Cannot wake up after suspend/hiberate
When my Lenovo Laptop upgrade from linux610 to linux-meta(linux615), the laptop cannot wake up when opening the laptop lid after entering suspend/hiberate status by closing the laptop lid. The screen will be totally black, no mouse pointer and no login dialog. Try to use linux612-LTS but got the same issue.
sudo inxi -Fazy
  Kernel: 6.15.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    clocksource: hpet avail: acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.15-x86_64
    root=UUID=adb6b68e-9f4c-4959-bd8a-b7564d79b8be rw quiet
  Desktop: Xfce v: 4.20.1 tk: Gtk v: 3.24.48 wm: xfwm4 v: 4.20.0
    with: xfce4-panel tools: light-locker dm: LightDM v: 1.32.0 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: LENOVO product: 82N6 v: Lenovo Legion R9000K2021H
    serial: <filter> Chassis: type: 10 v: Lenovo Legion R9000K2021H
    serial: <filter>
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76479 WIN serial: <filter>
    part-nu: LENOVO_MT_82N6_BU_idea_FM_Legion R9000K2021H
    uuid: 3822e454-83ce-11ec-80f1-88a4c298b865 UEFI: LENOVO v: GKCN60WW
    date: 03/07/2023
  ID-1: BAT0 charge: 55.6 Wh (74.0%) condition: 75.1/80.0 Wh (93.9%)
    power: 40.7 W volts: 16.8 min: 15.4 model: Sunwoda L20D4PC1 type: Li-poly
    serial: <filter> status: charging cycles: 304
  Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard
    status: discharging
  Info: model: AMD Ryzen 9 5900HX with Radeon Graphics socket: FP6 bits: 64
    type: MT MCP arch: Zen 3 gen: 3 level: v3 note: check built: 2021-22
    microcode: 0xA500011
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 2395 min/max: 423/4683 boost: enabled
    base/boost: 3300/4650 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.2 V ext-clock: 100 MHz cores: 1: 2395 2: 2395 3: 2395 4: 2395
    5: 2395 6: 2395 7: 2395 8: 2395 9: 2395 10: 2395 11: 2395 12: 2395 13: 2395
    14: 2395 15: 2395 16: 2395 bogomips: 105407
    affected
  Device-1: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
    vendor: Lenovo driver: nvidia v: 575.64
    alternate: nouveau,nova_core,nvidia_drm non-free: 550-570.xx+
    status: current (as of 2025-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s lanes: 8
    link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none empty: DP-1,
    DP-2, HDMI-A-1, eDP-2 bus-ID: 01:00.0 chip-ID: 10de:24dc class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
    Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
    code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
    lanes: 16 ports: active: eDP-1 empty: none bus-ID: 06:00.0
    chip-ID: 1002:1638 class-ID: 0300 temp: 46.0 C
  Device-3: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 174f:2435
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: xfwm4 v: 4.20.0 driver: X: loaded: amdgpu,nvidia
    unloaded: modesetting,nouveau,vesa alternate: fbdev,nv dri: radeonsi
    gpu: amdgpu display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 678x424mm (26.69x16.69")
    s-diag: 800mm (31.48")
  Monitor-1: eDP-1 mapped: eDP model-id: CSO 0x1609 built: 2021 res:
    mode: 2560x1600 hz: 165 scale: 100% (1) dpi: 188 gamma: 1.2
    size: 345x215mm (13.58x8.46") diag: 407mm (16") ratio: 16:10 modes:
    max: 2560x1600 min: 640x480
  API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
    drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
    surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.1.4-arch1.1
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir
    ACO DRM 3.63 6.15.3-1-MANJARO) device-ID: 1002:1638 memory: 3.91 GiB
    unified: no
  Info: Tools: api: clinfo, eglinfo, glxinfo de: xfce4-display-settings
    gpu: nvidia-settings, nvidia-smi, radeontop x11: xdriinfo, xdpyinfo, xprop,
    xrandr
  Device-1: NVIDIA GA104 High Definition Audio driver: snd_hda_intel v: kernel
    alternate: nova_core pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:228b class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
    lanes: 16 bus-ID: 06:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.15.3-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.5 status: n/a (root, process) tools: pw-cli
  Server-3: PulseAudio v: 17.0-43-g3e2bb status: active (root, process) with:
    tools: pacat,pactl,pavucontrol
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
    vendor: Lenovo driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    bus-ID: 04:00.0 chip-ID: 14c3:7961 class-ID: 0280
  IF: wlp4s0 state: down mac: <filter>
  Device-1: Foxconn / Hon Hai MediaTek Bluetooth Adapter driver: btusb v: 0.8
    type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:2
    chip-ID: 0489:e0cd class-ID: e001 serial: <filter>
  Report: btmgmt ID: hci0 rfk-id: 2 state: down bt-service: disabled
    rfk-block: hardware: no software: yes address: N/A
  Local Storage: total: 3.64 TiB used: 1.79 TiB (49.1%)
  ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Kingston model: SNV2S2000G
    lanes: 4 tech: SSD serial: <filter> fw-rev: SBM02103 temp: 39.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 226d 23h cycles: 2,345
    read-units: 1,167,334 [597 GB] written-units: 3,453,552 [1.76 TB]
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: SanDisk model: Ultra 3D NVMe
    size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 21705000 temp: 38.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 94d 7h cycles: 4,199
    read-units: 29,598,636 [15.1 TB] written-units: 31,526,209 [16.1 TB]
  ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.40%) used: 1.14 TiB (63.6%)
    fs: ext4 block-size: 4096 B dev: /dev/nvme1n1p2 maj-min: 259:2
    used: 46.5 MiB (15.5%) fs: vfat block-size: 512 B dev: /dev/nvme1n1p1
    maj-min: 259:1
  Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
  ID-1: swap-1 type: file size: 16 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  System Temperatures: cpu: 54.4 C mobo: 46.0 C gpu: amdgpu temp: 46.0 C
  Fan Speeds (rpm): N/A
  Memory: total: 60 GiB available: 58.71 GiB used: 5.33 GiB (9.1%)
  Processes: 377 Power: uptime: 6m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 23.45 GiB services: upowerd,xfce4-power-manager
  Packages: 3172 pm: pacman pkgs: 3167 libs: 580 tools: pamac,yay pm: flatpak
    pkgs: 0 pm: snap pkgs: 5 Compilers: clang: 20.1.6 gcc: 15.1.1 alt: 11/13/14
    Shell: Sudo (sudo) v: 1.9.17p1 default: Bash v: 5.2.37
    running-in: xfce4-terminal inxi: 3.3.38
sometimes it can wake up and work normally but sometimes it wakes up but mouse cursor and typing becomes very slow
HI @malone ,
I wonder whether you could read this post in order to solve your problem.
Hibernation failing (just booting without recovering previous state) - #9 by Nachordez
Regards,
