Hello! I have some issues with HDMI and color bit depth.
Manjaro+Wayland+KDE+AMD RX 6800XT
Monitor is OLED 240Hz 10bit with DSC over DP1.4 and HDMI 2.1, both supported by my GPU.
I have disabled DSC.
max capabilites with DSC OFF:
DP 165hz 8bit - 120Hz …
HDMI 165Hz 10bit…
On W10 (same PC and cables) I can run monitor over both ports at max refresh rate.
On Majaro:
DP - I can run it up to 240Hz(DSC ON) 165Hz(DSC OFF).
HDMI - I can only set 50Hz/60Hz.
XRANDR does not seem to show all monitor modes, only modes with lower refresh rate than Screen Settings refresh rate.
Only 50/60Hz for HDMI port.
I don’t see any obvious setting for color bit depth 8/10bit.
Gpu seems to be set as 24bit color, not 30bit color.
[ 14.233] (==) AMDGPU(0): Depth 24, (–) framebuffer bpp 32
Thanks!
System info:
Kernel: 6.12.44-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=3ed7fbee-dc8b-41a9-bccc-769c9eb2ce05 rw quiet splash
udev.log_priority=3 amdgpu.ppfeaturemask=0xffffffff
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.17.0
Type: Desktop System: Micro-Star product: MS-7B86 v: 1.0
serial: <superuser required>
Mobo: Micro-Star model: B450 GAMING PLUS (MS-7B86) v: 1.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 1.J5 date: 09/04/2024
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard K270
status: discharging
Device-2: hidpp_battery_1 model: Logitech G304 Lightspeed Wireless Gaming
Mouse serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
System RAM: total: 32 GiB available: 31.27 GiB used: 3 GiB (9.6%)
Device-1: Channel-A DIMM 0 type: no module installed
(unregistered) size: 16 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: G.Skill
part-no: F4-3200C16-16GFX serial: N/A
Device-3: Channel-B DIMM 0 type: no module installed
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102E
desc: 6x512 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 1734 min/max: 550/4651 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 1734 2: 1734 3: 1734
4: 1734 5: 1734 6: 1734 7: 1734 8: 1734 9: 1734 10: 1734 11: 1734 12: 1734
bogomips: 88825
xsaves xtopology
affected
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT
/ 6900 XT] vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-2
code: Navi-2x process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4
speed: 16 GT/s lanes: 16 ports: active: DP-1 off: HDMI-A-2
empty: DP-2,HDMI-A-1,Writeback-1 bus-ID: 28:00.0 chip-ID: 1002:73bf
class-ID: 0300
compositor: kwin_wayland driver: X: loaded: amdgpu
gpu: amdgpu display-ID: 0
Monitor-1: DP-1 model: MSI MPG341CX OLED built: 2023 res: mode: 3440x1440
hz: 120 scale: 114% (1.15) to: 2991x1252 dpi: 109 gamma: 1.2 chroma: red:
x: 0.690 y: 0.302 green: x: 0.239 y: 0.718 blue: x: 0.145 y: 0.059 white:
x: 0.314 y: 0.329 size: 800x337mm (31.5x13.27") diag: 868mm (34.2")
modes: 3440x1440, 2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050,
1280x1024, 1440x900, 1280x960, 1280x800, 1152x864, 1280x720, 1024x768,
800x600, 720x576, 720x480, 640x480, 720x400
EDID-Warnings: 1: parse_edid: unknown tag 112
Monitor-2: HDMI-A-2 model: MSI MPG341CX OLED serial: <filter> built: 2023
res: 3440x1440 dpi: 109 gamma: 1.2 chroma: red: x: 0.690 y: 0.302 green:
x: 0.239 y: 0.718 blue: x: 0.145 y: 0.059 white: x: 0.314 y: 0.329
size: 800x337mm (31.5x13.27") diag: 868mm (34.2") modes: 3440x1440,
2560x1440, 1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024,
1440x900, 1280x960, 1280x800, 1152x864, 1280x720, 1024x768, 800x600,
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.1-arch1.4
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6800 XT (radeonsi
navi21 LLVM 20.1.8 DRM 3.61 6.12.44-3-MANJARO) device-ID: 1002:73bf
memory: 15.62 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 6 device: 0 type: discrete-gpu name: AMD
Radeon RX 6800 XT (RADV NAVI21) driver: mesa radv v: 25.2.1-arch1.4
device-ID: 1002:73bf surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: corectrl wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio
bus-ID: 28:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: Creative Sound Blaster X3
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2.4.1:9 chip-ID: 041e:3264
class-ID: 0102 serial: <filter>
API: ALSA v: k6.12.44-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 21:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlo1 state: down mac: <filter>
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 15.46 TiB used: 134.71 GiB (0.9%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: SSD 970 EVO 500GB
size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 37.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 2B2QEXM7 temp: 32.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
tech: SSD serial: <filter> fw-rev: 023 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 model: SATA3 2TB SSD size: 1.82 TiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD
serial: <filter> fw-rev: 7A0 scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 870 EVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: MBR
ID-6: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST4000DM004-2CV104
size: 3.64 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 5425 serial: <filter> fw-rev: 0001 scheme: GPT
ID-7: /dev/sde maj-min: 8:64 vendor: Seagate model: Expansion Desk
size: 5.46 TiB block-size: physical: 4096 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 0915 scheme: GPT
ID-1: / raw-size: 208.98 GiB size: 204.65 GiB (97.92%)
used: 134.67 GiB (65.8%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:8
label: N/A uuid: 3ed7fbee-dc8b-41a9-bccc-769c9eb2ce05
used: 43.7 MiB (45.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
label: N/A uuid: E07B-0BCF
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/nvme0n1p2 maj-min: 259:5 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:6 size: 214.34 GiB fs: ntfs label: N/A
uuid: CC52A01A52A00AF2
ID-3: /dev/nvme0n1p4 maj-min: 259:7 size: 512 MiB fs: ntfs label: N/A
uuid: 545E30A15E307DB4
ID-4: /dev/nvme1n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
ID-5: /dev/nvme1n1p2 maj-min: 259:2 size: 1.64 TiB fs: ntfs label: NVME2
uuid: 6A48135648131FFD
ID-6: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
ID-7: /dev/sda2 maj-min: 8:2 size: 419.17 GiB fs: ntfs label: DATASSD
uuid: 300A55D10A559526
ID-8: /dev/sdb1 maj-min: 8:17 size: 1.82 TiB fs: ntfs label: DATASSD2
uuid: 2E709C34709C04AD
ID-9: /dev/sdd1 maj-min: 8:49 size: 3.64 TiB fs: ntfs label: HDD_INT_01
uuid: 74C04F0D7A5E9168
ID-10: /dev/sde1 maj-min: 8:65 size: 128 MiB fs: <superuser required>
ID-11: /dev/sde2 maj-min: 8:66 size: 5.46 TiB fs: exfat label: HDD_EXT_01
uuid: 22EC-16BB
Hub-2: 1-2:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2822
Hub-3: 1-2.4:4 info: Realtek RTS5411 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5411
Device-1: 1-2.4.1:9 info: Creative Sound Blaster X3
type: HID,abstract (modem),CDC-data,audio
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid interfaces: 7 rev: 2.0
chip-ID: 041e:3264 class-ID: 0102 serial: <filter>
Device-2: 1-4:3 info: Logitech USB Receiver type: keyboard,mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
chip-ID: 046d:c53f class-ID: 0300
Device-3: 1-5:5 info: Logitech Unifying Receiver type: keyboard,mouse,HID
chip-ID: 046d:c52b class-ID: 0300
Hub-4: 1-9:10 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2211
Device-1: 1-9.3:11 info: Micro Star MSI Gaming Controller type: HID
lanes: 1 mode: 1.1 power: 100mA chip-ID: 1462:3fa4 class-ID: 0300
serial: <filter>
Hub-5: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-6: 2-2:2 info: VIA Labs USB3.1 Hub ports: 4 rev: 3.2
speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 2109:0822
Hub-7: 2-2.4:3 info: Realtek Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bda:0411
Device-1: 2-2.4.2:4 info: Seagate RSS LLC Desktop HDD 5TB (ST5000DM000)
type: mass storage driver: uas interfaces: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 8mA
chip-ID: 0bc2:331a class-ID: 0806 serial: <filter>
Hub-8: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-9: 3-1:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
Hub-10: 3-1.3:4 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
Hub-11: 3-1.4:6 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
Hub-12: 3-2:3 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
Hub-13: 3-2.3:5 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
Hub-14: 3-2.4:7 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
Hub-15: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-16: 4-1:2 info: VIA Labs USB3.1 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0822
Hub-17: 4-1.3:4 info: VIA Labs USB3.1 Hub ports: 4 rev: 3.2
Hub-18: 4-1.4:5 info: VIA Labs USB3.1 Hub ports: 4 rev: 3.2
Hub-19: 4-2:3 info: VIA Labs USB3.1 Hub ports: 4 rev: 3.2
Hub-20: 4-2.3:6 info: VIA Labs USB3.1 Hub ports: 4 rev: 3.2
Hub-21: 4-2.4:7 info: VIA Labs USB3.1 Hub ports: 4 rev: 3.2
System Temperatures: cpu: 35.0 C mobo: 31.0 C gpu: amdgpu temp: 44.0 C
mem: 40.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 733 fan-3: 278 fan-4: 285 fan-5: 308
fan-6: 1145 gpu: amdgpu fan: 0
Packages: pm: pacman pkgs: 1526 libs: 464 tools: pamac,yay pm: flatpak
pkgs: 0
1: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
2: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
3: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
5: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
6: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
7: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
8: https://mirror.init7.net/manjaro/stable/$repo/$arch
9: https://manjaro.kurdy.org/stable/$repo/$arch
10: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
11: https://manjaro.ynh.ovh/stable/$repo/$arch
12: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
13: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
14: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
15: https://mirror.zetup.net/manjaro/stable/$repo/$arch
16: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
17: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
18: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
19: https://mirror.easyname.at/manjaro/stable/$repo/$arch
20: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
21: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
22: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
23: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
24: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
25: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
26: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
27: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
28: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
29: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
30: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
31: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
32: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
33: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
34: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
35: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
36: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
37: http://mirror.fcix.net/manjaro/stable/$repo/$arch
38: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
39: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
40: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
41: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
42: https://mirrors2.manjaro.org/stable/$repo/$arch
43: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
44: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
45: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
46: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
47: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
48: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
49: https://mirrors.manjaro.org/repo/stable/$repo/$arch
50: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
51: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
52: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
53: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
54: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
55: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
56: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
57: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
58: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
59: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 327
1: cpu: 8.1% command: konsole pid: 19294 mem: 242.8 MiB (0.7%)
2: cpu: 5.2% command: zsh pid: 19322 mem: 12.2 MiB (0.0%)
3: cpu: 3.9% command: firefox pid: 16889 mem: 748.0 MiB (2.3%)
4: cpu: 1.9% command: firefox pid: 17234 mem: 352.8 MiB (1.1%)
5: cpu: 1.7% command: kwin_wayland pid: 16214 mem: 417.7 MiB (1.3%)
Memory top: 5 of 327
1: mem: 748.0 MiB (2.3%) command: firefox pid: 16889 cpu: 3.9%
2: mem: 451.8 MiB (1.4%) command: plasmashell pid: 16249 cpu: 0.4%
3: mem: 417.7 MiB (1.3%) command: kwin_wayland pid: 16214 cpu: 1.7%
4: mem: 352.8 MiB (1.1%) command: firefox pid: 17234 cpu: 1.9%
5: mem: 301.0 MiB (0.9%) command: firefox pid: 17377 cpu: 0.2%
Processes: 327 Power: uptime: 1h 19m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB
services: power-profiles-daemon,upowerd Init: systemd v: 257
Compilers: gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.3.3
running-in: konsole inxi: 3.3.39
Xorg log read EDID from both ports (I have the monitor with both cables for this test)
Xorg.0.log:
14.104] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 14.233] (WW) Falling back to old probe method for modesetting
[ 14.233] (EE) open /dev/dri/card0: No such file or directory
[ 14.233] (II) AMDGPU(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 14.233] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[ 14.233] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[ 14.233] (==) AMDGPU(0): Default visual is TrueColor
[ 14.233] (II) Applying OutputClass "AMDgpu" options to /dev/dri/card1
[ 14.233] (==) AMDGPU(0): RGB weight 888
[ 14.233] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[ 14.233] (--) AMDGPU(0): Chipset: "AMD Radeon RX 6800 XT" (ChipID = 0x73bf)
[ 14.233] (II) Loading sub module "fb"
[ 14.233] (II) LoadModule: "fb"
[ 14.233] (II) Module "fb" already built-in
[ 14.233] (II) Loading sub module "dri2"
[ 14.233] (II) LoadModule: "dri2"
[ 14.233] (II) Module "dri2" already built-in
[ 14.356] (II) Loading sub module "glamoregl"
[ 14.356] (II) LoadModule: "glamoregl"
[ 14.356] (II) Loading /usr/lib/xorg/modules/libglamoregl.so
[ 14.360] (II) Module glamoregl: vendor="X.Org Foundation"
[ 14.360] compiled for 1.21.1.18, module version = 1.0.1
[ 14.360] ABI class: X.Org ANSI C Emulation, version 0.4
[ 14.377] (II) AMDGPU(0): glamor X acceleration enabled on AMD Radeon RX 6800 XT (radeonsi, navi21, LLVM 20.1.8, DRM 3.61, 6.12.44-3-MANJARO)
[ 14.377] (II) AMDGPU(0): glamor detected, initialising EGL layer.
[ 14.377] (==) AMDGPU(0): TearFree property default: auto
[ 14.377] (==) AMDGPU(0): VariableRefresh: disabled
[ 14.377] (==) AMDGPU(0): AsyncFlipSecondaries: disabled
[ 14.377] (II) AMDGPU(0): KMS Pageflipping: enabled
[ 14.378] (II) AMDGPU(0): Output DisplayPort-0 has no monitor section
[ 14.379] (II) AMDGPU(0): Output DisplayPort-1 has no monitor section
[ 14.379] (II) AMDGPU(0): Output HDMI-A-0 has no monitor section
[ 14.381] (II) AMDGPU(0): Output HDMI-A-1 has no monitor section
[ 14.431] (II) AMDGPU(0): EDID for output DisplayPort-0
[ 14.431] (II) AMDGPU(0): Manufacturer: MSI Model: 4dd0 Serial#: 0
[ 14.431] (II) AMDGPU(0): Year: 2023 Week: 51
[ 14.431] (II) AMDGPU(0): EDID Version: 1.4
[ 14.431] (II) AMDGPU(0): Digital Display Input
[ 14.431] (II) AMDGPU(0): 10 bits per channel
[ 14.431] (II) AMDGPU(0): Digital interface is DisplayPort
[ 14.431] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 80 vert.: 34
[ 14.431] (II) AMDGPU(0): Gamma: 2.20
[ 14.431] (II) AMDGPU(0): DPMS capabilities: Off
[ 14.431] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4 YCrCb 4:2:2
[ 14.431] (II) AMDGPU(0): First detailed timing is preferred mode
[ 14.431] (II) AMDGPU(0): Preferred mode is native pixel format and refresh rate
[ 14.431] (II) AMDGPU(0): Display is continuous-frequency
[ 14.431] (II) AMDGPU(0): redX: 0.689 redY: 0.303 greenX: 0.241 greenY: 0.715
[ 14.431] (II) AMDGPU(0): blueX: 0.145 blueY: 0.059 whiteX: 0.313 whiteY: 0.329
[ 14.431] (II) AMDGPU(0): Supported established timings:
[ 14.431] (II) AMDGPU(0): 720x400@70Hz
[ 14.431] (II) AMDGPU(0): 640x480@60Hz
[ 14.431] (II) AMDGPU(0): 640x480@67Hz
[ 14.431] (II) AMDGPU(0): 640x480@72Hz
[ 14.431] (II) AMDGPU(0): 640x480@75Hz
[ 14.431] (II) AMDGPU(0): 800x600@56Hz
[ 14.431] (II) AMDGPU(0): 800x600@60Hz
[ 14.431] (II) AMDGPU(0): 800x600@72Hz
[ 14.431] (II) AMDGPU(0): 800x600@75Hz
[ 14.431] (II) AMDGPU(0): 1024x768@60Hz
[ 14.431] (II) AMDGPU(0): 1024x768@70Hz
[ 14.431] (II) AMDGPU(0): 1024x768@75Hz
[ 14.431] (II) AMDGPU(0): 1280x1024@75Hz
[ 14.431] (II) AMDGPU(0): Manufacturer's mask: 0
[ 14.431] (II) AMDGPU(0): Supported standard timings:
[ 14.431] (II) AMDGPU(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 14.431] (II) AMDGPU(0): #1: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 14.431] (II) AMDGPU(0): #2: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 14.431] (II) AMDGPU(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 14.431] (II) AMDGPU(0): #4: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 14.431] (II) AMDGPU(0): #5: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 14.431] (II) AMDGPU(0): #6: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 14.431] (II) AMDGPU(0): Supported detailed timing:
[ 14.431] (II) AMDGPU(0): clock: 319.8 MHz Image Size: 800 x 337 mm
[ 14.431] (II) AMDGPU(0): h_active: 3440 h_sync: 3488 h_sync_end 3520 h_blank_end 3600 h_border: 0
[ 14.431] (II) AMDGPU(0): v_active: 1440 v_sync: 1443 v_sync_end 1453 v_blanking: 1481 v_border: 0
[ 14.431] (II) AMDGPU(0): clock: 148.5 MHz Image Size: 800 x 337 mm
[ 14.431] (II) AMDGPU(0): h_active: 1920 h_sync: 2008 h_sync_end 2052 h_blank_end 2200 h_border: 0
[ 14.432] (II) AMDGPU(0): v_active: 1080 v_sync: 1084 v_sync_end 1089 v_blanking: 1125 v_border: 0
[ 14.432] (II) AMDGPU(0): Ranges: V min: 48 V max: 165 Hz, H min: 300 H max: 300 kHz, PixClock max 955 MHz
[ 14.432] (II) AMDGPU(0): Monitor name: MPG341CX OLED
[ 14.432] (II) AMDGPU(0): Supported detailed timing:
[ 14.432] (II) AMDGPU(0): clock: 241.5 MHz Image Size: 800 x 337 mm
[ 14.432] (II) AMDGPU(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 14.432] (II) AMDGPU(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1481 v_border: 0
[ 14.432] (II) AMDGPU(0): clock: 497.8 MHz Image Size: 800 x 337 mm
[ 14.432] (II) AMDGPU(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1525 v_border: 0
[ 14.432] (II) AMDGPU(0): Number of EDID sections to follow: 2
[ 14.432] (II) AMDGPU(0): EDID (in hex):
[ 14.432] (II) AMDGPU(0): 00ffffffffffff003669d04d00000000
[ 14.432] (II) AMDGPU(0): 33210104b55022783bac05b04d3db725
[ 14.432] (II) AMDGPU(0): 0f5054bfcf00714f81c0814081809500
[ 14.432] (II) AMDGPU(0): b300d1c00101e77c70a0d0a029503020
[ 14.432] (II) AMDGPU(0): 3a0020513100001a023a801871382d40
[ 14.432] (II) AMDGPU(0): 582c450020513100001e000000fd0c30
[ 14.432] (II) AMDGPU(0): a52d2d5f010a202020202020000000fc
[ 14.432] (II) AMDGPU(0): 004d50473334314358204f4c454402a1
[ 14.432] (II) AMDGPU(0): 020339f14901030204901211133f2309
[ 14.432] (II) AMDGPU(0): 070783010000e2002a741a0000030330
[ 14.432] (II) AMDGPU(0): a500a066024f03a5000000000000e305
[ 14.432] (II) AMDGPU(0): e201e6060701664b00565e00a0a0a029
[ 14.432] (II) AMDGPU(0): 503020350020513100001a6fc200a0a0
[ 14.432] (II) AMDGPU(0): a055503020350020513100001a000000
[ 14.432] (II) AMDGPU(0): 00000000000000000000000000000000
[ 14.432] (II) AMDGPU(0): 00000000000000000000000000000092
[ 14.432] (II) AMDGPU(0): 701279030003013ca2e300086f0d9f00
[ 14.432] (II) AMDGPU(0): 2f801f009f05b2003100090052010108
[ 14.432] (II) AMDGPU(0): 6f0d9f002f801f009f05540002000900
[ 14.432] (II) AMDGPU(0): b76901086f0d9f002f801f009f057600
[ 14.432] (II) AMDGPU(0): 02000900000000000000000000000000
[ 14.432] (II) AMDGPU(0): 0000000000000000000000000000ad90
[ 14.432] (II) AMDGPU(0): Printing probed modes for output DisplayPort-0
[ 14.432] (II) AMDGPU(0): Modeline "3440x1440"x60.0 319.75 3440 3488 3520 3600 1440 1443 1453 1481 +hsync -vsync (88.8 kHz eP)
[ 14.432] (II) AMDGPU(0): Modeline "3440x1440"x165.0 926.00 3440 3488 3520 3600 1440 1443 1453 1559 +hsync -vsync (257.2 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "3440x1440"x120.0 658.75 3440 3488 3520 3600 1440 1443 1453 1525 +hsync -vsync (183.0 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "3440x1440"x100.0 582.75 3440 3488 3520 3600 1440 1490 1500 1619 +hsync -vsync (161.9 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "2560x1440"x120.0 497.75 2560 2608 2640 2720 1440 1443 1448 1525 +hsync -vsync (183.0 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1920x1200"x60.0 319.75 1920 3488 3520 3600 1200 1443 1453 1481 +hsync -vsync (88.8 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1920x1080"x120.0 297.00 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (135.0 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1920x1080"x119.9 296.70 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (134.9 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1600x1200"x60.0 319.75 1600 3488 3520 3600 1200 1443 1453 1481 +hsync -vsync (88.8 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1680x1050"x60.0 146.25 1680 1784 1960 2240 1050 1053 1059 1089 -hsync +vsync (65.3 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1440x900"x59.9 106.50 1440 1520 1672 1904 900 903 909 934 -hsync +vsync (55.9 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1280x800"x60.0 319.75 1280 3488 3520 3600 800 1443 1453 1481 +hsync -vsync (88.8 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 14.432] (II) AMDGPU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 14.432] (II) AMDGPU(0): EDID for output DisplayPort-1
[ 14.432] (II) AMDGPU(0): EDID for output HDMI-A-0
[ 14.434] (II) AMDGPU(0): EDID for output HDMI-A-1
[ 14.434] (II) AMDGPU(0): Manufacturer: MSI Model: 4dd0 Serial#: 16843009
[ 14.434] (II) AMDGPU(0): Year: 2023 Week: 51
[ 14.434] (II) AMDGPU(0): EDID Version: 1.3
[ 14.434] (II) AMDGPU(0): Digital Display Input
[ 14.434] (II) AMDGPU(0): Max Image Size [cm]: horiz.: 80 vert.: 34
[ 14.434] (II) AMDGPU(0): Gamma: 2.20
[ 14.434] (II) AMDGPU(0): DPMS capabilities: Off
[ 14.434] (II) AMDGPU(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 14.434] (II) AMDGPU(0): First detailed timing is preferred mode
[ 14.434] (II) AMDGPU(0): redX: 0.689 redY: 0.303 greenX: 0.241 greenY: 0.715
[ 14.434] (II) AMDGPU(0): blueX: 0.145 blueY: 0.059 whiteX: 0.313 whiteY: 0.329
[ 14.434] (II) AMDGPU(0): Supported established timings:
[ 14.434] (II) AMDGPU(0): 720x400@70Hz
[ 14.434] (II) AMDGPU(0): 640x480@60Hz
[ 14.434] (II) AMDGPU(0): 640x480@67Hz
[ 14.434] (II) AMDGPU(0): 640x480@72Hz
[ 14.434] (II) AMDGPU(0): 640x480@75Hz
[ 14.434] (II) AMDGPU(0): 800x600@56Hz
[ 14.434] (II) AMDGPU(0): 800x600@60Hz
[ 14.434] (II) AMDGPU(0): 800x600@72Hz
[ 14.434] (II) AMDGPU(0): 800x600@75Hz
[ 14.434] (II) AMDGPU(0): 1024x768@60Hz
[ 14.434] (II) AMDGPU(0): 1024x768@70Hz
[ 14.434] (II) AMDGPU(0): 1024x768@75Hz
[ 14.434] (II) AMDGPU(0): 1280x1024@75Hz
[ 14.434] (II) AMDGPU(0): Manufacturer's mask: 0
[ 14.434] (II) AMDGPU(0): Supported standard timings:
[ 14.434] (II) AMDGPU(0): #0: hsize: 1152 vsize 864 refresh: 75 vid: 20337
[ 14.434] (II) AMDGPU(0): #1: hsize: 1280 vsize 720 refresh: 60 vid: 49281
[ 14.434] (II) AMDGPU(0): #2: hsize: 1280 vsize 960 refresh: 60 vid: 16513
[ 14.434] (II) AMDGPU(0): #3: hsize: 1280 vsize 1024 refresh: 60 vid: 32897
[ 14.434] (II) AMDGPU(0): #4: hsize: 1440 vsize 900 refresh: 60 vid: 149
[ 14.434] (II) AMDGPU(0): #5: hsize: 1680 vsize 1050 refresh: 60 vid: 179
[ 14.434] (II) AMDGPU(0): #6: hsize: 1920 vsize 1080 refresh: 60 vid: 49361
[ 14.434] (II) AMDGPU(0): Supported detailed timing:
[ 14.434] (II) AMDGPU(0): clock: 265.2 MHz Image Size: 800 x 337 mm
[ 14.434] (II) AMDGPU(0): h_active: 3440 h_sync: 3488 h_sync_end 3520 h_blank_end 3600 h_border: 0
[ 14.434] (II) AMDGPU(0): v_active: 1440 v_sync: 1443 v_sync_end 1453 v_blanking: 1474 v_border: 0
[ 14.434] (II) AMDGPU(0): clock: 319.8 MHz Image Size: 800 x 337 mm
[ 14.434] (II) AMDGPU(0): v_active: 1440 v_sync: 1443 v_sync_end 1453 v_blanking: 1481 v_border: 0
[ 14.434] (II) AMDGPU(0): Ranges: V min: 48 V max: 240 Hz, H min: 30 H max: 400 kHz, PixClock max 1505 MHz
[ 14.434] (II) AMDGPU(0): Monitor name: MPG341CX OLED
[ 14.434] (II) AMDGPU(0): clock: 241.5 MHz Image Size: 800 x 337 mm
[ 14.434] (II) AMDGPU(0): h_active: 2560 h_sync: 2608 h_sync_end 2640 h_blank_end 2720 h_border: 0
[ 14.434] (II) AMDGPU(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1481 v_border: 0
[ 14.434] (II) AMDGPU(0): clock: 497.8 MHz Image Size: 800 x 337 mm
[ 14.434] (II) AMDGPU(0): v_active: 1440 v_sync: 1443 v_sync_end 1448 v_blanking: 1525 v_border: 0
[ 14.434] (II) AMDGPU(0): Number of EDID sections to follow: 1
[ 14.434] (II) AMDGPU(0): EDID (in hex):
[ 14.434] (II) AMDGPU(0): 00ffffffffffff003669d04d01010101
[ 14.434] (II) AMDGPU(0): 33210103805022782aac05b04d3db725
[ 14.434] (II) AMDGPU(0): 0f5054bfcf00714f81c0814081809500
[ 14.434] (II) AMDGPU(0): b300d1c001019d6770a0d0a022503020
[ 14.434] (II) AMDGPU(0): 3a0020513100001ae77c70a0d0a02950
[ 14.434] (II) AMDGPU(0): 30203a0020513100001a000000fd0830
[ 14.434] (II) AMDGPU(0): f01e9196000a202020202020000000fc
[ 14.434] (II) AMDGPU(0): 004d50473334314358204f4c4544014a
[ 14.434] (II) AMDGPU(0): 02034cf1e27802490103020490121113
[ 14.434] (II) AMDGPU(0): 3f230907078301000067030c00200038
[ 14.434] (II) AMDGPU(0): 446ad85dc4017880601230f0741a0000
[ 14.434] (II) AMDGPU(0): 030330f0e6a066024f03f00000000000
[ 14.434] (II) AMDGPU(0): 00e305e201e6060701664b00565e00a0
[ 14.434] (II) AMDGPU(0): a0a029503020350020513100001a6fc2
[ 14.434] (II) AMDGPU(0): 00a0a0a055503020350020513100001a
[ 14.434] (II) AMDGPU(0): 000000000000000000000000000000b3
[ 14.434] (--) AMDGPU(0): HDMI max TMDS frequency 340000KHz
[ 14.434] (II) AMDGPU(0): Printing probed modes for output HDMI-A-1
[ 14.434] (II) AMDGPU(0): Modeline "3440x1440"x50.0 265.25 3440 3488 3520 3600 1440 1443 1453 1474 +hsync -vsync (73.7 kHz eP)
[ 14.434] (II) AMDGPU(0): Modeline "3440x1440"x60.0 319.75 3440 3488 3520 3600 1440 1443 1453 1481 +hsync -vsync (88.8 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "2560x1440"x120.0 497.75 2560 2608 2640 2720 1440 1443 1448 1525 +hsync -vsync (183.0 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "2560x1440"x60.0 241.50 2560 2608 2640 2720 1440 1443 1448 1481 +hsync -vsync (88.8 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1920x1200"x50.0 265.25 1920 3488 3520 3600 1200 1443 1453 1474 +hsync -vsync (73.7 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1920x1080"x120.0 297.00 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (135.0 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1920x1080"x119.9 296.70 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (134.9 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 -hsync -vsync (67.5 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1920x1080"x60.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1920x1080"x59.9 148.35 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.4 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1600x1200"x50.0 265.25 1600 3488 3520 3600 1200 1443 1453 1474 +hsync -vsync (73.7 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1680x1050"x59.9 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1280x1024"x75.0 135.00 1280 1296 1440 1688 1024 1025 1028 1066 +hsync +vsync (80.0 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1280x1024"x60.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1440x900"x59.9 88.75 1440 1488 1520 1600 900 903 909 926 +hsync -vsync (55.5 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1280x960"x60.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1280x800"x50.0 265.25 1280 3488 3520 3600 800 1443 1453 1474 +hsync -vsync (73.7 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1152x864"x75.0 108.00 1152 1216 1344 1600 864 865 868 900 +hsync +vsync (67.5 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1280x720"x60.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1280x720"x50.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1280x720"x59.9 74.18 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1024x768"x75.0 78.75 1024 1040 1136 1312 768 769 772 800 +hsync +vsync (60.0 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1024x768"x70.1 75.00 1024 1048 1184 1328 768 771 777 806 -hsync -vsync (56.5 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "1024x768"x60.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "800x600"x72.2 50.00 800 856 976 1040 600 637 643 666 +hsync +vsync (48.1 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "800x600"x75.0 49.50 800 816 896 1056 600 601 604 625 +hsync +vsync (46.9 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "800x600"x60.3 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "800x600"x56.2 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "720x576"x50.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "720x480"x60.0 27.03 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "720x480"x59.9 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "640x480"x75.0 31.50 640 656 720 840 480 481 484 500 -hsync -vsync (37.5 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "640x480"x72.8 31.50 640 664 704 832 480 489 492 520 -hsync -vsync (37.9 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "640x480"x66.7 30.24 640 704 768 864 480 483 486 525 -hsync -vsync (35.0 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "640x480"x60.0 25.20 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "640x480"x59.9 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 14.434] (II) AMDGPU(0): Modeline "720x400"x70.1 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 14.434] (II) AMDGPU(0): Output DisplayPort-0 connected
[ 14.434] (II) AMDGPU(0): Output DisplayPort-1 disconnected
[ 14.434] (II) AMDGPU(0): Output HDMI-A-0 disconnected
[ 14.434] (II) AMDGPU(0): Output HDMI-A-1 connected
[ 14.434] (II) AMDGPU(0): Using spanning desktop for initial modes
[ 14.434] (II) AMDGPU(0): Output DisplayPort-0 using initial mode 3440x1440 +0+0
[ 14.434] (II) AMDGPU(0): Output HDMI-A-1 using initial mode 3440x1440 +3440+0
