I upgraded my system and after a reboot, bluetooth stopped working. Bluetooth is enabled, I’m just unable to turn it on.
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Wed 2023-02-01 09:49:09 IST; 59s ago
Docs: man:bluetoothd(8)
Main PID: 3069 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 28686)
Memory: 844.0K
CPU: 114ms
CGroup: /system.slice/bluetooth.service
└─3069 /usr/lib/bluetooth/bluetoothd
Feb 01 09:49:09 pragyan systemd[1]: Started Bluetooth service.
Feb 01 09:49:09 pragyan bluetoothd[3069]: Starting SDP server
Feb 01 09:49:09 pragyan bluetoothd[3069]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Feb 01 09:49:09 pragyan bluetoothd[3069]: src/plugin.c:plugin_init() Failed to init vcp plugin
Feb 01 09:49:09 pragyan bluetoothd[3069]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Feb 01 09:49:09 pragyan bluetoothd[3069]: src/plugin.c:plugin_init() Failed to init mcp plugin
Feb 01 09:49:09 pragyan bluetoothd[3069]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Feb 01 09:49:09 pragyan bluetoothd[3069]: src/plugin.c:plugin_init() Failed to init bap plugin
Feb 01 09:49:09 pragyan bluetoothd[3069]: Bluetooth management interface 1.21 initialized
I followed the instructions at https://wiki.archlinux.org/title/bluetooth but that didn’t resolve my issue. I’ve tried sudo rfkill unblock bluetooth && sudo systemctl restart bluetooth multiple times, but to no avail.
