After updating system today, not able to use linux-wifi-hotspot.
Whenever I try to create connection, this happens:
venom $~ sudo create_ap wlo1 lo MyAccessPoint 12345678
WARN: Your adapter does not fully support AP virtual interface, enabling --no-virt
Config dir: /tmp/create_ap.wlo1.conf.XqDEUVbn
PID: 57784
Network Manager found, set wlo1 as unmanaged device... DONE
Sharing Internet using method: nat
Warning: Extension MASQUERADE revision 0 not supported, missing kernel module?
iptables v1.8.8 (legacy): can't initialize iptables table `nat': Table does not exist (do you need to insmod?)
Perhaps iptables or your kernel needs to be upgraded.
Doing cleanup.. done
Output of inxi -Fazy
Kernel: 5.15.74-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=57d6e70f-6350-4312-bbf6-23703119c8ae rw quiet apparmor=1
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: HP product: HP Laptop 15-da0xxx v: Type1ProductConfigId
Mobo: HP model: 84A7 v: 80.50 serial: <superuser required> UEFI: Insyde
v: F.36 date: 02/03/2021
ID-1: BAT1 charge: 0.2 Wh (14.3%) condition: 1.4/41.0 Wh (3.5%) volts: 11.8
min: 11.4 model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter>
status: N/A
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF0
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3400 high: 3402 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 3400 2: 3400 3: 3400
4: 3400 5: 3400 6: 3400 7: 3400 8: 3402 bogomips: 28808
vulnerable
prctl and seccomp
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling,
PBRSB-eIBRS: Not affected
Device-1: Intel UHD Graphics 620 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports:
active: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: NVIDIA GM108M [GeForce MX110] vendor: Hewlett-Packard
driver: nvidia v: 520.56.06 non-free: 520.xx+ status: current (as of 2022-10)
arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-19 pcie: gen: 2
speed: 5 GT/s lanes: 4 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:174e class-ID: 0302
Device-3: IMC Networks HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 13d3:56c9 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
loaded: modesetting,nvidia unloaded: nouveau alternate: fbdev,nv,vesa
dri: iris gpu: i915 display-ID: :0.0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0687 built: 2015 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
Sound API: ALSA v: k5.15.74-3-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.59 running: yes
vendor: Hewlett-Packard driver: r8168 v: 8.050.03-NAPI pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168
class-ID: 0200
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter
vendor: Hewlett-Packard driver: rtw_8723de v: N/A pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:d723
class-ID: 0280
IF: wlo1 state: down mac: <filter>
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-6:3 chip-ID: 0bda:b009 class-ID: e001 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 1.36 TiB used: 806.07 GiB (57.7%)
model: WDS500G2B0C-00PXH0 size: 465.76 GiB block-size: physical: 512 B
rev: 211210WD temp: 30.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: <filter> rev: RSM7 scheme: MBR
ID-1: / raw-size: 90 GiB size: 88.03 GiB (97.81%) used: 59.29 GiB (67.4%)
fs: ext4 dev: /dev/nvme0n1p8 maj-min: 259:8
used: 26.7 MiB (27.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
System Temperatures: cpu: 57.0 C pch: 51.0 C mobo: N/A
Processes: 285 Uptime: 1h 57m wakeups: 1 Memory: 7.67 GiB
used: 5.23 GiB (68.2%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: 1206
pm: pacman pkgs: 1205 libs: 339 tools: pamac,yay pm: flatpak pkgs: 1
Shell: fish v: 3.5.1 default: Bash v: 5.1.16 running-in: xfce4-terminal
inxi: 3.3.23
