Hi there,
I want to change the brightness of my built in screen. I am using Wayland, before installing it I had xorg and wrote a script with xrandr to dec/inc brightness with keys. But when I changed to Wayland it clearly wont work that way. I am now unable to control the brightness. First I tried the scroll thing in battery icon, but it tried to change the brightness of external monitor(probably because its the primary one). I tried gammastep and it gave this error
error: XDG_RUNTIME_DIR is invalid or not set in the environment.
Error: Could not connect to wayland display, exiting.
Error: Failed to start adjustment method: wayland
I also tried brightnessctl, but all the device brightnesses were at 0%, which is strange.
Available devices:
Device 'nvidia_wmi_ec_backlight' of class 'backlight':
Current brightness: 0 (-2147483648%)
Max brightness: 0
Device 'input24::compose' of class 'leds':
Current brightness: 0 (0%)
Max brightness: 1
Device 'input4::capslock' of class 'leds':
Max brightness: 1
Device 'input24::capslock' of class 'leds':
Max brightness: 1
Device 'input4::scrolllock' of class 'leds':
Max brightness: 1
Device 'input4::numlock' of class 'leds':
Current brightness: 1 (100%)
Max brightness: 1
Device 'input24::numlock' of class 'leds':
Max brightness: 1
Device 'rtl8xxxu-usb3-2' of class 'leds':
Current brightness: 2 (100%)
Max brightness: 2
Device 'input24::kana' of class 'leds':
Max brightness: 1
Device 'input24::scrolllock' of class 'leds':
Max brightness: 1
Device 'mmc0::' of class 'leds':
Max brightness: 255
I also tried
sudo echo 20 > /sys/class/backlight/nvidia_wmi_ec_backlight/brightness
I got permission denied, also in the file, the brightness and max-brightness were 0.
Does anybody know how to solve this?
Here is info:
Kernel: 6.5.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
Desktop: KDE Plasma v: 5.27.9 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 82UX v: Lenovo Slim 7 16ARH7
serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0T76530 WIN
serial: <superuser required> UEFI: LENOVO v: KLCN19WW date: 06/08/2023
ID-1: BAT0 charge: 52.4 Wh (78.7%) condition: 66.6/75.0 Wh (88.8%)
volts: 15.8 min: 15.4 model: LENOVO AP16L5J status: not charging
Info: 8-core model: AMD Ryzen 7 6800HS Creator Edition bits: 64 type: MT MCP
arch: Zen 3+ rev: 1 cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB
Speed (MHz): avg: 778 high: 2068 min/max: 400/4785 cores: 1: 1467 2: 400
3: 400 4: 400 5: 2068 6: 400 7: 400 8: 400 9: 400 10: 400 11: 1397 12: 1732
13: 400 14: 400 15: 1396 16: 400 bogomips: 102267
Device-1: NVIDIA GA107BM [GeForce RTX 3050 Mobile] vendor: Lenovo
driver: nvidia v: 535.129.03 arch: Ampere bus-ID: 01:00.0
Device-2: AMD Rembrandt [Radeon 680M] vendor: Lenovo driver: amdgpu
v: kernel arch: RDNA-2 bus-ID: 05:00.0 temp: 39.0 C
Device-3: IMC Networks [] driver: uvcvideo type: USB bus-ID: 5-1:2
Display: wayland server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2
compositor: kwin_wayland driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau dri: radeonsi gpu: nvidia,amdgpu resolution:
1: 1920x1080 2: 1707x1067
API: EGL v: 1.5 drivers: nvidia,radeonsi,swrast platforms:
active: wayland,x11,surfaceless,device inactive: gbm,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.1.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (rembrandt LLVM
16.0.6 DRM 3.54 6.5.9-1-MANJARO)
API: Vulkan v: 1.3.269 drivers: nvidia,radv surfaces: xcb,xlib,wayland
devices: 2
Device-1: AMD Rembrandt Radeon High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus-ID: 05:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
driver: snd_pci_acp6x v: kernel bus-ID: 05:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 05:00.6
API: ALSA v: k6.5.9-1-MANJARO status: kernel-api
Server-1: JACK v: 1.9.22 status: off
Server-2: PipeWire v: 0.3.83 status: off
Server-3: PulseAudio v: 16.1 status: active
Device-1: Realtek vendor: Lenovo driver: rtw89_8852be v: kernel port: 2000
bus-ID: 02:00.0
IF: wlp2s0 state: down mac: <filter>
Device-2: KYE Systems (Mouse Systems) GF3000F Ethernet Adapter
driver: hid-generic,usbhid type: USB bus-ID: 3-1:2
Device-1: Realtek [] driver: btusb v: 0.8 type: USB bus-ID: 3-3:3
Local Storage: total: 931.51 GiB used: 100.81 GiB (10.8%)
ID-1: /dev/nvme0n1 vendor: Western Digital model: WD BLACK SN850X 1000GB
size: 931.51 GiB temp: 36.9 C
ID-1: / size: 577.2 GiB used: 100.75 GiB (17.5%) fs: ext4
dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 256 MiB used: 67.5 MiB (26.4%) fs: vfat
dev: /dev/nvme0n1p1
System Temperatures: cpu: 51.6 C mobo: N/A gpu: amdgpu temp: 43.0 C
Fan Speeds (rpm): N/A
Processes: 377 Uptime: 54m Memory: total: 16 GiB note: est.
available: 13.34 GiB used: 5.11 GiB (38.3%) Init: systemd Compilers:
gcc: 13.2.1 clang: 16.0.6 Packages: 1424 Shell: Zsh v: 5.9 inxi: 3.3.31
thank you:)
