Hi,
I’m running Manjaro with Gnome on my Dell E6540 with internal graphic and Radeon HD 8790M. I tried everything from google, but I still cannot set proper (2560x1920) resolution on my external monitor. I tried everything related to xrandr and even adding the mode to the grub configuration via “video” param.
mhwd
0000:01:00.0 (0300:1002:6606) Display controller ATI Technologies Inc:
NAME VERSION FREEDRIVER TYPE
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
> 0000:00:02.0 (0300:8086:0416) Display controller Intel Corporation:
hwinfo --gfx
14: PCI 100.0: 0300 VGA compatible controller (VGA)
[Created at pci.386]
Unique ID: VCu0.u2_+XjLzvq8
Parent ID: vSkL.geGWmNVGCLE
SysFS ID: /devices/pci0000:00/0000:00:01.0/0000:01:00.0
SysFS BusID: 0000:01:00.0
Hardware Class: graphics card
Model: "ATI Mars XTX [Radeon HD 8790M]"
Vendor: pci 0x1002 "ATI Technologies Inc"
Device: pci 0x6606 "Mars XTX [Radeon HD 8790M]"
SubVendor: pci 0x1028 "Dell"
SubDevice: pci 0x05be
Driver: "radeon"
Driver Modules: "radeon"
Memory Range: 0xe0000000-0xefffffff (ro,non-prefetchable)
Memory Range: 0xf7c00000-0xf7c3ffff (rw,non-prefetchable)
I/O Ports: 0xe000-0xe0ff (rw)
Memory Range: 0xf7c40000-0xf7c5ffff (ro,non-prefetchable,disabled)
IRQ: 42 (147 events)
Module Alias: "pci:v00001002d00006606sv00001028sd000005BEbc03sc00i00"
Driver Info #0:
Driver Status: radeon is active
Driver Activation Cmd: "modprobe radeon"
Driver Info #1:
Driver Status: amdgpu is active
Driver Activation Cmd: "modprobe amdgpu"
Config Status: cfg=new, avail=yes, need=no, active=unknown
Attached to: #10 (PCI bridge)
25: PCI 02.0: 0300 VGA compatible controller (VGA)
Unique ID: _Znp.GzMbEN+zY61
SysFS ID: /devices/pci0000:00/0000:00:02.0
SysFS BusID: 0000:00:02.0
Device Name: "Onboard IGD"
Model: "Intel 4th Gen Core Processor Integrated Graphics Controller"
Vendor: pci 0x8086 "Intel Corporation"
Device: pci 0x0416 "4th Gen Core Processor Integrated Graphics Controller"
Revision: 0x06
Driver: "i915"
Driver Modules: "i915"
Memory Range: 0xf5800000-0xf5bfffff (rw,non-prefetchable)
Memory Range: 0xd0000000-0xdfffffff (ro,non-prefetchable)
I/O Ports: 0xf000-0xf03f (rw)
Memory Range: 0x000c0000-0x000dffff (rw,non-prefetchable,disabled)
IRQ: 40 (540409 events)
Module Alias: "pci:v00008086d00000416sv00001028sd000005BEbc03sc00i00"
Driver Info #0:
Driver Status: i915 is active
Driver Activation Cmd: "modprobe i915"
Primary display adapter: #14
inxi -Fazy
Kernel: 5.10.42-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=116b8fba-0702-42e7-825f-855d16e94f1a rw quiet
cryptdevice=UUID=318e7943-f7f1-4ba9-8975-e2f471b4e623:luks-318e7943-f7f1-4ba9-8975-e2f471b4e623
root=/dev/mapper/luks-318e7943-f7f1-4ba9-8975-e2f471b4e623 splash apparmor=1
security=apparmor
resume=/dev/mapper/luks-914fedc4-7849-4618-96d9-17e1c7822055
udev.log_priority=3 video=HDMI-A-1:2560x1920@60
Desktop: GNOME 3.38.4 tk: GTK 3.24.29 wm: gnome-shell dm: GDM 40.0
Type: Laptop System: Dell product: Latitude E6540 v: 00 serial: <filter>
Chassis: type: 9 serial: <filter>
Mobo: Dell model: 0725FP v: A00 serial: <filter> UEFI: Dell v: A16
date: 09/01/2015
ID-1: BAT0 charge: 34.0 Wh (100.0%) condition: 34.0/66.6 Wh (51.1%)
volts: 12.8 min: 11.1 model: Sanyo DELL 96JC94A type: Li-ion
serial: <filter> status: Full
Info: Dual Core model: Intel Core i5-4310M bits: 64 type: MT MCP
arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache:
L2: 3 MiB
bogomips: 21556
Speed: 2694 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 2694 2: 2694
3: 2695 4: 2694
Type: l1tf
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Dell
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
Device-2: AMD Mars XTX [Radeon HD 8790M] vendor: Dell driver: radeon
v: kernel alternate: amdgpu bus-ID: 01:00.0 chip-ID: 1002:6606
class-ID: 0300
Device-3: Microdia Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.5:3 chip-ID: 0c45:64d0 class-ID: 0e02
Display: wayland server: X.org 1.20.11 compositor: gnome-shell driver:
loaded: radeon note: n/a (using device driver) - try sudo/root display-ID: 0
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2)
v: 4.5 Mesa 21.1.2 compat-v: 3.0 direct render: Yes
Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c
class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
class-ID: 0403
Sound Server-1: ALSA v: k5.10.42-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Device-1: Intel Ethernet I217-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
Device-2: Intel Centrino Ultimate-N 6300 driver: iwlwifi v: kernel
port: e000 bus-ID: 03:00.0 chip-ID: 8086:422b class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Local Storage: total: 953.87 GiB used: 66.53 GiB (7.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: GOODRAM model: SSDPR-CX400-01T-G2
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: P1.3 scheme: GPT
ID-1: / raw-size: 936.47 GiB size: 920.7 GiB (98.32%) used: 66.53 GiB (7.2%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-318e7943-f7f1-4ba9-8975-e2f471b4e623
used: 448 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: partition size: 17.1 GiB used: 1.8 MiB (0.0%)
priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-914fedc4-7849-4618-96d9-17e1c7822055
System Temperatures: cpu: 50.0 C mobo: 50.0 C sodimm: SODIMM C gpu: radeon
temp: 45.0 C
Fan Speeds (RPM): cpu: 3507
Processes: 311 Uptime: 2h 20m wakeups: 8 Memory: 15.54 GiB
used: 6.56 GiB (42.2%) Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 Packages: 1308 pacman: 1295 lib: 323 flatpak: 0 snap: 13
Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.04
for p in /sys/class/drm//status; do con=${p%/status}; echo -n "${con#/card?-}: "; cat $p; done
DP-1: disconnected
DP-2: disconnected
eDP-1: connected
HDMI-A-1: connected
HDMI-A-2: disconnected
HDMI-A-3: disconnected
VGA-1: disconnected
VGA-2: disconnected
xrandr
Screen 0: minimum 16 x 16, current 3286 x 1080, maximum 32767 x 32767
XWAYLAND0 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 670mm x 280mm
1920x1080 59.96*+
1440x1080 59.99
1400x1050 59.98
1280x1024 59.89
1280x960 59.94
1152x864 59.96
1024x768 59.92
800x600 59.86
640x480 59.38
320x240 59.52
1680x1050 59.95
1440x900 59.89
1280x800 59.81
720x480 59.71
640x400 59.95
320x200 58.96
1600x900 59.95
1368x768 59.88
1280x720 59.86
1024x576 59.90
864x486 59.92
720x400 59.55
640x350 59.77
2560x1080_60.00 60.00
XWAYLAND1 connected 1366x768+1920+0 (normal left inverted right x axis y axis) 340mm x 190mm
1366x768 59.98*+
1024x768 59.92
800x600 59.86
640x480 59.38
320x240 59.52
720x480 59.71
640x400 59.95
320x200 58.96
1280x720 59.86
1024x576 59.90
864x486 59.92
720x400 59.55
640x350 59.77
Do you have any idea how to solve this? Thank you in advance.
