboard catchall"
[ 28.492] (**) USB2.0 HD UVC WebCam: USB2.0 HD: Applying InputClass "libinput keyboard catchall"
[ 28.492] (**) USB2.0 HD UVC WebCam: USB2.0 HD: Applying InputClass "system-keyboard"
[ 28.492] (II) Using input driver 'libinput' for 'USB2.0 HD UVC WebCam: USB2.0 HD'
[ 28.492] (**) USB2.0 HD UVC WebCam: USB2.0 HD: always reports core events
[ 28.492] (**) Option "Device" "/dev/input/event19"
[ 28.492] (**) Option "_source" "server/udev"
[ 28.495] (II) event19 - USB2.0 HD UVC WebCam: USB2.0 HD: is tagged by udev as: Keyboard
[ 28.495] (II) event19 - USB2.0 HD UVC WebCam: USB2.0 HD: device is a keyboard
[ 28.496] (II) event19 - USB2.0 HD UVC WebCam: USB2.0 HD: device removed
[ 28.539] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-5/1-5:1.0/input/input35/event19"
[ 28.539] (II) XINPUT: Adding extended input device "USB2.0 HD UVC WebCam: USB2.0 HD" (type: KEYBOARD, id 13)
[ 28.539] (**) Option "xkb_layout" "us"
[ 28.539] (**) Option "xkb_variant" "dvorak"
[ 28.542] (II) event19 - USB2.0 HD UVC WebCam: USB2.0 HD: is tagged by udev as: Keyboard
[ 28.543] (II) event19 - USB2.0 HD UVC WebCam: USB2.0 HD: device is a keyboard
[ 28.544] (II) config/udev: Adding input device HDA Intel PCH Mic (/dev/input/event12)
[ 28.544] (II) No input driver specified, ignoring this device.
[ 28.544] (II) This device may have been added with another device file.
[ 28.545] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event13)
[ 28.545] (II) No input driver specified, ignoring this device.
[ 28.545] (II) This device may have been added with another device file.
[ 28.546] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=3 (/dev/input/event14)
[ 28.546] (II) No input driver specified, ignoring this device.
[ 28.546] (II) This device may have been added with another device file.
[ 28.547] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=7 (/dev/input/event15)
[ 28.547] (II) No input driver specified, ignoring this device.
[ 28.547] (II) This device may have been added with another device file.
[ 28.548] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=8 (/dev/input/event16)
[ 28.548] (II) No input driver specified, ignoring this device.
[ 28.548] (II) This device may have been added with another device file.
[ 28.549] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=9 (/dev/input/event17)
[ 28.549] (II) No input driver specified, ignoring this device.
[ 28.549] (II) This device may have been added with another device file.
[ 28.550] (II) config/udev: Adding input device HDA Intel PCH HDMI/DP,pcm=10 (/dev/input/event18)
[ 28.550] (II) No input driver specified, ignoring this device.
[ 28.550] (II) This device may have been added with another device file.
[ 28.551] (II) config/udev: Adding input device Asus WMI hotkeys (/dev/input/event7)
[ 28.551] (**) Asus WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 28.551] (**) Asus WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 28.551] (**) Asus WMI hotkeys: Applying InputClass "system-keyboard"
[ 28.551] (II) Using input driver 'libinput' for 'Asus WMI hotkeys'
[ 28.551] (**) Asus WMI hotkeys: always reports core events
[ 28.551] (**) Option "Device" "/dev/input/event7"
[ 28.551] (**) Option "_source" "server/udev"
[ 28.553] (II) event7 - Asus WMI hotkeys: is tagged by udev as: Keyboard
[ 28.554] (II) event7 - Asus WMI hotkeys: device is a keyboard
[ 28.554] (II) event7 - Asus WMI hotkeys: device removed
[ 28.605] (**) Option "config_info" "udev:/sys/devices/platform/asus-nb-wmi/input/input24/event7"
[ 28.605] (II) XINPUT: Adding extended input device "Asus WMI hotkeys" (type: KEYBOARD, id 14)
[ 28.605] (**) Option "xkb_layout" "us"
[ 28.605] (**) Option "xkb_variant" "dvorak"
[ 28.608] (II) event7 - Asus WMI hotkeys: is tagged by udev as: Keyboard
[ 28.608] (II) event7 - Asus WMI hotkeys: device is a keyboard
[ 28.609] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event3)
[ 28.609] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 28.609] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 28.609] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 28.609] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 28.609] (**) AT Translated Set 2 keyboard: always reports core events
[ 28.610] (**) Option "Device" "/dev/input/event3"
[ 28.610] (**) Option "_source" "server/udev"
[ 28.612] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 28.612] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 28.614] (II) event3 - AT Translated Set 2 keyboard: device removed
[ 28.645] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input3/event3"
[ 28.645] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 15)
[ 28.645] (**) Option "xkb_layout" "us"
[ 28.645] (**) Option "xkb_variant" "dvorak"
[ 28.648] (II) event3 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 28.649] (II) event3 - AT Translated Set 2 keyboard: device is a keyboard
[ 28.652] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/event9)
[ 28.652] (**) ETPS/2 Elantech Touchpad: Applying InputClass "evdev touchpad catchall"
[ 28.652] (**) ETPS/2 Elantech Touchpad: Applying InputClass "libinput touchpad catchall"
[ 28.652] (**) ETPS/2 Elantech Touchpad: Applying InputClass "touchpad"
[ 28.652] (II) Using input driver 'libinput' for 'ETPS/2 Elantech Touchpad'
[ 28.652] (**) ETPS/2 Elantech Touchpad: always reports core events
[ 28.652] (**) Option "Device" "/dev/input/event9"
[ 28.652] (**) Option "_source" "server/udev"
[ 28.654] (II) event9 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 28.658] (II) event9 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 28.658] (II) event9 - ETPS/2 Elantech Touchpad: device removed
[ 28.699] (**) Option "Tapping" "on"
[ 28.699] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio4/input/input22/event9"
[ 28.699] (II) XINPUT: Adding extended input device "ETPS/2 Elantech Touchpad" (type: TOUCHPAD, id 16)
[ 28.702] (**) Option "AccelerationScheme" "none"
[ 28.702] (**) ETPS/2 Elantech Touchpad: (accel) selected scheme none/0
[ 28.702] (**) ETPS/2 Elantech Touchpad: (accel) acceleration factor: 2.000
[ 28.702] (**) ETPS/2 Elantech Touchpad: (accel) acceleration threshold: 4
[ 28.704] (II) event9 - ETPS/2 Elantech Touchpad: is tagged by udev as: Touchpad
[ 28.708] (II) event9 - ETPS/2 Elantech Touchpad: device is a touchpad
[ 28.709] (II) config/udev: Adding input device ETPS/2 Elantech Touchpad (/dev/input/mouse1)
[ 28.709] (**) ETPS/2 Elantech Touchpad: Applying InputClass "touchpad"
[ 28.709] (II) Using input driver 'libinput' for 'ETPS/2 Elantech Touchpad'
[ 28.709] (**) ETPS/2 Elantech Touchpad: always reports core events
[ 28.709] (**) Option "Device" "/dev/input/mouse1"
[ 28.710] (**) Option "_source" "server/udev"
[ 28.752] (II) mouse1 - not using input device '/dev/input/mouse1'.
[ 28.752] (EE) libinput: ETPS/2 Elantech Touchpad: Failed to create a device for /dev/input/mouse1
[ 28.752] (EE) PreInit returned 2 for "ETPS/2 Elantech Touchpad"
[ 28.752] (II) UnloadModule: "libinput"
[ 28.753] (II) config/udev: Adding input device PC Speaker (/dev/input/event8)
[ 28.753] (II) No input driver specified, ignoring this device.
[ 28.753] (II) This device may have been added with another device file.
[ 29.510] (**) Logitech B330/M330/M331: Applying InputClass "evdev pointer catchall"
[ 29.510] (**) Logitech B330/M330/M331: Applying InputClass "evdev keyboard catchall"
[ 29.510] (**) Logitech B330/M330/M331: Applying InputClass "libinput pointer catchall"
[ 29.510] (**) Logitech B330/M330/M331: Applying InputClass "libinput keyboard catchall"
[ 29.510] (**) Logitech B330/M330/M331: Applying InputClass "system-keyboard"
[ 29.510] (II) Using input driver 'libinput' for 'Logitech B330/M330/M331'
[ 29.510] (**) Logitech B330/M330/M331: always reports core events
[ 29.510] (**) Option "Device" "/dev/input/event4"
[ 29.510] (**) Option "_source" "_driver/libinput"
[ 29.510] (II) libinput: Logitech B330/M330/M331: is a virtual subdevice
[ 29.510] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2.1/1-2.1:1.1/0003:046D:C52F.0002/0003:046D:4057.0003/input/input17/event4"
[ 29.510] (II) XINPUT: Adding extended input device "Logitech B330/M330/M331" (type: KEYBOARD, id 17)
[ 29.510] (**) Option "xkb_layout" "us"
[ 29.511] (**) Option "xkb_variant" "dvorak"
[ 85.817] (II) modeset(0): EDID vendor "CMN", prod id 4961
[ 85.817] (II) modeset(0): Printing DDC gathered Modelines:
[ 85.817] (II) modeset(0): Modeline "1920x1080"x0.0 138.78 1920 1966 1996 2080 1080 1082 1086 1112 -hsync -vsync (66.7 kHz eP)
[ 85.817] (II) modeset(0): Modeline "1920x1080"x0.0 92.52 1920 1966 1996 2080 1080 1082 1086 1112 -hsync -vsync (44.5 kHz e)
[ 92.680] (II) modeset(0): EDID vendor "CMN", prod id 4961
[ 92.680] (II) modeset(0): Printing DDC gathered Modelines:
[ 92.681] (II) modeset(0): Modeline "1920x1080"x0.0 138.78 1920 1966 1996 2080 1080 1082 1086 1112 -hsync -vsync (66.7 kHz eP)
[ 92.681] (II) modeset(0): Modeline "1920x1080"x0.0 92.52 1920 1966 1996 2080 1080 1082 1086 1112 -hsync -vsync (44.5 kHz e)
[ 125.347] (EE) event9 - ETPS/2 Elantech Touchpad: kernel bug: Touch jump detected and discarded.
See https://wayland.freedesktop.org/libinput/doc/1.16.4/touchpad-jumping-cursors.html for details
[ 283.050] (EE) event9 - ETPS/2 Elantech Touchpad: client bug: event processing lagging behind by 15ms, your system is too slow
