this is similar to another topic I did, but the solution is not the same. I try to boot into my system but it doesn’t. I guess the problem is with nvidia drivers. I’m using a tty terminal.
Here is some information:
Yeah, I tried, but there’s a conflict between drivers and when I try to delete them I get an error that says that the driver I’m trying to uninstall is not installed.
I tried doing:
sudo mhwd -a pci nonfree 0300
And it says that I have the drivers successfully installed, and when I do:
mhwd -li
It says that I have nvidia-linux installed.
I will try to do what you’re saying as soon as I get home.
Thanks!
