I have connected some devices via USB interfaces, external HD or tablet etc…
I can see them as follows:
But not mounted as devices in Dolphin,
What can I do to just use them in the GUI to drag and drop files?
Danke!
Danke!
Hi @mzoli,
Is the drive formatted?
Please provide the output of:
fdisk -l
When posting terminal output, copy the output and paste it here, wrapped in three (3) backticks, before AND after the pasted text. Like this:
pasted text
Sed
sollicitudin dolor
eget nisl elit id
condimentum
arcu erat varius
cursus sem quis eros.
Instead of like this:
Sed sollicitudin dolor eget nisl elit id condimentum arcu erat varius cursus sem quis eros.
Thereby increasing legibility thus making it easier for those trying to provide assistance.
Oops, I didn’t know the syntax policy. Thank you!
Disk /dev/nvme0n1: 119.24 GiB, 128035676160 bytes, 250069680 sectors
Disk model: KINGSTON OM8PDP3128B-A01
Disklabel type: gpt
Disk identifier: 0F157A14-53B2-1647-972F-986AE2E9D579
Device Start End Sectors Size Type
/dev/nvme0n1p1 4096 618495 614400 300M EFI System
/dev/nvme0n1p2 618496 250067789 249449294 118.9G Linux filesystem
Disk /dev/sda: 931.51 GiB, 1000204885504 bytes, 1953525167 sectors
Disk model: Expansion
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0xae822853
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 64 1953520128 1953520065 931.5G 7 HPFS/NTFS/exFAT
I restarted the PC and now I can see the external HD. ![]()
