I have bought several different USB to HDMI convertors with the hope of getting one to work but no hope so far.
The last one I bought was suggested to me by another linux user, he suggested the HOCO
hub which comes together with 2 USB and an Ethernet port.
Here is the result of the mhwd -lh -d --usb
command:
02: USB 00.0: 10a00 Hub
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2:1.0
SysFS BusID: 1-2:1.0
Hardware Class: hub
Model: "Super Top 4-Port hub"
Hotplug: USB
Vendor: usb 0x14cd "Super Top"
Device: usb 0x8601 "4-Port hub"
Driver: "hub"
Driver Modules: "usbcore"
Speed: 480 Mbps
Module Alias: "usb:v14CDp8601d0000dc09dsc00dp01ic09isc00ip00in00"
Attached to: #5 (Hub)
03: USB 00.0: 11500 Bluetooth Device
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb1/1-14/1-14:1.0
SysFS BusID: 1-14:1.0
Hardware Class: bluetooth
Model: "Intel Bluetooth 9460/9560 Jefferson Peak (JfP)"
Hotplug: USB
Vendor: usb 0x8087 "Intel Corp."
Device: usb 0x0aaa "Bluetooth 9460/9560 Jefferson Peak (JfP)"
Revision: "0.02"
Driver: "btusb"
Driver Modules: "btusb"
Speed: 12 Mbps
Module Alias: "usb:v8087p0AAAd0002dcE0dsc01dp01icE0isc01ip01in00"
Driver Info #0:
Driver Status: btusb is active
Driver Activation Cmd: "modprobe btusb"
04: USB 00.0: 0000 Unclassified device
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0
SysFS BusID: 1-6:1.0
Hardware Class: unknown
Model: "Syntek Integrated Camera"
Hotplug: USB
Vendor: usb 0x174f "Syntek"
Device: usb 0x244c "Integrated Camera"
Revision: "0.13"
Serial ID: "0001"
Driver: "uvcvideo"
Driver Modules: "uvcvideo"
Device File: /dev/input/event19
Device Files: /dev/input/event19, /dev/input/by-id/usb-Generic_Integrated_Camera_0001-event-if00, /dev/input/by-path/pci-0000:00:14.0-usb-0:6:1.0-event
Device Number: char 13:83
Speed: 480 Mbps
Module Alias: "usb:v174Fp244Cd0013dcEFdsc02dp01ic0Eisc01ip00in00"
Driver Info #0:
Driver Status: uvcvideo is active
Driver Activation Cmd: "modprobe uvcvideo"
05: USB 00.0: 10a00 Hub
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb1/1-0:1.0
SysFS BusID: 1-0:1.0
Hardware Class: hub
Model: "Linux Foundation 2.0 root hub"
Hotplug: USB
Vendor: usb 0x1d6b "Linux Foundation"
Device: usb 0x0002 "2.0 root hub"
Revision: "5.15"
Serial ID: "0000:00:14.0"
Driver: "hub"
Speed: 480 Mbps
Module Alias: "usb:v1D6Bp0002d0515dc09dsc00dp01ic09isc00ip00in00"
08: USB 00.0: 0200 Ethernet controller
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2.2/1-2.2:1.0
SysFS BusID: 1-2.2:1.0
Hardware Class: network
Model: "Realtek RTL8152 Fast Ethernet Adapter"
Hotplug: USB
Vendor: usb 0x0bda "Realtek Semiconductor Corp."
Device: usb 0x8152 "RTL8152 Fast Ethernet Adapter"
Revision: "20.00"
Serial ID: "00E04C360355"
Driver: "r8152"
Driver Modules: "r8152"
Device File: enp0s20f0u2u2
Speed: 480 Mbps
HW Address: 00:e0:4c:36:03:55
Permanent HW Address: 00:e0:4c:36:03:55
Link detected: no
Module Alias: "usb:v0BDAp8152d2000dc00dsc00dp00icFFiscFFip00in00"
Driver Info #0:
Driver Status: r8152 is active
Driver Activation Cmd: "modprobe r8152"
Attached to: #2 (Hub)
09: USB 00.0: 10a00 Hub
SysFS ID: /devices/pci0000:00/0000:00:14.0/usb2/2-0:1.0
SysFS BusID: 2-0:1.0
Hardware Class: hub
Model: "Linux Foundation 3.0 root hub"
Hotplug: USB
Device: usb 0x0003 "3.0 root hub"
Revision: "5.15"
Driver: "hub"
Module Alias: "usb:v1D6Bp0003d0515dc09dsc00dp03ic09isc00ip00in00"
As you can see, only the USB 2.0, USB 3.0 and the Ethernet ports show up here, not the HDIM port.
Any ideas or driver suggestions?
Thanks.
