When my computer has my regular amount of programs running (i.e. too much RAM), it won’t enter sleep mode, instead logging me off and “rebooting” (I guess) the log-in screen.
However, when I stop most of the programs (i.e. clear up some RAM), then it can enter sleep mode fine.
In any case, this was done with plenty of swap available and zswap off.
Output of journalctl contains an error report from nvidia-suspend.sh AFAIU.
Different logs from my test:
- I close every program
- I launch a toplevel (
utop) and allocate a large thing so that my RAM is filled systemctl suspend
All of this were done one right after the other, after I had filled my RAM
❯ LC_ALL=C free -h
total used free shared buff/cache available
Mem: 7,6Gi 7,0Gi 179Mi 216Mi 946Mi 588Mi
Swap: 17Gi 659Mi 16Gi
❯ LC_ALL=C inxi --za -zv8
Kernel: 6.15.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-6.15-x86_64 root=UUID=<filter> rw
quiet udev.log_priority=3
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.16.0
Type: Laptop System: LENOVO product: 81LK v: IdeaPad L340-15IRH Gaming
serial: <superuser required> Chassis: type: 10 v: IdeaPad L340-15IRH Gaming
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
part-nu: LENOVO_MT_81LK_BU_idea_FM_IdeaPad L340-15IRH Gaming
uuid: <superuser required> UEFI: LENOVO v: BGCN36WW date: 05/24/2022
ID-1: BAT0 charge: 35.4 Wh (97.3%) condition: 36.4/45.0 Wh (80.9%)
volts: 12.6 min: 11.4 model: SMP L18M3PF1 type: Li-poly serial: <filter>
status: not charging cycles: 813
System RAM: total: 8 GiB available: 7.62 GiB used: 7.09 GiB (93.0%)
Array-1: capacity: 16 GiB slots: 1 modules: 1 EC: None
Device-1: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 8 GiB
speed: 2400 MT/s volts: curr: 1 width (bits): data: 64 total: 64
manufacturer: SK Hynix part-no: HMAA1GS6CJR6N-XN serial: <filter>
Info: model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Coffee Lake
gen: core 9 level: v3 note: check built: 2018 process: Intel 14nm family: 6
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 900 min/max: 800/4100 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900
8: 900 bogomips: 38400
smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
Vulnerabilities: <filter>
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Lenovo
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 575.64.03 alternate: nouveau,nova_core,nvidia_drm
non-free: 550-570.xx+ status: current (as of 2025-04; EOL~2026-12-xx)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s ports:
active: none empty: DP-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1f91
class-ID: 0300
Device-3: Chicony Integrated Camera (1280x720@30) driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:3
chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia unloaded: nouveau
alternate: fbdev,nv,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: BOE Display 0x0812 built: 2018 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
x: 0.584 y: 0.361 green: x: 0.353 y: 0.569 blue: x: 0.161 y: 0.129 white:
x: 0.314 y: 0.329 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
drv: nvidia device: 2 drv: iris device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 630 (CFL
GT2) device-ID: 8086:3e9b memory: 7.44 GiB unified: yes
API: Vulkan v: 1.4.321 layers: 6 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 575.64.03
device-ID: 10de:1f91 surfaces: N/A device: 1 type: integrated-gpu
name: Intel UHD Graphics 630 (CFL GT2) driver: mesa intel
v: 25.1.6-arch1.1 device-ID: 8086:3e9b surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
x11: xdpyinfo, xprop, xrandr
<REMOVED>
<REMOVED>
<REMOVED>
Local Storage: total: 1.38 TiB used: 503.89 GiB (35.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW512G8L
lanes: 4 tech: SSD serial: <filter> fw-rev: L02C temp: 34.9 C scheme: GPT
SMART: yes health: PASSED on: 2y 29d 1h cycles: 4,766
read-units: 69,696,072 [35.6 TB] written-units: 78,519,818 [40.2 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD10JPVX-22JC3T0 family: Blue Mobile size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s tech: HDD
rpm: 5400 serial: <filter> fw-rev: 1A01 temp: 39 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 3y 104d 2h cycles: 8722
Old-Age: g-sense error rate: 549
<REMOVED>
ID-1: swap-1 type: partition size: 10 GiB used: 837.2 MiB (8.2%)
priority: -2 dev: /dev/nvme0n1p9 maj-min: 259:9 label: N/A uuid: <filter>
ID-2: swap-2 type: file size: 7.63 GiB used: 0 KiB (0.0%) priority: -3
file: /swapfile
<REMOVED>
<REMOVED>
System Temperatures: cpu: 52.0 C pch: 49.0 C mobo: N/A
Fan Speeds (rpm): N/A
<REMOVED, up-to-date branch testing, flatpak pkgs: 0>
Processes:
CPU top: 5 of 245
1: cpu: 28.3% command: utop started-by: ocamlrun pid: 62657
mem: 5752.1 MiB (73.6%)
2: cpu: 12.2% command: kwin_x11 pid: 1205 mem: 71.7 MiB (0.9%)
3: cpu: 9.7% command: Xorg pid: 803 mem: 64.7 MiB (0.8%)
4: cpu: 1.3% command: pulseaudio pid: 1241 mem: 17.9 MiB (0.2%)
5: cpu: 1.0% command: plasmashell pid: 1235 mem: 251.2 MiB (3.2%)
Memory top: 5 of 245
1: mem: 5752.1 MiB (73.6%) command: utop started-by: ocamlrun pid: 62657
cpu: 28.3%
2: mem: 251.2 MiB (3.2%) command: plasmashell pid: 1235 cpu: 1.0%
3: mem: 71.7 MiB (0.9%) command: kwin_x11 pid: 1205 cpu: 12.2%
4: mem: 66.4 MiB (0.8%) command: yakuake pid: 1510 cpu: 0.1%
5: mem: 64.7 MiB (0.8%) command: Xorg pid: 803 cpu: 9.7%
Processes: 245 Power: uptime: 6h 24m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 fails: 16 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 3.02 GiB
services: org_kde_powerdevil,upowerd Init: systemd v: 257
Compilers: clang: 20.1.8 gcc: 15.1.1 Shell: Zsh v: 5.9 running-in: yakuake
inxi: 3.3.38
❯ systemctl suspend
(failed)
❯ LC_ALL=C journalctl --catalog --boot=0
Jul 19 23:46:12 $HOSTNAME polkitd[671]: Registered Authentication Agent for unix-process:62867:2309848 (system bus name :1.363 [/usr/bin/pkttyagent --notify-fd 6 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale fr_FR.UTF-8)
Jul 19 23:46:12 $HOSTNAME systemd-logind[674]: The system will suspend now!
Jul 19 23:46:12 $HOSTNAME NetworkManager[664]: <info> [1752961572.9206] manager: sleep: sleep requested (sleeping: no enabled: yes)
Jul 19 23:46:12 $HOSTNAME NetworkManager[664]: <info> [1752961572.9211] device (enp8s0): state change: unavailable -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
Jul 19 23:46:12 $HOSTNAME ModemManager[751]: <msg> [sleep-monitor-systemd] system is about to suspend
Jul 19 23:46:12 $HOSTNAME NetworkManager[664]: <info> [1752961572.9280] device (wlp7s0): state change: unavailable -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
Jul 19 23:46:12 $HOSTNAME NetworkManager[664]: <info> [1752961572.9283] device (wlp7s0): set-hw-addr: reset MAC address to 10:63:C8:76:2B:EB (unmanage)
Jul 19 23:46:12 $HOSTNAME NetworkManager[664]: <info> [1752961572.9287] device (p2p-dev-wlp7s0): state change: unavailable -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
Jul 19 23:46:12 $HOSTNAME NetworkManager[664]: <info> [1752961572.9288] manager: NetworkManager state is now ASLEEP
Jul 19 23:46:12 $HOSTNAME polkitd[671]: Unregistered Authentication Agent for unix-process:unknown (system bus name :1.363, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale fr_FR.UTF-8) (disconnected from bus)
Jul 19 23:46:13 $HOSTNAME systemd[1]: Reached target Sleep.
-- Subject: A start job for unit sleep.target has finished successfully
-- Defined-By: systemd
-- Support: https://forum.manjaro.org/c/support
-- A start job for unit sleep.target has finished successfully.
-- The job identifier is 11271.
Jul 19 23:46:13 $HOSTNAME systemd[1]: Starting NVIDIA system suspend actions...
-- Subject: A start job for unit nvidia-suspend.service has begun execution
-- A start job for unit nvidia-suspend.service has begun execution.
-- The job identifier is 11272.
Jul 19 23:46:13 $HOSTNAME suspend[62923]: nvidia-suspend.service
Jul 19 23:46:13 $HOSTNAME logger[62923]: <13>Jul 19 23:46:13 suspend: nvidia-suspend.service
Jul 19 23:46:13 $HOSTNAME kernel: ------------[ cut here ]------------
Jul 19 23:46:13 $HOSTNAME kernel: WARNING: CPU: 5 PID: 62928 at nvidia/nv.c:4648 nv_set_system_power_state+0x41e/0x480 [nvidia]
Jul 19 23:46:13 $HOSTNAME kernel: Modules linked in: udp_diag tcp_diag inet_diag tls ccm rfcomm qrtr squashfs uhid cmac algif_hash algif_skcipher af_alg bnep uinput nvidia_uvm(POE) snd_sof_pci_intel_cnl snd_sof_intel_hda_generic soundwire_intel snd_sof_intel_hda_sdw_bpt snd_sof_intel_hda_common snd_soc_hdac_hda snd_sof_intel_hda_mlink snd_sof_intel_hda soundwire_cadence snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_acpi_intel_match intel_uncore_frequency uvcvideo snd_soc_acpi_intel_sdca_quirks intel_uncore_frequency_common soundwire_generic_allocation snd_soc_acpi videobuf2_vmalloc uvc soundwire_bus videobuf2_memops snd_soc_sdca videobuf2_v4l2 intel_tcc_cooling crc8 videobuf2_common btusb x86_pkg_temp_thermal intel_powerclamp snd_soc_avs btrtl coretemp snd_soc_hda_codec videodev btintel snd_hda_ext_core btbcm snd_hda_codec_realtek btmtk mc kvm_intel snd_soc_core snd_hda_codec_generic ath10k_pci bluetooth snd_compress snd_hda_scodec_component ac97_bus kvm snd_hda_codec_hdmi ath10k_core snd_pcm_dmaengine snd_hda_intel
Jul 19 23:46:13 $HOSTNAME kernel: irqbypass polyval_clmulni snd_intel_dspcfg joydev ath polyval_generic snd_intel_sdw_acpi mousedev iTCO_wdt snd_hda_codec ghash_clmulni_intel mac80211 sha512_ssse3 intel_pmc_bxt 8250_dw processor_thermal_device_pci_legacy iTCO_vendor_support sha256_ssse3 intel_rapl_msr sha1_ssse3 processor_thermal_device processor_thermal_wt_hint snd_hda_core aesni_intel crypto_simd processor_thermal_rfim r8169 snd_hwdep processor_thermal_rapl cryptd nvidia_drm(POE) mei_hdcp mei_pxp libarc4 rapl nvidia_modeset(POE) intel_rapl_common realtek snd_pcm i2c_i801 vfat intel_cstate spi_nor snd_timer intel_lpss_pci mdio_devres processor_thermal_wt_req i2c_smbus fat intel_uncore cfg80211 pcspkr intel_wmi_thunderbolt wmi_bmof libphy mtd i2c_mux snd mei_me ideapad_laptop intel_lpss i2c_hid_acpi processor_thermal_power_floor soundcore drm_ttm_helper i2c_hid platform_profile idma64 processor_thermal_mbox mei sparse_keymap elan_i2c intel_soc_dts_iosf intel_pch_thermal int3403_thermal rfkill intel_pmc_core int340x_thermal_zone
Jul 19 23:46:13 $HOSTNAME kernel: pmt_telemetry nvidia(POE) pmt_class int3400_thermal acpi_pad acpi_tad intel_vsec pinctrl_cannonlake acpi_thermal_rel mac_hid sg crypto_user loop dm_mod nfnetlink ip_tables x_tables i915 i2c_algo_bit drm_buddy nvme ttm nvme_core intel_gtt nvme_keyring spi_intel_pci serio_raw drm_display_helper spi_intel nvme_auth cec video wmi
Jul 19 23:46:13 $HOSTNAME kernel: CPU: 5 UID: 0 PID: 62928 Comm: nvidia-sleep.sh Tainted: P W OE 6.15.6-1-MANJARO #1 PREEMPT(full) c78dfb73bc6d0427c63a6ddf45ed4497a5261954
Jul 19 23:46:14 $HOSTNAME kernel: Tainted: [P]=PROPRIETARY_MODULE, [W]=WARN, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
Jul 19 23:46:14 $HOSTNAME kernel: Hardware name: LENOVO 81LK/LNVNB161216, BIOS BGCN36WW 05/24/2022
Jul 19 23:46:14 $HOSTNAME kernel: RIP: 0010:nv_set_system_power_state+0x41e/0x480 [nvidia]
Jul 19 23:46:14 $HOSTNAME kernel: Code: 75 0e eb 3f 48 8b ad d0 06 00 00 48 85 ed 74 33 48 8b bd 30 03 00 00 ba 01 00 00 00 44 89 e6 e8 08 c8 ff ff 89 c3 85 c0 74 da <0f> 0b 48 c7 c7 70 ff f7 c1 41 bc 01 00 00 00 e8 1e 23 72 d7 e9 ef
Jul 19 23:46:14 $HOSTNAME kernel: RSP: 0018:ffffd0da061fb9d8 EFLAGS: 00010202
Jul 19 23:46:14 $HOSTNAME kernel: RAX: 0000000000000051 RBX: 0000000000000051 RCX: ffff8c528b2f86b0
Jul 19 23:46:14 $HOSTNAME kernel: RDX: ffff8c528b2f86b0 RSI: 0000000000000282 RDI: ffff8c528b2f86a8
Jul 19 23:46:14 $HOSTNAME kernel: RBP: ffff8c528b2f8000 R08: 0000000000000000 R09: ffffffffc0e01bf4
Jul 19 23:46:14 $HOSTNAME kernel: R10: ffff8c53107c8000 R11: fffff6160641f200 R12: 0000000000000001
Jul 19 23:46:14 $HOSTNAME kernel: R13: 0000000000000000 R14: ffff8c53107c8000 R15: ffff8c528b2f86a8
Jul 19 23:46:14 $HOSTNAME kernel: FS: 00007fcb3c9e7b80(0000) GS:ffff8c544c06d000(0000) knlGS:0000000000000000
Jul 19 23:46:14 $HOSTNAME kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Jul 19 23:46:14 $HOSTNAME kernel: CR2: 00005616f0bfb3b0 CR3: 000000010f88a004 CR4: 00000000003726f0
Jul 19 23:46:14 $HOSTNAME kernel: Call Trace:
Jul 19 23:46:14 $HOSTNAME kernel: <TASK>
Jul 19 23:46:14 $HOSTNAME kernel: nv_procfs_write_suspend+0xfe/0x180 [nvidia 94afa3767297af80bd646f5b9a33ade4ba16a3ee]
Jul 19 23:46:14 $HOSTNAME kernel: proc_reg_write+0x57/0xb0
Jul 19 23:46:14 $HOSTNAME kernel: vfs_write+0xef/0x470
Jul 19 23:46:14 $HOSTNAME kernel: ? f_dupfd+0x62/0xb0
Jul 19 23:46:14 $HOSTNAME kernel: ? do_fcntl+0x422/0x840
Jul 19 23:46:14 $HOSTNAME kernel: ? do_truncate+0xab/0xf0
Jul 19 23:46:14 $HOSTNAME kernel: ksys_write+0x73/0xe0
Jul 19 23:46:14 $HOSTNAME kernel: do_syscall_64+0x7b/0x810
Jul 19 23:46:14 $HOSTNAME kernel: ? _copy_to_user+0x36/0x50
Jul 19 23:46:14 $HOSTNAME kernel: ? cp_new_stat+0x130/0x170
Jul 19 23:46:14 $HOSTNAME kernel: ? __do_sys_newfstat+0x68/0x70
Jul 19 23:46:14 $HOSTNAME kernel: ? syscall_exit_to_user_mode+0x37/0x1c0
Jul 19 23:46:14 $HOSTNAME kernel: ? do_syscall_64+0x87/0x810
Jul 19 23:46:14 $HOSTNAME kernel: ? filp_flush+0x61/0xa0
Jul 19 23:46:14 $HOSTNAME kernel: ? filp_close+0x25/0x40
Jul 19 23:46:14 $HOSTNAME kernel: ? do_dup2+0xae/0x160
Jul 19 23:46:14 $HOSTNAME kernel: ? ksys_dup3+0x67/0xf0
Jul 19 23:46:14 $HOSTNAME kernel: ? __count_memcg_events+0xb0/0x150
Jul 19 23:46:14 $HOSTNAME kernel: ? count_memcg_events.constprop.0+0x1a/0x30
Jul 19 23:46:14 $HOSTNAME kernel: ? handle_mm_fault+0x1d2/0x2d0
Jul 19 23:46:14 $HOSTNAME kernel: ? do_user_addr_fault+0x21a/0x690
Jul 19 23:46:14 $HOSTNAME kernel: ? irqentry_exit_to_user_mode+0x2c/0x1b0
Jul 19 23:46:14 $HOSTNAME kernel: entry_SYSCALL_64_after_hwframe+0x76/0x7e
Jul 19 23:46:14 $HOSTNAME kernel: RIP: 0033:0x7fcb3caea006
Jul 19 23:46:14 $HOSTNAME kernel: Code: 5d e8 41 8b 93 08 03 00 00 59 5e 48 83 f8 fc 75 19 83 e2 39 83 fa 08 75 11 e8 26 ff ff ff 66 0f 1f 44 00 00 48 8b 45 10 0f 05 <48> 8b 5d f8 c9 c3 0f 1f 40 00 f3 0f 1e fa 55 48 89 e5 48 83 ec 08
Jul 19 23:46:14 $HOSTNAME kernel: RSP: 002b:00007ffef5675800 EFLAGS: 00000202 ORIG_RAX: 0000000000000001
Jul 19 23:46:14 $HOSTNAME kernel: RAX: ffffffffffffffda RBX: 0000000000000008 RCX: 00007fcb3caea006
Jul 19 23:46:14 $HOSTNAME kernel: RDX: 0000000000000008 RSI: 0000561710766a40 RDI: 0000000000000001
Jul 19 23:46:14 $HOSTNAME kernel: RBP: 00007ffef5675820 R08: 0000000000000000 R09: 0000000000000000
Jul 19 23:46:14 $HOSTNAME kernel: R10: 0000000000000000 R11: 0000000000000202 R12: 0000000000000008
Jul 19 23:46:14 $HOSTNAME kernel: R13: 0000561710766a40 R14: 00007fcb3cc3f5c0 R15: 00005617107653a0
Jul 19 23:46:14 $HOSTNAME kernel: </TASK>
Jul 19 23:46:14 $HOSTNAME kernel: ---[ end trace 0000000000000000 ]---
Jul 19 23:46:14 $HOSTNAME nvidia-sleep.sh[62928]: /usr/bin/nvidia-sleep.sh: ligne 45 : echo: erreur d'écriture: Erreur d'entrée/sortie
Jul 19 23:46:14 $HOSTNAME systemd[1]: nvidia-suspend.service: Main process exited, code=exited, status=1/FAILURE
-- Subject: Unit process exited
-- An ExecStart= process belonging to unit nvidia-suspend.service has exited.
-- The process' exit code is 'exited' and its exit status is 1.
Jul 19 23:46:14 $HOSTNAME systemd[1]: nvidia-suspend.service: Failed with result 'exit-code'.
-- Subject: Unit failed
-- The unit nvidia-suspend.service has entered the 'failed' state with result 'exit-code'.
Jul 19 23:46:14 $HOSTNAME systemd[1]: Failed to start NVIDIA system suspend actions.
-- Subject: A start job for unit nvidia-suspend.service has failed
-- A start job for unit nvidia-suspend.service has finished with a failure.
-- The job identifier is 11272 and the job result is failed.
Jul 19 23:46:14 $HOSTNAME systemd[1]: Starting System Suspend...
-- Subject: A start job for unit systemd-suspend.service has begun execution
-- A start job for unit systemd-suspend.service has begun execution.
-- The job identifier is 11268.
Jul 19 23:46:14 $HOSTNAME systemd-sleep[62940]: User sessions remain unfrozen on explicit request ($SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=0).
Jul 19 23:46:14 $HOSTNAME systemd-sleep[62940]: This is not recommended, and might result in unexpected behavior, particularly
Jul 19 23:46:14 $HOSTNAME systemd-sleep[62940]: in suspend-then-hibernate operations or setups with encrypted home directories.
Jul 19 23:46:14 $HOSTNAME systemd-sleep[62940]: Performing sleep operation 'suspend'...
-- Subject: System sleep state suspend entered
-- The system has now entered the suspend sleep state.
Jul 19 23:46:14 $HOSTNAME kernel: PM: suspend entry (deep)
Jul 19 23:46:14 $HOSTNAME kernel: Filesystems sync: 0.003 seconds
Jul 19 23:46:16 $HOSTNAME kernel: Freezing user space processes
Jul 19 23:46:16 $HOSTNAME kernel: Freezing user space processes completed (elapsed 0.001 seconds)
Jul 19 23:46:16 $HOSTNAME kernel: OOM killer disabled.
Jul 19 23:46:16 $HOSTNAME kernel: Freezing remaining freezable tasks
Jul 19 23:46:16 $HOSTNAME kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
Jul 19 23:46:16 $HOSTNAME kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Jul 19 23:46:16 $HOSTNAME kernel: NVRM: GPU 0000:01:00.0: PreserveVideoMemoryAllocations module parameter is set. System Power Management attempted without driver procfs suspend interface. Please refer to the 'Configuring Power Management Support' section in the driver README.
Jul 19 23:46:16 $HOSTNAME kernel: sd 4:0:0:0: [sda] Synchronizing SCSI cache
Jul 19 23:46:16 $HOSTNAME kernel: nvidia 0000:01:00.0: PM: pci_pm_suspend(): nv_pmops_suspend [nvidia] returns -5
Jul 19 23:46:16 $HOSTNAME kernel: ata5.00: Entering standby power mode
Jul 19 23:46:16 $HOSTNAME kernel: nvidia 0000:01:00.0: PM: dpm_run_callback(): pci_pm_suspend returns -5
Jul 19 23:46:16 $HOSTNAME kernel: nvidia 0000:01:00.0: PM: failed to suspend async: error -5
Jul 19 23:46:16 $HOSTNAME kernel: PM: Some devices failed to suspend, or early wake event detected
Jul 19 23:46:16 $HOSTNAME kernel: nvme nvme0: 8/0/0 default/read/poll queues
Jul 19 23:46:16 $HOSTNAME kernel: ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Jul 19 23:46:16 $HOSTNAME kernel: sd 4:0:0:0: [sda] Starting disk
Jul 19 23:46:16 $HOSTNAME kernel: ata5.00: configured for UDMA/133
Jul 19 23:46:16 $HOSTNAME kernel: ata5.00: Entering active power mode
Jul 19 23:46:16 $HOSTNAME kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
Jul 19 23:46:16 $HOSTNAME kernel: OOM killer enabled.
Jul 19 23:46:16 $HOSTNAME kernel: Restarting tasks ... done.
Jul 19 23:46:16 $HOSTNAME kernel: random: crng reseeded on system resumption
Jul 19 23:46:17 $HOSTNAME kernel: PM: suspend exit
Jul 19 23:46:17 $HOSTNAME kernel: PM: suspend entry (s2idle)
Jul 19 23:46:17 $HOSTNAME kernel: Filesystems sync: 0.002 seconds
Jul 19 23:46:18 $HOSTNAME kernel: Freezing user space processes
Jul 19 23:46:18 $HOSTNAME kernel: Freezing user space processes completed (elapsed 0.001 seconds)
Jul 19 23:46:18 $HOSTNAME kernel: OOM killer disabled.
Jul 19 23:46:18 $HOSTNAME kernel: Freezing remaining freezable tasks
Jul 19 23:46:18 $HOSTNAME kernel: Freezing remaining freezable tasks completed (elapsed 0.000 seconds)
Jul 19 23:46:18 $HOSTNAME kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Jul 19 23:46:18 $HOSTNAME kernel: sd 4:0:0:0: [sda] Synchronizing SCSI cache
Jul 19 23:46:18 $HOSTNAME kernel: NVRM: GPU 0000:01:00.0: PreserveVideoMemoryAllocations module parameter is set. System Power Management attempted without driver procfs suspend interface. Please refer to the 'Configuring Power Management Support' section in the driver README.
Jul 19 23:46:18 $HOSTNAME kernel: nvidia 0000:01:00.0: PM: pci_pm_suspend(): nv_pmops_suspend [nvidia] returns -5
Jul 19 23:46:18 $HOSTNAME kernel: ata5.00: Entering standby power mode
Jul 19 23:46:18 $HOSTNAME kernel: nvidia 0000:01:00.0: PM: dpm_run_callback(): pci_pm_suspend returns -5
Jul 19 23:46:18 $HOSTNAME kernel: nvidia 0000:01:00.0: PM: failed to suspend async: error -5
Jul 19 23:46:18 $HOSTNAME kernel: PM: Some devices failed to suspend, or early wake event detected
Jul 19 23:46:18 $HOSTNAME kernel: OOM killer enabled.
Jul 19 23:46:18 $HOSTNAME kernel: Restarting tasks ... done.
Jul 19 23:46:18 $HOSTNAME kernel: random: crng reseeded on system resumption
Jul 19 23:46:18 $HOSTNAME systemd-sleep[62940]: Failed to put system to sleep. System resumed again: Input/output error
-- Subject: System sleep state suspend left
-- The system has now left the suspend sleep state.
Jul 19 23:46:18 $HOSTNAME kernel: PM: suspend exit
Jul 19 23:46:18 $HOSTNAME kernel: ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
Jul 19 23:46:18 $HOSTNAME kernel: sd 4:0:0:0: [sda] Starting disk
Jul 19 23:46:18 $HOSTNAME kernel: ata5.00: configured for UDMA/133
Jul 19 23:46:18 $HOSTNAME kernel: ata5.00: Entering active power mode
Jul 19 23:46:18 $HOSTNAME kernel: mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
Jul 19 23:46:18 $HOSTNAME plasmashell[1235]: kpipewire_logging: PipeWire remote error: -116 no global 37 any more
Jul 19 23:46:19 $HOSTNAME kcminit[63191]: Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_mouse.so"
Jul 19 23:46:19 $HOSTNAME kcminit[63191]: Initializing "/usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_touchpad.so"
Jul 19 23:46:19 $HOSTNAME kcminit[63191]: kcm_touchpad: Using X11 backend
Jul 19 23:46:19 $HOSTNAME systemd[1]: systemd-suspend.service: Main process exited, code=exited, status=1/FAILURE
-- An ExecStart= process belonging to unit systemd-suspend.service has exited.
Jul 19 23:46:19 $HOSTNAME systemd[1]: systemd-suspend.service: Failed with result 'exit-code'.
-- The unit systemd-suspend.service has entered the 'failed' state with result 'exit-code'.
Jul 19 23:46:19 $HOSTNAME systemd[1]: Failed to start System Suspend.
-- Subject: A start job for unit systemd-suspend.service has failed
-- A start job for unit systemd-suspend.service has finished with a failure.
-- The job identifier is 11268 and the job result is failed.
Jul 19 23:46:19 $HOSTNAME systemd[1]: Dependency failed for Suspend.
-- Subject: A start job for unit suspend.target has failed
-- A start job for unit suspend.target has finished with a failure.
-- The job identifier is 11267 and the job result is dependency.
Jul 19 23:46:19 $HOSTNAME systemd[1]: suspend.target: Job suspend.target/start failed with result 'dependency'.
Jul 19 23:46:19 $HOSTNAME systemd-logind[674]: Operation 'suspend' finished.
Jul 19 23:46:19 $HOSTNAME NetworkManager[664]: <info> [1752961579.7418] manager: sleep: wake requested (sleeping: yes enabled: yes)
Jul 19 23:46:19 $HOSTNAME ModemManager[751]: <msg> [sleep-monitor-systemd] system is resuming
Jul 19 23:46:19 $HOSTNAME NetworkManager[664]: <info> [1752961579.7427] device (enp8s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
Jul 19 23:46:19 $HOSTNAME systemd[1]: Stopped target Sleep.
-- Subject: A stop job for unit sleep.target has finished
-- A stop job for unit sleep.target has finished.
-- The job identifier is 11430 and the job result is done.
Jul 19 23:46:19 $HOSTNAME bluetoothd[667]: Failed to set mode: Failed (0x03)
Jul 19 23:46:19 $HOSTNAME kded6[1204]: kf.bluezqt: PendingCall Error: "Failed"
Jul 19 23:46:19 $HOSTNAME systemd[1]: Starting NVIDIA system resume actions...
-- Subject: A start job for unit nvidia-resume.service has begun execution
-- A start job for unit nvidia-resume.service has begun execution.
-- The job identifier is 11429.
Jul 19 23:46:19 $HOSTNAME kernel: Generic FE-GE Realtek PHY r8169-0-800:00: attached PHY driver (mii_bus:phy_addr=r8169-0-800:00, irq=MAC)
Jul 19 23:46:19 $HOSTNAME suspend[63261]: nvidia-resume.service
Jul 19 23:46:19 $HOSTNAME logger[63261]: <13>Jul 19 23:46:19 suspend: nvidia-resume.service
Jul 19 23:46:19 $HOSTNAME systemd[1]: nvidia-resume.service: Deactivated successfully.
-- Subject: Unit succeeded
-- The unit nvidia-resume.service has successfully entered the 'dead' state.
Jul 19 23:46:19 $HOSTNAME systemd[1]: Finished NVIDIA system resume actions.
-- Subject: A start job for unit nvidia-resume.service has finished successfully
-- A start job for unit nvidia-resume.service has finished successfully.
Jul 19 23:46:19 $HOSTNAME kernel: r8169 0000:08:00.0 enp8s0: Link is Down
Jul 19 23:46:19 $HOSTNAME NetworkManager[664]: <info> [1752961579.9187] device (wlp7s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
Jul 19 23:46:19 $HOSTNAME NetworkManager[664]: <info> [1752961579.9229] device (wlp7s0): set-hw-addr: set MAC address to CE:8A:11:81:F1:51 (scanning)
Jul 19 23:46:19 $HOSTNAME NetworkManager[664]: <info> [1752961579.9243] device (p2p-dev-wlp7s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
Jul 19 23:46:19 $HOSTNAME NetworkManager[664]: <info> [1752961579.9262] manager: NetworkManager state is now DISCONNECTED
Jul 19 23:46:23 $HOSTNAME ModemManager[751]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1d.4/0000:07:00.0': not supported by any plugin
Jul 19 23:46:23 $HOSTNAME ModemManager[751]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1d.5/0000:08:00.0': not supported by any plugin
(corresponding dmesg)
[20886.121505] ------------[ cut here ]------------
[20886.121508] WARNING: CPU: 5 PID: 62928 at nvidia/nv.c:4648 nv_set_system_power_state+0x41e/0x480 [nvidia]
[20886.122015] Modules linked in: udp_diag tcp_diag inet_diag tls ccm rfcomm qrtr squashfs uhid cmac algif_hash algif_skcipher af_alg bnep uinput nvidia_uvm(POE) snd_sof_pci_intel_cnl snd_sof_intel_hda_generic soundwire_intel snd_sof_intel_hda_sdw_bpt snd_sof_intel_hda_common snd_soc_hdac_hda snd_sof_intel_hda_mlink snd_sof_intel_hda soundwire_cadence snd_sof_pci snd_sof_xtensa_dsp snd_sof snd_sof_utils snd_soc_acpi_intel_match intel_uncore_frequency uvcvideo snd_soc_acpi_intel_sdca_quirks intel_uncore_frequency_common soundwire_generic_allocation snd_soc_acpi videobuf2_vmalloc uvc soundwire_bus videobuf2_memops snd_soc_sdca videobuf2_v4l2 intel_tcc_cooling crc8 videobuf2_common btusb x86_pkg_temp_thermal intel_powerclamp snd_soc_avs btrtl coretemp snd_soc_hda_codec videodev btintel snd_hda_ext_core btbcm snd_hda_codec_realtek btmtk mc kvm_intel snd_soc_core snd_hda_codec_generic ath10k_pci bluetooth snd_compress snd_hda_scodec_component ac97_bus kvm snd_hda_codec_hdmi ath10k_core snd_pcm_dmaengine snd_hda_intel
[20886.122057] irqbypass polyval_clmulni snd_intel_dspcfg joydev ath polyval_generic snd_intel_sdw_acpi mousedev iTCO_wdt snd_hda_codec ghash_clmulni_intel mac80211 sha512_ssse3 intel_pmc_bxt 8250_dw processor_thermal_device_pci_legacy iTCO_vendor_support sha256_ssse3 intel_rapl_msr sha1_ssse3 processor_thermal_device processor_thermal_wt_hint snd_hda_core aesni_intel crypto_simd processor_thermal_rfim r8169 snd_hwdep processor_thermal_rapl cryptd nvidia_drm(POE) mei_hdcp mei_pxp libarc4 rapl nvidia_modeset(POE) intel_rapl_common realtek snd_pcm i2c_i801 vfat intel_cstate spi_nor snd_timer intel_lpss_pci mdio_devres processor_thermal_wt_req i2c_smbus fat intel_uncore cfg80211 pcspkr intel_wmi_thunderbolt wmi_bmof libphy mtd i2c_mux snd mei_me ideapad_laptop intel_lpss i2c_hid_acpi processor_thermal_power_floor soundcore drm_ttm_helper i2c_hid platform_profile idma64 processor_thermal_mbox mei sparse_keymap elan_i2c intel_soc_dts_iosf intel_pch_thermal int3403_thermal rfkill intel_pmc_core int340x_thermal_zone
[20886.122101] pmt_telemetry nvidia(POE) pmt_class int3400_thermal acpi_pad acpi_tad intel_vsec pinctrl_cannonlake acpi_thermal_rel mac_hid sg crypto_user loop dm_mod nfnetlink ip_tables x_tables i915 i2c_algo_bit drm_buddy nvme ttm nvme_core intel_gtt nvme_keyring spi_intel_pci serio_raw drm_display_helper spi_intel nvme_auth cec video wmi
[20886.122123] CPU: 5 UID: 0 PID: 62928 Comm: nvidia-sleep.sh Tainted: P W OE 6.15.6-1-MANJARO #1 PREEMPT(full) c78dfb73bc6d0427c63a6ddf45ed4497a5261954
[20886.122127] Tainted: [P]=PROPRIETARY_MODULE, [W]=WARN, [O]=OOT_MODULE, [E]=UNSIGNED_MODULE
[20886.122128] Hardware name: LENOVO 81LK/LNVNB161216, BIOS BGCN36WW 05/24/2022
[20886.122130] RIP: 0010:nv_set_system_power_state+0x41e/0x480 [nvidia]
[20886.122432] Code: 75 0e eb 3f 48 8b ad d0 06 00 00 48 85 ed 74 33 48 8b bd 30 03 00 00 ba 01 00 00 00 44 89 e6 e8 08 c8 ff ff 89 c3 85 c0 74 da <0f> 0b 48 c7 c7 70 ff f7 c1 41 bc 01 00 00 00 e8 1e 23 72 d7 e9 ef
[20886.122434] RSP: 0018:ffffd0da061fb9d8 EFLAGS: 00010202
[20886.122436] RAX: 0000000000000051 RBX: 0000000000000051 RCX: ffff8c528b2f86b0
[20886.122438] RDX: ffff8c528b2f86b0 RSI: 0000000000000282 RDI: ffff8c528b2f86a8
[20886.122439] RBP: ffff8c528b2f8000 R08: 0000000000000000 R09: ffffffffc0e01bf4
[20886.122440] R10: ffff8c53107c8000 R11: fffff6160641f200 R12: 0000000000000001
[20886.122441] R13: 0000000000000000 R14: ffff8c53107c8000 R15: ffff8c528b2f86a8
[20886.122443] FS: 00007fcb3c9e7b80(0000) GS:ffff8c544c06d000(0000) knlGS:0000000000000000
[20886.122444] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
[20886.122445] CR2: 00005616f0bfb3b0 CR3: 000000010f88a004 CR4: 00000000003726f0
[20886.122447] Call Trace:
[20886.122450] <TASK>
[20886.122453] nv_procfs_write_suspend+0xfe/0x180 [nvidia 94afa3767297af80bd646f5b9a33ade4ba16a3ee]
[20886.122759] proc_reg_write+0x57/0xb0
[20886.122763] vfs_write+0xef/0x470
[20886.122766] ? f_dupfd+0x62/0xb0
[20886.122769] ? do_fcntl+0x422/0x840
[20886.122772] ? do_truncate+0xab/0xf0
[20886.122775] ksys_write+0x73/0xe0
[20886.122778] do_syscall_64+0x7b/0x810
[20886.122781] ? _copy_to_user+0x36/0x50
[20886.122783] ? cp_new_stat+0x130/0x170
[20886.122787] ? __do_sys_newfstat+0x68/0x70
[20886.122791] ? syscall_exit_to_user_mode+0x37/0x1c0
[20886.122794] ? do_syscall_64+0x87/0x810
[20886.122797] ? filp_flush+0x61/0xa0
[20886.122799] ? filp_close+0x25/0x40
[20886.122801] ? do_dup2+0xae/0x160
[20886.122803] ? ksys_dup3+0x67/0xf0
[20886.122805] ? syscall_exit_to_user_mode+0x37/0x1c0
[20886.122807] ? do_syscall_64+0x87/0x810
[20886.122809] ? __count_memcg_events+0xb0/0x150
[20886.122811] ? count_memcg_events.constprop.0+0x1a/0x30
[20886.122814] ? handle_mm_fault+0x1d2/0x2d0
[20886.122816] ? do_user_addr_fault+0x21a/0x690
[20886.122820] ? irqentry_exit_to_user_mode+0x2c/0x1b0
[20886.122822] entry_SYSCALL_64_after_hwframe+0x76/0x7e
[20886.122824] RIP: 0033:0x7fcb3caea006
[20886.122848] Code: 5d e8 41 8b 93 08 03 00 00 59 5e 48 83 f8 fc 75 19 83 e2 39 83 fa 08 75 11 e8 26 ff ff ff 66 0f 1f 44 00 00 48 8b 45 10 0f 05 <48> 8b 5d f8 c9 c3 0f 1f 40 00 f3 0f 1e fa 55 48 89 e5 48 83 ec 08
[20886.122849] RSP: 002b:00007ffef5675800 EFLAGS: 00000202 ORIG_RAX: 0000000000000001
[20886.122852] RAX: ffffffffffffffda RBX: 0000000000000008 RCX: 00007fcb3caea006
[20886.122853] RDX: 0000000000000008 RSI: 0000561710766a40 RDI: 0000000000000001
[20886.122854] RBP: 00007ffef5675820 R08: 0000000000000000 R09: 0000000000000000
[20886.122855] R10: 0000000000000000 R11: 0000000000000202 R12: 0000000000000008
[20886.122856] R13: 0000561710766a40 R14: 00007fcb3cc3f5c0 R15: 00005617107653a0
[20886.122859] </TASK>
[20886.122860] ---[ end trace 0000000000000000 ]---
[20886.436163] PM: suspend entry (deep)
[20886.439869] Filesystems sync: 0.003 seconds
[20886.961928] Freezing user space processes
[20886.963520] Freezing user space processes completed (elapsed 0.001 seconds)
[20886.963523] OOM killer disabled.
[20886.963524] Freezing remaining freezable tasks
[20886.964542] Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
[20886.964641] printk: Suspending console(s) (use no_console_suspend to debug)
[20887.016993] NVRM: GPU 0000:01:00.0: PreserveVideoMemoryAllocations module parameter is set. System Power Management attempted without driver procfs suspend interface. Please refer to the 'Configuring Power Management Support' section in the driver README.
[20887.017023] sd 4:0:0:0: [sda] Synchronizing SCSI cache
[20887.017003] nvidia 0000:01:00.0: PM: pci_pm_suspend(): nv_pmops_suspend [nvidia] returns -5
[20887.017372] ata5.00: Entering standby power mode
[20887.017598] nvidia 0000:01:00.0: PM: dpm_run_callback(): pci_pm_suspend returns -5
[20887.017604] nvidia 0000:01:00.0: PM: failed to suspend async: error -5
[20887.581561] PM: Some devices failed to suspend, or early wake event detected
[20887.598558] nvme nvme0: 8/0/0 default/read/poll queues
[20887.890766] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[20887.891519] sd 4:0:0:0: [sda] Starting disk
[20887.892178] ata5.00: configured for UDMA/133
[20887.892238] ata5.00: Entering active power mode
[20889.085365] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
[20889.086317] OOM killer enabled.
[20889.086322] Restarting tasks ... done.
[20889.089562] random: crng reseeded on system resumption
[20889.155420] PM: suspend exit
[20889.155522] PM: suspend entry (s2idle)
[20889.157661] Filesystems sync: 0.002 seconds
[20889.616556] Freezing user space processes
[20889.618550] Freezing user space processes completed (elapsed 0.001 seconds)
[20889.618555] OOM killer disabled.
[20889.618557] Freezing remaining freezable tasks
[20889.619553] Freezing remaining freezable tasks completed (elapsed 0.000 seconds)
[20889.619561] printk: Suspending console(s) (use no_console_suspend to debug)
[20889.632599] sd 4:0:0:0: [sda] Synchronizing SCSI cache
[20889.633139] NVRM: GPU 0000:01:00.0: PreserveVideoMemoryAllocations module parameter is set. System Power Management attempted without driver procfs suspend interface. Please refer to the 'Configuring Power Management Support' section in the driver README.
[20889.633151] nvidia 0000:01:00.0: PM: pci_pm_suspend(): nv_pmops_suspend [nvidia] returns -5
[20889.634259] ata5.00: Entering standby power mode
[20889.634334] nvidia 0000:01:00.0: PM: dpm_run_callback(): pci_pm_suspend returns -5
[20889.634346] nvidia 0000:01:00.0: PM: failed to suspend async: error -5
[20890.197908] PM: Some devices failed to suspend, or early wake event detected
[20890.317958] OOM killer enabled.
[20890.317960] Restarting tasks ... done.
[20890.318853] random: crng reseeded on system resumption
[20890.385521] PM: suspend exit
[20890.505691] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[20890.506292] sd 4:0:0:0: [sda] Starting disk
[20890.506877] ata5.00: configured for UDMA/133
[20890.506915] ata5.00: Entering active power mode
[20890.526719] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_ops [i915])
[20891.912643] Generic FE-GE Realtek PHY r8169-0-800:00: attached PHY driver (mii_bus:phy_addr=r8169-0-800:00, irq=MAC)
[20892.063721] r8169 0000:08:00.0 enp8s0: Link is Down
I’m available for more info and more experiments (including info I removed from inxi if you explain why they’d be useful to you)
