Hello everyone!
I run the command
$ sudo pacman -Syu
to update my pc and here is the result
core is up to date
extra is up to date
multilib is up to date
warning: julius: local (4.6-3) is newer than extra (1.7.0-2)
resolving dependencies...
:: installing icu (76.1-1) breaks dependency 'libicui18n.so=75-64' required by electron29
:: installing icu (76.1-1) breaks dependency 'libicuuc.so=75-64' required by electron29
:: installing flac (1.5.0-1) breaks dependency 'libFLAC.so=12-64' required by electron29
:: installing icu (76.1-1) breaks dependency 'libicui18n.so=75-64' required by electron30
:: installing icu (76.1-1) breaks dependency 'libicuuc.so=75-64' required by electron30
:: installing flac (1.5.0-1) breaks dependency 'libFLAC.so=12-64' required by electron30
Is there anything I can do? Or are there more information you need?
Thanks for the attention!
