I probably set that one manually at some point as I’m indeed in Belgium. I still fail to begin to understand why certain programs need to (temporarily?) change the locale as shown here from a human language to C to run. I’ve had this old workaround (not mine) line
Exec=$(export LC_ALL=C; mkvtoolnix-gui) %F`
in the aforementioned mkvtoolnix-gui.desktop
so that the program would launch. And so in this attempt to fix plasma, I renamed it to no avail. Hence the org.kde.plasma.kicker: Entry is not valid "applications:org.bunkus.mkvtoolnix-gui.desktop" 0x55bd8e8de5b0
red herring. Sorry I forgot about it.
But the locale thing, even if it may not be the reason for plasmashell failing, is concerning still as now I notice that the locale warning is more universal than previously thought
[manuel@manuel-desktop ~]$ kate
[manuel@manuel-desktop ~]$ kate --version
Detected locale "C" with character encoding "ANSI_X3.4-1968", which is not UTF-8.
Qt depends on a UTF-8 locale, and has switched to "C.UTF-8" instead.
If this causes problems, reconfigure your locale. See the locale(1) manual
for more information.
kate 24.08.3
[manuel@manuel-desktop ~]$ plasmashell --version
plasmashell 6.2.4
[manuel@manuel-desktop ~]$ man --version
man: can't set the locale; make sure $LC_* and $LANG are correct
man 2.13.0
noting that all these programs launch normally despite the warning, including plasmashell which launches, loads everything, then dies after those last lines ... Trace/breakpoint trap (core dumped)
are displayed.
At any rate, I will follow the mods’ advice, I had no idea rolling releases were supposed to be updated this often, I thought it was optional. I will do a fresh install and investigate these snapshot solutions and adapt to the new “lifestyle”. I’ve been lucky for years, even the year old update jump to plasma 6 had been smooth enough. I had even swapped this SDD from another machine to this laptop seamlessly, I guess a fresh install was way overdue.
Thank you all for your help and patience.
Edit: oh btw it’s not a “known issue” but the post before mine in “Ask for help with Manjaro KDE” had the same issue as I and he printed
Dec 03 09:41:43 systemd[3335]: Starting KDE Plasma Workspace...
Dec 03 09:41:43 systemd[3335]: Started KDE Plasma Workspace.
Dec 03 09:41:43 plasmashell[10778]: KPackageStructure of KPluginMetaData(pluginId:"com.samirgaire10.Google-Gemini", fileName: "/home/kris/.local/share/plasma/plasmoids/com.samirgaire10.Google-Gemini/metadata.json") does not match requested format "Plasma/Applet"
Dec 03 09:41:43 plasmashell[10778]: KPackageStructure of KPluginMetaData(pluginId:"org.kde.plasma.simplemenu", fileName: "/usr/share/plasma/plasmoids/org.kde.plasma.simplemenu/metadata.json") does not match requested format "Plasma/Applet"
Dec 03 09:41:43 plasmashell[10778]: KPackageStructure of KPluginMetaData(pluginId:"org.kde.merkuro.contact", fileName: "/usr/share/plasma/plasmoids/org.kde.merkuro.contact/metadata.json") does not match requested format "Plasma/Applet"
Dec 03 09:41:43 systemd[3335]: Starting Track hardware statistics...
Dec 03 09:41:43 ksystemstats[10806]: Loaded plugin "ksystemstats_plugin_cpu" from file "/usr/lib/qt6/plugins/ksystemstats/ksystemstats_plugin_cpu.so"
Dec 03 09:41:43 plasmashell[10778]: kf.plasma.quick: Applet preload policy set to 1
Dec 03 09:41:43 ksystemstats[10806]: Loaded plugin "ksystemstats_plugin_disk" from file "/usr/lib/qt6/plugins/ksystemstats/ksystemstats_plugin_disk.so"
Dec 03 09:41:43 plasmashell[10778]: qml: false
Dec 03 09:41:43 plasmashell[10778]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:201:9
Dec 03 09:41:43 plasmashell[10778]: Toolbox not loading, toolbox package is either invalid or disabled.
Dec 03 09:41:43 ksystemstats[10806]: Found unsupported GPU: /sys/devices/pci0000:00/0000:00:02.0/drm/card1
Dec 03 09:41:43 ksystemstats[10806]: Loaded plugin "ksystemstats_plugin_gpu" from file "/usr/lib/qt6/plugins/ksystemstats/ksystemstats_plugin_gpu.so"
Dec 03 09:41:43 ksystemstats[10806]: Loaded plugin "ksystemstats_plugin_lmsensors" from file "/usr/lib/qt6/plugins/ksystemstats/ksystemstats_plugin_lmsensors.so"
Dec 03 09:41:43 ksystemstats[10806]: Loaded plugin "ksystemstats_plugin_memory" from file "/usr/lib/qt6/plugins/ksystemstats/ksystemstats_plugin_memory.so"
Dec 03 09:41:43 NetworkManager[1416]: <info> [1733218903.9548] audit: op="statistics" interface="wlp0s20f3" ifindex=2 args="500" pid=10806 uid=1000 result="success"
Dec 03 09:41:43 NetworkManager[1416]: <info> [1733218903.9582] audit: op="statistics" interface="C8:2A:DD:B6:95:DA" args="500" pid=10806 uid=1000 result="success"
Dec 03 09:41:43 ksystemstats[10806]: Loaded plugin "ksystemstats_plugin_network" from file "/usr/lib/qt6/plugins/ksystemstats/ksystemstats_plugin_network.so"
Dec 03 09:41:43 ksystemstats[10806]: Loaded plugin "ksystemstats_plugin_osinfo" from file "/usr/lib/qt6/plugins/ksystemstats/ksystemstats_plugin_osinfo.so"
Dec 03 09:41:43 NetworkManager[1416]: <info> [1733218903.9614] audit: op="statistics" interface="0C:C4:13:1A:F0:68" args="500" pid=10806 uid=1000 result="success"
Dec 03 09:41:43 ksystemstats[10806]: Loaded plugin "ksystemstats_plugin_power" from file "/usr/lib/qt6/plugins/ksystemstats/ksystemstats_plugin_power.so"
Dec 03 09:41:43 ksystemstats[10806]: Loaded plugin "ksystemstats_plugin_pressure" from file "/usr/lib/qt6/plugins/ksystemstats/ksystemstats_plugin_pressure.so"
Dec 03 09:41:43 systemd[3335]: Started Track hardware statistics.
Dec 03 09:41:43 NetworkManager[1416]: <info> [1733218903.9647] audit: op="statistics" interface="enp60s0u2u4" ifindex=3 args="500" pid=10806 uid=1000 result="success"
Dec 03 09:41:43 NetworkManager[1416]: <info> [1733218903.9921] audit: op="statistics" interface="C8:2A:DD:B6:95:DA" args="500" pid=10806 uid=1000 result="success"
Dec 03 09:41:43 NetworkManager[1416]: <info> [1733218903.9954] audit: op="statistics" interface="enp60s0u2u4" ifindex=3 args="500" pid=10806 uid=1000 result="success"
Dec 03 09:41:43 NetworkManager[1416]: <info> [1733218903.9990] audit: op="statistics" interface="enp60s0u2u4" ifindex=3 args="500" pid=10806 uid=1000 result="success"
Dec 03 09:41:44 plasmashell[10778]: qml: false
Dec 03 09:41:44 plasmashell[10778]: file:///usr/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:178:25: QML FolderViewDropArea (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "minimumWidth":
Dec 03 09:41:44 plasmashell[10778]: Toolbox not loading, toolbox package is either invalid or disabled.
Dec 03 09:41:44 plasmashell[10778]: qrc:/qt/qml/org/kde/ksysguard/faces/ExtendedLegend.qml:58: TypeError: Cannot read property 'sensors' of null
Dec 03 09:41:44 appimagelauncherd[3353]: Directories to watch disappeared, unintegrating AppImages formerly found in there
Dec 03 09:41:45 plasmashell[10778]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/main.qml:50:9: QML KSortFilterProxyModel: Binding loop detected for property "sourceModel"
Dec 03 09:41:45 plasmashell[10778]: qt.dbus.integration: Could not connect "org.cups.cupsd.Notifier" to PrinterFinishingsChanged(QString, QString, QString, uint, QString, bool) :
Dec 03 09:41:45 plasmashell[10778]: qt.gui.imageio: libpng warning: iCCP: known incorrect sRGB profile
Dec 03 09:41:51 plasmashell[10778]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Dec 03 09:41:51 plasmashell[10778]: qt.gui.imageio: libpng warning: iCCP: known incorrect sRGB profile
Dec 03 09:41:51 plasmashell[10907]: LaunchProcess: failed to execvp:
Dec 03 09:41:51 plasmashell[10907]: /usr/lib/qt6/QtWebEngineProcess
Dec 03 09:41:51 kernel: audit: type=1400 audit(1733218911.700:203): apparmor="DENIED" operation="exec" class="file" info="no new privs" error=-1 profile="plasmashell" name="/usr/lib/qt6/QtWebEngineProcess" pid=10907 comm="plasmashell" requested_mask="x" denied_mask="x" fsuid=1000 ouid=0 target="unc>
Dec 03 09:41:51 plasmashell[10908]: LaunchProcess: failed to execvp:
Dec 03 09:41:51 plasmashell[10908]: /usr/lib/qt6/QtWebEngineProcess
Dec 03 09:41:51 kernel: audit: type=1400 audit(1733218911.707:204): apparmor="DENIED" operation="exec" class="file" info="no new privs" error=-1 profile="plasmashell" name="/usr/lib/qt6/QtWebEngineProcess" pid=10908 comm="plasmashell" requested_mask="x" denied_mask="x" fsuid=1000 ouid=0 target="unc>
Dec 03 09:41:51 plasmashell[10778]: [10778:10778:1203/094151.716232:FATAL:zygote_host_impl_linux.cc(201)] Check failed: . : No such file or directory (2)
Dec 03 09:41:51 kernel: traps: plasmashell[10778] trap int3 ip:7b1ecddba904 sp:7fff2536f4a0 error:0 in libQt6WebEngineCore.so.6.8.0[45ba904,7b1ec98b7000+958b000]
Dec 03 09:41:51 systemd-coredump[10909]: Process 10778 (plasmashell) of user 1000 terminated abnormally with signal 5/TRAP, processing...
Dec 03 09:41:51 systemd[1]: Started Process Core Dump (PID 10909/UID 0).
Dec 03 09:41:54 systemd-coredump[10910]: [🡕] Process 10778 (plasmashell) of user 1000 dumped core.
Stack trace of thread 10778:
#0 0x00007b1ecddba904 n/a (libQt6WebEngineCore.so.6 + 0x45ba904)
#1 0x00007b1ecddbb5b4 n/a (libQt6WebEngineCore.so.6 + 0x45bb5b4)
#2 0x00007b1ecddbcd06 n/a (libQt6WebEngineCore.so.6 + 0x45bcd06)
#3 0x00007b1ecddbce23 n/a (libQt6WebEngineCore.so.6 + 0x45bce23)
#4 0x00007b1ecddbf54a n/a (libQt6WebEngineCore.so.6 + 0x45bf54a)
#5 0x00007b1ecce89347 n/a (libQt6WebEngineCore.so.6 + 0x3689347)
#6 0x00007b1ecd655f0a n/a (libQt6WebEngineCore.so.6 + 0x3e55f0a)
#7 0x00007b1ecc2ad97a n/a (libQt6WebEngineCore.so.6 + 0x2aad97a)
#8 0x00007b1ecc2556e5 n/a (libQt6WebEngineCore.so.6 + 0x2a556e5)
#9 0x00007b1ecd6586d8 n/a (libQt6WebEngineCore.so.6 + 0x3e586d8)
#10 0x00007b1ec9a39c58 n/a (libQt6WebEngineCore.so.6 + 0x239c58)
#11 0x00007b1ec9a3ba44 n/a (libQt6WebEngineCore.so.6 + 0x23ba44)
#12 0x00007b1f4aa0ada4 _ZN26QQuickWebEngineViewPrivateC1Ev (libQt6WebEngineQuick.so.6 + 0x46da4)
#13 0x00007b1f4aa0ebf0 _ZN19QQuickWebEngineViewC1EP10QQuickItem (libQt6WebEngineQuick.so.6 + 0x4abf0)
#14 0x00007b1f4aa35ca7 n/a (libQt6WebEngineQuick.so.6 + 0x71ca7)
#15 0x00007b1fd414ab24 _ZNK8QQmlType6createEPPvm (libQt6Qml.so.6 + 0x34ab24)
#16 0x00007b1fd414abd4 _ZNK8QQmlType18createWithQQmlDataEv (libQt6Qml.so.6 + 0x34abd4)
#17 0x00007b1fd410a54f _ZN17QQmlObjectCreator14createInstanceEiP7QObjectb (libQt6Qml.so.6 + 0x30a54f)
#18 0x00007b1fd410b855 _ZN17QQmlObjectCreator18setPropertyBindingEPK16QQmlPropertyDataPKN3QV412CompiledData7BindingE (libQt6Qml.so.6 + 0x30b855)
#19 0x00007b1fd410e4ae _ZN17QQmlObjectCreator13setupBindingsE6QFlagsINS_11BindingModeEE (libQt6Qml.so.6 + 0x30e4ae)
#20 0x00007b1fd411549f _ZN17QQmlObjectCreator16populateInstanceEiP7QObjectS1_PK16QQmlPropertyDataPKN3QV412CompiledData7BindingE (libQt6Qml.so.6 + 0x31549f)
#21 0x00007b1fd410a08c _ZN17QQmlObjectCreator14createInstanceEiP7QObjectb (libQt6Qml.so.6 + 0x30a08c)
#22 0x00007b1fd410b855 _ZN17QQmlObjectCreator18setPropertyBindingEPK16QQmlPropertyDataPKN3QV412CompiledData7BindingE (libQt6Qml.so.6 + 0x30b855)
#23 0x00007b1fd410e4ae _ZN17QQmlObjectCreator13setupBindingsE6QFlagsINS_11BindingModeEE (libQt6Qml.so.6 + 0x30e4ae)
#24 0x00007b1fd411549f _ZN17QQmlObjectCreator16populateInstanceEiP7QObjectS1_PK16QQmlPropertyDataPKN3QV412CompiledData7BindingE (libQt6Qml.so.6 + 0x31549f)
#25 0x00007b1fd410a08c _ZN17QQmlObjectCreator14createInstanceEiP7QObjectb (libQt6Qml.so.6 + 0x30a08c)
#26 0x00007b1fd4117e74 n/a (libQt6Qml.so.6 + 0x317e74)
#27 0x00007b1fd409c737 _ZN20QQmlComponentPrivate11beginCreateE14QQmlRefPointerI15QQmlContextDataE (libQt6Qml.so.6 + 0x29c737)
#28 0x00007b1fd409ccae _ZN13QQmlComponent11beginCreateEP11QQmlContext (libQt6Qml.so.6 + 0x29ccae)
#29 0x00007b1fd5831876 _ZN11PlasmaQuick15SharedQmlEngine25createObjectFromComponentEP13QQmlComponentP11QQmlContextRK5QHashI7QString8QVariantE (libPlasmaQuick.so.6 + 0x4c876)
#30 0x00007b1fd580f3ef n/a (libPlasmaQuick.so.6 + 0x2a3ef)
#31 0x00007b1fd580f4d1 n/a (libPlasmaQuick.so.6 + 0x2a4d1)
#32 0x00007b1fd2da348a _ZN7QObject5eventEP6QEvent (libQt6Core.so.6 + 0x1a348a)
#33 0x00007b1fd4efe31a _ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent (libQt6Widgets.so.6 + 0xfe31a)
#34 0x00007b1fd2d585a8 _ZN16QCoreApplication15notifyInternal2EP7QObjectP6QEvent (libQt6Core.so.6 + 0x1585a8)
#35 0x00007b1fd2d59035 _ZN23QCoreApplicationPrivate16sendPostedEventsEP7QObjectiP11QThreadData (libQt6Core.so.6 + 0x159035)
#36 0x00007b1fd2fc23fc n/a (libQt6Core.so.6 + 0x3c23fc)
#37 0x00007b1fd18b2559 n/a (libglib-2.0.so.0 + 0x5d559)
#38 0x00007b1fd1915157 n/a (libglib-2.0.so.0 + 0xc0157)
#39 0x00007b1fd18b1a55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)
#40 0x00007b1fd2fbf71d _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3bf71d)
#41 0x00007b1fd2d64566 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x164566)
#42 0x00007b1fd2d59a2f _ZN16QCoreApplication4execEv (libQt6Core.so.6 + 0x159a2f)
#43 0x00005b7396b2b17f n/a (plasmashell + 0x2817f)
#44 0x00007b1fd2634e08 n/a (libc.so.6 + 0x25e08)
#45 0x00007b1fd2634ecc __libc_start_main (libc.so.6 + 0x25ecc)
#46 0x00005b7396b2b695 n/a (plasmashell + 0x28695)
Stack trace of thread 10794:
#0 0x00007b1fd271abb0 ppoll (libc.so.6 + 0x10bbb0)
#1 0x00007b1fd1915227 n/a (libglib-2.0.so.0 + 0xc0227)
#2 0x00007b1fd18b1a55 g_main_context_iteration (libglib-2.0.so.0 + 0x5ca55)
#3 0x00007b1fd2fbf71d _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt6Core.so.6 + 0x3bf71d)
#4 0x00007b1fd2d64566 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt6Core.so.6 + 0x164566)
#5 0x00007b1fd2e571d2 _ZN7QThread3runEv (libQt6Core.so.6 + 0x2571d2)
#6 0x00007b1fd2ed840f n/a (libQt6Core.so.6 + 0x2d840f)
#7 0x00007b1fd26a339d n/a (libc.so.6 + 0x9439d)
#8 0x00007b1fd272849c n/a (libc.so.6 + 0x11949c)
Dec 03 09:41:54 systemd[1]: systemd-coredump@2-10909-0.service: Deactivated successfully.
Dec 03 09:41:54 systemd[1]: systemd-coredump@2-10909-0.service: Consumed 2.319s CPU time, 1.1G memory peak.
Dec 03 09:41:54 systemd[3335]: plasma-plasmashell.service: Main process exited, code=dumped, status=5/TRAP
Dec 03 09:41:54 systemd[3335]: plasma-plasmashell.service: Failed with result 'core-dump'.
Dec 03 09:41:54 systemd[3335]: plasma-plasmashell.service: Consumed 5.254s CPU time, 911.7M memory peak.
Dec 03 09:41:54 systemd[3335]: plasma-plasmashell.service: Scheduled restart job, restart counter is at 3.
Dec 03 09:41:54 systemd[3335]: plasma-plasmashell.service: Start request repeated too quickly.
Dec 03 09:41:54 systemd[3335]: Failed to start KDE Plasma Workspace.
Dec 03 09:41:55 systemd[1]: systemd-localed.service: Deactivated successfully.
Dec 03 09:42:06 systemd[3335]: Starting KRunner...
Dec 03 09:42:06 systemd[3335]: Started KRunner.
and there’s not much in there about locales, so I assume that it was indeed a red herring. His solution was removing Apparmor but I don’t have it installed.
Edit 2: I repaired the plasmashell by removing /home/manuel/.local/share/plasma
. It now launches to this output
kf.plasma.core: Applet invalid: Cannot find a package for "com.samirgaire10.Deepl-plasma6"
kf.plasma.quick: File name empty!
kf.plasma.quick: error when loading applet "com.samirgaire10.Deepl-plasma6" QList("Error loading Applet: package com.samirgaire10.Deepl-plasma6 does not exist.")
error getting max keyboard brightness via dbus QDBusError("org.freedesktop.DBus.Error.UnknownObject", "No such object path '/org/kde/Solid/PowerManagement/Actions/KeyboardBrightnessControl'")
kameleon supported false
kameleon enabled true
file:///usr/share/plasma/plasmoids/org.kde.plasma.brightness/contents/ui/PopupDialog.qml:93: TypeError: Value is null and could not be converted to an object
I have no idea what any of this means but yes I guess my plasma config was too old then. Hopefully someone in KDE can spot the problem with these outputs. I’ll go the fresh install route regardless. Thanks again.
Edit 3: I narrowed it down to /home/manuel/.local/share/plasma/plasmoids/com.samirgaire10.Deepl-plasma6
. Is that precise enough to mark this as solved?
