Cannot connect to WIFI!
Hello
I’m use tl-wn725n usb adaptor for connecting to network…
But when I’m update manjaro, driver not work and cannot connect to network
$ ifconfig -a
br-cba5408eb4a6: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 172.18.0.1  netmask 255.255.0.0  broadcast 172.18.255.255
        ether 02:42:22:a8:a4:a5  txqueuelen 0  (Ethernet)
        RX packets 0  bytes 0 (0.0 B)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 0  bytes 0 (0.0 B)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
docker0: flags=4099<UP,BROADCAST,MULTICAST>  mtu 1500
        inet 172.17.0.1  netmask 255.255.0.0  broadcast 172.17.255.255
        ether 02:42:b4:ec:13:55  txqueuelen 0  (Ethernet)
lo: flags=73<UP,LOOPBACK,RUNNING>  mtu 65536
        inet 127.0.0.1  netmask 255.0.0.0
        inet6 ::1  prefixlen 128  scopeid 0x10<host>
        loop  txqueuelen 1000  (Local Loopback)
        RX packets 10  bytes 1630 (1.5 KiB)
        TX packets 10  bytes 1630 (1.5 KiB)
$ mhwd --listinstalled
> Installed PCI configs:
         network-r8168            2016.04.20                true            PCI
    video-nvidia-390xx            2021.12.18               false            PCI
           video-linux            2018.05.04                true            PCI
inxi -N
    driver: r8169
  Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
    driver: r8188eu
I search about this issue but can not fix them
Please help me… :pray:
I’m edit post…
thanks @Olli , but 8188eu-dkms had been installed before
$ -Nazi
    lanes: 1 port: de00 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
    driver: r8188eu bus-ID: 2-1:2 chip-ID: 0bda:8179 class-ID: 0000
    serial: <filter>
Based on this comment
lo network interface, does not connect to any network
So still I have no network interface!
I remember seeing topics on this before.
There should be support in the kernel for it with the module rtl8xxxu.
The driver r8188eu has been part of mainline kernel since 2021.
Did you remember the kernel headers when you installed the dkms driver mentioned?
If I was right 510 Of course I am very skeptical
@linux-aarhus
  • delete package yay -Rcns 8188eu-dkms
  • reboot
  • sudo mhwd -i pci network-r8168
  • reboot and work
  • Restart Network Manager if needed sudo systemctl restart NetworkManager
Source
