Hello,
I’m struggling to make a massive update with pacman
and trying to solve the icu (75.1-1)
update.
I have tried to update the mirrors:
sudo pacman-mirrors --fasttrack && sudo pacman -Syu
I have deleted the orphan packages (I had issues with electron25 and electron22):
sudo pacman -Rs $(pacman -Qdtq)
I have manually installed libicuuc.so.75 downloading the tar, uncompressing it, moving it to /usr/bin
and creating a symbolic link like said on the r/archlinux Oromis-Elda’s post title “libicuuc.so.75 - icu package update issues” .
The latest thing I’m trying is updating overwriting icu files with:
sudo pacman -Syyuu -overwrite "*" icu
At that point I receive the output saying manjaro is trying to install icu (75.1-1) and breaks dependency:
core 121,0 KiB 417 KiB/s 00:00 [##################################] 100%
extra 7,9 MiB 28,2 MiB/s 00:00 [##################################] 100%
community 45,0 B 1125 B/s 00:00 [##################################] 100%
multilib 138,4 KiB 3,38 MiB/s 00:00 [##################################] 100%
:: Replace dbus-python with extra/python-dbus? [Y/n] Y
warning: nano-syntax-highlighting: downgrading from version 2020.10.10+10+g1aa64a8-2 to version 2020.10.10-1
warning: ranger: downgrading from version 1.9.3+719+g136416c7-1 to version 1.9.3-11
resolving dependencies...
:: installing pacman (6.1.0-3) breaks dependency 'libalpm.so=13-64' required by libpamac
:: installing icu (75.1-1) breaks dependency 'icu<75' required by manjaro-settings-manager
Any ideas on how to solve this?
Thank you!
