I configured bash as default shell, when I look in /etc/passwd in my user account I have bash, but when I open a terminal I have the zsh. What did I wrong ?
Thank you a lot
Welcome to the forum! ![]()
You didn’t do anything wrong. The default shell inside graphical terminal windows in Manjaro has already for a while been zsh. However, you can change this.
Since you are using Plasma — and therefore konsole as your terminal — you must go into the konsole settings menu and choose “Configure Konsole”. Then, choose “Profiles”.
You will see that the default profile is read-only. Copy that profile into a new profile with a name of your choice.
Now, edit the profile you just created and you will immediately see the shell it invokes. Change that to /bin/bash (or /usr/bin/bash) and make sure you tick the box to make it the default. Then save it and activate the profile. ![]()
Note: yakuake uses the same profiles as konsole, so if you use that, then you must tell it to use the newly created profile as well.
thank you very much, it worked. I right clicked on the Konsole window and created a new profile, this was the only option available regarding profile. After that I saved it as default profile. Opening a new Konsole I got bash as my shell. great thx a lot.
Another thing I am a little bit confused, when I had zsh as default shell a ps showed me three zsh processes active. Strange, never happened to me. Now with the bash I have, as I expected, only one process with bash using ps.
Again, thx a lot for the fastest answer I ever got on a user forum.
yours, sincerely
Erich
You cannot edit the default profile. Its locked.
(“Built-in” = Read-only)
OP got it right creating a new one.
(which would make sense for preserving defaults anyways … like we do with systemd conf.d folders)
Read again: I didn’t say that the OP had to edit the default profile, but that he had to copy the default profile into a new profile and then edit this new profile.
Which is exactly what he then did. ![]()
Just for curiosity, where is the profile located ? Should be possible edit it by hand.
Thx a lot
/usr/share/konsole/breath.profile and /usr/share/manjaro-kde-settings/xdg/konsolerc.
Concretely, this is the list of files contained in the package manjaro-kde-settings. ![]()
[nx-74205:/dev/pts/3][/home/aragorn]
[aragorn] > pacman -Ql manjaro-kde-settings
manjaro-kde-settings /etc/
manjaro-kde-settings /etc/profile.d/
manjaro-kde-settings /etc/profile.d/manjaro-kde-settings-xdg.sh
manjaro-kde-settings /etc/profile.d/qt5-accessibility.sh
manjaro-kde-settings /etc/sddm.conf.d/
manjaro-kde-settings /etc/sddm.conf.d/00_manjaro_settings.conf
manjaro-kde-settings /etc/sddm.conf.d/virtualkeyboard.conf
manjaro-kde-settings /etc/skel/
manjaro-kde-settings /etc/skel/.config/
manjaro-kde-settings /etc/skel/.config/gtk-3.0/
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/close-active.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/close-backdrop-active.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/close-backdrop-hover.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/close-backdrop-normal.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/close-hover.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/close-normal.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximize-active.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximize-backdrop-active.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximize-backdrop-hover.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximize-backdrop-normal.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximize-hover.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximize-normal.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximized-active.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximized-backdrop-active.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximized-backdrop-hover.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximized-backdrop-normal.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximized-hover.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/maximized-normal.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/minimize-active.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/minimize-backdrop-active.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/minimize-backdrop-hover.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/minimize-backdrop-normal.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/minimize-hover.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/assets/minimize-normal.svg
manjaro-kde-settings /etc/skel/.config/gtk-3.0/colors.css
manjaro-kde-settings /etc/skel/.config/gtk-3.0/gtk.css
manjaro-kde-settings /etc/skel/.config/gtk-3.0/settings.ini
manjaro-kde-settings /etc/skel/.config/gtk-3.0/window_decorations.css
manjaro-kde-settings /etc/skel/.config/kdeglobals
manjaro-kde-settings /etc/skel/.xinitrc
manjaro-kde-settings /usr/
manjaro-kde-settings /usr/share/
manjaro-kde-settings /usr/share/konsole/
manjaro-kde-settings /usr/share/konsole/Breath.profile
manjaro-kde-settings /usr/share/manjaro-kde-settings/
manjaro-kde-settings /usr/share/manjaro-kde-settings/xdg/
manjaro-kde-settings /usr/share/manjaro-kde-settings/xdg/kdeglobals
manjaro-kde-settings /usr/share/manjaro-kde-settings/xdg/konsolerc
manjaro-kde-settings /usr/share/manjaro-kde-settings/xdg/ksmserverrc
manjaro-kde-settings /usr/share/manjaro-kde-settings/xdg/kwinrc
manjaro-kde-settings /usr/share/manjaro-kde-settings/xdg/yakuakerc
But… ![]()
I wouldn’t advise that, because /usr is supposed to be read-only to non-root users, and directly editing those files may lead to corruption.
The reason why it was done that way — and for the record, I myself objected to making zsh into the default shell inside graphical terminals — is that the system shell is still bash, and lots of things depend on that being the case.
That´s right, editing the system wide profile is not useful, since one can achieve to change the shell for the konsole also using a user specific profile. but where is the information id the user created profile located ? I achieved erroneously to have two profiles, called profile 1 and profile 2. They are located in .local/share/konsole. How can I eliminate one of these two ? Is is enough to delete one of them, or is there another configuration file keeping track of these profiles ? there is the konsolerc file which keeps the information which one of the profiles is used. But the profile list, where comes it from ?
I also noticed, that in “switch profile” choice of konsole I have also the choice between Breath and Built-in. What is the difference between the two of them ?
Thx a bunch
You can delete the one that’s not in use from within the Konsole settings — see my screenshot higher up.
No, you can delete the one that’s not in use.
You’ve already given the answer to that yourself.
~/.local/share/konsole/name-of-your-profile.profile
They are two names for the same profile, i.e. the one included in the manjaro-kde-settings package. It’s the read-only profile.
Now I understand. Thank you very much and have a great day.
