Cannot start Plasma (KDE-Dev, Unstable)
For a couple of weeks on KDE-Dev (Unstable).
  • I enter my password in SDDM
  • I see the spinner
  • A dialog box appears saying kded5 needs my KDE Wallet Password
  • I enter it and eventually I see my cursor, but the spinner stops.
  • I can ctrl alt f4 and login to a tty and sudo pacman -Syyu so I know my wireless got activated
When I
$ plasmashell
qt.qpa.xcb: could not connect to display
qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: wayland-org.kde.kwin.qpa, eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
  Kernel: 5.9.14-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
  root=UUID=5d6d64f6-19a9-4612-a6bb-4a61c7d62775 rw udev.log_priority=3
  Console: tty 4 DM: SDDM Distro: Manjaro Linux
  Type: Laptop System: Hewlett-Packard product: HP EliteBook 8440p v: N/A
  serial: <filter> Chassis: type: 10 serial: <filter>
  Mobo: Hewlett-Packard model: 172A v: KBC Version 30.30 serial: <filter>
  BIOS: Hewlett-Packard v: 68CCU Ver. F.0E date: 08/23/2010
  ID-1: BAT0 charge: 31.4 Wh condition: 31.4/56.6 Wh (56%) volts: 12.3/11.1
  model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: Full
  Info: Dual Core model: Intel Core i7 M 620 bits: 64 type: MT MCP
  arch: Nehalem family: 6 model-id: 25 (37) stepping: 5 microcode: 7
  L2 cache: 4096 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 21294
  Speed: 1464 MHz min/max: 1199/2667 MHz boost: enabled Core speeds (MHz):
  1: 1464 2: 1463 3: 1463 4: 1463
  Type: l1tf
  Type: mds
  status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
  Device-1: Intel Core Processor Integrated Graphics vendor: Hewlett-Packard
  driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0046
  Device-2: Chicony HP Webcam [2 MP Macro] type: USB driver: uvcvideo
  bus ID: 1-1.5:5 chip ID: 04f2:b15e
  Display: server: X.org 1.20.10 driver: intel unloaded: modesetting
  alternate: fbdev,vesa tty: 200x56
  Message: Advanced graphics data unavailable in console. Try -G --display
  Device-1: Intel 5 Series/3400 Series High Definition Audio
  vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus ID: 00:1b.0
  chip ID: 8086:3b56
  Sound Server: ALSA v: k5.9.14-1-MANJARO
  Device-1: Intel 82577LM Gigabit Network vendor: Hewlett-Packard
  driver: e1000e v: kernel port: 5020 bus ID: 00:19.0 chip ID: 8086:10ea
  IF: enp0s25 state: down mac: <filter>
  Device-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi v: kernel
  port: 5000 bus ID: 43:00.0 chip ID: 8086:4238
  Local Storage: total: 232.89 GiB used: 12.49 GiB (5.4%)
  ID-1: /dev/sda vendor: Toshiba model: MK2556GSY size: 232.89 GiB block size:
  physical: 512 B logical: 512 B speed: 3.0 Gb/s rotation: 7200 rpm
  serial: <filter> rev: 3C scheme: MBR
  ID-1: / raw size: 116.09 GiB size: 113.77 GiB (98.00%)
  used: 12.49 GiB (11.0%) fs: ext4 dev: /dev/sda4
  System Temperatures: cpu: 35.0 C mobo: 0.0 C
  Processes: 151 Uptime: 11m wakeups: 1 Memory: 3.64 GiB
  used: 439.6 MiB (11.8%) Init: systemd v: 247 Compilers: gcc: 10.2.0
  Packages: pacman: 1111 lib: 349 flatpak: 0 Shell: Bash v: 5.1.0
  running in: tty 4 inxi: 3.1.09
Did you?
sudo pacman -Syyu libxcb lib32-libxcb qt5-base
Thank you. Pacman gave me a warning that all three were up-to-date, re-installing.
I selected Yes (the default), and there were no errors downloading and installing.
I rebooted, but the same symptoms as before.
