I recently updated my system to AM5/X670e and I am unable to setup KVM passthrough.
I have been trying every possible guide/tutorial/advice out there, and NOTHING works.
I am ending up without desktop, or black desktop.
When my dGPU uses the vfio_pci driver, I don’t have desktop, and when I have, it uses amdgpu.
This is not my first VM, I have been using them with/without passthrough since 2015 but this is the first time I am trying for over a week and keep hitting a wall.
I will provide as much information as I can below…
- I am enabling in BIOS IOMMU and SVM (IOMMU in two places)
- I am setting my iGPU as Initial and Forced (in two places)
- I found my dGPU IDs (1002:73bf,1002:ab28,1002:73a6,1002:73a4 vga,hdmi sound, USB-C, serial)
- Adding IDs to command line along with other parameters (been tried many, from none to all at times)
GRUB_CMDLINE_LINUX_DEFAULT="quiet amd_iommu=force_enable iommu=pt rd.driver.pre=vfio-pci vfio-pci.ids=1002:73bf,1002:ab28,1002:73a6,1002:73a4 kvm.ignore_msrs=1 splash apparmor=1 security=apparmor udev.log_priority=3"
- sudo update-grub (no errors)
After rebooting, Manjaro loads on my dGPU screen and my iGPU screen is black, and going to sleep/no-signal soon after. I am typing my password blindly, and then plasma desktop loads.
Previously the behaviour was different and as soon as I added the IDs in Kernel parameters, my dGPU was not present.
Going some steps further, and:
6. Editing /etc/mkinitcpio.conf
MODULES="vfio vfio_iommu_type1 vfio_pci irqbypass kvm kvm_amd xhci_hcd"
- mkinitcpio -P and reboot
Now, the process stops here:
If I hit ctrl+alt+F2, I am able to login, but if I try to run startx I am getting this error:
When I run “lspci -nnv” I am getting this:
So the dVGA is using vfio-pci driver and little later this:
so my iGPU is using the amdgpu driver.
However it doesn’t work…
- Editing /etc/mkinitcpio.conf again, and removing “vfio_pci”
Now I have the same behavior, black screen, login screen on my dGPU, I blindly type my password, and then plasma desktop loads, but dGPU is using amdgpu driver.
Can somebody please help here…?
inxi -F
Host: wizzy-am5-manjaro Kernel: 6.2.12-1-MANJARO arch: x86_64 bits: 64
Desktop: KDE Plasma v: 5.27.4 Distro: Manjaro Linux
Type: Desktop System: Gigabyte product: X670E AORUS MASTER v: -CF
serial: <superuser required>
Mobo: Gigabyte model: X670E AORUS MASTER v: x.x
serial: <superuser required> UEFI: American Megatrends LLC. v: F10a
date: 03/22/2023
Info: 16-core model: AMD Ryzen 9 7950X3D bits: 64 type: MT MCP cache:
L2: 16 MiB
Speed (MHz): avg: 3240 min/max: 3000/5759 cores: 1: 3000 2: 4200 3: 3000
4: 3000 5: 3000 6: 3000 7: 3000 8: 3600 9: 2880 10: 3000 11: 3000 12: 3000
13: 3000 14: 3000 15: 3000 16: 3000 17: 4200 18: 3000 19: 3000 20: 3000
21: 3000 22: 3000 23: 3000 24: 4200 25: 3000 26: 3000 27: 3000 28: 4200
29: 4200 30: 3000 31: 4200 32: 3000
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] driver: amdgpu
v: kernel
Device-2: AMD Raphael driver: amdgpu v: kernel
Device-3: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo
Display: x11 server: X.Org v: 21.1.8 driver: X: loaded: amdgpu
unloaded: modesetting,radeon dri: radeonsi gpu: amdgpu resolution: 1: N/A
2: 1200x1920~60Hz 3: 2560x1440~60Hz
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: AMD Radeon RX 6900 XT (navi21
LLVM 15.0.7 DRM 3.49 6.2.12-1-MANJARO)
Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel
Device-2: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel
Device-4: Logitech HD Pro Webcam C920 type: USB
Device-5: Creative Sound Blaster X5 type: USB
driver: cdc_acm,hid-generic,snd-usb-audio,usbhid
API: ALSA v: k6.2.12-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 16.1 status: active
driver: r8169
IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac: ac:15:a2:60:d2:5e
Device-2: Intel Ethernet I225-V driver: igc
IF: enp15s0 state: up speed: 1000 Mbps duplex: full mac: 74:56:3c:4b:74:7e
Device-3: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi
IF: wlp16s0 state: down mac: ae:15:d2:17:95:f6
Device-1: Intel AX210 Bluetooth type: USB driver: btusb
Local Storage: total: 7.34 TiB used: 1.11 TiB (15.1%)
ID-1: /dev/nvme0n1 vendor: Seagate model: XPG GAMMIX S50 Lite
ID-2: /dev/nvme1n1 vendor: Kingston model: SKC3000D2048G size: 1.86 TiB
ID-3: /dev/nvme2n1 vendor: Samsung model: SSD 970 EVO 500GB
ID-4: /dev/sda vendor: Toshiba model: HDWE140 size: 3.64 TiB
ID-5: /dev/sdb vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
ID-1: / size: 390.01 GiB used: 20.71 GiB (5.3%) fs: ext4 dev: /dev/nvme2n1p2
ID-2: /boot/efi size: 299.4 MiB used: 316 KiB (0.1%) fs: vfat
dev: /dev/nvme2n1p1
ID-1: swap-1 type: partition size: 68.15 GiB used: 0 KiB (0.0%)
dev: /dev/nvme2n1p3
System Temperatures: cpu: 45.2 C mobo: N/A
GPU: device: amdgpu temp: 39.0 C device: amdgpu temp: 35.0 C fan: 0
Processes: 561 Uptime: 34m Memory: 61.95 GiB used: 38.45 GiB (62.1%)
Shell: Zsh inxi: 3.3.26
dmesg
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x020: 'AVX-512 opmask'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x040: 'AVX-512 Hi256'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x080: 'AVX-512 ZMM_Hi256'
[ 0.000000] x86/fpu: Supporting XSAVE feature 0x200: 'Protection Keys User registers'
[ 0.000000] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.000000] x86/fpu: xstate_offset[5]: 832, xstate_sizes[5]: 64
[ 0.000000] x86/fpu: xstate_offset[6]: 896, xstate_sizes[6]: 512
[ 0.000000] x86/fpu: xstate_offset[7]: 1408, xstate_sizes[7]: 1024
[ 0.000000] x86/fpu: xstate_offset[9]: 2432, xstate_sizes[9]: 8
[ 0.000000] x86/fpu: Enabled xstate features 0x2e7, context size is 2440 bytes, using 'compacted' format.
[ 0.000000] signal: max sigframe size: 3376
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000009afefff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000009aff000-0x0000000009ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000a000000-0x000000000a1fffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000a200000-0x000000000a20ffff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000000a210000-0x000000000affffff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000b000000-0x000000000b020fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000000b021000-0x000000006fcccfff] usable
[ 0.000000] BIOS-e820: [mem 0x000000006fccd000-0x0000000075cccfff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000075ccd000-0x0000000075dccfff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x0000000075dcd000-0x0000000077dccfff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x0000000077dcd000-0x000000007a07efff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007a07f000-0x000000007a1fefff] type 20
[ 0.000000] BIOS-e820: [mem 0x000000007a1ff000-0x000000007bffafff] usable
[ 0.000000] BIOS-e820: [mem 0x000000007bffb000-0x000000007cffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000007d7f3000-0x000000007fffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000f0000000-0x00000000f7ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fd000000-0x00000000ffffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000100000000-0x0000000ff7ffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000ff8000000-0x0000001077ffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000107eec0000-0x00000010a01fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000fd00000000-0x000000ffffffffff] reserved
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] efi: EFI v2.80 by American Megatrends
[ 0.000000] efi: ACPI=0x77db5000 ACPI 2.0=0x77db5014 SMBIOS=0x796ec000 SMBIOS 3.0=0x796eb000 MEMATTR=0x6af2a698 ESRT=0
x6e50c118
[ 0.000000] SMBIOS 3.5.0 present.
[ 0.000000] DMI: Gigabyte Technology Co., Ltd. X670E AORUS MASTER/X670E AORUS MASTER, BIOS F10a 03/22/2023
[ 0.000000] tsc: Fast TSC calibration using PIT
[ 0.000000] tsc: Detected 4200.055 MHz processor
[ 0.000118] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000120] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000124] last_pfn = 0xff8000 max_arch_pfn = 0x400000000
[ 0.000909] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.001083] last_pfn = 0x7bffb max_arch_pfn = 0x400000000
[ 0.003478] esrt: Reserving ESRT space from 0x000000006e50c118 to 0x000000006e50c1a0.
[ 0.003485] e820: update [mem 0x6e50c000-0x6e50cfff] usable ==> reserved
[ 0.003504] Using GB pages for direct mapping
[ 0.003725] Secure boot disabled
[ 0.003725] RAMDISK: [mem 0x361fd000-0x370f5fff]
[ 0.003729] ACPI: Early table checksum verification disabled
[ 0.003732] ACPI: RSDP 0x0000000077DB5014 000024 (v02 ALASKA)
[ 0.003734] ACPI: XSDT 0x0000000077DB4728 000114 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.003737] ACPI: FACP 0x0000000075DB9000 000114 (v06 ALASKA A M I 01072009 AMI 00010013)
[ 0.003740] ACPI: DSDT 0x0000000075D43000 02FFEA (v02 ALASKA A M I 01072009 INTL 20200717)
[ 0.003742] ACPI: FACS 0x0000000077DB1000 000040
[ 0.003743] ACPI: SSDT 0x0000000075DC3000 009F10 (v02 GBT GSWApp 00000001 INTL 20200717)
[ 0.003744] ACPI: SSDT 0x0000000075DBB000 007B85 (v02 AMD Splinter 00000002 MSFT 05000000)
[ 0.003745] ACPI: SSDT 0x0000000075DBA000 0003F1 (v02 ALASKA CPUSSDT 01072009 AMI 01072009)
[ 0.003746] ACPI: FIDT 0x0000000075DB1000 00009C (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.003747] ACPI: MCFG 0x0000000075DB0000 00003C (v01 ALASKA A M I 01072009 MSFT 00010013)
[ 0.003748] ACPI: HPET 0x0000000075DAF000 000038 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.003749] ACPI: WDRT 0x0000000075DAE000 000047 (v01 ALASKA A M I 01072009 AMI 00000005)
[ 0.003751] ACPI: FPDT 0x0000000075DAD000 000044 (v01 ALASKA A M I 01072009 AMI 01000013)
[ 0.003752] ACPI: VFCT 0x0000000075D97000 015AA0 (v01 ALASKA A M I 00000001 AMD 31504F47)
[ 0.003753] ACPI: BGRT 0x0000000075D96000 000038 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.003754] ACPI: SSDT 0x0000000075D8C000 009BAE (v02 AMD AmdTable 00000001 AMD 00000001)
[ 0.003755] ACPI: CRAT 0x0000000075D8A000 001D28 (v01 AMD AmdTable 00000001 AMD 00000001)
[ 0.003756] ACPI: CDIT 0x0000000075D89000 000029 (v01 AMD AmdTable 00000001 AMD 00000001)
[ 0.003757] ACPI: SSDT 0x0000000075D87000 0015B0 (v02 AMD CPMDFIG2 00000001 INTL 20200717)
[ 0.003758] ACPI: SSDT 0x0000000075D84000 0029D4 (v02 AMD CDFAAIG2 00000001 INTL 20200717)
[ 0.003759] ACPI: SSDT 0x0000000075D83000 00089A (v02 AMD CPMDFDG2 00000001 INTL 20200717)
[ 0.003760] ACPI: SSDT 0x0000000075D7A000 008EB0 (v02 AMD CPMCMN 00000001 INTL 20200717)
[ 0.003762] ACPI: SSDT 0x0000000075D77000 0022DE (v02 AMD AOD 00000001 INTL 20200717)
[ 0.003763] ACPI: WSMT 0x0000000075D76000 000028 (v01 ALASKA A M I 01072009 AMI 00010013)
[ 0.003764] ACPI: APIC 0x0000000075D75000 00015E (v05 ALASKA A M I 01072009 AMI 00010013)
[ 0.003765] ACPI: SSDT 0x0000000075D74000 000575 (v02 AMD EXTGPP00 00000001 INTL 20200717)
[ 0.003766] ACPI: SSDT 0x0000000075D73000 000698 (v02 AMD USB 00000001 INTL 20200717)
[ 0.003767] ACPI: IVRS 0x0000000075DB8000 0000D0 (v02 AMD AmdTable 00000001 AMD 00000001)
[ 0.003768] ACPI: SSDT 0x0000000075DB7000 0004E0 (v02 AMD MEMTOOL0 00000002 INTL 20200717)
[ 0.003769] ACPI: SSDT 0x0000000075DB6000 00090B (v02 AMD CPMMSOSC 00000001 INTL 20200717)
[ 0.003770] ACPI: SSDT 0x0000000075DB5000 00045C (v02 AMD AMDWOV 00000001 INTL 20200717)
[ 0.003771] ACPI: SSDT 0x0000000075DB3000 001266 (v02 AMD CPMACPV4 00000001 INTL 20200717)
[ 0.003772] ACPI: SSDT 0x0000000075DB2000 000085 (v02 AMD AmdTable 00000001 INTL 20200717)
[ 0.003774] ACPI: SSDT 0x0000000075D42000 0000D8 (v02 AMD AmdTable 00000001 INTL 20200717)
[ 0.003774] ACPI: Reserving FACP table memory at [mem 0x75db9000-0x75db9113]
[ 0.003775] ACPI: Reserving DSDT table memory at [mem 0x75d43000-0x75d72fe9]
[ 0.003775] ACPI: Reserving FACS table memory at [mem 0x77db1000-0x77db103f]
[ 0.003776] ACPI: Reserving SSDT table memory at [mem 0x75dc3000-0x75dccf0f]
[ 0.003776] ACPI: Reserving SSDT table memory at [mem 0x75dbb000-0x75dc2b84]
[ 0.003776] ACPI: Reserving SSDT table memory at [mem 0x75dba000-0x75dba3f0]
[ 0.003776] ACPI: Reserving FIDT table memory at [mem 0x75db1000-0x75db109b]
[ 0.003777] ACPI: Reserving MCFG table memory at [mem 0x75db0000-0x75db003b]
[ 0.003777] ACPI: Reserving HPET table memory at [mem 0x75daf000-0x75daf037]
[ 0.003777] ACPI: Reserving WDRT table memory at [mem 0x75dae000-0x75dae046]
[ 0.003778] ACPI: Reserving FPDT table memory at [mem 0x75dad000-0x75dad043]
[ 0.003778] ACPI: Reserving VFCT table memory at [mem 0x75d97000-0x75daca9f]
[ 0.003778] ACPI: Reserving BGRT table memory at [mem 0x75d96000-0x75d96037]
[ 0.003778] ACPI: Reserving SSDT table memory at [mem 0x75d8c000-0x75d95bad]
[ 0.003779] ACPI: Reserving CRAT table memory at [mem 0x75d8a000-0x75d8bd27]
[ 0.003779] ACPI: Reserving CDIT table memory at [mem 0x75d89000-0x75d89028]
[ 0.003779] ACPI: Reserving SSDT table memory at [mem 0x75d87000-0x75d885af]
[ 0.003780] ACPI: Reserving SSDT table memory at [mem 0x75d84000-0x75d869d3]
[ 0.003780] ACPI: Reserving SSDT table memory at [mem 0x75d83000-0x75d83899]
[ 0.003780] ACPI: Reserving SSDT table memory at [mem 0x75d7a000-0x75d82eaf]
[ 0.003781] ACPI: Reserving SSDT table memory at [mem 0x75d77000-0x75d792dd]
[ 0.003781] ACPI: Reserving WSMT table memory at [mem 0x75d76000-0x75d76027]
[ 0.003781] ACPI: Reserving APIC table memory at [mem 0x75d75000-0x75d7515d]
[ 0.003781] ACPI: Reserving SSDT table memory at [mem 0x75d74000-0x75d74574]
[ 0.003782] ACPI: Reserving SSDT table memory at [mem 0x75d73000-0x75d73697]
[ 0.003782] ACPI: Reserving IVRS table memory at [mem 0x75db8000-0x75db80cf]
[ 0.003782] ACPI: Reserving SSDT table memory at [mem 0x75db7000-0x75db74df]
[ 0.003783] ACPI: Reserving SSDT table memory at [mem 0x75db6000-0x75db690a]
[ 0.003783] ACPI: Reserving SSDT table memory at [mem 0x75db5000-0x75db545b]
[ 0.003783] ACPI: Reserving SSDT table memory at [mem 0x75db3000-0x75db4265]
[ 0.003784] ACPI: Reserving SSDT table memory at [mem 0x75db2000-0x75db2084]
[ 0.003784] ACPI: Reserving SSDT table memory at [mem 0x75d42000-0x75d420d7]
[ 0.003827] No NUMA configuration found
[ 0.003828] Faking a node at [mem 0x0000000000000000-0x0000000ff7ffffff]
[ 0.003830] NODE_DATA(0) allocated [mem 0xff7ffb000-0xff7ffffff]
[ 0.003867] Zone ranges:
[ 0.003868] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.003868] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.003869] Normal [mem 0x0000000100000000-0x0000000ff7ffffff]
[ 0.003870] Device empty
[ 0.003870] Movable zone start for each node
[ 0.003870] Early memory node ranges
[ 0.003871] node 0: [mem 0x0000000000001000-0x000000000009ffff]
[ 0.003871] node 0: [mem 0x0000000000100000-0x0000000009afefff]
[ 0.003872] node 0: [mem 0x000000000a000000-0x000000000a1fffff]
[ 0.003872] node 0: [mem 0x000000000a210000-0x000000000affffff]
[ 0.003872] node 0: [mem 0x000000000b021000-0x000000006fcccfff]
[ 0.003873] node 0: [mem 0x000000007a1ff000-0x000000007bffafff]
[ 0.003873] node 0: [mem 0x0000000100000000-0x0000000ff7ffffff]
[ 0.003876] Initmem setup node 0 [mem 0x0000000000001000-0x0000000ff7ffffff]
[ 0.003879] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.003888] On node 0, zone DMA: 96 pages in unavailable ranges
[ 0.003962] On node 0, zone DMA32: 1281 pages in unavailable ranges
[ 0.003970] On node 0, zone DMA32: 16 pages in unavailable ranges
[ 0.004766] On node 0, zone DMA32: 33 pages in unavailable ranges
[ 0.004818] On node 0, zone DMA32: 9522 pages in unavailable ranges
[ 0.043117] On node 0, zone Normal: 16389 pages in unavailable ranges
[ 0.043869] ACPI: PM-Timer IO Port: 0x808
[ 0.043876] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[ 0.043887] IOAPIC[0]: apic_id 32, version 33, address 0xfec00000, GSI 0-23
[ 0.043890] IOAPIC[1]: apic_id 33, version 33, address 0xfec01000, GSI 24-55
[ 0.043892] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.043893] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.043895] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.043896] ACPI: HPET id: 0x10228201 base: 0xfed00000
[ 0.043904] e820: update [mem 0x6b73a000-0x6b790fff] usable ==> reserved
[ 0.043912] smpboot: Allowing 32 CPUs, 0 hotplug CPUs
[ 0.043925] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.043926] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[ 0.043927] PM: hibernation: Registered nosave memory: [mem 0x09aff000-0x09ffffff]
[ 0.043928] PM: hibernation: Registered nosave memory: [mem 0x0a200000-0x0a20ffff]
[ 0.043928] PM: hibernation: Registered nosave memory: [mem 0x0b000000-0x0b020fff]
[ 0.043929] PM: hibernation: Registered nosave memory: [mem 0x6b73a000-0x6b790fff]
[ 0.043930] PM: hibernation: Registered nosave memory: [mem 0x6e50c000-0x6e50cfff]
[ 0.043931] PM: hibernation: Registered nosave memory: [mem 0x6fccd000-0x75cccfff]
[ 0.043931] PM: hibernation: Registered nosave memory: [mem 0x75ccd000-0x75dccfff]
[ 0.043931] PM: hibernation: Registered nosave memory: [mem 0x75dcd000-0x77dccfff]
[ 0.043932] PM: hibernation: Registered nosave memory: [mem 0x77dcd000-0x7a07efff]
[ 0.043932] PM: hibernation: Registered nosave memory: [mem 0x7a07f000-0x7a1fefff]
[ 0.043933] PM: hibernation: Registered nosave memory: [mem 0x7bffb000-0x7cffffff]
[ 0.043933] PM: hibernation: Registered nosave memory: [mem 0x7d000000-0x7d7f2fff]
[ 0.043933] PM: hibernation: Registered nosave memory: [mem 0x7d7f3000-0x7fffffff]
[ 0.043933] PM: hibernation: Registered nosave memory: [mem 0x80000000-0xefffffff]
[ 0.043934] PM: hibernation: Registered nosave memory: [mem 0xf0000000-0xf7ffffff]
[ 0.043934] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfcffffff]
[ 0.043934] PM: hibernation: Registered nosave memory: [mem 0xfd000000-0xffffffff]
[ 0.043935] [mem 0x80000000-0xefffffff] available for PCI devices
[ 0.043936] Booting paravirtualized kernel on bare hardware
[ 0.043937] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[ 0.046399] setup_percpu: NR_CPUS:320 nr_cpumask_bits:32 nr_cpu_ids:32 nr_node_ids:1
[ 0.046885] percpu: Embedded 63 pages/cpu s221184 r8192 d28672 u262144
[ 0.046889] pcpu-alloc: s221184 r8192 d28672 u262144 alloc=1*2097152
[ 0.046890] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[ 0.046893] pcpu-alloc: [0] 16 17 18 19 20 21 22 23 [0] 24 25 26 27 28 29 30 31
[ 0.046910] Fallback order for Node 0: 0
[ 0.046912] Built 1 zonelists, mobility grouping on. Total pages: 15907392
[ 0.046913] Policy zone: Normal
[ 0.046913] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=e3624de6-54ff-4ca9-b2da-fd258cd2f759 rw
quiet splash resume=UUID=70ee4e13-e50a-4dc8-9c7a-465e0f472998 udev.log_priority=3 amd_iommu=on iommu=pt hugepages=16384
video=vesafb:off,efifb:off vfio-pci.ids=1002:73bf,1002:ab28,1002:73a6,1002:73a4 systemd.unified_cgroup_hierarchy=1
[ 0.046961] AMD-Vi: Unknown option - 'on'
[ 0.046987] Unknown kernel command line parameters "splash BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64", will be passed to use
r space.
[ 0.047183] random: crng init done
[ 0.047184] printk: log_buf_len individual max cpu contribution: 4096 bytes
[ 0.047184] printk: log_buf_len total cpu_extra contributions: 126976 bytes
[ 0.047184] printk: log_buf_len min size: 131072 bytes
[ 0.047256] printk: log_buf_len: 262144 bytes
[ 0.047256] printk: early log buf free: 116160(88%)
[ 0.048145] Dentry cache hash table entries: 8388608 (order: 14, 67108864 bytes, linear)
[ 0.048589] Inode-cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.048731] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.048764] software IO TLB: area num 32.
[ 0.105459] Memory: 63280900K/64640216K available (16391K kernel code, 2157K rwdata, 11144K rodata, 2152K init, 5312K
bss, 1359056K reserved, 0K cma-reserved)
[ 0.105526] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=32, Nodes=1
[ 0.105533] ftrace: allocating 46623 entries in 183 pages
[ 0.111624] ftrace: allocated 183 pages with 6 groups
[ 0.111673] Dynamic Preempt: full
[ 0.111703] rcu: Preemptible hierarchical RCU implementation.
[ 0.111704] rcu: RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=32.
[ 0.111704] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.111705] Trampoline variant of Tasks RCU enabled.
[ 0.111705] Rude variant of Tasks RCU enabled.
[ 0.111705] Tracing variant of Tasks RCU enabled.
[ 0.111706] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[ 0.111706] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=32
[ 0.113620] NR_IRQS: 20736, nr_irqs: 1224, preallocated irqs: 16
[ 0.113778] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.113910] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[ 0.113928] Console: colour dummy device 80x25
[ 0.113938] printk: console [tty0] enabled
[ 0.113952] ACPI: Core revision 20220331
[ 0.114136] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[ 0.114148] APIC: Switch to symmetric I/O mode setup
[ 0.114676] AMD-Vi: Using global IVHD EFR:0x246577efa2254afa, EFR2:0x0
[ 0.114878] x2apic: IRQ remapping doesn't support X2APIC mode
[ 0.114881] Switched APIC routing to physical flat.
[ 0.115471] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.130820] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x3c8a953995d, max_idle_ns: 440795320529 ns
[ 0.130822] Calibrating delay loop (skipped), value calculated using timer frequency.. 8403.11 BogoMIPS (lpj=14000183)
[ 0.130823] pid_max: default: 32768 minimum: 301
[ 0.132372] LSM: Security Framework initializing
[ 0.132376] landlock: Up and running.
[ 0.132377] Yama: becoming mindful.
[ 0.132380] LSM support for eBPF active
[ 0.132430] Mount-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.132472] Mountpoint-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.132588] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.132625] LVT offset 1 assigned for vector 0xf9
[ 0.132751] LVT offset 2 assigned for vector 0xf4
[ 0.132787] process: using mwait in idle threads
[ 0.132788] Last level iTLB entries: 4KB 512, 2MB 512, 4MB 256
[ 0.132788] Last level dTLB entries: 4KB 3072, 2MB 3072, 4MB 1536, 1GB 0
[ 0.132790] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[ 0.132792] Spectre V2 : Mitigation: Retpolines
[ 0.132792] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.132793] Spectre V2 : Spectre v2 / SpectreRSB : Filling RSB on VMEXIT
[ 0.132793] Spectre V2 : Enabling Restricted Speculation for firmware calls
[ 0.132794] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.132794] Spectre V2 : User space: Mitigation: STIBP always-on protection
[ 0.132795] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.141703] Freeing SMP alternatives memory: 40K
[ 0.248542] smpboot: CPU0: AMD Ryzen 9 7950X3D 16-Core Processor (family: 0x19, model: 0x61, stepping: 0x2)
[ 0.248596] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.248598] cblist_init_generic: Setting shift to 5 and lim to 1.
[ 0.248604] cblist_init_generic: Setting shift to 5 and lim to 1.
[ 0.248611] cblist_init_generic: Setting shift to 5 and lim to 1.
[ 0.248615] Performance Events: Fam17h+ 16-deep LBR, core perfctr, AMD PMU driver.
[ 0.248625] ... version: 2
[ 0.248626] ... bit width: 48
[ 0.248626] ... generic registers: 6
[ 0.248626] ... value mask: 0000ffffffffffff
[ 0.248627] ... max period: 00007fffffffffff
[ 0.248627] ... fixed-purpose events: 0
[ 0.248627] ... event mask: 000000000000003f
[ 0.248665] rcu: Hierarchical SRCU implementation.
[ 0.248665] rcu: Max phase no-delay instances is 1000.
[ 0.248862] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[ 0.248957] smp: Bringing up secondary CPUs ...
[ 0.248995] x86: Booting SMP configuration:
[ 0.248995] .... node #0, CPUs: #1 #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15 #16
[ 0.284206] Spectre V2 : Update user space SMT mitigation: STIBP always-on
[ 0.284221] #17 #18 #19 #20 #21 #22 #23 #24 #25 #26 #27 #28 #29 #30 #31
[ 0.317507] smp: Brought up 1 node, 32 CPUs
[ 0.317507] smpboot: Max logical packages: 1
[ 0.317507] smpboot: Total of 32 processors activated (268911.66 BogoMIPS)
[ 0.319150] devtmpfs: initialized
[ 0.319150] x86/mm: Memory block size: 128MB
[ 0.322121] ACPI: PM: Registering ACPI NVS region [mem 0x0a200000-0x0a20ffff] (65536 bytes)
[ 0.322121] ACPI: PM: Registering ACPI NVS region [mem 0x75dcd000-0x77dccfff] (33554432 bytes)
[ 0.322121] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[ 0.322121] futex hash table entries: 8192 (order: 7, 524288 bytes, linear)
[ 0.322121] pinctrl core: initialized pinctrl subsystem
[ 0.322121] PM: RTC time: 13:51:41, date: 2023-04-21
[ 0.322121] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.322121] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.322121] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.322121] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.322121] audit: initializing netlink subsys (disabled)
[ 0.322121] audit: type=2000 audit(1682085100.206:1): state=initialized audit_enabled=0 res=1
[ 0.322121] thermal_sys: Registered thermal governor 'fair_share'
[ 0.322121] thermal_sys: Registered thermal governor 'bang_bang'
[ 0.322121] thermal_sys: Registered thermal governor 'step_wise'
[ 0.322121] thermal_sys: Registered thermal governor 'user_space'
[ 0.322121] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.322121] cpuidle: using governor ladder
[ 0.322121] cpuidle: using governor menu
[ 0.322121] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.322121] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[ 0.322121] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
[ 0.322121] PCI: Using configuration type 1 for base access
[ 0.322121] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 1.586381] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 1.586384] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 1.586384] HugeTLB: registered 2.00 MiB page size, pre-allocated 16384 pages
[ 1.586385] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 1.587565] ACPI: Added _OSI(Module Device)
[ 1.587566] ACPI: Added _OSI(Processor Device)
[ 1.587567] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 1.587567] ACPI: Added _OSI(Processor Aggregator Device)
[ 1.588696] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP7._PRW], AE_ALREADY_EXISTS (20220331/ds
wload2-326)
[ 1.588699] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20220331/psobject-220)
[ 1.597571] ACPI BIOS Error (bug): Failure creating named object [\_SB.PCI0.GPP2._PRW], AE_ALREADY_EXISTS (20220331/ds
wload2-326)
[ 1.597573] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20220331/psobject-220)
[ 1.597576] ACPI BIOS Error (bug): Failure creating named object [\_GPE._L08], AE_ALREADY_EXISTS (20220331/dswload2-32
6)
[ 1.597577] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20220331/psobject-220)
[ 1.597578] ACPI: Skipping parse of AML opcode: Method (0x0014)
[ 1.598146] ACPI: 18 ACPI AML tables successfully acquired and loaded
[ 1.599299] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[ 1.621798] ACPI: Interpreter enabled
[ 1.621798] ACPI: PM: (supports S0 S3 S4 S5)
[ 1.621798] ACPI: Using IOAPIC for interrupt routing
[ 1.621798] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 1.621798] PCI: Ignoring E820 reservations for host bridge windows
[ 1.621881] ACPI: Enabled 10 GPEs in block 00 to 1F
[ 1.622421] ACPI: PM: Power Resource [PWRS]
[ 1.622540] ACPI: PM: Power Resource [PWRS]
[ 1.622643] ACPI: PM: Power Resource [PWRS]
[ 1.622985] ACPI: PM: Power Resource [PWRS]
[ 1.623062] ACPI: PM: Power Resource [PWRS]
[ 1.623123] ACPI: PM: Power Resource [PWRS]
[ 1.624168] ACPI: PM: Power Resource [PWRS]
[ 1.624228] ACPI: PM: Power Resource [PWRS]
[ 1.624293] ACPI: PM: Power Resource [PWRS]
[ 1.624352] ACPI: PM: Power Resource [PWRS]
[ 1.624420] ACPI: PM: Power Resource [PWRS]
[ 1.624770] ACPI: PM: Power Resource [PWRS]
[ 1.624846] ACPI: PM: Power Resource [PWRS]
[ 1.625170] ACPI: PM: Power Resource [PWRS]
[ 1.625246] ACPI: PM: Power Resource [PWRS]
[ 1.625571] ACPI: PM: Power Resource [PWRS]
[ 1.625646] ACPI: PM: Power Resource [PWRS]
[ 1.625706] ACPI: PM: Power Resource [PWRS]
[ 1.625770] ACPI: PM: Power Resource [PWRS]
[ 1.625857] ACPI: PM: Power Resource [PWRS]
[ 1.625946] ACPI: PM: Power Resource [PWRS]
[ 1.626282] ACPI: PM: Power Resource [PWRS]
[ 1.626357] ACPI: PM: Power Resource [PWRS]
[ 1.626415] ACPI: PM: Power Resource [PWRS]
[ 1.626480] ACPI: PM: Power Resource [PWRS]
[ 1.626541] ACPI: PM: Power Resource [PWRS]
[ 1.626608] ACPI: PM: Power Resource [PWRS]
[ 1.626666] ACPI: PM: Power Resource [PWRS]
[ 1.626729] ACPI: PM: Power Resource [PWRS]
[ 1.626818] ACPI: PM: Power Resource [PWRS]
[ 1.626906] ACPI: PM: Power Resource [PWRS]
[ 1.626964] ACPI: PM: Power Resource [PWRS]
[ 1.627027] ACPI: PM: Power Resource [PWRS]
[ 1.627115] ACPI: PM: Power Resource [PWRS]
[ 1.627204] ACPI: PM: Power Resource [PWRS]
[ 1.627292] ACPI: PM: Power Resource [PWRS]
[ 1.627383] ACPI: PM: Power Resource [PWRS]
[ 1.627471] ACPI: PM: Power Resource [PWRS]
[ 1.627561] ACPI: PM: Power Resource [PWRS]
[ 1.627620] ACPI: PM: Power Resource [PWRS]
[ 1.627684] ACPI: PM: Power Resource [PWRS]
[ 1.627742] ACPI: PM: Power Resource [PWRS]
[ 1.627808] ACPI: PM: Power Resource [PWRS]
[ 1.627867] ACPI: PM: Power Resource [PWRS]
[ 1.627930] ACPI: PM: Power Resource [PWRS]
[ 1.628017] ACPI: PM: Power Resource [PWRS]
[ 1.628107] ACPI: PM: Power Resource [PWRS]
[ 1.628197] ACPI: PM: Power Resource [PWRS]
[ 1.628307] ACPI: PM: Power Resource [PWRS]
[ 1.628367] ACPI: PM: Power Resource [PWRS]
[ 1.628433] ACPI: PM: Power Resource [PWRS]
[ 1.628492] ACPI: PM: Power Resource [PWRS]
[ 1.628555] ACPI: PM: Power Resource [PWRS]
[ 1.628614] ACPI: PM: Power Resource [PWRS]
[ 1.628677] ACPI: PM: Power Resource [PWRS]
[ 1.628764] ACPI: PM: Power Resource [PWRS]
[ 1.630357] ACPI: PM: Power Resource [PWRS]
[ 1.630447] ACPI: PM: Power Resource [PWRS]
[ 1.630499] ACPI: PM: Power Resource [PWR1]
[ 1.632092] ACPI: PM: Power Resource [M237]
[ 1.632111] ACPI: PM: Power Resource [M237]
[ 1.632133] ACPI: PM: Power Resource [M237]
[ 1.633916] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 1.633920] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 1.633982] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR DPC]
[ 1.633989] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-7f] only partially covers this bridge
[ 1.634216] PCI host bridge to bus 0000:00
[ 1.634217] pci_bus 0000:00: root bus resource [io 0x0000-0x03af window]
[ 1.634218] pci_bus 0000:00: root bus resource [io 0x03e0-0x0cf7 window]
[ 1.634219] pci_bus 0000:00: root bus resource [io 0x03b0-0x03df window]
[ 1.634219] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 1.634219] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000dffff window]
[ 1.634220] pci_bus 0000:00: root bus resource [mem 0x80000000-0xfcffffff window]
[ 1.634220] pci_bus 0000:00: root bus resource [mem 0x1080000000-0xffffffffff window]
[ 1.634221] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.634230] pci 0000:00:00.0: [1022:14d8] type 00 class 0x060000
[ 1.634285] pci 0000:00:00.2: [1022:14d9] type 00 class 0x080600
[ 1.634336] pci 0000:00:01.0: [1022:14da] type 00 class 0x060000
[ 1.634371] pci 0000:00:01.1: [1022:14db] type 01 class 0x060400
[ 1.634430] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[ 1.634508] pci 0000:00:01.2: [1022:14db] type 01 class 0x060400
[ 1.634527] pci 0000:00:01.2: enabling Extended Tags
[ 1.634567] pci 0000:00:01.2: PME# supported from D0 D3hot D3cold
[ 1.634645] pci 0000:00:02.0: [1022:14da] type 00 class 0x060000
[ 1.634680] pci 0000:00:02.1: [1022:14db] type 01 class 0x060400
[ 1.634699] pci 0000:00:02.1: enabling Extended Tags
[ 1.634738] pci 0000:00:02.1: PME# supported from D0 D3hot D3cold
[ 1.634857] pci 0000:00:02.2: [1022:14db] type 01 class 0x060400
[ 1.634876] pci 0000:00:02.2: enabling Extended Tags
[ 1.634916] pci 0000:00:02.2: PME# supported from D0 D3hot D3cold
[ 1.634993] pci 0000:00:03.0: [1022:14da] type 00 class 0x060000
[ 1.635035] pci 0000:00:04.0: [1022:14da] type 00 class 0x060000
[ 1.635081] pci 0000:00:08.0: [1022:14da] type 00 class 0x060000
[ 1.635117] pci 0000:00:08.1: [1022:14dd] type 01 class 0x060400
[ 1.635132] pci 0000:00:08.1: enabling Extended Tags
[ 1.635153] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[ 1.635207] pci 0000:00:08.3: [1022:14dd] type 01 class 0x060400
[ 1.635221] pci 0000:00:08.3: enabling Extended Tags
[ 1.635242] pci 0000:00:08.3: PME# supported from D0 D3hot D3cold
[ 1.635304] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[ 1.635379] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[ 1.635463] pci 0000:00:18.0: [1022:14e0] type 00 class 0x060000
[ 1.635480] pci 0000:00:18.1: [1022:14e1] type 00 class 0x060000
[ 1.635496] pci 0000:00:18.2: [1022:14e2] type 00 class 0x060000
[ 1.635512] pci 0000:00:18.3: [1022:14e3] type 00 class 0x060000
[ 1.635529] pci 0000:00:18.4: [1022:14e4] type 00 class 0x060000
[ 1.635549] pci 0000:00:18.5: [1022:14e5] type 00 class 0x060000
[ 1.635566] pci 0000:00:18.6: [1022:14e6] type 00 class 0x060000
[ 1.635582] pci 0000:00:18.7: [1022:14e7] type 00 class 0x060000
[ 1.635645] pci 0000:01:00.0: [1002:1478] type 01 class 0x060400
[ 1.635655] pci 0000:01:00.0: reg 0x10: [mem 0xfcc00000-0xfcc03fff]
[ 1.635730] pci 0000:01:00.0: PME# supported from D0 D3hot D3cold
[ 1.635845] pci 0000:00:01.1: PCI bridge to [bus 01-03]
[ 1.635847] pci 0000:00:01.1: bridge window [io 0xf000-0xffff]
[ 1.635849] pci 0000:00:01.1: bridge window [mem 0xfc900000-0xfccfffff]
[ 1.635851] pci 0000:00:01.1: bridge window [mem 0xf800000000-0xfc0fffffff 64bit pref]
[ 1.635886] pci 0000:02:00.0: [1002:1479] type 01 class 0x060400
[ 1.635966] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 1.636212] pci 0000:01:00.0: PCI bridge to [bus 02-03]
[ 1.636216] pci 0000:01:00.0: bridge window [io 0xf000-0xffff]
[ 1.636218] pci 0000:01:00.0: bridge window [mem 0xfc900000-0xfcbfffff]
[ 1.636221] pci 0000:01:00.0: bridge window [mem 0xf800000000-0xfc0fffffff 64bit pref]
[ 1.636256] pci 0000:03:00.0: [1002:73bf] type 00 class 0x030000
[ 1.636269] pci 0000:03:00.0: reg 0x10: [mem 0xf800000000-0xfbffffffff 64bit pref]
[ 1.636277] pci 0000:03:00.0: reg 0x18: [mem 0xfc00000000-0xfc0fffffff 64bit pref]
[ 1.636282] pci 0000:03:00.0: reg 0x20: [io 0xf000-0xf0ff]
[ 1.636287] pci 0000:03:00.0: reg 0x24: [mem 0xfca00000-0xfcafffff]
[ 1.636293] pci 0000:03:00.0: reg 0x30: [mem 0xfcb00000-0xfcb1ffff pref]
[ 1.636309] pci 0000:03:00.0: BAR 0: assigned to efifb
[ 1.636357] pci 0000:03:00.0: PME# supported from D1 D2 D3hot D3cold
[ 1.636464] pci 0000:03:00.1: [1002:ab28] type 00 class 0x040300
[ 1.636472] pci 0000:03:00.1: reg 0x10: [mem 0xfcb24000-0xfcb27fff]
[ 1.636537] pci 0000:03:00.1: PME# supported from D1 D2 D3hot D3cold
[ 1.636601] pci 0000:03:00.2: [1002:73a6] type 00 class 0x0c0330
[ 1.636613] pci 0000:03:00.2: reg 0x10: [mem 0xfc900000-0xfc9fffff 64bit]
[ 1.636684] pci 0000:03:00.2: PME# supported from D0 D3hot D3cold
[ 1.636745] pci 0000:03:00.3: [1002:73a4] type 00 class 0x0c8000
[ 1.636756] pci 0000:03:00.3: reg 0x10: [mem 0xfcb20000-0xfcb23fff 64bit]
[ 1.636817] pci 0000:03:00.3: PME# supported from D0 D3hot
[ 1.636897] pci 0000:02:00.0: PCI bridge to [bus 03]
[ 1.636900] pci 0000:02:00.0: bridge window [io 0xf000-0xffff]
[ 1.636902] pci 0000:02:00.0: bridge window [mem 0xfc900000-0xfcbfffff]
[ 1.636905] pci 0000:02:00.0: bridge window [mem 0xf800000000-0xfc0fffffff 64bit pref]
[ 1.636955] pci 0000:04:00.0: [1cc1:5350] type 00 class 0x010802
[ 1.636965] pci 0000:04:00.0: reg 0x10: [mem 0xfcf00000-0xfcf03fff 64bit]
[ 1.637102] pci 0000:00:01.2: PCI bridge to [bus 04]
[ 1.637105] pci 0000:00:01.2: bridge window [mem 0xfcf00000-0xfcffffff]
[ 1.637153] pci 0000:05:00.0: [1022:43f4] type 01 class 0x060400
[ 1.637180] pci 0000:05:00.0: enabling Extended Tags
[ 1.637220] pci 0000:05:00.0: PME# supported from D0 D3hot D3cold
[ 1.637356] pci 0000:00:02.1: PCI bridge to [bus 05-15]
[ 1.637358] pci 0000:00:02.1: bridge window [io 0xe000-0xefff]
[ 1.637360] pci 0000:00:02.1: bridge window [mem 0xfbb00000-0xfc4fffff]
[ 1.637422] pci 0000:06:00.0: [1022:43f5] type 01 class 0x060400
[ 1.637450] pci 0000:06:00.0: enabling Extended Tags
[ 1.637493] pci 0000:06:00.0: PME# supported from D0 D3hot D3cold
[ 1.637576] pci 0000:06:04.0: [1022:43f5] type 01 class 0x060400
[ 1.637604] pci 0000:06:04.0: enabling Extended Tags
[ 1.637646] pci 0000:06:04.0: PME# supported from D0 D3hot D3cold
[ 1.637726] pci 0000:06:05.0: [1022:43f5] type 01 class 0x060400
[ 1.637754] pci 0000:06:05.0: enabling Extended Tags
[ 1.637797] pci 0000:06:05.0: PME# supported from D0 D3hot D3cold
[ 1.637877] pci 0000:06:06.0: [1022:43f5] type 01 class 0x060400
[ 1.637905] pci 0000:06:06.0: enabling Extended Tags
[ 1.637947] pci 0000:06:06.0: PME# supported from D0 D3hot D3cold
[ 1.638029] pci 0000:06:08.0: [1022:43f5] type 01 class 0x060400
[ 1.638058] pci 0000:06:08.0: enabling Extended Tags
[ 1.638098] pci 0000:06:08.0: PME# supported from D0 D3hot D3cold
[ 1.638199] pci 0000:06:0c.0: [1022:43f5] type 01 class 0x060400
[ 1.638227] pci 0000:06:0c.0: enabling Extended Tags
[ 1.638256] pci 0000:06:0c.0: PME# supported from D0 D3hot D3cold
[ 1.638311] pci 0000:06:0d.0: [1022:43f5] type 01 class 0x060400
[ 1.638339] pci 0000:06:0d.0: enabling Extended Tags
[ 1.638368] pci 0000:06:0d.0: PME# supported from D0 D3hot D3cold
[ 1.638420] pci 0000:05:00.0: PCI bridge to [bus 06-15]
[ 1.638423] pci 0000:05:00.0: bridge window [io 0xe000-0xefff]
[ 1.638425] pci 0000:05:00.0: bridge window [mem 0xfbb00000-0xfc4fffff]
[ 1.638448] pci 0000:06:00.0: PCI bridge to [bus 07]
[ 1.638475] pci 0000:06:04.0: PCI bridge to [bus 08]
[ 1.638502] pci 0000:06:05.0: PCI bridge to [bus 09]
[ 1.638529] pci 0000:06:06.0: PCI bridge to [bus 0a]
[ 1.638569] pci 0000:0b:00.0: [1022:43f4] type 01 class 0x060400
[ 1.638613] pci 0000:0b:00.0: enabling Extended Tags
[ 1.638679] pci 0000:0b:00.0: PME# supported from D0 D3hot D3cold
[ 1.638847] pci 0000:06:08.0: PCI bridge to [bus 0b-13]
[ 1.638850] pci 0000:06:08.0: bridge window [io 0xe000-0xefff]
[ 1.638851] pci 0000:06:08.0: bridge window [mem 0xfbb00000-0xfc2fffff]
[ 1.638934] pci 0000:0c:00.0: [1022:43f5] type 01 class 0x060400
[ 1.638980] pci 0000:0c:00.0: enabling Extended Tags
[ 1.639050] pci 0000:0c:00.0: PME# supported from D0 D3hot D3cold
[ 1.639178] pci 0000:0c:04.0: [1022:43f5] type 01 class 0x060400
[ 1.639224] pci 0000:0c:04.0: enabling Extended Tags
[ 1.639290] pci 0000:0c:04.0: PME# supported from D0 D3hot D3cold
[ 1.639416] pci 0000:0c:06.0: [1022:43f5] type 01 class 0x060400
[ 1.639462] pci 0000:0c:06.0: enabling Extended Tags
[ 1.639528] pci 0000:0c:06.0: PME# supported from D0 D3hot D3cold
[ 1.639653] pci 0000:0c:07.0: [1022:43f5] type 01 class 0x060400
[ 1.639699] pci 0000:0c:07.0: enabling Extended Tags
[ 1.639765] pci 0000:0c:07.0: PME# supported from D0 D3hot D3cold
[ 1.639891] pci 0000:0c:08.0: [1022:43f5] type 01 class 0x060400
[ 1.639937] pci 0000:0c:08.0: enabling Extended Tags
[ 1.640003] pci 0000:0c:08.0: PME# supported from D0 D3hot D3cold
[ 1.640135] pci 0000:0c:0c.0: [1022:43f5] type 01 class 0x060400
[ 1.640180] pci 0000:0c:0c.0: enabling Extended Tags
[ 1.640226] pci 0000:0c:0c.0: PME# supported from D0 D3hot D3cold
[ 1.640296] pci 0000:0c:0d.0: [1022:43f5] type 01 class 0x060400
[ 1.640340] pci 0000:0c:0d.0: enabling Extended Tags
[ 1.640387] pci 0000:0c:0d.0: PME# supported from D0 D3hot D3cold
[ 1.640462] pci 0000:0b:00.0: PCI bridge to [bus 0c-13]
[ 1.640467] pci 0000:0b:00.0: bridge window [io 0xe000-0xefff]
[ 1.640469] pci 0000:0b:00.0: bridge window [mem 0xfbb00000-0xfc2fffff]
[ 1.640503] pci 0000:0c:00.0: PCI bridge to [bus 0d]
[ 1.640569] pci 0000:0e:00.0: [10ec:8161] type 00 class 0x020000
[ 1.640590] pci 0000:0e:00.0: reg 0x10: [io 0xe000-0xe0ff]
[ 1.640617] pci 0000:0e:00.0: reg 0x18: [mem 0xfc204000-0xfc204fff 64bit]
[ 1.640635] pci 0000:0e:00.0: reg 0x20: [mem 0xfc200000-0xfc203fff 64bit]
[ 1.640776] pci 0000:0e:00.0: supports D1 D2
[ 1.640777] pci 0000:0e:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 1.641051] pci 0000:0c:04.0: PCI bridge to [bus 0e]
[ 1.641055] pci 0000:0c:04.0: bridge window [io 0xe000-0xefff]
[ 1.641058] pci 0000:0c:04.0: bridge window [mem 0xfc200000-0xfc2fffff]
[ 1.641126] pci 0000:0f:00.0: [8086:15f3] type 00 class 0x020000
[ 1.641148] pci 0000:0f:00.0: reg 0x10: [mem 0xfbd00000-0xfbdfffff]
[ 1.641184] pci 0000:0f:00.0: reg 0x1c: [mem 0xfbe00000-0xfbe03fff]
[ 1.641331] pci 0000:0f:00.0: PME# supported from D0 D3hot D3cold
[ 1.641534] pci 0000:0c:06.0: PCI bridge to [bus 0f]
[ 1.641540] pci 0000:0c:06.0: bridge window [mem 0xfbd00000-0xfbefffff]
[ 1.641606] pci 0000:10:00.0: [8086:2725] type 00 class 0x028000
[ 1.641635] pci 0000:10:00.0: reg 0x10: [mem 0xfc100000-0xfc103fff 64bit]
[ 1.641789] pci 0000:10:00.0: PME# supported from D0 D3hot D3cold
[ 1.641973] pci 0000:0c:07.0: PCI bridge to [bus 10]
[ 1.641980] pci 0000:0c:07.0: bridge window [mem 0xfc100000-0xfc1fffff]
[ 1.642051] pci 0000:11:00.0: [2646:5013] type 00 class 0x010802
[ 1.642104] pci 0000:11:00.0: reg 0x10: [mem 0xfc000000-0xfc003fff 64bit]
[ 1.642231] pci 0000:11:00.0: enabling Extended Tags
[ 1.643048] pci 0000:0c:08.0: PCI bridge to [bus 11]
[ 1.643055] pci 0000:0c:08.0: bridge window [mem 0xfc000000-0xfc0fffff]
[ 1.643103] pci 0000:12:00.0: [1022:43f7] type 00 class 0x0c0330
[ 1.643120] pci 0000:12:00.0: reg 0x10: [mem 0xfbf00000-0xfbf07fff 64bit]
[ 1.643161] pci 0000:12:00.0: enabling Extended Tags
[ 1.643212] pci 0000:12:00.0: PME# supported from D0 D3hot D3cold
[ 1.643296] pci 0000:0c:0c.0: PCI bridge to [bus 12]
[ 1.643300] pci 0000:0c:0c.0: bridge window [mem 0xfbf00000-0xfbffffff]
[ 1.643349] pci 0000:13:00.0: [1022:43f6] type 00 class 0x010601
[ 1.643385] pci 0000:13:00.0: reg 0x24: [mem 0xfbb80000-0xfbb803ff]
[ 1.643390] pci 0000:13:00.0: reg 0x30: [mem 0xfbb00000-0xfbb7ffff pref]
[ 1.643396] pci 0000:13:00.0: enabling Extended Tags
[ 1.643438] pci 0000:13:00.0: PME# supported from D0 D3hot D3cold
[ 1.643508] pci 0000:0c:0d.0: PCI bridge to [bus 13]
[ 1.643513] pci 0000:0c:0d.0: bridge window [mem 0xfbb00000-0xfbcfffff]
[ 1.643579] pci 0000:14:00.0: [1022:43f7] type 00 class 0x0c0330
[ 1.643590] pci 0000:14:00.0: reg 0x10: [mem 0xfc400000-0xfc407fff 64bit]
[ 1.643615] pci 0000:14:00.0: enabling Extended Tags
[ 1.643646] pci 0000:14:00.0: PME# supported from D0 D3hot D3cold
[ 1.643709] pci 0000:06:0c.0: PCI bridge to [bus 14]
[ 1.643712] pci 0000:06:0c.0: bridge window [mem 0xfc400000-0xfc4fffff]
[ 1.643743] pci 0000:15:00.0: [1022:43f6] type 00 class 0x010601
[ 1.643765] pci 0000:15:00.0: reg 0x24: [mem 0xfc380000-0xfc3803ff]
[ 1.643769] pci 0000:15:00.0: reg 0x30: [mem 0xfc300000-0xfc37ffff pref]
[ 1.643773] pci 0000:15:00.0: enabling Extended Tags
[ 1.643799] pci 0000:15:00.0: PME# supported from D0 D3hot D3cold
[ 1.643845] pci 0000:06:0d.0: PCI bridge to [bus 15]
[ 1.643848] pci 0000:06:0d.0: bridge window [mem 0xfc300000-0xfc3fffff]
[ 1.643917] pci 0000:16:00.0: [144d:a808] type 00 class 0x010802
[ 1.643929] pci 0000:16:00.0: reg 0x10: [mem 0xfce00000-0xfce03fff 64bit]
[ 1.644081] pci 0000:00:02.2: PCI bridge to [bus 16]
[ 1.644085] pci 0000:00:02.2: bridge window [mem 0xfce00000-0xfcefffff]
[ 1.644131] pci 0000:17:00.0: [1002:164e] type 00 class 0x030000
[ 1.644138] pci 0000:17:00.0: reg 0x10: [mem 0xfc20000000-0xfc2fffffff 64bit pref]
[ 1.644142] pci 0000:17:00.0: reg 0x18: [mem 0xfc30000000-0xfc301fffff 64bit pref]
[ 1.644146] pci 0000:17:00.0: reg 0x20: [io 0xd000-0xd0ff]
[ 1.644149] pci 0000:17:00.0: reg 0x24: [mem 0xfc800000-0xfc87ffff]
[ 1.644154] pci 0000:17:00.0: enabling Extended Tags
[ 1.644184] pci 0000:17:00.0: PME# supported from D1 D2 D3hot D3cold
[ 1.644240] pci 0000:17:00.1: [1002:1640] type 00 class 0x040300
[ 1.644244] pci 0000:17:00.1: reg 0x10: [mem 0xfc880000-0xfc883fff]
[ 1.644258] pci 0000:17:00.1: enabling Extended Tags
[ 1.644276] pci 0000:17:00.1: PME# supported from D1 D2 D3hot D3cold
[ 1.644308] pci 0000:17:00.2: [1022:1649] type 00 class 0x108000
[ 1.644336] pci 0000:17:00.2: reg 0x18: [mem 0xfc700000-0xfc7fffff]
[ 1.644342] pci 0000:17:00.2: reg 0x24: [mem 0xfc884000-0xfc885fff]
[ 1.644346] pci 0000:17:00.2: enabling Extended Tags
[ 1.644396] pci 0000:17:00.3: [1022:15b6] type 00 class 0x0c0330
[ 1.644403] pci 0000:17:00.3: reg 0x10: [mem 0xfc600000-0xfc6fffff 64bit]
[ 1.644418] pci 0000:17:00.3: enabling Extended Tags
[ 1.644439] pci 0000:17:00.3: PME# supported from D0 D3hot D3cold
[ 1.644472] pci 0000:17:00.4: [1022:15b7] type 00 class 0x0c0330
[ 1.644479] pci 0000:17:00.4: reg 0x10: [mem 0xfc500000-0xfc5fffff 64bit]
[ 1.644494] pci 0000:17:00.4: enabling Extended Tags
[ 1.644514] pci 0000:17:00.4: PME# supported from D0 D3hot D3cold
[ 1.644556] pci 0000:00:08.1: PCI bridge to [bus 17]
[ 1.644557] pci 0000:00:08.1: bridge window [io 0xd000-0xdfff]
[ 1.644558] pci 0000:00:08.1: bridge window [mem 0xfc500000-0xfc8fffff]
[ 1.644560] pci 0000:00:08.1: bridge window [mem 0xfc20000000-0xfc301fffff 64bit pref]
[ 1.644579] pci 0000:18:00.0: [1022:15b8] type 00 class 0x0c0330
[ 1.644590] pci 0000:18:00.0: reg 0x10: [mem 0xfcd00000-0xfcdfffff 64bit]
[ 1.644611] pci 0000:18:00.0: enabling Extended Tags
[ 1.644635] pci 0000:18:00.0: PME# supported from D0 D3hot D3cold
[ 1.644682] pci 0000:00:08.3: PCI bridge to [bus 18]
[ 1.644685] pci 0000:00:08.3: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 1.646484] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 1.646508] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[ 1.646527] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 1.646554] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 1.646576] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 1.646595] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 1.646613] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 1.646631] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 1.647497] iommu: Default domain type: Passthrough (set via kernel command line)
[ 1.647592] SCSI subsystem initialized
[ 1.647596] libata version 3.00 loaded.
[ 1.647596] ACPI: bus type USB registered
[ 1.647596] usbcore: registered new interface driver usbfs
[ 1.647596] usbcore: registered new interface driver hub
[ 1.647596] usbcore: registered new device driver usb
[ 1.653561] pps_core: LinuxPPS API ver. 1 registered
[ 1.653561] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.653563] PTP clock support registered
[ 1.653566] EDAC MC: Ver: 3.0.0
[ 1.654172] Registered efivars operations
[ 1.654230] NetLabel: Initializing
[ 1.654231] NetLabel: domain hash size = 128
[ 1.654231] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 1.654237] NetLabel: unlabeled traffic allowed by default
[ 1.654239] mctp: management component transport protocol core
[ 1.654239] NET: Registered PF_MCTP protocol family
[ 1.654241] PCI: Using ACPI for IRQ routing
[ 1.656809] PCI: pci_cache_line_size set to 64 bytes
[ 1.656811] pci 0000:00:02.1: can't claim BAR 14 [mem 0xfbb00000-0xfc4fffff]: address conflict with AMDIF031:00 [mem 0
xfbc00000-0xfbc00fff]
[ 1.656813] pci 0000:05:00.0: can't claim BAR 14 [mem 0xfbb00000-0xfc4fffff]: no compatible bridge window
[ 1.656814] pci 0000:06:08.0: can't claim BAR 14 [mem 0xfbb00000-0xfc2fffff]: no compatible bridge window
[ 1.656814] pci 0000:0b:00.0: can't claim BAR 14 [mem 0xfbb00000-0xfc2fffff]: no compatible bridge window
[ 1.656815] pci 0000:0c:04.0: can't claim BAR 14 [mem 0xfc200000-0xfc2fffff]: no compatible bridge window
[ 1.656816] pci 0000:0c:06.0: can't claim BAR 14 [mem 0xfbd00000-0xfbefffff]: no compatible bridge window
[ 1.656816] pci 0000:0c:07.0: can't claim BAR 14 [mem 0xfc100000-0xfc1fffff]: no compatible bridge window
[ 1.656816] pci 0000:0c:08.0: can't claim BAR 14 [mem 0xfc000000-0xfc0fffff]: no compatible bridge window
[ 1.656817] pci 0000:0c:0c.0: can't claim BAR 14 [mem 0xfbf00000-0xfbffffff]: no compatible bridge window
[ 1.656817] pci 0000:0c:0d.0: can't claim BAR 14 [mem 0xfbb00000-0xfbcfffff]: no compatible bridge window
[ 1.656818] pci 0000:06:0c.0: can't claim BAR 14 [mem 0xfc400000-0xfc4fffff]: no compatible bridge window
[ 1.656818] pci 0000:06:0d.0: can't claim BAR 14 [mem 0xfc300000-0xfc3fffff]: no compatible bridge window
[ 1.656839] pci 0000:0f:00.0: can't claim BAR 0 [mem 0xfbd00000-0xfbdfffff]: no compatible bridge window
[ 1.656839] pci 0000:0f:00.0: can't claim BAR 3 [mem 0xfbe00000-0xfbe03fff]: no compatible bridge window
[ 1.656847] pci 0000:11:00.0: can't claim BAR 0 [mem 0xfc000000-0xfc003fff 64bit]: no compatible bridge window
[ 1.656849] pci 0000:12:00.0: can't claim BAR 0 [mem 0xfbf00000-0xfbf07fff 64bit]: no compatible bridge window
[ 1.656853] pci 0000:14:00.0: can't claim BAR 0 [mem 0xfc400000-0xfc407fff 64bit]: no compatible bridge window
[ 1.656884] pci 0000:0e:00.0: can't claim BAR 2 [mem 0xfc204000-0xfc204fff 64bit]: no compatible bridge window
[ 1.656885] pci 0000:0e:00.0: can't claim BAR 4 [mem 0xfc200000-0xfc203fff 64bit]: no compatible bridge window
[ 1.656891] pci 0000:10:00.0: can't claim BAR 0 [mem 0xfc100000-0xfc103fff 64bit]: no compatible bridge window
[ 1.656900] pci 0000:13:00.0: can't claim BAR 5 [mem 0xfbb80000-0xfbb803ff]: no compatible bridge window
[ 1.656903] pci 0000:15:00.0: can't claim BAR 5 [mem 0xfc380000-0xfc3803ff]: no compatible bridge window
[ 1.656913] Expanded resource Reserved due to conflict with PCI Bus 0000:00
[ 1.656913] e820: reserve RAM buffer [mem 0x09aff000-0x0bffffff]
[ 1.656914] e820: reserve RAM buffer [mem 0x0a200000-0x0bffffff]
[ 1.656915] e820: reserve RAM buffer [mem 0x0b000000-0x0bffffff]
[ 1.656915] e820: reserve RAM buffer [mem 0x6b73a000-0x6bffffff]
[ 1.656915] e820: reserve RAM buffer [mem 0x6e50c000-0x6fffffff]
[ 1.656916] e820: reserve RAM buffer [mem 0x6fccd000-0x6fffffff]
[ 1.656916] e820: reserve RAM buffer [mem 0x7bffb000-0x7bffffff]
[ 1.657507] pci 0000:03:00.0: vgaarb: setting as boot VGA device
[ 1.657507] pci 0000:03:00.0: vgaarb: bridge control possible
[ 1.657507] pci 0000:03:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 1.657507] pci 0000:17:00.0: vgaarb: bridge control possible
[ 1.657507] pci 0000:17:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[ 1.657507] vgaarb: loaded
[ 1.657540] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 1.657542] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 1.659552] clocksource: Switched to clocksource tsc-early
[ 1.659552] VFS: Disk quotas dquot_6.6.0
[ 1.659552] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.659552] pnp: PnP ACPI init
[ 1.659552] system 00:00: [mem 0xf0000000-0xf7ffffff] has been reserved
[ 1.659552] system 00:01: [mem 0xff8000000-0x1077ffffff window] has been reserved
[ 1.659552] system 00:03: [io 0x0a00-0x0a2f] has been reserved
[ 1.659552] system 00:03: [io 0x0a30-0x0a3f] has been reserved
[ 1.659552] system 00:03: [io 0x0a40-0x0a4f] has been reserved
[ 1.659552] system 00:03: [mem 0xfe000000-0xfe01ffff] has been reserved
[ 1.659552] system 00:04: [io 0x04d0-0x04d1] has been reserved
[ 1.659552] system 00:04: [io 0x040b] has been reserved
[ 1.659552] system 00:04: [io 0x04d6] has been reserved
[ 1.659552] system 00:04: [io 0x0c00-0x0c01] has been reserved
[ 1.659552] system 00:04: [io 0x0c14] has been reserved
[ 1.659552] system 00:04: [io 0x0c50-0x0c51] has been reserved
[ 1.659552] system 00:04: [io 0x0c52] has been reserved
[ 1.659552] system 00:04: [io 0x0c6c] has been reserved
[ 1.659552] system 00:04: [io 0x0c6f] has been reserved
[ 1.659552] system 00:04: [io 0x0cd8-0x0cdf] has been reserved
[ 1.659552] system 00:04: [io 0x0800-0x089f] has been reserved
[ 1.659552] system 00:04: [io 0x0b00-0x0b0f] has been reserved
[ 1.659552] system 00:04: [io 0x0b20-0x0b3f] has been reserved
[ 1.659552] system 00:04: [io 0x0900-0x090f] has been reserved
[ 1.659552] system 00:04: [io 0x0910-0x091f] has been reserved
[ 1.659552] system 00:04: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 1.659552] system 00:04: [mem 0xfec01000-0xfec01fff] could not be reserved
[ 1.659552] system 00:04: [mem 0xfedc0000-0xfedc0fff] has been reserved
[ 1.659552] system 00:04: [mem 0xfee00000-0xfee00fff] has been reserved
[ 1.659552] system 00:04: [mem 0xfed80000-0xfed8ffff] could not be reserved
[ 1.659552] system 00:04: [mem 0xfec10000-0xfec10fff] has been reserved
[ 1.659552] system 00:04: [mem 0xfeb00000-0xfeb00fff] has been reserved
[ 1.659552] system 00:04: [mem 0xff000000-0xffffffff] has been reserved
[ 1.659552] pnp: PnP ACPI: found 5 devices
[ 1.664328] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 1.664355] NET: Registered PF_INET protocol family
[ 1.664443] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 1.665755] tcp_listen_portaddr_hash hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 1.665784] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 1.665946] TCP established hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 1.666194] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 1.666256] TCP: Hash tables configured (established 524288 bind 65536)
[ 1.666366] MPTCP token hash table entries: 65536 (order: 8, 1572864 bytes, linear)
[ 1.666450] UDP hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 1.666530] UDP-Lite hash table entries: 32768 (order: 8, 1048576 bytes, linear)
[ 1.666597] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 1.666600] NET: Registered PF_XDP protocol family
[ 1.666602] pci 0000:13:00.0: can't claim BAR 6 [mem 0xfbb00000-0xfbb7ffff pref]: no compatible bridge window
[ 1.666604] pci 0000:15:00.0: can't claim BAR 6 [mem 0xfc300000-0xfc37ffff pref]: no compatible bridge window
[ 1.666611] pci 0000:00:02.1: BAR 14: assigned [mem 0x80000000-0x808fffff]
[ 1.666612] pci 0000:02:00.0: PCI bridge to [bus 03]
[ 1.666614] pci 0000:02:00.0: bridge window [io 0xf000-0xffff]
[ 1.666617] pci 0000:02:00.0: bridge window [mem 0xfc900000-0xfcbfffff]
[ 1.666619] pci 0000:02:00.0: bridge window [mem 0xf800000000-0xfc0fffffff 64bit pref]
[ 1.666622] pci 0000:01:00.0: PCI bridge to [bus 02-03]
[ 1.666623] pci 0000:01:00.0: bridge window [io 0xf000-0xffff]
[ 1.666626] pci 0000:01:00.0: bridge window [mem 0xfc900000-0xfcbfffff]
[ 1.666627] pci 0000:01:00.0: bridge window [mem 0xf800000000-0xfc0fffffff 64bit pref]
[ 1.666631] pci 0000:00:01.1: PCI bridge to [bus 01-03]
[ 1.666631] pci 0000:00:01.1: bridge window [io 0xf000-0xffff]
[ 1.666633] pci 0000:00:01.1: bridge window [mem 0xfc900000-0xfccfffff]
[ 1.666634] pci 0000:00:01.1: bridge window [mem 0xf800000000-0xfc0fffffff 64bit pref]
[ 1.666643] pci 0000:00:01.2: PCI bridge to [bus 04]
[ 1.666645] pci 0000:00:01.2: bridge window [mem 0xfcf00000-0xfcffffff]
[ 1.666654] pci 0000:05:00.0: BAR 14: assigned [mem 0x80000000-0x808fffff]
[ 1.666655] pci 0000:06:08.0: BAR 14: assigned [mem 0x80000000-0x806fffff]
[ 1.666655] pci 0000:06:0c.0: BAR 14: assigned [mem 0x80700000-0x807fffff]
[ 1.666656] pci 0000:06:0d.0: BAR 14: assigned [mem 0x80800000-0x808fffff]
[ 1.666657] pci 0000:06:00.0: PCI bridge to [bus 07]
[ 1.666667] pci 0000:06:04.0: PCI bridge to [bus 08]
[ 1.666673] pci 0000:06:05.0: PCI bridge to [bus 09]
[ 1.666679] pci 0000:06:06.0: PCI bridge to [bus 0a]
[ 1.666684] pci 0000:0b:00.0: BAR 14: assigned [mem 0x80000000-0x806fffff]
[ 1.666685] pci 0000:0c:04.0: BAR 14: assigned [mem 0x80000000-0x800fffff]
[ 1.666686] pci 0000:0c:06.0: BAR 14: assigned [mem 0x80100000-0x802fffff]
[ 1.666686] pci 0000:0c:07.0: BAR 14: assigned [mem 0x80300000-0x803fffff]
[ 1.666687] pci 0000:0c:08.0: BAR 14: assigned [mem 0x80400000-0x804fffff]
[ 1.666687] pci 0000:0c:0c.0: BAR 14: assigned [mem 0x80500000-0x805fffff]
[ 1.666688] pci 0000:0c:0d.0: BAR 14: assigned [mem 0x80600000-0x806fffff]
[ 1.666688] pci 0000:0c:00.0: PCI bridge to [bus 0d]
[ 1.666698] pci 0000:0e:00.0: BAR 4: assigned [mem 0x80000000-0x80003fff 64bit]
[ 1.666712] pci 0000:0e:00.0: BAR 2: assigned [mem 0x80004000-0x80004fff 64bit]
[ 1.666726] pci 0000:0c:04.0: PCI bridge to [bus 0e]
[ 1.666727] pci 0000:0c:04.0: bridge window [io 0xe000-0xefff]
[ 1.666731] pci 0000:0c:04.0: bridge window [mem 0x80000000-0x800fffff]
[ 1.666737] pci 0000:0f:00.0: BAR 0: assigned [mem 0x80100000-0x801fffff]
[ 1.666741] pci 0000:0f:00.0: BAR 3: assigned [mem 0x80200000-0x80203fff]
[ 1.666745] pci 0000:0c:06.0: PCI bridge to [bus 0f]
[ 1.666749] pci 0000:0c:06.0: bridge window [mem 0x80100000-0x802fffff]
[ 1.666755] pci 0000:10:00.0: BAR 0: assigned [mem 0x80300000-0x80303fff 64bit]
[ 1.666769] pci 0000:0c:07.0: PCI bridge to [bus 10]
[ 1.666772] pci 0000:0c:07.0: bridge window [mem 0x80300000-0x803fffff]
[ 1.666779] pci 0000:11:00.0: BAR 0: assigned [mem 0x80400000-0x80403fff 64bit]
[ 1.666801] pci 0000:0c:08.0: PCI bridge to [bus 11]
[ 1.666804] pci 0000:0c:08.0: bridge window [mem 0x80400000-0x804fffff]
[ 1.666811] pci 0000:12:00.0: BAR 0: assigned [mem 0x80500000-0x80507fff 64bit]
[ 1.666818] pci 0000:0c:0c.0: PCI bridge to [bus 12]
[ 1.666821] pci 0000:0c:0c.0: bridge window [mem 0x80500000-0x805fffff]
[ 1.666828] pci 0000:13:00.0: BAR 6: assigned [mem 0x80600000-0x8067ffff pref]
[ 1.666828] pci 0000:13:00.0: BAR 5: assigned [mem 0x80680000-0x806803ff]
[ 1.666831] pci 0000:0c:0d.0: PCI bridge to [bus 13]
[ 1.666834] pci 0000:0c:0d.0: bridge window [mem 0x80600000-0x806fffff]
[ 1.666840] pci 0000:0b:00.0: PCI bridge to [bus 0c-13]
[ 1.666842] pci 0000:0b:00.0: bridge window [io 0xe000-0xefff]
[ 1.666845] pci 0000:0b:00.0: bridge window [mem 0x80000000-0x806fffff]
[ 1.666851] pci 0000:06:08.0: PCI bridge to [bus 0b-13]
[ 1.666852] pci 0000:06:08.0: bridge window [io 0xe000-0xefff]
[ 1.666854] pci 0000:06:08.0: bridge window [mem 0x80000000-0x806fffff]
[ 1.666859] pci 0000:14:00.0: BAR 0: assigned [mem 0x80700000-0x80707fff 64bit]
[ 1.666863] pci 0000:06:0c.0: PCI bridge to [bus 14]
[ 1.666866] pci 0000:06:0c.0: bridge window [mem 0x80700000-0x807fffff]
[ 1.666870] pci 0000:15:00.0: BAR 6: assigned [mem 0x80800000-0x8087ffff pref]
[ 1.666870] pci 0000:15:00.0: BAR 5: assigned [mem 0x80880000-0x808803ff]
[ 1.666872] pci 0000:06:0d.0: PCI bridge to [bus 15]
[ 1.666874] pci 0000:06:0d.0: bridge window [mem 0x80800000-0x808fffff]
[ 1.666878] pci 0000:05:00.0: PCI bridge to [bus 06-15]
[ 1.666879] pci 0000:05:00.0: bridge window [io 0xe000-0xefff]
[ 1.666881] pci 0000:05:00.0: bridge window [mem 0x80000000-0x808fffff]
[ 1.666885] pci 0000:00:02.1: PCI bridge to [bus 05-15]
[ 1.666886] pci 0000:00:02.1: bridge window [io 0xe000-0xefff]
[ 1.666887] pci 0000:00:02.1: bridge window [mem 0x80000000-0x808fffff]
[ 1.666897] pci 0000:00:02.2: PCI bridge to [bus 16]
[ 1.666899] pci 0000:00:02.2: bridge window [mem 0xfce00000-0xfcefffff]
[ 1.666908] pci 0000:00:08.1: PCI bridge to [bus 17]
[ 1.666913] pci 0000:00:08.1: bridge window [io 0xd000-0xdfff]
[ 1.666915] pci 0000:00:08.1: bridge window [mem 0xfc500000-0xfc8fffff]
[ 1.666916] pci 0000:00:08.1: bridge window [mem 0xfc20000000-0xfc301fffff 64bit pref]
[ 1.666917] pci 0000:00:08.3: PCI bridge to [bus 18]
[ 1.666919] pci 0000:00:08.3: bridge window [mem 0xfcd00000-0xfcdfffff]
[ 1.666921] pci_bus 0000:00: resource 4 [io 0x0000-0x03af window]
[ 1.666922] pci_bus 0000:00: resource 5 [io 0x03e0-0x0cf7 window]
[ 1.666923] pci_bus 0000:00: resource 6 [io 0x03b0-0x03df window]
[ 1.666923] pci_bus 0000:00: resource 7 [io 0x0d00-0xffff window]
[ 1.666923] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000dffff window]
[ 1.666924] pci_bus 0000:00: resource 9 [mem 0x80000000-0xfcffffff window]
[ 1.666924] pci_bus 0000:00: resource 10 [mem 0x1080000000-0xffffffffff window]
[ 1.666925] pci_bus 0000:01: resource 0 [io 0xf000-0xffff]
[ 1.666925] pci_bus 0000:01: resource 1 [mem 0xfc900000-0xfccfffff]
[ 1.666926] pci_bus 0000:01: resource 2 [mem 0xf800000000-0xfc0fffffff 64bit pref]
[ 1.666926] pci_bus 0000:02: resource 0 [io 0xf000-0xffff]
[ 1.666927] pci_bus 0000:02: resource 1 [mem 0xfc900000-0xfcbfffff]
[ 1.666927] pci_bus 0000:02: resource 2 [mem 0xf800000000-0xfc0fffffff 64bit pref]
[ 1.666928] pci_bus 0000:03: resource 0 [io 0xf000-0xffff]
[ 1.666928] pci_bus 0000:03: resource 1 [mem 0xfc900000-0xfcbfffff]
[ 1.666928] pci_bus 0000:03: resource 2 [mem 0xf800000000-0xfc0fffffff 64bit pref]
[ 1.666929] pci_bus 0000:04: resource 1 [mem 0xfcf00000-0xfcffffff]
[ 1.666929] pci_bus 0000:05: resource 0 [io 0xe000-0xefff]
[ 1.666930] pci_bus 0000:05: resource 1 [mem 0x80000000-0x808fffff]
[ 1.666930] pci_bus 0000:06: resource 0 [io 0xe000-0xefff]
[ 1.666930] pci_bus 0000:06: resource 1 [mem 0x80000000-0x808fffff]
[ 1.666931] pci_bus 0000:0b: resource 0 [io 0xe000-0xefff]
[ 1.666931] pci_bus 0000:0b: resource 1 [mem 0x80000000-0x806fffff]
[ 1.666932] pci_bus 0000:0c: resource 0 [io 0xe000-0xefff]
[ 1.666932] pci_bus 0000:0c: resource 1 [mem 0x80000000-0x806fffff]
[ 1.666933] pci_bus 0000:0e: resource 0 [io 0xe000-0xefff]
[ 1.666933] pci_bus 0000:0e: resource 1 [mem 0x80000000-0x800fffff]
[ 1.666933] pci_bus 0000:0f: resource 1 [mem 0x80100000-0x802fffff]
[ 1.666934] pci_bus 0000:10: resource 1 [mem 0x80300000-0x803fffff]
[ 1.666934] pci_bus 0000:11: resource 1 [mem 0x80400000-0x804fffff]
[ 1.666935] pci_bus 0000:12: resource 1 [mem 0x80500000-0x805fffff]
[ 1.666935] pci_bus 0000:13: resource 1 [mem 0x80600000-0x806fffff]
[ 1.666935] pci_bus 0000:14: resource 1 [mem 0x80700000-0x807fffff]
[ 1.666936] pci_bus 0000:15: resource 1 [mem 0x80800000-0x808fffff]
[ 1.666936] pci_bus 0000:16: resource 1 [mem 0xfce00000-0xfcefffff]
[ 1.666937] pci_bus 0000:17: resource 0 [io 0xd000-0xdfff]
[ 1.666937] pci_bus 0000:17: resource 1 [mem 0xfc500000-0xfc8fffff]
[ 1.666938] pci_bus 0000:17: resource 2 [mem 0xfc20000000-0xfc301fffff 64bit pref]
[ 1.666938] pci_bus 0000:18: resource 1 [mem 0xfcd00000-0xfcdfffff]
[ 1.667007] pci 0000:03:00.1: D0 power state depends on 0000:03:00.0
[ 1.667044] pci 0000:03:00.2: D0 power state depends on 0000:03:00.0
[ 1.667173] pci 0000:03:00.3: D0 power state depends on 0000:03:00.0
[ 1.667367] pci 0000:17:00.1: D0 power state depends on 0000:17:00.0
[ 1.667496] PCI: CLS 64 bytes, default 64
[ 1.667503] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 1.667521] pci 0000:00:01.0: Adding to iommu group 0
[ 1.667523] Trying to unpack rootfs image as initramfs...
[ 1.667527] pci 0000:00:01.1: Adding to iommu group 1
[ 1.667532] pci 0000:00:01.2: Adding to iommu group 2
[ 1.667541] pci 0000:00:02.0: Adding to iommu group 3
[ 1.667546] pci 0000:00:02.1: Adding to iommu group 4
[ 1.667551] pci 0000:00:02.2: Adding to iommu group 5
[ 1.667556] pci 0000:00:03.0: Adding to iommu group 6
[ 1.667560] pci 0000:00:04.0: Adding to iommu group 7
[ 1.667567] pci 0000:00:08.0: Adding to iommu group 8
[ 1.667572] pci 0000:00:08.1: Adding to iommu group 9
[ 1.667576] pci 0000:00:08.3: Adding to iommu group 10
[ 1.667583] pci 0000:00:14.0: Adding to iommu group 11
[ 1.667586] pci 0000:00:14.3: Adding to iommu group 11
[ 1.667601] pci 0000:00:18.0: Adding to iommu group 12
[ 1.667604] pci 0000:00:18.1: Adding to iommu group 12
[ 1.667607] pci 0000:00:18.2: Adding to iommu group 12
[ 1.667610] pci 0000:00:18.3: Adding to iommu group 12
[ 1.667613] pci 0000:00:18.4: Adding to iommu group 12
[ 1.667616] pci 0000:00:18.5: Adding to iommu group 12
[ 1.667619] pci 0000:00:18.6: Adding to iommu group 12
[ 1.667623] pci 0000:00:18.7: Adding to iommu group 12
[ 1.667628] pci 0000:01:00.0: Adding to iommu group 13
[ 1.667639] pci 0000:02:00.0: Adding to iommu group 14
[ 1.667658] pci 0000:03:00.0: Adding to iommu group 15
[ 1.667674] pci 0000:03:00.1: Adding to iommu group 16
[ 1.667691] pci 0000:03:00.2: Adding to iommu group 17
[ 1.667709] pci 0000:03:00.3: Adding to iommu group 18
[ 1.667714] pci 0000:04:00.0: Adding to iommu group 19
[ 1.667720] pci 0000:05:00.0: Adding to iommu group 20
[ 1.667734] pci 0000:06:00.0: Adding to iommu group 21
[ 1.667742] pci 0000:06:04.0: Adding to iommu group 22
[ 1.667751] pci 0000:06:05.0: Adding to iommu group 23
[ 1.667760] pci 0000:06:06.0: Adding to iommu group 24
[ 1.667768] pci 0000:06:08.0: Adding to iommu group 25
[ 1.667777] pci 0000:06:0c.0: Adding to iommu group 26
[ 1.667786] pci 0000:06:0d.0: Adding to iommu group 27
[ 1.667791] pci 0000:0b:00.0: Adding to iommu group 25
[ 1.667802] pci 0000:0c:00.0: Adding to iommu group 25
[ 1.667812] pci 0000:0c:04.0: Adding to iommu group 25
[ 1.667824] pci 0000:0c:06.0: Adding to iommu group 25
[ 1.667834] pci 0000:0c:07.0: Adding to iommu group 25
[ 1.667845] pci 0000:0c:08.0: Adding to iommu group 25
[ 1.667856] pci 0000:0c:0c.0: Adding to iommu group 25
[ 1.667867] pci 0000:0c:0d.0: Adding to iommu group 25
[ 1.667874] pci 0000:0e:00.0: Adding to iommu group 25
[ 1.667880] pci 0000:0f:00.0: Adding to iommu group 25
[ 1.667887] pci 0000:10:00.0: Adding to iommu group 25
[ 1.667894] pci 0000:11:00.0: Adding to iommu group 25
[ 1.667897] pci 0000:12:00.0: Adding to iommu group 25
[ 1.667899] pci 0000:13:00.0: Adding to iommu group 25
[ 1.667901] pci 0000:14:00.0: Adding to iommu group 26
[ 1.667903] pci 0000:15:00.0: Adding to iommu group 27
[ 1.667908] pci 0000:16:00.0: Adding to iommu group 28
[ 1.667922] pci 0000:17:00.0: Adding to iommu group 29
[ 1.667928] pci 0000:17:00.1: Adding to iommu group 30
[ 1.667934] pci 0000:17:00.2: Adding to iommu group 31
[ 1.667939] pci 0000:17:00.3: Adding to iommu group 32
[ 1.667945] pci 0000:17:00.4: Adding to iommu group 33
[ 1.667952] pci 0000:18:00.0: Adding to iommu group 34
[ 1.668100] pci 0000:00:00.2: can't derive routing for PCI INT A
[ 1.668101] pci 0000:00:00.2: PCI INT A: not connected
[ 1.668178] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 1.668178] AMD-Vi: Extended features (0x246577efa2254afa, 0x0): PPR NX GT [5] IA GA PC GA_vAPIC
[ 1.668181] AMD-Vi: Interrupt remapping enabled
[ 1.760601] Freeing initrd memory: 15332K
