I use a program called lightBurn. but nautilus is not able to match the program with its .lbrn file
I have used several alternatives from the basic “right click - open with another application - see all applications. (I can’t find the program listed)” to others a little more elaborate
lightBurn is a program that claims to be cross-platform and I find it strange that it can’t be recognized by nautilus, double-click and voila, open the file with the correct program. I did a test recently with your version of kde and if it worked, delpin recognized it.
opening with doubleclick is simple. but it’s not gnome and I just want it to work fine on my favorite desktop.
I just installed Manjaro for the 1st time and used your tip to install Lightburn. The installation worked fine, but the program doesn’t start although it shows up in my app list.
I can’t post a question yet, since I just signed up 10 minutes ago so I’m asking in a reply. Any idea what’s up?
Thanks for the help, but I can’t figure out how to run it. I’ve moved to the proper directory, /usr/bin and found the executable, I’ve searched lists of essential commands, but still don’t know how. Could you tell me please?
it doesn’t even work on Arch (anymore) at the moment.
You may be better off using the .run file that is available from the website.
like @carlos-prz suggested
It comes with the correct library versions - which the AUR package does not use.
It uses the system libraries - the version of which does not match and thus the thing does not work.
it is much more likely that the command to run this LightBurn.run file
in/from inside your $HOME directory
is something like this:
sh -x ~/Downloads/LightBurn-Linux64-v1.3.01.run
sudo isn’t a magic wand - it just lets you change the context, to run commands as the super user
which is not required in that case - and also: no actual command was given
just “sudo” by itself will not magically start to execute the .run file
to make life easier, set the .run file to “executable”
then you can start it by simply calling it like this: ~/Downloads/LightBurn-Linux64-v1.3.01.run
sh -x is what runs it as an executable - even if it isn’t set as executable
