vmware workstation 16.1.
manjaro-kde-21.02-development-unstable-210225-linux510.iso
hang:
“A start job is running for LiveMedia MHWD Script”
hang:
Not the most explanatory post.
Do you have an ethernet cable? Try disconnecting it during the boot of your VM.
thank you.
do have ethernet.
use “manjaro-kde-20.2.1-210103-linux59.iso” works ok!
Thanks for the tip, had the same issue using manjaro-kde-21.0.1-210410-linux510.iso from download page, but older iso worked
Thank you. I bet going with a slightly older ISO would also work for some other Arch based distros I couldn’t get to work in VMware (like Garuda).
If you would care to use the search function there is a couple of topics on the matter - also stating possible solutions.
Edit the boot arguments by editing the grub command line. Possible workarounds are
