Cannot find a GRUB drive for /dev/sda1
Hey, so I’ve been updating my device and didnt connect it to a charger so it ran out of power of course. i was then trying to follow a guide (here in the Forum from Aragorn, here’s the link: [HowTo] Recovering from an interrupted update/upgrade) to fix the damage. I made a bootable USB and got to the desktop. Here’s where the Problem starts:
sudo su -                                                        ✔
[manjaro-gnome ~]# lsblk --fs
NAME        FSTYPE   FSVER            LABEL              UUID                                 FSAVAIL FSUSE% MOUNTPOINTS
loop0       squashfs 4.0        0   100% /run/miso/sfs/livefs
loop1       squashfs 4.0        0   100% /run/miso/sfs/mhwdfs
loop2       squashfs 4.0        0   100% /run/miso/sfs/desktopfs
loop3       squashfs 4.0        0   100% /run/miso/sfs/rootfs
sda         iso9660  Joliet Extension MANJARO_GNOME_2604 2026-03-27-22-40-38-00                     0   100% /run/miso/bootmnt
├─sda1      iso9660  Joliet Extension MANJARO_GNOME_2604 2026-03-27-22-40-38-00
└─sda2      vfat     FAT12            MISO_EFI           345D-D0ED
nvme0n1
├─nvme0n1p1 vfat     FAT32                               A23D-F494
└─nvme0n1p2 ext4     1.0                                 19bc98ff-66a6-435a-a5d8-68932eb8ebf1
[manjaro-gnome ~]# manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sda1.  Check your device.map.
==> Mounting (ManjaroLinux) [/dev/nvme0n1p2]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
[manjaro-gnome /]# sudo fdisk -l /dev/sda
Disk /dev/sda: 14.45 GiB, 15518924800 bytes, 30310400 sectors
Disk model: Rainbow Line
Disklabel type: dos
Disk identifier: 0x00000000
Device     Boot    Start      End  Sectors  Size Id Type
/dev/sda1  *          64 10769951 10769888  5.1G  0 Empty
/dev/sda2       10769952 10778143     8192    4M ef EFI (FAT-12/16/32)
As you can see, it cant find a grub drive. i then looked for a solution to that and only found to look at the fdisk and change the type to Linux. <
As i am still very new to Manjaro and Linux in general, this is where my knowledge ends.
Can you help me? thank you very much <3
Please ignore the “error”, /dev/sda is your live USB, just continue with the guide.
Your system is on the nvme and the first partition is the EFI partition which is where grub goes.
But…sda is the usb…you don’t need it anyways. :wink: The main nvme hard disk seems to mount correctly.
Just go to the next steps in the tutorial (pacman -Syu and so on).
