Can't adjust volume and keyboard volume control after updating
audio gone halp
Kernel: 5.11.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
           Desktop: KDE Plasma 5.21.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
           dm: LightDM 1.30.0, SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: LENOVO product: 2441A75 v: ThinkPad W530
           Mobo: LENOVO model: 2441A75 serial: <superuser required> UEFI: LENOVO
           v: G5ETB0WW (2.70 ) date: 03/08/2018
Battery:   ID-1: BAT0 charge: 38.8 Wh condition: 39.3/86.6 Wh (45%) volts: 12.6/11.1
           model: LGC 45N1011 type: Li-ion serial: 33762 status: Charging
CPU:       Info: Quad Core model: Intel Core i7-3720QM bits: 64 type: MT MCP
           arch: Ivy Bridge rev: 9 L2 cache: 6 MiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 41524
           Speed: 1489 MHz min/max: 1200/3600 MHz Core speeds (MHz): 1: 1489 2: 1464 3: 1367
           4: 3496 5: 1318 6: 3336 7: 3491 8: 1906
Graphics:  Device-1: Intel 3rd Gen Core processor Graphics vendor: Lenovo driver: i915
           v: kernel bus ID: 00:02.0 chip ID: 8086:0166 class ID: 0300
           Device-2: NVIDIA GK107GLM [Quadro K1000M] vendor: Lenovo driver: nvidia
           v: 390.141 bus ID: 01:00.0 chip ID: 10de:0ffc class ID: 0300
           Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
           loaded: modesetting unloaded: amdgpu,nvidia resolution: 1920x1080~60Hz s-dpi: 96
           OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 20.3.4
           compat-v: 3.0 direct render: Yes
Audio:     Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Lenovo
           driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:1e20 class ID: 0403
           Device-2: NVIDIA GK107 HDMI Audio vendor: Lenovo driver: snd_hda_intel v: kernel
           bus ID: 01:00.1 chip ID: 10de:0e1b class ID: 0403
           Sound Server: ALSA v: k5.11.2-1-MANJARO
Network:   Device-1: Intel 82579LM Gigabit Network vendor: Lenovo driver: e1000e v: kernel
           port: 7080 bus ID: 00:19.0 chip ID: 8086:1502 class ID: 0200
           IF: enp0s25 state: down mac: 3c:97:0e:69:b7:24
           Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi v: kernel
           port: 6000 bus ID: 03:00.0 chip ID: 8086:0085 class ID: 0280
           IF: wlp3s0 state: up mac: 84:3a:4b:32:28:e2
Bluetooth: Device-1: Broadcom BCM20702 Bluetooth 4.0 [ThinkPad] type: USB driver: btusb
           v: 0.8 bus ID: 1-1.4:4 chip ID: 0a5c:21e6 class ID: fe01 serial: 74E543C5043C
           Report: ID: hci0 state: up running pscan iscan bt-v: 2.1 lmp-v: 4.0 sub-v: 220e
           hci-v: 4.0 rev: 1000 address: 74:E5:43:C5:04:3C
Drives:    Local Storage: total: 2.17 TiB used: 1.66 TiB (76.6%)
           ID-1: /dev/mmcblk0 model: UD128 size: 119.28 GiB rotation: SSD serial: 0xbafb05ee
           scheme: MBR
           ID-2: /dev/sda vendor: Silicon Power model: SPCC Solid State Disk
           size: 238.47 GiB speed: 6.0 Gb/s rotation: SSD serial: AA000000000000000588
           rev: 2A0 scheme: GPT
           ID-3: /dev/sdb vendor: Western Digital model: WD20SPZX-22UA7T0 size: 1.82 TiB
           speed: 6.0 Gb/s rotation: 5400 rpm serial: WD-WXD1E3916HVY rev: 1A01 scheme: GPT
Partition: ID-1: / size: 95.97 GiB used: 36.03 GiB (37.5%) fs: ext4 dev: /dev/sda9
           ID-2: /home size: 30.67 GiB used: 10.7 GiB (34.9%) fs: ext4 dev: /dev/sda8
Swap:      ID-1: swap-1 type: partition size: 2 GiB used: 0 KiB (0.0%) priority: -2
           dev: /dev/sda7
Sensors:   System Temperatures: cpu: 51.0 C mobo: 0.0 C
           Fan Speeds (RPM): cpu: 2705
Info:      Processes: 258 Uptime: 13m wakeups: 1 Memory: 15.46 GiB used: 3.95 GiB (25.5%)
           Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages: pacman: 1999 Shell: Bash
           v: 5.1.0 running in: konsole inxi: 3.3.01 Kernel: 5.11.2-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
           scheme: MBR
           dev: /dev/sda7
