Hi all,
first time I post here.
I am on Manjaro Gnome, the system is up to date as of 2021-04-21.
Since I first installed the OS I noticed that the system does not allow me to perform a GUI log in (the interface is frozen) until a wifi connection has been established. The same occurs even when the systems wakes from sleep mode.
It’s nothing terrible, but it is annoying, since the process can take 10-20 seconds, depending on the considered wifi.
The issue occurs of course only if a know wifi is detected: when a visit a new location an no wifi is known, I can login much faster.
It sounds like something that should be configurable, but I haven’t found hints about where to look, even after extensive Googling.
Thanks in advance,
Michele
