Hi all,
I’m trying to connect to my new wifi network with my old laptop, the same laptop that connected to my old wifi network. I’m 100% sure that the wifi password is right, I’m using it on other devices, but I can’t connect to the new AP.
Here’s what the log is saying
apr 26 11:39:45 pungolo NetworkManager[732]: <info> [1619429985.3414] device (wlp3s0): Activation: (wifi) connection 'war' has security, and secrets exist. No new secrets needed.
apr 26 11:39:45 pungolo NetworkManager[732]: <info> [1619429985.3416] Config: added 'ssid' value 'war'
apr 26 11:39:45 pungolo NetworkManager[732]: <info> [1619429985.3418] Config: added 'scan_ssid' value '1'
apr 26 11:39:45 pungolo NetworkManager[732]: <info> [1619429985.3419] Config: added 'bgscan' value 'simple:30:-70:86400'
apr 26 11:39:45 pungolo NetworkManager[732]: <info> [1619429985.3421] Config: added 'key_mgmt' value 'SAE FT-SAE'
apr 26 11:39:45 pungolo NetworkManager[732]: <info> [1619429985.3422] Config: added 'auth_alg' value 'OPEN'
apr 26 11:39:45 pungolo NetworkManager[732]: <info> [1619429985.3423] Config: added 'psk' value '<hidden>'
apr 26 11:39:45 pungolo NetworkManager[732]: <info> [1619429985.4193] device (wlp3s0): supplicant interface state: interface_disabled -> inactive
apr 26 11:39:45 pungolo NetworkManager[732]: <info> [1619429985.4339] device (wlp3s0): supplicant interface state: inactive -> scanning
apr 26 11:39:48 pungolo wpa_supplicant[771]: wlp3s0: SME: Trying to authenticate with 50:e0:39:2d:dd:df (SSID='war' freq=5180 MHz)
apr 26 11:39:48 pungolo NetworkManager[732]: <info> [1619429988.4972] device (wlp3s0): supplicant interface state: scanning -> authenticating
apr 26 11:39:48 pungolo kernel: wlp3s0: authenticate with 50:e0:39:2d:dd:df
apr 26 11:39:48 pungolo kernel: wlp3s0: send auth to 50:e0:39:2d:dd:df (try 1/3)
apr 26 11:39:48 pungolo kernel: wlp3s0: authenticated
apr 26 11:39:48 pungolo wpa_supplicant[771]: wlp3s0: PMKSA-CACHE-ADDED 50:e0:39:2d:dd:df 0
apr 26 11:39:48 pungolo wpa_supplicant[771]: wlp3s0: Trying to associate with 50:e0:39:2d:dd:df (SSID='war' freq=5180 MHz)
apr 26 11:39:48 pungolo NetworkManapr 26 11:39:45 pungolo NetworkManager[732]: <info> [1619429985.3414] device (wlp3s0): Activation: (wifi) connection 'war' has security, and secrets exist. No new secrets needed.
apr 26 11:39:48 pungolo NetworkManager[732]: <info> [1619429988.6800] device (wlp3s0): supplicant interface state: authenticating -> associating
apr 26 11:39:48 pungolo kernel: wlp3s0: associate with 50:e0:39:2d:dd:df (try 1/3)
apr 26 11:39:48 pungolo kernel: wlp3s0: RX AssocResp from 50:e0:39:2d:dd:df (capab=0x1011 status=31 aid=4)
apr 26 11:39:48 pungolo kernel: wlp3s0: 50:e0:39:2d:dd:df denied association (code=31)
apr 26 11:39:48 pungolo wpa_supplicant[771]: wlp3s0: CTRL-EVENT-ASSOC-REJECT bssid=50:e0:39:2d:dd:df status_code=31
apr 26 11:39:48 pungolo wpa_supplicant[771]: wlp3s0: SME: Deauth request to the driver failed
apr 26 11:39:48 pungolo wpa_supplicant[771]: wlp3s0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="war" auth_failures=1 duration=10 reason=CONN_FAILED
apr 26 11:39:48 pungolo NetworkManager[732]: <info> [1619429988.7462] device (wlp3s0): supplicant interface state: associating -> disconnected
apr 26 11:39:58 pungolo NetworkManager[732]: <info> [1619429998.7502] device (wlp3s0): supplicant interface state: disconnected -> scanning
apr 26 11:39:58 pungolo wpa_supplicant[771]: wlp3s0: CTRL-EVENT-SSID-REENABLED id=0 ssid="war"
apr 26 11:39:58 pungolo wpa_supplicant[771]: wlp3s0: SME: Trying to authenticate with 50:e0:39:2d:dd:de (SSID='war' freq=2432 MHz)
apr 26 11:39:58 pungolo NetworkManager[732]: <info> [1619429998.7947] device (wlp3s0): supplicant interface state: scanning -> authenticating
apr 26 11:39:58 pungolo kernel: wlp3s0: authenticate with 50:e0:39:2d:dd:de
apr 26 11:39:58 pungolo kernel: wlp3s0: send auth to 50:e0:39:2d:dd:de (try 1/3)
apr 26 11:39:58 pungolo kernel: wlp3s0: authenticated
apr 26 11:39:58 pungolo wpa_supplicant[771]: wlp3s0: PMKSA-CACHE-ADDED 50:e0:39:2d:dd:de 0
apr 26 11:39:58 pungolo wpa_supplicant[771]: wlp3s0: Trying to associate with 50:e0:39:2d:dd:de (SSID='war' freq=2432 MHz)
apr 26 11:39:58 pungolo NetworkManager[732]: <info> [1619429998.9015] device (wlp3s0): supplicant interface state: authenticating -> associating
apr 26 11:39:58 pungolo kernel: wlp3s0: associate with 50:e0:39:2d:dd:de (try 1/3)
apr 26 11:39:58 pungolo kernel: wlp3s0: RX AssocResp from 50:e0:39:2d:dd:de (capab=0x1411 status=31 aid=3)
apr 26 11:39:58 pungolo kernel: wlp3s0: 50:e0:39:2d:dd:de denied association (code=31)
apr 26 11:39:58 pungolo wpa_supplicant[771]: wlp3s0: CTRL-EVENT-ASSOC-REJECT bssid=50:e0:39:2d:dd:de status_code=31
apr 26 11:39:58 pungolo wpa_supplicant[771]: wlp3s0: SME: Deauth request to the driver failed
apr 26 11:39:58 pungolo wpa_supplicant[771]: wlp3s0: CTRL-EVENT-SSID-TEMP-DISABLED id=0 ssid="war" auth_failures=2 duration=20 reason=CONN_FAILED
apr 26 11:39:58 pungolo NetworkManager[732]: <info> [1619429998.9562] device (wlp3s0): supplicant interface state: associating -> disconnectedager[732]: <info> [1619429988.6800] device (wlp3s0): supplicant interface state: authenticating -> associating
apr 26 11:39:58 pungolo wpa_supplicapr 26 11:39:45 pungolo NetworkManager[732]: <info> [1619429985.3414] device (wlp3s0): Activation: (wifi) connection 'war' has security, and secrets exist. No new secrets needed.
apr 26 11:39:58 pungolo NetworkManager[732]: <info> [1619429998.9562] device (wlp3s0): supplicant interface state: associating -> disconnectedant[771]: wlp3s0: CTRL-EVENT-ASSOC-REJECT bssid=50:e0:39:2d:dd:de status_code=31
this reason=CONN_FAILED is not helping me. I tried with a different network adapter on the same PC and I also tried with a live version of Linux Mint on the same PC. Same result
Any ideas?
