Hi guys,
First of all thanks for replying.
I have realise that my MacBook can connect SSH through Wi-Fi, so maybe it’s not the router… I tried to connect SSH with my Manjaro Laptop and by my mobile phone which has a custom android version ( /e/project ) having no results.
Return of SSH when trying to connect by Wi-Fi:
ssh -v admin@*****.com
OpenSSH_8.6p1, OpenSSL 1.1.1k 25 Mar 2021
debug1: Reading configuration data /data/data/com.termux/files/usr/etc/ssh/ssh_config
debug1: Authenticator provider $SSH_SK_PROVIDER did not resolve; disabling
debug1: Connecting to *****.com [123.456.789.10] port 22.
debug1: connect to address 123.456.789.10 port 22: Connection timed out
ssh: connect to host *****.com port 22: Connection timed out
Return of SSH when trying to connect by Mobile Data:
debug1: Connecting to u-u.monster [185.253.155.236] port 22.
debug1: Connection established.
debug1: identity file /data/data/com.termux/files/home/.ssh/id_rsa type 0
debug1: identity file /data/data/com.termux/files/home/.ssh/id_rsa-cert type -1
debug1: identity file /data/data/com.termux/files/home/.ssh/id_dsa type -1
debug1: identity file /data/data/com.termux/files/home/.ssh/id_dsa-cert type -1
debug1: identity file /data/data/com.termux/files/home/.ssh/id_ecdsa type -1
debug1: identity file /data/data/com.termux/files/home/.ssh/id_ecdsa-cert type -1
debug1: identity file /data/data/com.termux/files/home/.ssh/id_ecdsa_sk type -1
debug1: identity file /data/data/com.termux/files/home/.ssh/id_ecdsa_sk-cert type -1
debug1: identity file /data/data/com.termux/files/home/.ssh/id_ed25519 type -1
debug1: identity file /data/data/com.termux/files/home/.ssh/id_ed25519-cert type -1
debug1: identity file /data/data/com.termux/files/home/.ssh/id_ed25519_sk type -1
debug1: identity file /data/data/com.termux/files/home/.ssh/id_ed25519_sk-cert type -1
debug1: identity file /data/data/com.termux/files/home/.ssh/id_xmss type -1
debug1: identity file /data/data/com.termux/files/home/.ssh/id_xmss-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_8.6
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.9p1 Debian-10+deb10u2
debug1: compat_banner: match: OpenSSH_7.9p1 Debian-10+deb10u2 pat OpenSSH* compat 0x04000000
debug1: Authenticating to domain.com:22 as ‘admin’
debug1: load_hostkeys: fopen /data/data/com.termux/files/home/.ssh/known_hosts2: No such file or directory
debug1: load_hostkeys: fopen /data/data/com.termux/files/usr/etc/ssh/ssh_known_hosts: No such file or directory
debug1: load_hostkeys: fopen /data/data/com.termux/files/usr/etc/ssh/ssh_known_hosts2: No such file or directory
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ssh-ed25519
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: compression: none
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: SSH2_MSG_KEX_ECDH_REPLY received
debug1: Server host key: ssh-ed25519 SHA256:+UsoRJPg7pqOz0Ed7THprLgHSaOftnLZx9K+RK4er9k
debug1: Host ‘domain.com’ is known and matches the ED25519 host key.
debug1: Found key in /data/data/com.termux/files/home/.ssh/known_hosts:4
debug1: rekey out after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: rekey in after 134217728 blocks
debug1: Will attempt key: /data/data/com.termux/files/home/.ssh/id_rsa RSA SHA256:gkbJVeuPG13A8SrcRGhVQjJyRXqHhwMkgj0PWdgoA0Q
debug1: Will attempt key: /data/data/com.termux/files/home/.ssh/id_dsa
debug1: Will attempt key: /data/data/com.termux/files/home/.ssh/id_ecdsa
debug1: Will attempt key: /data/data/com.termux/files/home/.ssh/id_ecdsa_sk
debug1: Will attempt key: /data/data/com.termux/files/home/.ssh/id_ed25519
debug1: Will attempt key: /data/data/com.termux/files/home/.ssh/id_ed25519_sk
debug1: Will attempt key: /data/data/com.termux/files/home/.ssh/id_xmss
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521>
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey,password
debug1: Next authentication method: publickey
debug1: Offering public key: /data/data/com.termux/files/home/.ssh/id_rsa RSA SHA256:
aBhj25nfhTWHMOwh9 t3o23t7mhew9eto23y0weimasu
debug1: Trying private key: /data/data/com.termux/files/home/.ssh/id_dsa
debug1: Trying private key: /data/data/com.termux/files/home/.ssh/id_ecdsa
debug1: Trying private key: /data/data/com.termux/files/home/.ssh/id_ecdsa_sk
debug1: Trying private key: /data/data/com.termux/files/home/.ssh/id_ed25519
debug1: Trying private key: /data/data/com.termux/files/home/.ssh/id_ed25519_sk
debug1: Trying private key: /data/data/com.termux/files/home/.ssh/id_xmss
debug1: Next authentication method: password
admin@*****.com’s password:
When trying to connect localhost connected to the Wi-Fi it returns:
ssh -v u0_a153@localhost
debug1: Connecting to localhost [127.0.0.1] port 22.
debug1: connect to address 127.0.0.1 port 22: Connection refused
ssh: connect to host localhost port 22: Connection refused
Any idea what could be causing this?
On the other hand, I have ping every manjaros’s NTP server and everything seems to be working correctly… but still having wrong the system clock and the status returns “System clock syncronized: No”, even doing “systemctl enable systemd-timesyncd.servic” & “systemctl start systemd-timesyncd.service”
Thank you all.
