For a few weeks now, I have not been able to open external links from within Electron applications, such as Teams for Linux or Prospect Mail.
I tried the solution suggested here, but had no luck. Namely:
teams-for-linux >/dev/null 2>/dev/null
doesn’t solve the problem; -
xdg-settings
is not installed (command not found...
); when I try to installxdg-utils
, I get a message saying thatxdg-utils
andxdg-utils-handlr
are in conflict. Should I replace the latter with the former? -
xdg-open forum.manjaro.org
yields the error message/usr/bin/xdg-open: line 2: handlr: command not found
While explicit links can be copied and pasted in the browser, embedded links cannot, which sometimes makes my life very difficult.
Any help would be greatly appreciated.
Output of `inxi -Fazy`
Kernel: 6.2.8-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/vmlinuz-6.2-x86_64
root=UUID=ca0b13f1-3220-4bc9-9dc7-77d2311111e0 rw rootflags=subvol=@ quiet
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 info: latte-dock
wm: kwin_x11 vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 4180Q3U v: ThinkPad T420
Mobo: LENOVO model: 4180Q3U serial: <superuser required>
UEFI-[Legacy]: LENOVO v: 83ET82WW (1.52 ) date: 06/04/2018
ID-1: BAT0 charge: 18.4 Wh (27.7%) condition: 66.5/57.7 Wh (115.2%)
volts: 10.5 min: 11.1 model: SANYO 45N1023 type: Li-ion serial: <filter>
status: charging
Info: model: Intel Core i7-2640M bits: 64 type: MT MCP arch: Sandy Bridge
gen: core 2 level: v2 built: 2010-12 process: Intel 32nm family: 6
model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1148 high: 1618 min/max: 800/3500 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 930 2: 958 3: 1086
4: 1618 bogomips: 22337
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
Type: itlb_multihit status: KVM: VMX unsupported
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Lenovo ThinkPad T420 driver: i915 v: kernel arch: Gen-6
code: Sandybridge process: Intel 32nm built: 2011 ports:
active: DP-1,LVDS-1 empty: DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0126 class-ID: 0300
Device-2: Chicony integrated camera type: USB driver: uvcvideo
bus-ID: 1-1.6:5 chip-ID: 04f2:b221 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: crocus gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1980 s-dpi: 96 s-size: 506x522mm (19.92x20.55")
s-diag: 727mm (28.62")
Monitor-1: DP-1 pos: top-left model: BenQ GW2780 serial: <filter>
built: 2021 res: 1920x1080 hz: 60 dpi: 82 gamma: 1.2
size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
Monitor-2: LVDS-1 pos: primary,bottom-r model: LG Display 0x02e2
built: 2010 res: 1600x900 hz: 60 dpi: 131 gamma: 1.2
size: 310x174mm (12.2x6.85") diag: 355mm (14") ratio: 16:9 modes: 1600x900
API: OpenGL v: 3.3 Mesa 23.0.1 renderer: Mesa Intel HD Graphics 3000 (SNB
GT2) direct-render: Yes
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1c20 class-ID: 0403
API: ALSA v: k6.2.8-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-3: PipeWire v: 0.3.67 status: off with: pipewire-media-session
status: active tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-jack
type: module tools: pacat,pactl,pulsemixer
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo ThinkPad T520
driver: e1000e v: kernel port: 5080 bus-ID: 00:19.0 chip-ID: 8086:1502
class-ID: 0200
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 8086:0085 class-ID: 0280
IF-ID-1: wwp0s29u1u4i6 state: down mac: <filter>
Device-1: Broadcom BCM2045B (BDC-2.1) type: USB driver: btusb v: 0.8
bus-ID: 1-1.4:4 chip-ID: 0a5c:217f class-ID: fe01 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 4 state: up address: see --recommends
Local Storage: total: 1.36 TiB used: 1.02 TiB (74.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 500GB
type: SSD serial: <filter> rev: 3B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HTS541010A9E680
type: HDD rpm: 5400 serial: <filter> rev: A7G0 scheme: MBR
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 24.23 GiB (24.2%)
fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot raw-size: 512 MiB size: 511 MiB (99.80%)
used: 188.9 MiB (37.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 365.26 GiB size: 365.26 GiB (100.00%)
used: 307.79 GiB (84.3%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
used: 24.23 GiB (24.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 63.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3512
Processes: 335 Uptime: 2h 28m wakeups: 2 Memory: 15.41 GiB
used: 7.28 GiB (47.2%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 2557 libs: 462 tools: pamac,paru pm: flatpak pkgs: 0 Shell: Zsh v: 5.9
running-in: konsole inxi: 3.3.26
