Cannot resume from suspend using bluetooth devices
I switched to manjaro (and linux in general) pretty recently. One thing I can’t fix is to wake up my laptop with either BT Keyboard or Mouse. Apparently BT is switched off when system goes into suspend.
I am using s2idle suspend mode.
As stated in wiki.archlinux.org->title->bluetooth I edited /etc/bluetooth/main.conf and set up an udev rule in order to avoid the BT adapter to be switched off.
holycow% lsusb | grep bluetooth -i
Bus 001 Device 007: ID 8087:0029 Intel Corp. AX200 Bluetooth
holycow% cat /etc/udev/rules.d/91-keyboardmousewakeup.rules
SUBSYSTEM=="usb", ATTRS{idVendor}=="8087", ATTRS{idProduct}=="0029" RUN+="/bin/sh -c 'echo enabled > /sys$env{DEVPATH}/../power/wakeup;'"%
I could not find any suspicious journal entries.
Insyde bios does not provide any switches to dis- or enable wakeup from BT, as far es I can tell.
I disabled TLP to test if there is a problem.
Would be glad, if somebody could point me in the right direction.
Here some system infos:
  Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    root=UUID=7d84116a-49de-45f9-bbba-39703fe1776f rw quiet apparmor=1
    security=apparmor udev.log_priority=3 mem_sleep_default=s2idle
    resume=UUID=2d46df93-1c4e-4c7d-8600-a91a6ba51488
  Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
  Type: Laptop System: Notebook product: N150CU v: N/A
  Mobo: Notebook model: N150CU serial: <superuser required> UEFI: INSYDE
    v: 1.07.14TNB date: 12/09/2020
  ID-1: BAT0 charge: 32.6 Wh (93.4%) condition: 34.9/35.3 Wh (98.7%)
    volts: 12.2 min: 11.4 model: Notebook BAT type: Li-ion serial: <filter>
    status: Charging
  Info: model: Intel Core i7-10510U bits: 64 type: MT MCP
    arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
    stepping: 0xC (12) microcode: 0xEA
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 3300 high: 3301 min/max: 400/4900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 3301 2: 3300 3: 3301
    4: 3300 5: 3300 6: 3300 7: 3300 8: 3300 bogomips: 36812
  Type: srbds mitigation: TSX disabled
  Device-1: Intel CometLake-U GT2 [UHD Graphics] vendor: CLEVO/KAPOK
    driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
  Device-2: Chicony Chicony USB2.0 Camera type: USB driver: uvcvideo
    bus-ID: 1-7:5 chip-ID: 04f2:b685 class-ID: 0e02
  Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
    loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2")
    s-diag: 1052mm (41.4")
  Monitor-1: DP-1-1 res: 1920x1080 hz: 60 dpi: 94
    size: 521x293mm (20.5x11.5") diag: 598mm (23.5")
  Monitor-2: DP-1-2 res: 1920x1080 hz: 60 dpi: 94
  OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.5
    direct render: Yes
  Device-1: Intel Comet Lake PCH-LP cAVS vendor: CLEVO/KAPOK
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
    bus-ID: 00:1f.3 chip-ID: 8086:02c8 class-ID: 0403
  Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.40 running: yes
    vendor: CLEVO/KAPOK driver: r8169 v: kernel port: 3000 bus-ID: 3b:00.1
  IF: enp59s0f1 state: down mac: <filter>
  Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 3c:00.0
    chip-ID: 8086:2723 class-ID: 0280
  IF: wlp60s0 state: up mac: <filter>
  Device-3: Realtek RTL8153 Gigabit Ethernet Adapter type: USB driver: r8152
    bus-ID: 4-1.1:7 chip-ID: 0bda:8153 class-ID: 0000 serial: <filter>
  IF: enp58s0u1u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
    bus-ID: 1-10:7 chip-ID: 8087:0029 class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
  Local Storage: total: 931.51 GiB used: 534.47 GiB (57.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
    lanes: 4 type: SSD serial: <filter> rev: P3CR010 temp: 40.9 C scheme: GPT
  ID-1: / raw-size: 244.7 GiB size: 239.8 GiB (98.00%) used: 19.91 GiB (8.3%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-3: /home raw-size: 652.34 GiB size: 641.1 GiB (98.28%)
    used: 514.39 GiB (80.2%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-1: swap-1 type: partition size: 34.17 GiB used: 170.6 MiB (0.5%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3
  System Temperatures: cpu: 67.0 C pch: 56.0 C mobo: N/A
  Processes: 333 Uptime: 1d 12h 55m wakeups: 450 Memory: 31.17 GiB
  used: 8.29 GiB (26.6%) Init: systemd v: 249 tool: systemctl Compilers:
  gcc: 11.1.0 Packages: 1384 pacman: 1374 lib: 373 flatpak: 3 snap: 7
  Shell: Zsh v: 5.8 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
