Cannot use Wayland with KDE on Nvidia?
Just installed Manjaro and when it launched it was running on Wayland, but when I installed latest proprietary Nvidia driver I wasn’t able to change resolution from 102x768 to any other. So on logon screen I switched to X11 which was working normally, but Wayland is not working anymore. Every time I select it I get black sreen right after logging in. I tried to follow “Plasma/Wayland/Nvidia” guide from KDE Wiki (I wanted to paste a link but I can’t do it here) and looks like everything in my system meets requirements from it, but Wayland still doesn’t work.
inxi -zv8:
  Kernel: 6.9.2-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=e047511d-02a4-4a33-94b0-ddcf26d7a611 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
  Type: Desktop System: Aquarius product: Aquarius Pro, Std, Elt Series v: N/A
    serial: <superuser required>
  Mobo: ASUSTeK model: B85M-E v: Rev X.0x serial: <superuser required>
    part-nu: All uuid: <superuser required> UEFI: American Megatrends v: 3602
    date: 04/04/2018
  System RAM: total: 16 GiB available: 15.52 GiB used: 2.34 GiB (15.1%)
  Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
  Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Kingston part-no: KHX1600C10D3/4G serial: <filter>
  Device-2: ChannelA-DIMM1 type: DDR3 detail: synchronous size: 4 GiB
    manufacturer: Kingston part-no: KHX1600C10D3/8G serial: <filter>
  Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
  Device-4: ChannelB-DIMM1 type: DDR3 detail: synchronous size: 4 GiB
  Info: model: Intel Xeon E3-1270 v3 bits: 64 type: MT MCP arch: Haswell
    level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
    model-id: 0x3C (60) stepping: 3 microcode: 0x28
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 1549 high: 3900 min/max: 800/3900 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 3492 2: 1000 3: 800
    4: 800 5: 800 6: 3900 7: 800 8: 800 bogomips: 55888
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    fsgsbase fxsr ht ibpb ibrs ida invpcid lahf_lm lm mca mce md_clear mmx
    monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
    pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
    rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: NVIDIA GM206 [GeForce GTX 960] vendor: Gigabyte driver: nvidia
    v: 550.78 alternate: nouveau,nvidia_drm non-free: 545.xx+ status: current
    (as of 2024-04; EOL~2026-12-xx) arch: Maxwell code: GMxxx
    process: TSMC 28nm built: 2014-2019 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: none off: HDMI-A-1 empty: DP-1,DVI-D-1,DVI-I-1
    bus-ID: 01:00.0 chip-ID: 10de:1401 class-ID: 0300
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1920x1080 s-dpi: 92 s-size: 530x301mm (20.87x11.85")
    s-diag: 610mm (24")
  Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 93
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.78
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 960/PCIe/SSE2
    memory: 3.91 GiB
  API: Vulkan v: 1.3.279 layers: 10 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GTX 960 driver: nvidia v: 550.78 device-ID: 10de:1401
    surfaces: xcb,xlib
  Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
    class-ID: 0403
  Device-2: NVIDIA GM206 High Definition Audio vendor: Gigabyte
    bus-ID: 01:00.1 chip-ID: 10de:0fba class-ID: 0403
  API: ALSA v: k6.9.2-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
    vendor: ASUSTeK P8 series driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IP v4: <filter> type: dynamic scope: global broadcast: <filter>
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 0bda:8771
  Local Storage: total: 1.26 TiB used: 226.93 GiB (17.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Apacer model: AS340 240GB
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 1A0 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WD10EALX-009BA0 size: 931.51 GiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 1H15
    scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 model: SSD 128GB size: 119.24 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: XKR scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: Move Speed model: SD size: 14.65 GiB
    block-size: physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s
    lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 5.00 scheme: MBR
  ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%)
    used: 47.37 GiB (40.7%) fs: ext4 dev: /dev/sdc2 maj-min: 8:34 label: N/A
    uuid: e047511d-02a4-4a33-94b0-ddcf26d7a611
    used: 296 KiB (0.1%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: N/A
    uuid: B928-8A85
  ID-3: /run/media/varg/8761c504-7871-46af-aaf3-d8bf21cd28bd
    raw-size: 931.51 GiB size: 931.51 GiB (100.00%) used: 179.56 GiB (19.3%)
    fs: btrfs dev: /dev/sdb1 maj-min: 8:17 label: N/A
    uuid: 8761c504-7871-46af-aaf3-d8bf21cd28bd
  ID-1: /dev/sda1 maj-min: 8:1 size: 100 MiB fs: vfat label: N/A
    uuid: 746B-42E5
  ID-2: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-3: /dev/sda3 maj-min: 8:3 size: 222.69 GiB fs: ntfs label: N/A
    uuid: 3692747492743B07
  ID-4: /dev/sda4 maj-min: 8:4 size: 780 MiB fs: ntfs label: N/A
    uuid: 361AE7A41AE75F7D
  ID-5: /dev/sdd1 maj-min: 8:49 size: 3.57 GiB fs: iso9660
  ID-6: /dev/sdd2 maj-min: 8:50 size: 4 MiB fs: vfat label: MISO_EFI
    uuid: 36BC-DF40
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-5:2 info: Logitech Corded Keyboard K280e type: keyboard,HID
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 046d:c328 class-ID: 0300
  Device-2: 3-6:3 info: A4Tech XL-730K / XL-747H XL-750BK XL-755BK Mice
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    chip-ID: 09da:9090 class-ID: 0301
  Device-3: 3-7:4 info: LogiLink UDisk flash drive type: mass storage
    driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 100mA chip-ID: abcd:1234 class-ID: 0806
    serial: <filter>
  Device-4: 3-10:5 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:8771 class-ID: e001 serial: <filter>
  Hub-6: 4-0:1 info: super-speed hub ports: 6 rev: 3.0
  System Temperatures: cpu: 47.0 C mobo: N/A gpu: nvidia temp: 39 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 41%
  Packages: pm: pacman pkgs: 1377 libs: 445 tools: pamac pm: flatpak pkgs: 0
    1: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    2: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    3: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 280
  1: cpu: 11.6% command: brave pid: 7672 mem: 216.3 MiB (1.3%)
  2: cpu: 9.3% command: brave pid: 7739 mem: 228.5 MiB (1.4%)
  3: cpu: 4.8% command: brave pid: 1240 mem: 449.2 MiB (2.8%)
  4: cpu: 3.2% command: brave pid: 1277 mem: 226.2 MiB (1.4%)
  5: cpu: 3.1% command: brave pid: 1840 mem: 229.2 MiB (1.4%)
  Memory top: 5 of 280
  1: mem: 449.2 MiB (2.8%) command: brave pid: 1240 cpu: 4.8%
  2: mem: 394.0 MiB (2.4%) command: plasmashell pid: 827 cpu: 1.0%
  3: mem: 229.2 MiB (1.4%) command: brave pid: 1840 cpu: 3.1%
  4: mem: 228.5 MiB (1.4%) command: brave pid: 7739 cpu: 9.3%
  5: mem: 226.2 MiB (1.4%) command: brave pid: 1277 cpu: 3.2%
  Processes: 280 Power: uptime: 20m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: gcc: 14.1.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.34
I’d really like to use Wayland because in X11 every animation feels so laggy and this drives me crazy.
post the output of
echo $XDG_SESSION_TYPE && glxinfo | grep server
and btw. nvidia and wayland doesn’t work properly.
x11 server glx vendor string: NVIDIA Corporation server glx version string: 1.4 server glx extensions:
:point_up: i think this is a point you should focus. your governor drives the cores @800MHz, no wonder that it lags.
https://wiki.archlinux.org/title/Scaling_governor
which governor should I use? Performance, ondemand or conservative?
it’s an old lady, use ondemand and performance. also check how to edit the cpuconfig to edit the minimum frequency. but try ondemand and performance first and think about renewing the thermal paste of this cpu, while it’s known for heating and sweating and therefor throtteling.
Changed to perfomance, now all cores run 3900MHz. Looks like most of the animations became smooth, but minimizing and maximizing fullscreen windows still feels quite choppy. I changed thermal paste few months ago, so there must be no throttling for the time being
yes, several users reported this and i can agree, same here. it became a little bit smoother with an update some days ago but it seems to be plasma-related. nevertheless try if there are some newer updates avaiable.
sudo pacman -Syu
if you’ve installed something from aur run also
pamac update -a --force-refresh
Maybe this help:
Looks like this is actual fix for me! But i’m a bit concerned that in MODULES= i have no other nvidia modules like in example. Are they useful or I can skip them?
Also on wayland I can see some glitches in browser while typing this so now i’m asking myself: was it worth it? :upside_down_face:
Im fine with X11 on my nvidia PC. My AMD Laptop has terrible desktop performance with X11 under KDE.
Its up to you, if you want to use it.
Same for me and many other’s… you can also use LTS Kernel 6.6, where you probably can skip this. Your choice.
