Greetings and happy new year!
update: I finally reinstalled Manjaro. The problem is solved. I still have no idea why this happened. The initial question follows:
I come here as a last chance, after multiple tentative to find a solution for a problem that appeared suddenly (maybe after an update) and that is very annoying for the french-typing person and terminal lover I am!
I use Manjaro, with i3, but the problem is also present with plasma and seems non-correlated with the environment.
For this message, I will call the ^
-key, the key to the right of the p on a French AZERTY keyboard, which has a ^
and ¨
and can be used to write ^
or ¨
Since a few days, I cannot add ^
or ¨
accents to letters on my terminal (for example, with konsole or alacritty) such as
ê
with^
-key then e (same for o, u and any other letter)ë
with Shift+^ then e (same for o, u, and any other letter)
The problem is also present on terminal applications such as nvim.
Nevertheless, this works for non-terminal applications such as Firefox. This doesn’t seem to be a problem of keyboards, my /etc/
This doesn’t work even if I push space or right after it.
I tried with another terminals (kitty, alacrity) and the same problem appeared.
Nevertheless, the ^
-key works perfectly on non-terminal applications such as Firefox or discord.
Also, I can write the character ^
on the terminal using the combination AltGr+9.
Finally, note that if I use keyboard configurations that set the ^
-key as ^
, such as the “no dead key” variant, I am able to use the touch on my terminal to write ‘^’, but the shortcuts ^+e or ^+o doesn’t work…
Do you have any idea what could be happening?
Thank you so much for reading me!
Here is my keyboard configuration file /etc/default/keyboards
# KEYBOARD CONFIGURATION FILE
# Consult the keyboard(5) manual page.
XKBMODEL="pc105"
XKBLAYOUT="fr"
XKBVARIANT=""
XKBOPTIONS=""
BACKSPACE="guess"
Here is my locales /etc/default/locale :
LANG=en_US.UTF-8
LC_ADDRESS=fr_FR.UTF-8
LC_IDENTIFICATION=fr_FR.UTF-8
LC_MEASUREMENT=fr_FR.UTF-8
LC_MONETARY=fr_FR.UTF-8
LC_NAME=fr_FR.UTF-8
LC_NUMERIC=fr_FR.UTF-8
LC_PAPER=fr_FR.UTF-8
LC_TELEPHONE=fr_FR.UTF-8
LC_TIME=fr_FR.UTF-8
