After the recent update, I cannot record my desktop/screen using the h264_amf codec in Simple Screen recorder. It was working fine before.
LOG:
[PageRecord::StartPage] Starting page ...
[PageRecord::StartPage] Started page.
[PageRecord::StartOutput] Starting output ...
[Muxer::Init] Using format mp4 (MP4 (MPEG-4 Part 14)).
[Muxer::AddStream] Using codec h264_amf (AMD AMF H.264 Encoder).
[VideoEncoder::PrepareStream] Using pixel format nv12.
[BaseEncoder::Init] Error: Can't open codec!
[h264_amf @ 0x564984fee580] DLL libamfrt64.so.1 failed to open
[PageRecord::StartOutput] Error: Something went wrong during initialization.
Full system info:
Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: ROG Strix G713QM_G713QM v: 1.0
serial: <superuser required>
Mobo: ASUSTeK model: G713QM v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: G713QM.314 date: 09/03/2021
ID-1: BAT0 charge: 55.6 Wh (62.0%) condition: 89.7/90.0 Wh (99.7%)
volts: 15.8 min: 15.9 model: AS3GWAF3KC GA50358 type: Li-ion
serial: <filter> status: N/A
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master 2S
status: Discharging
RAM: total: 15.12 GiB used: 3.48 GiB (23.0%)
RAM Report:
Info: 8-core model: AMD Ryzen 7 5800H with Radeon Graphics bits: 64
type: MT MCP smt: enabled arch: Zen 3 rev: 0 cache: L1: 512 KiB L2: 4 MiB
L3: 16 MiB
Speed (MHz): avg: 1373 high: 3321 min/max: 1200/4462 boost: enabled
cores: 1: 1197 2: 1197 3: 3321 4: 1197 5: 1333 6: 1197 7: 1197 8: 1135
9: 1135 10: 1135 11: 1545 12: 1197 13: 1198 14: 1197 15: 1397 16: 1396
bogomips: 102241
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Device-1: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: ASUSTeK
driver: nvidia v: 495.46 bus-ID: 01:00.0 chip-ID: 10de:2520 class-ID: 0300
Device-2: AMD Cezanne vendor: ASUSTeK driver: amdgpu v: kernel
bus-ID: 05:00.0 chip-ID: 1002:1638 class-ID: 0300
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: modesetting,nvidia resolution: 1920x1200~60Hz s-dpi: 93
OpenGL: renderer: NVIDIA GeForce RTX 3060 Laptop GPU/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:228e class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 05:00.1 chip-ID: 1002:1637
class-ID: 0403
Device-3: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: ASUSTeK driver: N/A bus-ID: 05:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-4: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-5: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-2.3:5 chip-ID: 0c76:1620
class-ID: 0300
Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: no
vendor: ASUSTeK driver: r8169 v: kernel port: e000 bus-ID: 02:00.0
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus-ID: 03:00.0
chip-ID: 8086:2723 class-ID: 0280
IF: wlp3s0 state: down mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8
bus-ID: 3-4:3 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 5.89 TiB used: 1.61 TiB (27.3%)
ID-1: /dev/nvme0n1 vendor: SK Hynix model: HFM512GD3JX013N
size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
rev: 41000C20 temp: 30.9 C scheme: GPT
ID-2: /dev/sda type: USB vendor: Western Digital
model: WDS480G2G0A-00JH30 size: 447.14 GiB type: SSD serial: <filter>
scheme: GPT
ID-3: /dev/sdb type: USB vendor: Western Digital
model: WDS480G2G0A-00JH30 size: 447.13 GiB type: SSD serial: <filter>
scheme: GPT
ID-4: /dev/sdc type: USB vendor: Western Digital
model: WD My Passport 2627 size: 3.64 TiB type: N/A serial: <filter>
rev: 4008 scheme: GPT
ID-5: /dev/sdd type: USB vendor: Lenovo model: USB Hard Drive
size: 931.51 GiB type: N/A serial: <filter> rev: 3U scheme: GPT
ID-1: / size: 422.37 GiB used: 79.25 GiB (18.8%) fs: ext4 dev: /dev/sdb2
label: N/A uuid: 581c79c3-b5ca-4ee2-9d67-c226c64d502f
ID-2: /boot/efi size: 299.4 MiB used: 288 KiB (0.1%) fs: vfat
dev: /dev/sdb1 label: NO_LABEL uuid: 75B0-09E2
ID-3: /media/aurora/fastlinuxmedia size: 48.61 GiB
used: 42.47 GiB (87.4%) fs: ext4 dev: /dev/sda2 label: linuxdata
uuid: 3d658ccb-7e50-40f4-82dc-e0c74b3a2143
ID-4: /media/aurora/fastmedia size: 397.24 GiB used: 270.85 GiB (68.2%)
fs: ntfs dev: /dev/sda1 label: fastDATA_1 uuid: 42D6C57FD6C57427
ID-5: /media/aurora/media size: 2.66 TiB used: 1.22 TiB (45.8%) fs: ntfs
dev: /dev/sdc1 label: Data4TB uuid: 3CBAA0BDBAA07554
ID-6: /media/aurora/slowlinuxmedia size: 47.06 GiB used: 4.95 GiB (10.5%)
fs: ext4 dev: /dev/sdc2 label: slowDatalinux
uuid: a7749fa2-dbf5-4cdd-bfa3-6c32a947f6f3
ID-1: swap-1 type: partition size: 16.64 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb3 label: N/A
uuid: ae036e38-c2e4-4d71-ac66-4cfc9e1b4d52
ID-1: /dev/nvme0n1p1 size: 260 MiB fs: vfat label: SYSTEM uuid: C839-BD33
ID-2: /dev/nvme0n1p2 size: 16 MiB fs: <superuser required> label: N/A
uuid: N/A
ID-3: /dev/nvme0n1p3 size: 456.24 GiB fs: ntfs label: OS
uuid: 48103B67103B5B60
ID-4: /dev/nvme0n1p4 size: 750 MiB fs: ntfs label: RECOVERY
uuid: FCE20CA0E20C616E
ID-5: /dev/nvme0n1p5 size: 19.5 GiB fs: ntfs label: RESTORE
uuid: C8D2C855D2C84A00
ID-6: /dev/nvme0n1p6 size: 200 MiB fs: vfat label: MYASUS uuid: F0C8-80F8
ID-7: /dev/sdd1 size: 931.51 GiB fs: ext4 label: N/A
uuid: f8be4f07-2be3-446f-be1d-0ba2be4b50f8
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 1-2:2 info: VIA Labs VL813 Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2813 class-ID: 0900
Device-1: 1-2.2:4 info: Motorola PCS Moto G (5) Plus
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s
power: 500mA chip-ID: 22b8:2e81 class-ID: 0000 serial: <filter>
Device-2: 1-2.3:5 info: JMTek LLC. USB PnP Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0c76:1620 class-ID: 0300
Device-3: 1-3:3 info: ASUSTek N-KEY Device type: Keyboard
driver: asus,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 0b05:1866 class-ID: 0301
Hub-3: 2-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Device-1: 2-1:2 info: Western Digital My Passport 2627 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 896mA
chip-ID: 1058:2627 class-ID: 0806 serial: <filter>
Hub-4: 2-2:3 info: VIA Labs VL813 Hub ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 2109:0813 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-6: 3-1:2 info: Genesys Logic Hub ports: 4 rev: 2.1 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-7: 3-1.2:4 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 3-1.2.1:5 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 3-1.2.2:6 info: SINO WEALTH Gaming KB type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s
power: 500mA chip-ID: 258a:002a class-ID: 0300
Device-3: 3-4:3 info: Intel AX200 Bluetooth type: Bluetooth driver: btusb
class-ID: e001
Hub-8: 4-0:1 info: Super-speed hub ports: 2 rev: 3.1 speed: 10 Gb/s
Hub-9: 4-1:2 info: Genesys Logic Hub ports: 4 rev: 3.1 speed: 5 Gb/s
chip-ID: 05e3:0612 class-ID: 0900
Device-1: 4-1.1:3 info: Lenovo Portable HDD type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s power: 8mA
chip-ID: 17ef:455a class-ID: 0806 serial: <filter>
Device-2: 4-1.3:4 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E SATA
6Gb/s bridge ASM1153 SATA 3Gb/s bridge ASM1153E SATA 6Gb/s bridge
type: Mass Storage driver: uas interfaces: 1 rev: 3.0 speed: 5 Gb/s
chip-ID: 174c:55aa class-ID: 0806 serial: <filter>
Device-3: 4-1.4:5 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E SATA
System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
GPU: device: nvidia screen: :0.0 temp: 39 C device: amdgpu temp: 45.0 C
Processes: 377 Uptime: 1h 37m wakeups: 9 Init: systemd v: 250 Compilers:
gcc: 11.1.0 alt: 10 clang: 13.0.0 Packages: 1813 pacman: 1807 flatpak: 6
Shell: Zsh v: 5.8 running-in: konsole inxi: 3.3.12
