Hi,
I installed, the AUR package, which showed no error. The printer gets shown in the devices list when I click add printer in the settings menu. If I try to add the printer, I get the error message
Failed to add the printer
How can I debug it?
Hi,
How can I debug it?
Did you try in your browser:
localhost:631
then Administration-Add Printer or Manage printer?
Also be sure that CUPS is installed and running.
in terminal: systemctl -a | grep cups
This manual intervention was required quite awhile ago:
sudo systemctl disable --now org.cups.cupsd.socket
sudo systemctl disable --now org.cups.cupsd.service
sudo systemctl disable --now org.cups.cupsd.path
sudo systemctl enable --now cups.service
sudo systemctl enable --now cups.socket
sudo systemctl enable --now cups.path
I overlooked the top navigation bar (and wondered how to use that page ).
Using the CUPS web interface worked.
cups.service|path|socket were all loaded and enabled. The disable and enable intervention didn’t do anything. I don’t know what the problem with the graphical UI is.
Anyway. It works now. Thanks!
