Cannot Run an Appimage (libgio-2.0 undefined symbol issue)?
I was trying to run this appimage for a Sonic Riders fan game: Release ExGL Riders V1.0.5 · BlueSwordM/Riders-Dolphin-EX · GitHub.
It’s supported on Linux (I saw a dev install it and play it on Arch from scratch so I know it works). The dev said that something was wrong with Manjaro though (something about linux headers) causing it to not work. Is there some workaround for this issue with appimages?
sarah@MidnightStarSign:~/Desktop/Utilities/Sonic Riders/ExGL-Dolphin-V1.0.5-Linux$ LD_PRELOAD=/lib64/libgmodule-2.0.so ./ExGL-Dolphin\ V1.0.5.AppImage
dolphin-emu: symbol lookup error: /usr/lib/libgio-2.0.so.0: undefined symbol: g_module_open_full
The current method for this is to use: LD_PRELOAD=/lib64/libgmodule-2.0.so ./ExGL-Dolphin\ V1.0.5.AppImage, but this also fails.
Not sure what would cause it to work on Arch, but not on Manjaro.
  Kernel: 5.18.17-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.18-x86_64
    root=UUID=6ce26050-4dcc-47b7-a937-45467d8b8d61 rw rootflags=subvol=@
    radeon.modeset=1 nvdia-drm.modeset=1 quiet
    cryptdevice=UUID=466d5812-64c7-4a28-bcc4-a1a5adfa9450:luks-466d5812-64c7-4a28-bcc4-a1a5adfa9450
    root=/dev/mapper/luks-466d5812-64c7-4a28-bcc4-a1a5adfa9450 apparmor=1
    security=apparmor
    resume=/dev/mapper/luks-81b2dc57-06f5-4471-b484-77c3a516f307
    udev.log_priority=3
  Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 4021
    date: 08/09/2021
  RAM: total: 62.71 GiB used: 30.77 GiB (49.1%)
  RAM Report: permissions: Unable to run dmidecode. Root privileges
    required.
  Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3 gen: 4
    built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25) model-id: 0x21 (33)
    stepping: 0 microcode: 0xA201016
  Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
    L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
    L3: 64 MiB desc: 2x32 MiB
  Speed (MHz): avg: 3899 high: 4534 min/max: 2200/5223 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4280 2: 4224
    3: 3801 4: 3583 5: 4476 6: 3598 7: 3562 8: 3969 9: 4527 10: 4039 11: 4411
    12: 3632 13: 3644 14: 3640 15: 3629 16: 3693 17: 3909 18: 3457 19: 4340
    20: 3609 21: 4179 22: 3616 23: 3592 24: 3978 25: 4369 26: 4534 27: 4259
    28: 3638 29: 3647 30: 3635 31: 3640 32: 3665 bogomips: 217694
    cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
    extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
    hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
    pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
    svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
    v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
    STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
  Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia
    v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
    (as of 2022-07) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
    bus-ID: 0b:00.0 chip-ID: 10de:2484 class-ID: 0300
  Device-2: AMD Cape Verde PRO [Radeon HD 7750/8740 / R7 250E]
    vendor: VISIONTEK driver: radeon v: kernel alternate: amdgpu arch: GCN-1
    code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 3
    speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports: active: DP-3,DP-4
    empty: DP-1, DP-2, DP-5, DP-6 bus-ID: 0c:00.0 chip-ID: 1002:683f
    class-ID: 0300
  Device-3: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
    bus-ID: 9-2:3 chip-ID: 0c45:6367 class-ID: 0102 serial: <filter>
  Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia gpu: radeon
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 5760x2160 s-dpi: 80 s-size: 1829x686mm (72.01x27.01")
    s-diag: 1953mm (76.91")
  Monitor-1: DP-1 pos: 1-2 res: 1920x1080 dpi: 93
    size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
  Monitor-2: DP-1-3 pos: primary,1-1 res: 1920x1080 dpi: 93
  Monitor-3: DP-1-4 pos: 2-1 res: 1920x1080 dpi: 82
    size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
  Monitor-4: DP-3 pos: primary,2-2 res: 1920x1080 dpi: 82
  Monitor-5: DP-4 pos: 2-3 res: 1920x1080 dpi: 82
  Monitor-6: HDMI-0 pos: 1-4 res: 1920x1080 dpi: 93
  OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2 v: 4.6.0 NVIDIA
    515.65.01 direct render: Yes
  Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 5-1:2 pcie: chip-ID: 0c76:120b
    gen: 4 class-ID: 0300 speed: 16 GT/s serial: <filter> lanes: 8 link-max:
    lanes: 16 bus-ID: 0b:00.1 chip-ID: 10de:228b class-ID: 0403
  Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
    Series] vendor: VISIONTEK driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 0c:00.1
    chip-ID: 1002:aab0 class-ID: 0403
  Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
    bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-4: JMTek LLC. Plugable USB Audio Device type: USB
    driver: hid-generic,snd-usb-audio,usbhid
  Device-5: ASUSTek ASUS AI Noise-Cancelling Mic Adapter type: USB
    driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-4:4 chip-ID: 0b05:194e
    class-ID: 0300 serial: <filter>
  Device-6: Schiit Audio Unison Universal Dac type: USB
    driver: snd-usb-audio bus-ID: 9-1:4 chip-ID: 30be:1019 class-ID: 0102
  Device-7: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
  Sound Server-1: ALSA v: k5.18.17-1-MANJARO running: yes
  Sound Server-3: JACK v: 1.9.21 running: no
  Sound Server-4: PulseAudio v: 16.1 running: yes
  Sound Server-5: PipeWire v: 0.3.56 running: no
  Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
    pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
  IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
  IP v4: <filter> scope: global
    driver: btusb v: 0.8 bus-ID: 5-5.3:10 chip-ID: 0a12:0001 class-ID: e001
  Device-1: luks-c847cf9f-c6b5-4624-a25e-4531e318851a maj-min: 254:2
    type: LUKS dm: dm-2 size: 3.64 TiB
  Components:
  p-1: sda1 maj-min: 8:1 size: 3.64 TiB
  Device-2: luks-466d5812-64c7-4a28-bcc4-a1a5adfa9450 maj-min: 254:0
    type: LUKS dm: dm-0 size: 864.75 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 864.75 GiB
  Device-3: luks-81b2dc57-06f5-4471-b484-77c3a516f307 maj-min: 254:1
    type: LUKS dm: dm-1 size: 66.26 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:3 size: 66.26 GiB
  Local Storage: total: 9.33 TiB used: 2.8 TiB (30.0%)
    model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
    rev: 111110WD temp: 52.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
    model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
    rev: 211070WD temp: 46.9 C scheme: GPT
  ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD4005FZBX-00K5WB0 size: 3.64 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
    rev: 1A01 scheme: GPT
  ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
  ID-5: /dev/sdc maj-min: 8:32 type: USB vendor: Generic model: USB3.0 CRW
    -SD size: 238.3 GiB block-size: physical: 512 B logical: 512 B type: N/A
    serial: <filter> rev: 1.00 scheme: MBR
  ID-1: / raw-size: 864.75 GiB size: 767 GiB (88.70%) used: 602.38 GiB (78.5%)
    fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-466d5812-64c7-4a28-bcc4-a1a5adfa9450 label: N/A
    uuid: 6ce26050-4dcc-47b7-a937-45467d8b8d61
  ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 26.1 MiB
    (5.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 4B3B-683F
  ID-3: /home raw-size: 864.75 GiB size: 767 GiB (88.70%) used: 602.38 GiB
    (78.5%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
  ID-4: /run/media/sarah/ConvergentRefuge raw-size: 3.64 TiB size: 3.64 TiB
    (100.00%) used: 2.05 TiB (56.3%) fs: btrfs dev: /dev/dm-2 maj-min: 254:2
    mapped: luks-c847cf9f-c6b5-4624-a25e-4531e318851a label: ConvergentRefuge
    uuid: 7d295e73-4143-4eb1-9d22-75a06b1d2984
  ID-5: /run/media/sarah/JerichoVariance raw-size: 3.64 TiB size: 3.64 TiB
    (100.00%) used: 129.71 GiB (3.5%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17
    label: JerichoVariance uuid: 1AB22D5664889CBD
  ID-6: /run/media/sarah/MSS_EXtended raw-size: 731.51 GiB size: 731.16 GiB
    (99.95%) used: 33.69 GiB (4.6%) fs: xfs dev: /dev/nvme1n1p1 maj-min: 259:5
    label: MSS EXtended uuid: 20339e0b-8343-433e-9209-ac67e31d9d73
  ID-7: /run/user/1000/keybase/kbfs raw-size: N/A size: 250 GiB used: 0 KiB
    (0.0%) fs: fuse dev: /dev/fuse label: N/A uuid: N/A
  ID-1: swap-1 type: partition size: 64 GiB used: 81.5 MiB (0.1%)
    priority: -2 dev: /dev/dm-1 maj-min: 254:1
    mapped: luks-81b2dc57-06f5-4471-b484-77c3a516f307 label: N/A
    uuid: c5112526-26fb-473c-b7ab-bb9ef049aa38
  ID-1: /dev/nvme1n1p2 maj-min: 259:6 size: 16 MiB fs: <superuser required>
  ID-2: /dev/nvme1n1p3 maj-min: 259:7 size: 199.98 GiB fs: ntfs label: N/A
    uuid: E658FD3258FD025B
  ID-3: /dev/sdc1 maj-min: 8:33 size: 238.27 GiB fs: exfat label: N/A
    uuid: 3363-6564
  Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Hub-2: 1-2:2 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
    chip-ID: 045b:0209 class-ID: 0900
  Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  Hub-4: 2-2:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
    chip-ID: 045b:0210 class-ID: 0900
  Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-6: 3-1:2 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    power: 100mA chip-ID: 2109:3431 class-ID: 0900
  Hub-7: 3-1.2:3 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
    chip-ID: 2109:2813 class-ID: 0900
  Device-1: 3-1.3:5 info: Microsoft Xbox One Controller (Firmware 2015)
    type: <vendor specific> driver: usbfs interfaces: 3 rev: 2.0 speed: 12 Mb/s
    power: 500mA chip-ID: 045e:02dd class-ID: ff00 serial: <filter>
  Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
  Hub-9: 4-2:2 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
    chip-ID: 2109:0813 class-ID: 0900
  Hub-10: 5-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 5-1:2 info: JMTek LLC. Plugable USB Audio Device type: Audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
    speed: 12 Mb/s power: 100mA chip-ID: 0c76:120b class-ID: 0300
    serial: <filter>
  Hub-11: 5-2:3 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
    speed: 480 Mb/s power: 100mA chip-ID: 1a40:0201 class-ID: 0900
  Device-1: 5-2.1:5 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
    type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 1.5 Mb/s power: 98mA chip-ID: 1bcf:08a0 class-ID: 0301
  Device-2: 5-2.5:6 info: Microdia Backlit Gaming Keyboard
    type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    speed: 12 Mb/s power: 400mA chip-ID: 0c45:652f class-ID: 0301
  Device-3: 5-2.6:8 info: HUION H420 type: Mouse,HID driver: uclogic,usbhid
    interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 256c:006e
    class-ID: 0300
  Hub-12: 5-2.7:11 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
    power: 100mA chip-ID: 1a40:0101 class-ID: 0900
  Device-1: 5-2.7.4:12 info: Texas Instruments TI-Nspire Calculator
    type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
    power: 500mA chip-ID: 0451:e012 class-ID: 0000
  Device-2: 5-4:4 info: ASUSTek ASUS AI Noise-Cancelling Mic Adapter
    type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
    rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0b05:194e class-ID: 0300
    serial: <filter>
  Hub-13: 5-5:7 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Device-1: 5-5.3:10 info: Cambridge Silicon Radio Bluetooth Dongle (HCI
    mode) type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
    power: 100mA chip-ID: 0a12:0001 class-ID: e001
  Hub-14: 5-6:9 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
  Hub-15: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Hub-16: 7-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 7-4:2 info: ASUSTek AURA LED Controller type: HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
    chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
  Hub-17: 8-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  Device-1: 8-1:2 info: Realtek Card Reader type: Mass Storage
    driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 800mA
    chip-ID: 0bda:0307 class-ID: 0806 serial: <filter>
  Hub-18: 9-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 9-1:4 info: Schiit Audio Unison Universal Dac type: Audio
    driver: snd-usb-audio interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
  Device-2: 9-2:3 info: Microdia USB 2.0 Camera type: Video,Audio
    power: 500mA chip-ID: 0c45:6367 class-ID: 0102 serial: <filter>
  Hub-19: 10-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
  System Temperatures: cpu: 61.0 C mobo: 41.0 C
  Fan Speeds (RPM): fan-1: 1693 fan-2: 1197 fan-3: 1164 fan-4: 1183
    fan-5: 3183 fan-6: 0 fan-7: 0
  GPU: device: nvidia screen: :0.0 temp: 50 C fan: 0% device: radeon
    temp: 55.0 C
  Processes: 870 Uptime: 14h 39m wakeups: 0 Init: systemd v: 251
  default: graphical tool: systemctl Compilers: gcc: 12.1.1 alt: 10
  clang: 14.0.6 Packages: 2466 pacman: 2440 lib: 516 flatpak: 10 snap: 16
  Shell: Bash v: 5.1.16 running-in: yakuake inxi: 3.3.20
Looks like they include libgmodule-2.0.so in the image, which results to this error.
./ExGL-Dolphin\ V1.0.5.AppImage --appimage-extract
rm -f squashfs-root/usr/lib/libgmodule-2.0.so.0
wget https://github.com/AppImage/AppImageKit/releases/download/13/appimagetool-x86_64.AppImage
chmod u+x *.AppImage
./appimagetool-x86_64.AppImage squashfs-root ExGL-Dolphin-V1.0.5-fix.AppImage
Then it works. (I am on unstable branch)
