I’m new to Manjaro and had no problems using it until I installed kooha 2.2.3-1 (community) with “Add/Remove Software” and rebooted. Now I cannot connect to the wifi anymore. I tried reinstalling linux-firmware-whence and linux-firmware-marvell as suggested in another post with sudo pacman -U ...
, but it didn’t solve my problem. For most other topics they go above my understanding of linux and networks.
Could someone help me?
Here is the output when I run inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.15.102-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=14dfa502-8e74-4c37-b8d7-21541bd2086d rw quiet
cryptdevice=UUID=770ca29e-c4f6-40b9-a54f-3d7d9950d2fa:luks-770ca29e-c4f6-40b9-a54f-3d7d9950d2fa
root=/dev/mapper/luks-770ca29e-c4f6-40b9-a54f-3d7d9950d2fa
udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 82RK v: IdeaPad 3 15IAU7
serial: <superuser required> Chassis: type: 10 v: IdeaPad 3 15IAU7
Mobo: LENOVO model: LNVNB161216 v: SDK0T76463 WIN
serial: <superuser required> UEFI: LENOVO v: JKCN23WW date: 03/21/2022
ID-1: BAT0 charge: 15.8 Wh (42.0%) condition: 37.6/38.0 Wh (99.0%) volts: 7.5
min: 7.7 model: Celxpert L20C2PF0 type: Li-poly serial: <filter>
status: discharging cycles: 45
RAM: total: 15.36 GiB used: 1.99 GiB (13.0%)
Info: model: 12th Gen Intel Core i7-1255U bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x424
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 452 high: 600 min/max: 400/4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 516 2: 415 3: 567 4: 600
5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 500 12: 427 bogomips: 62688
bts cat_l2 cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid
f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp
hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe
pcid pclmulqdq pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
rdpid rdrand rdseed rdt_a rdtscp rep_good sdbg sep serialize sha_ni smap
smep smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq
umip vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec
xsaveopt xsaves xtopology xtpr
prctl and seccomp
Type: spectre_v2 status: Vulnerable: eIBRS with unprivileged eBPF
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+
ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:46a8 class-ID: 0300
Device-2: Syntek Integrated Camera type: USB driver: uvcvideo bus-ID: 3-8:4
chip-ID: 174f:2465 class-ID: fe01 serial: <filter>
Display: x11 server: X.Org v: 21.1.7 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0xe48d built: 2019 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.5 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Sound API: ALSA v: k5.15.102-1-MANJARO running: yes
Sound Server-1: JACK v: 1.9.22 running: no
Sound Server-3: PipeWire v: 0.3.65 running: yes
Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: N/A modules: iwlwifi
bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB
driver: btusb v: 0.8 bus-ID: 3-10:5 chip-ID: 8087:0aaa class-ID: e001
Device-1: luks-770ca29e-c4f6-40b9-a54f-3d7d9950d2fa maj-min: 254:0
type: LUKS dm: dm-0 size: 953.57 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 953.57 GiB
Local Storage: total: 968.41 GiB used: 51.64 GiB (5.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNW010TZL
size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: C01C temp: 30.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Kingston
model: DataTraveler SE9 size: 14.54 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%) used: 51.64 GiB (5.5%)
fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-770ca29e-c4f6-40b9-a54f-3d7d9950d2fa label: N/A
uuid: 14dfa502-8e74-4c37-b8d7-21541bd2086d
used: 4.6 MiB (1.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: NO_LABEL uuid: 7005-0FFD
ID-1: /dev/sda1 maj-min: 8:1 size: 14.53 GiB fs: vfat label: USB-STICK
uuid: 3A32-44C7
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-2: 2-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 20 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 3-1:2 info: Toshiba Kingston DataTraveler 102/2.0 / HEMA Flash
Drive 2 GB PNY Attache 4GB Stick type: Mass Storage driver: usb-storage
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA chip-ID: 0930:6545
class-ID: 0806 serial: <filter>
Device-2: 3-6:3 info: Shenzhen Goodix FingerPrint type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 27c6:550a class-ID: ff00
Device-3: 3-8:4 info: Syntek Integrated Camera type: Video driver: uvcvideo
interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 174f:2465
Device-4: 3-10:5 info: Intel Bluetooth 9460/9560 Jefferson Peak (JfP)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 8087:0aaa class-ID: e001
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 35.0 C mobo: N/A
Processes: 287 Uptime: 2m wakeups: 81 Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7 Packages: 1279
pm: pacman pkgs: 1273 libs: 323 tools: pamac,yay pm: flatpak pkgs: 6
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.25
This
…shows your Wireless’ drivers are not loaded for some reason. So let’s see if we can see anything. Please provide the output of:
lsmod | grep --ignore-case wifi
and
ls /etc/modprobe.d/
as well as
ls /etc/modules-load.d
Hi, thank you for the quick answer!
Here are the outputs:
iwlwifi 454656 0
cfg80211 1081344 1 iwlwifi
> ls /etc/modprobe.d/
modules.conf
Hmmmm…try the following:
See if there are any errors if you try to modprobe
it. Please run:
sudo modprobe --dry-run iwlwifi
And also:
cat /etc/modules-load.d/modules.conf
…and provide the output here.
Hm. This doesn’t seem to give me any output.
And /etc/modules-load.d/modules.conf
is empty too.
That’s good. Now let’s try reloading the module:
First remove it:
sudo modprobe --remove iwlwifi
Let’s reload it:
sudo modprobe iwlwifi
Here’s to hoping!
Okay, I ran the commands. Should I see something now? Wifi still says “No connections available”.
Reboot your PC and see if it works.
If not, please provide the output of:
…again, please.
Still no luck and it looks like inxi is giving me the same output too:
udev.log_priority=3
ID-1: BAT0 charge: 12.1 Wh (32.2%) condition: 37.6/38.0 Wh (99.0%) volts: 7.4
RAM: total: 15.36 GiB used: 1.44 GiB (9.4%)
microcode: 0x424
Speed (MHz): avg: 520 high: 924 min/max: 400/4700:3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 665 2: 924 3: 580 4: 450
5: 431 6: 400 7: 400 8: 400 9: 400 10: 402 11: 598 12: 595 bogomips: 62688
prctl and seccomp
screens: 1
direct-render: Yes
Components:
ID-1: / raw-size: 953.57 GiB size: 937.53 GiB (98.32%) used: 51.63 GiB (5.5%)
uuid: 3A32-44C7
System Temperatures: cpu: 38.0 C mobo: N/A
Processes: 278 Uptime: 1m wakeups: 113 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: 1279 pm: pacman pkgs: 1273 libs: 323 tools: pamac,yay pm: flatpak
pkgs: 6 Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.25
Yes. Yes it does.
I don’t know what else to try, short of a different kernel, so let’s do that:
Install the new kernel by running:
sudo mhwd --install linux61
Version 6.1 is either set to be the next LTS version, or already is an LTS version.
Reboot into the new kernel. See if it helped.
More info:
Hm. And before I try that, is there any way to reverse the installation of kooha? I am guessing it changed some configuration files in the process or something like that?
You can uninstall kooha - but you cannot reverse everything
sudo pacman -Rns kooha
But I am not convinced kooha is reponsible for your dysfunctional wifi.
When you install a package then - usually - you sync your system as a whole.
The most effective would be to use the latest kernel 6.2 as it likely have the best support for your hardware.
linux61 is the latest LTS and linux62 is the latest stable kernel - the latter IMO is an incredibly good kernel - very fast on my system.
There is no way to reverse it, except restoring a backup. That is the nature of Manjaro and how it’s always been.
I have seen here that an issue was sorted in kernel 5.17 and above. So it might just help.
In any case, with Manjaro, you can have multiple kernels installed. I have 3:
$ mhwd-kernel --listinstalled
Currently running: 6.2.0-1-MANJARO (linux62)
* linux515
* linux61
* linux62
…and the command I gave you doesn’t remove anything.
Thank you for your insights! I am currently trying to figure out how to install linux62 without an internet connection. For some reason also tethering with my phone is extremely slow, so sudo mhwd-kernel --install linux62
times out.
I downloaded the stable 6.2.8 from here: https://www.kernel.org/
Can I tell mhwd-kernel
somehow to use that file for the installation?
Unfortunately that is the wrong way to go about it.
So, download this file: https://mirror.alpix.eu/manjaro/stable/core/x86_64/linux61-6.1.19-1-x86_64.pkg.tar.zst
Save it somewhere on your PC, let’s say your $HOME
cd ~
wget https://mirror.alpix.eu/manjaro/stable/core/x86_64/linux61-6.1.19-1-x86_64.pkg.tar.zst
And install it from there:
cd ~
pacman -U linux61-6.1.19-1-x86_64.pkg.tar.zst
Then if all went well, reboot into it.
Hope this helps!
Reference:
Hi,
You should be able to download the desired kernel (e.g. linux519) to another computer from one of the mirror sites . Then transfer the file using a USB key, you can then install it using pacman -U linux519.pkg.tar.zst
Just figured it out 10 seconds before you answered haha. So I installed it and rebooted. Now everything works again
Thank you very much for the help!
system
Closed
March 28, 2023, 2:23am
17
