Cannot get Nacon controller to work
Hello
I have Nacon revolution x pro controller, and it does not work or shows up in settings.
Tried to install xone package from
here, no luck
dmesg shows no errors
[ 600.797261] usb 1-6.4: new full-speed USB device number 11 using xhci_hcd
[ 601.109478] usb 1-6.4: New USB device found, idVendor=3285, idProduct=0608, bcdDevice= 1.01
[ 601.109484] usb 1-6.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 601.109486] usb 1-6.4: Product: Revolution X
[ 601.109489] usb 1-6.4: Manufacturer: Nacon
[ 601.109490] usb 1-6.4: SerialNumber: 000013AB39C1AB70
What should i check next?
You installed it properly? Read the installation notes, probably from 4. mark.
Not sure if xone is suitable for your controller though.
thank you for your answer.
Funny thing, after you suggested i’ve read comments, apparently xone-dkms is deprecated.
Installed package recommended in the comments and voila
