Can't boot and can't use console
After a game i had a crash and after that i could not boot into system, i cant use console to debug or post fazzy, is there a way to restore grub so can restore timeshift backup?
Boot up from a live USB and run a full fsck on your root filesystem while it is unmounted.
Note: If your root filesystem is btrfs, you will need to use “btrfs check” instead.
Is it safe to do --repair flag here?
Edit: i cant get image upload to work, output is:
ubuntu@ubuntu:~$ sudo unmount /dev/sda1
sudo: unmount: command not found
ubuntu@ubuntu:~$ sudo umount /dev/sda1
umount: /dev/sda1: not mounted.
ubuntu@ubuntu:~$ sudo btrfs check /dev/sda1
Opening filesystem to check...
parent transid verify failed on 3065413632 wanted 1227286 found 1226794
Ignoring transid failure
parent transid verify failed on 3065462784 wanted 1227286 found 1226794
parent transid verify failed on 3063955456 wanted 1227286 found 1226796
parent transid verify failed on 3063988224 wanted 1227286 found 1226796
parent transid verify failed on 3064037376 wanted 1227286 found 1226796
ERROR: child eb corrupted: parent bytenr=3072589824 item=25 parent level=1 child bytenr=3064037376 child level=1
ERROR: failed to read block groups: Input/output error
ERROR: cannot open file system
ubuntu@ubuntu:~$
Mod edit: Fixed formatting; removed blockquotes and added ``` above and below the pasted Terminal output.
Yes, I would try that. From the looks of it, you don’t have anything left to lose. :face_with_diagonal_mouth:
What do you mean, is the disk totaly bricked? I cant cd into it and move stuff?
Edit: what caused this?
Not the disk, but the filesystem.
Not when it’s in this state, no.
:backhand_index_pointing_down:
You probably pushed the reset/power button. Your system was not properly shut down, and now the filesystem is damaged.
