Hi,
I made some update and now I can’t boot into my system
When I turn on my pc it goes => the logo of my hardware then luks asking for passphrase to uncrypt my disks and if the password is right it tell me :
Warning: /lib/modules/5.10.2-2-manjaro/modules.devname not found - ignoring
Cannot initialize device-mapper. Is dm_mod kernel module loaded ?
Cannot use device luks-5ff..., name is invalid or still in use.
A password is required to access the luks-5ff... volume :
Enter passphrase for dev/sda1
And when I enter the passphrase, it respond :
I tried to look up for a solution but I can’t even enter some command
I tried to change to TTY with ctrl+alt+Fx but none of them worked …
So I boot into my USB key with manjaro
When I’m on the desktop I do all the things you said starting with sudo su, mount the disks and then install grub
And after a reboot, I would be able to boot like always with all my data
That’s it ?
Sorry if it seems redundent I just want to be sure to not reinstall manjaro and delete my data !
OK so I did everything but the PacMan -syyu didn’t work (failed to synchronize all databases) even if I connected to the Internet and the mkinitcpio -p did his thing but when it try to build the 5.10.2-2 and the previous one it said “module not found”
When I boot again it didn’t change, I got the same error
