I have a Canon R10 camera that I could connect to my Manjaro system via USB and have its SD card show up as a removable drive. That’s not the case anymore. Plugging the camera in has no visible effect on my system nor on the camera itself.
I don’t remember when was the last time I was able to access the camera’s memory card this way but it was several months ago.
Plugging the same camera using the same USB cable on a Windows machine does work and the SD card is visible as an external storage device. Also the USB ports on the Manjaro machine work just fine when plugging in other devices
I have libgphoto-2 installed and running gphoto2 --auto-detectreturns:
Model Port
Canon EOS R10 usb:001,017
Return of inxi --full --admin --filter --width with the camera plugged in:
Kernel: 6.6.99-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
root=UUID=d97bae32-f42e-4c00-aace-99c27729fea7 rw quiet apparmor=1
security=apparmor resume=UUID=8d9f0b08-f95a-4dae-8463-e90447e43f5e
udev.log_priority=3
Desktop: Cinnamon v: 6.4.10 tk: GTK v: 3.24.49 wm: Muffin v: 6.4.1 tools:
avail: cinnamon-screensaver vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: LENOVO product: 20NB001SUS v: ThinkPad E590
Mobo: LENOVO model: 20NB001SUS v: SDK0J40697 WIN
serial: <superuser required> part-nu: LENOVO_MT_20NB_BU_SMB_FM_ThinkPad E590
uuid: <superuser required> UEFI: LENOVO v: R0YET49W (1.32 )
date: 03/14/2022
ID-1: BAT0 charge: 32.6 Wh (100.0%) condition: 32.6/45.7 Wh (71.3%)
volts: 12.3 min: 11.1 model: Celxpert 01AV448 type: Li-poly serial: <filter>
status: full cycles: 1433
Device-1: hidpp_battery_0 model: Logitech M720 Triathlon Multi-Device Mouse
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Info: model: Intel Core i7-8565U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check gen: core 8 level: v3 note: check
built: 2018 process: Intel 14nm family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0x100
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 800 min/max: 400/4600 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 bogomips: 32012
Type: indirect_target_selection mitigation: Aligned branch/return thunks
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
ports: active: HDMI-A-1,eDP-1 empty: DP-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3ea0 class-ID: 0300
Device-2: Canon Canon Digital Camera driver: N/A type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:17 chip-ID: 04a9:32f8
class-ID: 0601 serial: <filter>
Device-3: Bison SunplusIT Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:3 chip-ID: 5986:2113
class-ID: 0e02
Display: x11 server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
Screen-1: 0 s-res: 4480x1440 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary,top-left
model: ViewSonic VX2478 Series serial: <filter> built: 2019 res:
mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 124 gamma: 1.2
size: 526x296mm (20.71x11.65") diag: 604mm (23.8") ratio: 16:9 modes:
max: 2560x1440 min: 720x400
Monitor-2: eDP-1 pos: bottom-r model: Lenovo 0x40ba built: 2018 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2
size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
modes: 1920x1080
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
device-ID: 8086:3ea0 memory: 30.34 GiB unified: yes
Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:9dc8 class-ID: 0403
API: ALSA v: k6.6.99-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 1.4.6 status: active with: 1: pipewire-pulse
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Device-2: Intel Wi-Fi 5 Wireless-AC 9x6x [Thunder Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 05:00.0
chip-ID: 8086:2526 class-ID: 0280
IF: wlp5s0 state: up mac: <filter>
IF-ID-1: br-0c3f1127ec33 state: down mac: <filter>
IF-ID-2: br-7e9c3d76afc0 state: down mac: <filter>
IF-ID-3: br-8921cd838264 state: down mac: <filter>
IF-ID-4: br-93a16cba89ae state: down mac: <filter>
IF-ID-5: br-94e9640b65cb state: down mac: <filter>
IF-ID-6: br-dce6322ced5d state: down mac: <filter>
IF-ID-7: br-ebd36a73a43c state: down mac: <filter>
IF-ID-8: br-f623d385bd86 state: down mac: <filter>
IF-ID-9: docker0 state: down mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:2
chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 476.94 GiB used: 207.6 GiB (43.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 tech: SSD serial: <filter> fw-rev: 0108ADLA temp: 34.9 C
scheme: GPT
ID-1: / raw-size: 442.46 GiB size: 434.45 GiB (98.19%)
used: 207.6 GiB (47.8%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
used: 320 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 34.18 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 53.0 C pch: 41.0 C mobo: N/A
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Memory: total: 32 GiB available: 31.07 GiB used: 14.21 GiB (45.7%)
Processes: 343 Power: uptime: 5h 20m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.42 GiB services: csd-power,upowerd
Packages: 1613 pm: pacman pkgs: 1592 libs: 476 tools: pamac,yay pm: flatpak
pkgs: 21 Compilers: gcc: 15.1.1 Shell: Bash v: 5.3.0
running-in: gnome-terminal inxi: 3.3.38
