Cannot connect to WIFI - Beelink mini pc
Hello everyone,
I’m new to Manjaro and relatively new to Linux. Have been using Ubuntu on a virtual machine on Mac previously.
I recently bought a Beelink Ser5 Max mini pc 32GB RAM 1TB SSD, and tried to set it up. It came with Windows 11 Pro pre installed and I was able to connect to my Wifi on the windows os.
I downloaded Manjaro (also tried Ubuntu and Pop os) on a bootable usb to do a clean install and I can’t seem to connect to wifi with any of these Linux distros. (ps I already deleted the windows) The WiFi option does not even exist. I’ve read so many forums where people were able to connect previously and then lost the connection, and followed the steps to no avail. I’ve never been able to connect to WiFi with the Linux distros yet. I also don’t see anything related to WIFI or WLAN in the BIOS.
I have Intel AX200 WIFI6, and since my Manjaro version is 6.16, I should have the driver needed. However, when I checked, it can sense my Intel AX200, but it says driver: N/A. I downloaded the driver, and obviously rebooted, but it still didn’t work. I enabled and disabled the secure boot and nothing worked either. It still says unclaimed network.
I’m at wits end! Please help!! Thank you!
Welcome to the Manjaro community @GypsyVO
My BeeLink SER 5 Max (AMD 5800H) has had no issues with WiFi in the 2 years since I installed Manjaro on it, so if your machine’s specifications are similar, you most likely shouldn’t need to add any special drivers.
Maybe Windows wasn’t properly shut down, and that has blocked Manjaro from accessing the WiFi? I haven’t used Windows in more than 20 years, so others here may be able to provide more advice on that aspect.
Some system info would be helpful. Please post the output of:
inxi -zv8
as per the pre-prepared instructions below:
Update Announcements
System Information
inxi --filter --verbosity=8
or the short form:
inxi -zv8
Required reading
Resources
Hello @scotty65! Thank you for responding and for guiding me.
This is the output of “inxi -zv8”:
  Kernel: 6.16.0-5-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.16-x86_64
    root=UUID=4cd7a80d-f668-4a3c-954c-11e60198c8e1 rw rootflags=subvol=@
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A info: frameworks v: 6.17.0
  Type: Desktop Mobo: AZW model: SER v: V1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: ASE32001
    date: 03/26/2025
  System RAM: total: 32 GiB available: 27.18 GiB used: 2.33 GiB (8.6%)
  Array-1: capacity: 64 GiB slots: 4 modules: 4 EC: None
  Device-1: Channel-A DIMM 0 type: LPDDR5 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: spec: 6000 MT/s actual: 6300 MT/s volts:
    curr: 0.5 min: 0.5 max: 0.5 width (bits): data: 32 total: 32
    manufacturer: Micron Technology part-no: MT62F1536M64D8CL-026 serial: N/A
  Device-2: Channel-B DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-3: Channel-C DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Device-4: Channel-D DIMM 0 type: LPDDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 6800U with Radeon Graphics bits: 64 type: MT MCP
    arch: Zen 3+ gen: 3 level: v3 note: check built: 2022 process: TSMC n6 (7nm)
    family: 0x19 (25) model-id: 0x44 (68) stepping: 1 microcode: 0xA404108
    desc: 8x512 KiB L3: 16 MiB desc: 1x16 MiB
  Speed (MHz): avg: 1092 min/max: 402/4770 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1092 2: 1092 3: 1092
    4: 1092 5: 1092 6: 1092 7: 1092 8: 1092 9: 1092 10: 1092 11: 1092 12: 1092
    13: 1092 14: 1092 15: 1092 16: 1092 bogomips: 86236
    xsaves xtopology
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt [Radeon 680M]
    driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
    built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports:
    active: HDMI-A-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, DP-7, DP-8,
    Writeback-1 bus-ID: 04:00.0 chip-ID: 1002:1681 class-ID: 0300 temp: 38.0 C
  Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
    compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
    alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
    s-diag: 582mm (22.93") monitors: <missing: xrandr>
  Monitor-1: HDMI-A-1 model: ASUS VZ279HE serial: <filter> built: 2019
    res: 1920x1080 dpi: 82 gamma: 1.2 chroma: red: x: 0.655 y: 0.337 green:
    x: 0.322 y: 0.612 blue: x: 0.149 y: 0.067 white: x: 0.314 y: 0.329
    size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x960, 1280x800,
    1152x864, 1280x720, 1440x576, 1024x768, 1440x480, 832x624, 800x600,
    720x576, 720x480, 640x480, 720x400
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.7-arch1.1
    rembrandt LLVM 20.1.8 DRM 3.64 6.16.0-5-MANJARO) device-ID: 1002:1681
    memory: 3.91 GiB unified: no
  API: Vulkan v: 1.4.321 layers: N/A device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV REMBRANDT) driver: mesa radv v: 25.1.7-arch1.1
    device-ID: 1002:1681 surfaces: N/A
  Device-1: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    [Rembrandt/Strix] driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:1640 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD] Family 17h/19h/1ah HD Audio
    bus-ID: 04:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.16.0-5-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000
    bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Intel Wi-Fi 6 AX200 driver: N/A modules: iwlwifi pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:2723 class-ID: 0280
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2 chip-ID: 8087:0029
    class-ID: e001
  Local Storage: total: 931.51 GiB used: 12.99 GiB (1.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P3PSSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR413 temp: 37.9 C
    scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
    used: 12.99 GiB (1.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: 4cd7a80d-f668-4a3c-954c-11e60198c8e1
    used: 632 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: B218-9CD1
  ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-4: /var/cache raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  ID-5: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%)
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 3 rev: 2.0
  Device-1: 3-3:2 info: HS6209 2.4G Wireless Receiver type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 32c2:0018 class-ID: 0300
    serial: <filter>
  Hub-5: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 5-1:2 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0029 class-ID: e001
  Hub-6: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  Hub-7: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-8: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-9: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Device-1: 9-1:2 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
    type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 1bcf:08a0 class-ID: 0301
  Hub-10: 10-0:1 info: super-speed hub ports: 1 rev: 3.1
  System Temperatures: cpu: 40.0 C mobo: N/A gpu: amdgpu temp: 39.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1246 libs: 345 tools: pamac pm: flatpak pkgs: 0
    1: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirror.komelt.dev/manjaro/stable/$repo/$arch
    3: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 363
  1: cpu: 18.4% command: firefox pid: 2606 mem: 685.9 MiB (2.4%)
  2: cpu: 7.7% command: firefox pid: 2883 mem: 305.6 MiB (1.0%)
  3: cpu: 1.4% command: firefox pid: 2749 mem: 162.1 MiB (0.5%)
  4: cpu: 1.1% command: Xorg pid: 762 mem: 182.3 MiB (0.6%)
  5: cpu: 1.1% command: firefox pid: 2990 mem: 248.9 MiB (0.8%)
  Memory top: 5 of 363
  1: mem: 685.9 MiB (2.4%) command: firefox pid: 2606 cpu: 18.4%
  2: mem: 429.3 MiB (1.5%) command: plasmashell pid: 1037 cpu: 0.3%
  3: mem: 305.6 MiB (1.0%) command: firefox pid: 2883 cpu: 7.7%
  4: mem: 259.8 MiB (0.9%) command: kwin_x11 pid: 984 cpu: 1.0%
  5: mem: 248.9 MiB (0.8%) command: firefox pid: 2990 cpu: 1.1%
  Processes: 363 Power: uptime: 30m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 10.85 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: gcc: 15.1.1 Shell: Zsh v: 5.9 running-in: konsole inxi: 3.3.38
This is the output for “sudo dmesg | grep wifi”:
[    4.649394] iwlwifi 0000:03:00.0: enabling device (0000 -> 0002)
[    4.682996] iwlwifi 0000:03:00.0: CSR_RESET = 0x10
[    4.683000] iwlwifi 0000:03:00.0: Host monitor block 0x0 vector 0x0
[    4.683003] iwlwifi 0000:03:00.0:     value [iter 0]: 0x3f7f8830
[    4.683007] iwlwifi 0000:03:00.0:     value [iter 1]: 0x3f7f8830
[    4.683010] iwlwifi 0000:03:00.0:     value [iter 2]: 0x3f7f8c30
[    4.683012] iwlwifi 0000:03:00.0:     value [iter 3]: 0x3f7f0c30
[    4.683015] iwlwifi 0000:03:00.0:     value [iter 4]: 0x3f7f0430
[    4.683018] iwlwifi 0000:03:00.0:     value [iter 5]: 0x3f7f0430
[    4.683020] iwlwifi 0000:03:00.0:     value [iter 6]: 0x3f7f8c30
[    4.683023] iwlwifi 0000:03:00.0:     value [iter 7]: 0x3f7f8030
[    4.683026] iwlwifi 0000:03:00.0:     value [iter 8]: 0x3f7f8030
[    4.683028] iwlwifi 0000:03:00.0:     value [iter 9]: 0x3f7f8830
[    4.683031] iwlwifi 0000:03:00.0:     value [iter 10]: 0x3f7f8830
[    4.683034] iwlwifi 0000:03:00.0:     value [iter 11]: 0x3f7f0830
[    4.683037] iwlwifi 0000:03:00.0:     value [iter 12]: 0x3f7f0030
[    4.683039] iwlwifi 0000:03:00.0:     value [iter 13]: 0x3f7f8c30
[    4.683042] iwlwifi 0000:03:00.0:     value [iter 14]: 0x3f7f0c30
[    4.683043] iwlwifi 0000:03:00.0: Host monitor block 0x0 vector 0x1
[    4.683047] iwlwifi 0000:03:00.0:     value [iter 0]: 0x044466c2
[    4.683050] iwlwifi 0000:03:00.0:     value [iter 1]: 0x044466c2
[    4.683053] iwlwifi 0000:03:00.0:     value [iter 2]: 0x044466c2
[    4.683055] iwlwifi 0000:03:00.0:     value [iter 3]: 0x044466c2
[    4.683058] iwlwifi 0000:03:00.0:     value [iter 4]: 0x044466c2
[    4.683061] iwlwifi 0000:03:00.0:     value [iter 5]: 0x044466c2
[    4.683063] iwlwifi 0000:03:00.0:     value [iter 6]: 0x044466c2
[    4.683066] iwlwifi 0000:03:00.0:     value [iter 7]: 0x044466c2
[    4.683069] iwlwifi 0000:03:00.0:     value [iter 8]: 0x044466c2
[    4.683071] iwlwifi 0000:03:00.0:     value [iter 9]: 0x044466c2
[    4.683074] iwlwifi 0000:03:00.0:     value [iter 10]: 0x044466c2
[    4.683077] iwlwifi 0000:03:00.0:     value [iter 11]: 0x044466c2
[    4.683080] iwlwifi 0000:03:00.0:     value [iter 12]: 0x044466c2
[    4.683082] iwlwifi 0000:03:00.0:     value [iter 13]: 0x044466c2
[    4.683085] iwlwifi 0000:03:00.0:     value [iter 14]: 0x044466c2
[    4.683086] iwlwifi 0000:03:00.0: Host monitor block 0x0 vector 0x6
[    4.683089] iwlwifi 0000:03:00.0:     value [iter 0]: 0xe00c4471
[    4.683092] iwlwifi 0000:03:00.0:     value [iter 1]: 0xe00c4471
[    4.683095] iwlwifi 0000:03:00.0:     value [iter 2]: 0xa00c4471
[    4.683098] iwlwifi 0000:03:00.0:     value [iter 3]: 0xa00c4471
[    4.683100] iwlwifi 0000:03:00.0:     value [iter 4]: 0xf00c4471
[    4.683103] iwlwifi 0000:03:00.0:     value [iter 5]: 0xf00c4471
[    4.683106] iwlwifi 0000:03:00.0:     value [iter 6]: 0xb00c4471
[    4.683108] iwlwifi 0000:03:00.0:     value [iter 7]: 0xb00c4471
[    4.683111] iwlwifi 0000:03:00.0:     value [iter 8]: 0xf00c4471
[    4.683114] iwlwifi 0000:03:00.0:     value [iter 9]: 0xf00c4471
[    4.683116] iwlwifi 0000:03:00.0:     value [iter 10]: 0xa00c4471
[    4.683119] iwlwifi 0000:03:00.0:     value [iter 11]: 0xa00c4471
[    4.683122] iwlwifi 0000:03:00.0:     value [iter 12]: 0xe00c4471
[    4.683124] iwlwifi 0000:03:00.0:     value [iter 13]: 0xe00c4471
[    4.683127] iwlwifi 0000:03:00.0:     value [iter 14]: 0xa00c4471
[    4.683129] iwlwifi 0000:03:00.0: Host monitor block 0x22 vector 0x0
[    4.683132] iwlwifi 0000:03:00.0:     value [iter 0]: 0x00000000
[    4.683363] iwlwifi 0000:03:00.0: probe with driver iwlwifi failed with error -110
@scotty65 I’m posting some of the other outputs here to help find resolution. Please help!!
This is the output of “inxi -NSazy”:
    root=UUID=4cd7a80d-f668-4a3c-954c-11e60198c8e1 rw rootflags=subvol=@ quiet
    splash udev.log_priority=3
This is the output of “rfkill list”:
0: hci0: Bluetooth
        Soft blocked: no
        Hard blocked: no
This is the output of “uname -a”:
Linux vicky-ooi 6.16.0-5-MANJARO #1 SMP PREEMPT_DYNAMIC Thu, 07 Aug 2025 04:47:37 +0000 x86_64 GNU/Linux
This is the output of “lspci -knn | grep Net -A3”:
This is the output for just “lspci”:
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe Root Complex (rev 01)
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Family 17h-19h IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe Dummy Host Bridge (rev 01)
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe Dummy Host Bridge (rev 01)
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe GPP Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe GPP Bridge
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe Dummy Host Bridge (rev 01)
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe Dummy Host Bridge (rev 01)
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h-19h PCIe Dummy Host Bridge (rev 01)
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h-19h Internal PCIe GPP Bridge (rev 10)
00:08.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h-19h Internal PCIe GPP Bridge (rev 10)
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 71)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Rembrandt Data Fabric: Device 18h; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Rembrandt Data Fabric: Device 18h; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Rembrandt Data Fabric: Device 18h; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Rembrandt Data Fabric: Device 18h; Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Rembrandt Data Fabric: Device 18h; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Rembrandt Data Fabric: Device 18h; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Rembrandt Data Fabric: Device 18h; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Rembrandt Data Fabric: Device 18h; Function 7
01:00.0 Non-Volatile memory controller: Micron Technology Inc 2550 NVMe SSD (DRAM-less) (rev 01)
02:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet Controller (rev 15)
03:00.0 Network controller: Intel Corporation Wi-Fi 6 AX200 (rev 1a)
04:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Rembrandt [Radeon 680M] (rev c1)
04:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Radeon High Definition Audio Controller [Rembrandt/Strix]
04:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 19h PSP/CCP
04:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Rembrandt USB4 XHCI controller #3
04:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Rembrandt USB4 XHCI controller #4
04:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h/1ah HD Audio Controller
04:00.7 Signal processing controller: Advanced Micro Devices, Inc. [AMD] Sensor Fusion Hub
05:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] Rembrandt USB4 XHCI controller #8
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Rembrandt USB4 XHCI controller #5
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Rembrandt USB4 XHCI controller #6
Output for “mhwd -li”:
> Installed PCI configs:
           video-linux            2024.05.06                true            PCI
Output for “journalctl -p 3 -xb”:
Aug 19 13:08:35 vicky-ooi kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SBRG.EC0], AE_NOT_FOUND (20250404/dswload2-162)
Aug 19 13:08:35 vicky-ooi kernel: ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20250404/psobject-220)
Aug 19 13:08:35 vicky-ooi kernel: hub 6-0:1.0: config failed, hub doesn't have any ports! (err -19)
Aug 19 13:08:35 vicky-ooi kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SBRG.EC0.OKEC], AE_NOT_FOUND (20250404/psargs-33>
Aug 19 13:08:35 vicky-ooi kernel: ACPI Error: Aborting method \_SB.GPIO._EVT due to previous error (AE_NOT_FOUND) (20250404/psparse-529)
Aug 19 13:08:35 vicky-ooi kernel: pcie_mp2_amd 0000:04:00.7: amd_sfh_hid_client_init failed err -95
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0: CSR_RESET = 0x10
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0: Host monitor block 0x0 vector 0x0
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 0]: 0x3f7f8830
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 1]: 0x3f7f8830
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 2]: 0x3f7f8c30
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 3]: 0x3f7f0c30
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 4]: 0x3f7f0430
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 5]: 0x3f7f0430
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 6]: 0x3f7f8c30
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 7]: 0x3f7f8030
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 8]: 0x3f7f8030
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 9]: 0x3f7f8830
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 10]: 0x3f7f8830
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 11]: 0x3f7f0830
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 12]: 0x3f7f0030
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 13]: 0x3f7f8c30
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 14]: 0x3f7f0c30
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0: Host monitor block 0x0 vector 0x1
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 0]: 0x044466c2
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 1]: 0x044466c2
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 2]: 0x044466c2
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 3]: 0x044466c2
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 4]: 0x044466c2
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 5]: 0x044466c2
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 6]: 0x044466c2
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 7]: 0x044466c2
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 8]: 0x044466c2
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 9]: 0x044466c2
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 10]: 0x044466c2
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 11]: 0x044466c2
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 12]: 0x044466c2
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 13]: 0x044466c2
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 14]: 0x044466c2
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0: Host monitor block 0x0 vector 0x6
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 0]: 0xe00c4471
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 1]: 0xe00c4471
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 2]: 0xa00c4471
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 3]: 0xa00c4471
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 4]: 0xf00c4471
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 5]: 0xf00c4471
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 6]: 0xb00c4471
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 7]: 0xb00c4471
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 8]: 0xf00c4471
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 9]: 0xf00c4471
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 10]: 0xa00c4471
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 11]: 0xa00c4471
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 12]: 0xe00c4471
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 13]: 0xe00c4471
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 14]: 0xa00c4471
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0: Host monitor block 0x22 vector 0x0
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0:     value [iter 0]: 0x00000000
Aug 19 13:08:35 vicky-ooi kernel: iwlwifi 0000:03:00.0: probe with driver iwlwifi failed with error -110
lines 15-60/60 (END)
The codes “iw dev” and “iw list” showed no output.
Mod edit: removed duplicate inxi output
Thanks for providing such detailed output.
These 2 parts of your reply I found to be most relevant:
I’m far from an expert when it comes to networking, but I did a bit of searching on the web and I do have the feeling that you may have to re-install Windows on your mini-PC (only temporarily though - just to fix this issue). It looks like my initial thought that Windows was not completely shut down may be correct.
I found a lengthy topic on the EndeavourOS forum which has the same type of card and same error code (-110), and it was solved by reinstalling Windows, opening an administrative powershell prompt, and typing powercfg /h off:
Some other posts/topics worth looking at too:
Edit: If you don’t have access to a Windows installer, I have sometimes seen members of this forum recommend using Hiren’s BootCD PE as a way to boot into a basic Windows installation. That may enable you to run the powercfg /h off command to disable hibernation in Windows. ventoy, which can be installed from the repos, is usually the recommended tool for creating bootable USB sticks.
My issue turned out to be the (old) Majaro linux-firmware package and the way that it was compressed. When I started using the (old) linux-firmware package directly from the Arch repository, my AX200 worked without manually copying my drivers to the firmware folder.
In any case, no more of all that with the new linux-firmware situation. linux-firmware-intel works with no shenanigans necessary.
I had seen that item about reinstalling Windows. I wiped Windows immediately and I wasn’t going to try that trick.
I use Ethernet 100 percent of the time, but I just want things to work :grinning:
I did that on all of my old PCs, but having WiFi on my mini-PC really has come in handy. I live 15 minute’s walk from Sydney’s CBD, but my apartment’s broadband Internet connection is only fibre-to-the-curb. It then goes from the street to my apartment via ~50 year old copper wires. I average 20+ Internet disconnections most days, and it sometimes takes up to half-an-hour for the modem to reconnect and achieve a stable connection. During those times, I just turn my cellphone into a hotspot, connect my mini-PC to it via WiFi, and browse the web on my PC using my phone’s 4G data instead.
@scotty65 i don’t know how to reinstall windows. i tried that and i entered grub rescue. can anyone help?
@jrichard326 i tried reinstalling the latest Manjaro linux-firmware package but it didnt work. the wifi thing is still not showing. any other ideas?
thanks!
linux-firmware-intel should be installed on your system if you did not modify by removing any of the firmware packages that you may have thought to be unnecessary. Contained in the compressed linux-firmware-intel.zst file are the files necessary to make the AX200 be recognized. Those files are:
iwlwifi-cc-a0-50.ucode.xz
iwlwifi-cc-a0-59.ucode.xz
iwlwifi-cc-a0-66.ucode.xz
iwlwifi-cc-a0-72.ucode.xz
iwlwifi-cc-a0-73.ucode.xz
iwlwifi-cc-a0-74.ucode.xz
iwlwifi-cc-a0-77.ucode.xz
When they load successfully it should look like this:
Beelink kernel: iwlwifi 0000:02:00.0: enabling device (0000 -> 0002)
Beelink kernel: iwlwifi 0000:02:00.0: Detected crf-id 0x3617, cnv-id 0x100530 wfpm id 0x80000000
Beelink kernel: iwlwifi 0000:02:00.0: PCI dev 2723/0084, rev=0x340, rfid=0x10a100
Beelink kernel: iwlwifi 0000:02:00.0: Detected Intel(R) Wi-Fi 6 AX200 160MHz
Beelink kernel: iwlwifi 0000:02:00.0: TLV_FW_FSEQ_VERSION: FSEQ Version: 89.3.35.37
Beelink kernel: iwlwifi 0000:02:00.0: loaded firmware version 77.864baa2e.0 cc-a0-77.ucode op_mode iwlmvm
Check in /usr/lib /firmware if those files are present. They should be , but if they are not, you could try pulling the linux-firmware-intel.zst file from /var/cache/pacman/pkg/ and extracting those files and copy over to /usr/lib/firmware and reboot
Hi @jrichard326, i checked what’s in the firmware directory, and those are in there.
Output of “cd usr/lib/firmware” and then “ls”:
3com                                  iwlwifi-ma-b0-gf4-a0-89.ucode.xz  radeon
acenic                                iwlwifi-ma-b0-gf4-a0.pnvm.xz      realtek
adaptec                               iwlwifi-ma-b0-gf-a0-83.ucode.xz   regulatory.db
advansys                              iwlwifi-ma-b0-gf-a0-86.ucode.xz   regulatory.db.p7s
aeonsemi                              iwlwifi-ma-b0-gf-a0-89.ucode.xz   rockchip
agere_ap_fw.bin.xz                    iwlwifi-ma-b0-gf-a0.pnvm.xz       rp2.fw.xz
agere_sta_fw.bin.xz                   iwlwifi-ma-b0-hr-b0-83.ucode.xz   rpm_firmware.bin
aica_firmware.bin                     iwlwifi-ma-b0-hr-b0-86.ucode.xz   rsi
airoha                                iwlwifi-ma-b0-hr-b0-89.ucode.xz   rsi_91x.fw.xz
amd                                   iwlwifi-Qu-b0-hr-b0-50.ucode.xz   rt2561.bin.xz
amdgpu                                iwlwifi-Qu-b0-hr-b0-59.ucode.xz   rt2561s.bin.xz
amdnpu                                iwlwifi-Qu-b0-hr-b0-66.ucode.xz   rt2661.bin.xz
amdtee                                iwlwifi-Qu-b0-hr-b0-72.ucode.xz   rt2860.bin.xz
amd-ucode                             iwlwifi-Qu-b0-hr-b0-73.ucode.xz   rt2870.bin.xz
amlogic                               iwlwifi-Qu-b0-hr-b0-74.ucode.xz   rt3070.bin.xz
amphion                               iwlwifi-Qu-b0-hr-b0-77.ucode.xz   rt3071.bin.xz
ar3k                                  iwlwifi-Qu-b0-jf-b0-50.ucode.xz   rt3090.bin.xz
ar5523.bin.xz                         iwlwifi-Qu-b0-jf-b0-59.ucode.xz   rt3290.bin.xz
ar7010_1_1.fw.xz                      iwlwifi-Qu-b0-jf-b0-66.ucode.xz   rt73.bin.xz
ar7010.fw.xz                          iwlwifi-Qu-b0-jf-b0-72.ucode.xz   rtl_bt
ar9170-1.fw.xz                        iwlwifi-Qu-b0-jf-b0-73.ucode.xz   rtl_nic
ar9170-2.fw.xz                        iwlwifi-Qu-b0-jf-b0-74.ucode.xz   rtlwifi
ar9271.fw.xz                          iwlwifi-Qu-b0-jf-b0-77.ucode.xz   rtw88
arm                                   iwlwifi-Qu-c0-hr-b0-50.ucode.xz   rtw89
as102_data1_st.hex.xz                 iwlwifi-Qu-c0-hr-b0-59.ucode.xz   s2250.fw.xz
as102_data2_st.hex.xz                 iwlwifi-Qu-c0-hr-b0-66.ucode.xz   s2250_loader.fw.xz
asihpi                                iwlwifi-Qu-c0-hr-b0-72.ucode.xz   s5p-mfc.fw.xz
ath10k                                iwlwifi-Qu-c0-hr-b0-73.ucode.xz   s5p-mfc-v12.fw.xz
ath11k                                iwlwifi-Qu-c0-hr-b0-74.ucode.xz   s5p-mfc-v6.fw.xz
ath12k                                iwlwifi-Qu-c0-hr-b0-77.ucode.xz   s5p-mfc-v6-v2.fw.xz
ath3k-1.fw.xz                         iwlwifi-Qu-c0-jf-b0-50.ucode.xz   s5p-mfc-v7.fw.xz
ath6k                                 iwlwifi-Qu-c0-jf-b0-59.ucode.xz   s5p-mfc-v8.fw.xz
ath9k_htc                             iwlwifi-Qu-c0-jf-b0-66.ucode.xz   sb16
atmel                                 iwlwifi-Qu-c0-jf-b0-72.ucode.xz   sdd_sagrad_1091_1098.bin.xz
atusb                                 iwlwifi-Qu-c0-jf-b0-73.ucode.xz   slicoss
av7110                                iwlwifi-Qu-c0-jf-b0-74.ucode.xz   sms1xxx-hcw-55xxx-dvbt-02.fw.xz
bmi260-init-data.fw.xz                iwlwifi-Qu-c0-jf-b0-77.ucode.xz   sms1xxx-hcw-55xxx-isdbt-02.fw.xz
bnx2                                  iwlwifi-QuZ-a0-hr-b0-50.ucode.xz  sms1xxx-nova-a-dvbt-01.fw.xz
bnx2x                                 iwlwifi-QuZ-a0-hr-b0-59.ucode.xz  sms1xxx-nova-b-dvbt-01.fw.xz
brcm                                  iwlwifi-QuZ-a0-hr-b0-66.ucode.xz  sms1xxx-stellar-dvbt-01.fw.xz
cadence                               iwlwifi-QuZ-a0-hr-b0-72.ucode.xz  sun
carl9170-1.fw.xz                      iwlwifi-QuZ-a0-hr-b0-73.ucode.xz  sxg
cavium                                iwlwifi-QuZ-a0-hr-b0-74.ucode.xz  TAS2XXX0C94.bin.xz
cirrus                                iwlwifi-QuZ-a0-hr-b0-77.ucode.xz  TAS2XXX0C95.bin.xz
cis                                   iwlwifi-QuZ-a0-jf-b0-50.ucode.xz  TAS2XXX0C96.bin.xz
cmmb_vega_12mhz.inp.xz                iwlwifi-QuZ-a0-jf-b0-59.ucode.xz  TAS2XXX0C97.bin.xz
cmmb_venice_12mhz.inp.xz              iwlwifi-QuZ-a0-jf-b0-66.ucode.xz  TAS2XXX103C8DE8-0.bin.xz
cnm                                   iwlwifi-QuZ-a0-jf-b0-72.ucode.xz  TAS2XXX103C8DE80.bin.xz
cpia2                                 iwlwifi-QuZ-a0-jf-b0-73.ucode.xz  TAS2XXX103C8DE8-1.bin.xz
cs42l43.bin.xz                        iwlwifi-QuZ-a0-jf-b0-74.ucode.xz  TAS2XXX103C8DE81.bin.xz
cs46xx                                iwlwifi-QuZ-a0-jf-b0-77.ucode.xz  TAS2XXX103C8DE9-0.bin.xz
ctefx.bin.xz                          iwlwifi-so-a0-gf4-a0-72.ucode.xz  TAS2XXX103C8DE90.bin.xz
ctefx-desktop.bin                     iwlwifi-so-a0-gf4-a0-73.ucode.xz  TAS2XXX103C8DE9-1.bin.xz
ctefx-r3di.bin                        iwlwifi-so-a0-gf4-a0-74.ucode.xz  TAS2XXX103C8DE91.bin.xz
ctspeq.bin.xz                         iwlwifi-so-a0-gf4-a0-77.ucode.xz  TAS2XXX10A40.bin.xz
cxgb3                                 iwlwifi-so-a0-gf4-a0-78.ucode.xz  TAS2XXX10A41.bin.xz
cxgb4                                 iwlwifi-so-a0-gf4-a0-79.ucode.xz  TAS2XXX11540.bin.xz
cypress                               iwlwifi-so-a0-gf4-a0-81.ucode.xz  TAS2XXX11541.bin.xz
dabusb                                iwlwifi-so-a0-gf4-a0-83.ucode.xz  TAS2XXX12040.bin.xz
digiface_firmware.bin                 iwlwifi-so-a0-gf4-a0-84.ucode.xz  TAS2XXX12041.bin.xz
digiface_firmware_rev11.bin           iwlwifi-so-a0-gf4-a0-86.ucode.xz  TAS2XXX12140.bin.xz
dpaa2                                 iwlwifi-so-a0-gf4-a0-89.ucode.xz  TAS2XXX12141.bin.xz
dsp56k                                iwlwifi-so-a0-gf4-a0.pnvm.xz      TAS2XXX1EB30.bin.xz
dvb-fe-xc4000-1.4.1.fw.xz             iwlwifi-so-a0-gf-a0-72.ucode.xz   TAS2XXX1EB31.bin.xz
dvb-fe-xc5000-1.6.114.fw.xz           iwlwifi-so-a0-gf-a0-73.ucode.xz   TAS2XXX1EB3.bin.xz
dvb-fe-xc5000c-4.1.30.7.fw.xz         iwlwifi-so-a0-gf-a0-74.ucode.xz   TAS2XXX2234.bin.xz
dvb_nova_12mhz_b0.inp.xz              iwlwifi-so-a0-gf-a0-77.ucode.xz   TAS2XXX2326.bin.xz
dvb_nova_12mhz.inp.xz                 iwlwifi-so-a0-gf-a0-78.ucode.xz   TAS2XXX3870.bin.xz
dvb-usb-dib0700-1.20.fw.xz            iwlwifi-so-a0-gf-a0-79.ucode.xz   TAS2XXX387D.bin.xz
dvb-usb-it9135-01.fw.xz               iwlwifi-so-a0-gf-a0-81.ucode.xz   TAS2XXX387E.bin.xz
dvb-usb-it9135-02.fw.xz               iwlwifi-so-a0-gf-a0-83.ucode.xz   TAS2XXX387F.bin.xz
dvb-usb-terratec-h5-drxk.fw.xz        iwlwifi-so-a0-gf-a0-84.ucode.xz   TAS2XXX3880.bin.xz
e100                                  iwlwifi-so-a0-gf-a0-86.ucode.xz   TAS2XXX3881.bin.xz
ea                                    iwlwifi-so-a0-gf-a0-89.ucode.xz   TAS2XXX3882.bin.xz
edgeport                              iwlwifi-so-a0-gf-a0.pnvm.xz       TAS2XXX3884.bin.xz
emi26                                 iwlwifi-so-a0-hr-b0-72.ucode.xz   TAS2XXX3886.bin.xz
emi62                                 iwlwifi-so-a0-hr-b0-73.ucode.xz   TAS2XXX38A5.bin.xz
emu                                   iwlwifi-so-a0-hr-b0-74.ucode.xz   TAS2XXX38A7.bin.xz
ene-ub6250                            iwlwifi-so-a0-hr-b0-77.ucode.xz   TAS2XXX38A8.bin.xz
ess                                   iwlwifi-so-a0-hr-b0-79.ucode.xz   TAS2XXX38B8.bin.xz
f2255usb.bin.xz                       iwlwifi-so-a0-hr-b0-81.ucode.xz   TAS2XXX38B9.bin.xz
go7007                                iwlwifi-so-a0-hr-b0-83.ucode.xz   TAS2XXX38BA.bin.xz
hfi1_dc8051.fw.xz                     iwlwifi-so-a0-hr-b0-84.ucode.xz   TAS2XXX38BB.bin.xz
hfi1_fabric.fw.xz                     iwlwifi-so-a0-hr-b0-86.ucode.xz   TAS2XXX38BE.bin.xz
hfi1_pcie.fw.xz                       iwlwifi-so-a0-hr-b0-89.ucode.xz   TAS2XXX38BF.bin.xz
hfi1_sbus.fw.xz                       iwlwifi-so-a0-jf-b0-72.ucode.xz   TAS2XXX38C3.bin.xz
htc_7010.fw.xz                        iwlwifi-so-a0-jf-b0-73.ucode.xz   TAS2XXX38CB.bin.xz
htc_9271.fw.xz                        iwlwifi-so-a0-jf-b0-74.ucode.xz   TAS2XXX38CD.bin.xz
i915                                  iwlwifi-so-a0-jf-b0-77.ucode.xz   TAS2XXX38D3.bin.xz
imx                                   iwlwifi-ty-a0-gf-a0-59.ucode.xz   TAS2XXX38D4.bin.xz
inside-secure                         iwlwifi-ty-a0-gf-a0-66.ucode.xz   TAS2XXX38D5.bin.xz
INT8866RCA2.bin.xz                    iwlwifi-ty-a0-gf-a0-72.ucode.xz   TAS2XXX38D6.bin.xz
intel                                 iwlwifi-ty-a0-gf-a0-73.ucode.xz   TAS2XXX38DF.bin.xz
intel-ucode                           iwlwifi-ty-a0-gf-a0-74.ucode.xz   TAS2XXX38E0.bin.xz
isci                                  iwlwifi-ty-a0-gf-a0-77.ucode.xz   TAS2XXX38FD.bin.xz
isdbt_nova_12mhz_b0.inp.xz            iwlwifi-ty-a0-gf-a0-78.ucode.xz   TAS2XXX391F.bin.xz
isdbt_nova_12mhz.inp.xz               iwlwifi-ty-a0-gf-a0-79.ucode.xz   TAS2XXX3920.bin.xz
isdbt_rio.inp.xz                      iwlwifi-ty-a0-gf-a0-81.ucode.xz   TAS2XXX3E300.bin.xz
iwlwifi-1000-5.ucode.xz               iwlwifi-ty-a0-gf-a0-83.ucode.xz   TAS2XXX3E301.bin.xz
iwlwifi-100-5.ucode.xz                iwlwifi-ty-a0-gf-a0-84.ucode.xz   TAS2XXX3EE00.bin.xz
iwlwifi-105-6.ucode.xz                iwlwifi-ty-a0-gf-a0-86.ucode.xz   TAS2XXX3EE01.bin.xz
iwlwifi-135-6.ucode.xz                iwlwifi-ty-a0-gf-a0-89.ucode.xz   TAS2XXX3EF00.bin.xz
iwlwifi-2000-6.ucode.xz               iwlwifi-ty-a0-gf-a0.pnvm.xz       TAS2XXX3EF01.bin.xz
iwlwifi-2030-6.ucode.xz               ixp4xx                            TAS2XXX3F000.bin.xz
iwlwifi-3160-17.ucode.xz              kaweth                            TAS2XXX3F001.bin.xz
iwlwifi-3168-29.ucode.xz              keyspan                           TAS2XXX3F100.bin.xz
iwlwifi-3945-2.ucode.xz               keyspan_pda                       TAS2XXX3F101.bin.xz
iwlwifi-4965-2.ucode.xz               korg                              TAS2XXX3F200.bin.xz
iwlwifi-5000-5.ucode.xz               lbtf_usb.bin.xz                   TAS2XXX3F201.bin.xz
iwlwifi-5150-2.ucode.xz               lgs8g75.fw.xz                     TAS2XXX3F300.bin.xz
iwlwifi-6000-4.ucode.xz               lt9611uxc_fw.bin.xz               TAS2XXX3F301.bin.xz
iwlwifi-6000g2a-6.ucode.xz            matrox                            TAS2XXX8DE80.bin.xz
iwlwifi-6000g2b-6.ucode.xz            mediatek                          TAS2XXX8DE81.bin.xz
iwlwifi-6050-5.ucode.xz               meson                             TAS2XXX8DE8.bin.xz
iwlwifi-7260-17.ucode.xz              microchip                         TAS2XXX8DE90.bin.xz
iwlwifi-7265-17.ucode.xz              mixart                            TAS2XXX8DE91.bin.xz
iwlwifi-7265D-29.ucode.xz             moxa                              TAS2XXX8DE9.bin.xz
iwlwifi-8000C-34.ucode.xz             mt7601u.bin.xz                    tdmb_nova_12mhz.inp.xz
iwlwifi-8000C-36.ucode.xz             mt7650.bin.xz                     tehuti
iwlwifi-8265-34.ucode.xz              mt7662.bin.xz                     ti
iwlwifi-8265-36.ucode.xz              mt7662_rom_patch.bin.xz           ti_3410.fw.xz
iwlwifi-9000-pu-b0-jf-b0-34.ucode.xz  mts_cdma.fw.xz                    ti_5052.fw.xz
iwlwifi-9000-pu-b0-jf-b0-38.ucode.xz  mts_edge.fw.xz                    TIAS2781RCA2.bin.xz
iwlwifi-9000-pu-b0-jf-b0-46.ucode.xz  mts_gsm.fw.xz                     TIAS2781RCA4.bin.xz
iwlwifi-9260-th-b0-jf-b0-34.ucode.xz  mts_mt9234mu.fw.xz                ti-connectivity
iwlwifi-9260-th-b0-jf-b0-38.ucode.xz  mts_mt9234zba.fw.xz               tigon
iwlwifi-9260-th-b0-jf-b0-46.ucode.xz  multiface_firmware.bin            ti-keystone
iwlwifi-bz-b0-fm-c0-92.ucode.xz       multiface_firmware_rev11.bin      tlg2300_firmware.bin.xz
iwlwifi-bz-b0-fm-c0-93.ucode.xz       myri10ge_eth_big_z8e.dat.xz       tsse_firmware.bin.xz
iwlwifi-bz-b0-fm-c0-94.ucode.xz       myri10ge_ethp_big_z8e.dat.xz      ttusb-budget
iwlwifi-bz-b0-fm-c0-96.ucode.xz       myri10ge_ethp_z8e.dat.xz          TXNW2781RCA0.bin.xz
iwlwifi-bz-b0-fm-c0-97.ucode.xz       myri10ge_eth_z8e.dat.xz           TXNW2781RCA1.bin.xz
iwlwifi-bz-b0-fm-c0-98.ucode.xz       myri10ge_rss_eth_big_z8e.dat.xz   TXNW2781RCA2.bin.xz
iwlwifi-bz-b0-fm-c0.pnvm.xz           myri10ge_rss_ethp_big_z8e.dat.xz  TXNW2781RCA4.bin.xz
iwlwifi-bz-b0-gf-a0-92.ucode.xz       myri10ge_rss_ethp_z8e.dat.xz      ueagle-atm
iwlwifi-bz-b0-gf-a0-94.ucode.xz       myri10ge_rss_eth_z8e.dat.xz       usbduxfast_firmware.bin.xz
iwlwifi-bz-b0-gf-a0-96.ucode.xz       myricom                           usbdux_firmware.bin.xz
iwlwifi-bz-b0-gf-a0-97.ucode.xz       nvidia                            usbduxsigma_firmware.bin.xz
iwlwifi-bz-b0-gf-a0-98.ucode.xz       nxp                               v4l-cx231xx-avcore-01.fw.xz
iwlwifi-bz-b0-gf-a0.pnvm.xz           ositech                           v4l-cx23418-apu.fw.xz
iwlwifi-bz-b0-hr-b0-96.ucode.xz       pcxhr                             v4l-cx23418-cpu.fw.xz
iwlwifi-bz-b0-hr-b0-98.ucode.xz       phanfw.bin.xz                     v4l-cx23418-dig.fw.xz
iwlwifi-bz-b0-hr-b0.pnvm.xz           powervr                           v4l-cx23885-avcore-01.fw.xz
iwlwifi-cc-a0-50.ucode.xz             qat_402xx.bin.xz                  v4l-cx25840.fw.xz
iwlwifi-cc-a0-59.ucode.xz             qat_402xx_mmp.bin.xz              vicam
iwlwifi-cc-a0-66.ucode.xz             qat_420xx.bin.xz                  vntwusb.fw.xz
iwlwifi-cc-a0-72.ucode.xz             qat_420xx_mmp.bin.xz              vpu_d.bin.xz
iwlwifi-cc-a0-73.ucode.xz             qat_4xxx.bin.xz                   vpu_p.bin.xz
iwlwifi-cc-a0-74.ucode.xz             qat_4xxx_mmp.bin.xz               vx
iwlwifi-cc-a0-77.ucode.xz             qat_895xcc.bin.xz                 vxge
iwlwifi-gl-c0-fm-c0-83.ucode.xz       qat_895xcc_mmp.bin.xz             wfx
iwlwifi-gl-c0-fm-c0-86.ucode.xz       qat_c3xxx.bin.xz                  whiteheat.fw.xz
iwlwifi-gl-c0-fm-c0-90.ucode.xz       qat_c3xxx_mmp.bin.xz              whiteheat_loader.fw.xz
iwlwifi-gl-c0-fm-c0-92.ucode.xz       qat_c62x.bin.xz                   wil6210.brd.xz
iwlwifi-gl-c0-fm-c0-94.ucode.xz       qat_c62x_mmp.bin.xz               wil6210.fw.xz
iwlwifi-gl-c0-fm-c0-96.ucode.xz       qat_mmp.bin.xz                    wsm_22.bin.xz
iwlwifi-gl-c0-fm-c0-97.ucode.xz       qca                               xe
iwlwifi-gl-c0-fm-c0-98.ucode.xz       r128                              yam
iwlwifi-gl-c0-fm-c0.pnvm.xz           r8a779x_usb3_v1.dlmem.xz          yamaha
iwlwifi-ma-b0-gf4-a0-83.ucode.xz      r8a779x_usb3_v2.dlmem.xz
iwlwifi-ma-b0-gf4-a0-86.ucode.xz      r8a779x_usb3_v3.dlmem.xz
However, I’m not sure how to load them?
Is Wi-Fi enabled in the network manager applet?
Try to load driver:
sudo modprobe iwlwifi
Hello @jrichard326 , i loaded that command, but nothing happened. I cant seem to find the network manager applet too?
I don’t have any additional ideas. I run xfce and the network manager applet is from that DE. I use Plasma only in VM and am not familiar enough to guide you.
If you want to try the Windows 11 route you can download the Windows 11.iso, create a USB with Ventoy, reinstall Windows and follow the directions contained in the EOS Forum link, post #52.
Windows .iso download (towards the middle of the page):
https://www.microsoft.com/en-us/software-download/windows11
@jrichard326 Thank you! I’ll try that, but I’m away for work for a month now and did not bring my mini pc with me, so I’ll have to deal with that when I get back. Can i keep this post open or does it close automatically?
As long as no solution has been assigned, the thread will remain open. But even if it were to get closed — e.g. to cut off the usual #MeToo necro-bumpers and thread hijackers — then all you need to do is contact either a Moderator or a Community Assistant and ask them to reopen the thread. :wink:
