bluetoothctl
Agent registered
[bluetooth]# scan on
No default controller available
[bluetooth]#
It doesn’t show devices.
bluetoothctl
Agent registered
[bluetooth]#
Hi @usualalteration,
Please provide the output of:
inxi --admin --verbosity=7 --filter --width
And
rfkill list all
CPU: dual core Intel Core i7-5500U (-MT MCP-) speed/min/max: 1447/500/3000 MHz
Kernel: 6.1.19-1-MANJARO x86_64 Up: 8h 53m Mem: 2049.7/15914.2 MiB (12.9%)
Storage: 931.51 GiB (2.4% used) Procs: 185 Shell: Bash inxi: 3.3.26
rfkill list all
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
Please don’t cut off the outputs asked, there’s a reason the information is necessary. That command would have --filter
’d out any personal identifiable information.
Please post the output of:
bluetoothctl
list
bluetoothctl
devices
[nicole@nicole-pc ~]$ bluetoothctl list
[nicole@nicole-pc ~]$ bluetoothctl devices
Please provide the outpput of:
bluetoothctl default-agent
And
bluetoothctl show
[nicole@nicole-pc ~]$ bluetoothctl default-agent
No agent is registered
[nicole@nicole-pc ~]$ bluetoothctl show
So let us try this again:
(The complete output this time, please.)
[nicole@nicole-pc ~]$ inxi --admin --verbosity=7 --filter --width
Kernel: 6.1.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=b2f9208f-a70b-4cf1-b16c-4076ad6e33f0 rw quiet splash apparmor=1
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Hewlett-Packard product: HP Notebook
v: Type1ProductConfigId serial: <superuser required> Chassis: type: 10
Mobo: Hewlett-Packard model: 80C2 v: 96.02 serial: <superuser required>
UEFI: Insyde v: F.02 date: 03/24/2015
ID-1: BAT1 charge: 20.5 Wh (100.0%) condition: 20.5/41.4 Wh (49.6%)
volts: 16.7 min: 14.8 model: COMPAL PABAS0241231 type: Li-ion
serial: <filter> status: full
Device-1: hidpp_battery_0 model: Logitech M350 Wireless Mouse
serial: <filter> charge: 50% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 15.54 GiB used: 4.18 GiB (26.9%)
Info: model: Intel Core i7-5500U bits: 64 type: MT MCP arch: Broadwell
gen: core 5 level: v3 note: check built: 2015-18 process: Intel 14nm
family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1369 high: 2395 min/max: 500/3000 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 798 2: 1786 3: 500
4: 2395 bogomips: 19161
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr ht ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr
nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln
pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow
tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
xtopology xtpr
vulnerable
STIBP: conditional, RSB filling, PBRSB-eIBRS: Not affected
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
520 Mobile] vendor: Hewlett-Packard driver: radeon v: kernel
alternate: amdgpu arch: GCN-1 code: Southern Islands process: TSMC 28nm
built: 2011-20 pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 03:00.0 chip-ID: 1002:6660 class-ID: 0380
temp: 43.0 C
Device-3: Chicony HP Truevision HD type: USB driver: uvcvideo bus-ID: 1-5:5
chip-ID: 04f2:b509 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.7 compositor: xfwm v: 4.18.0 driver: X:
loaded: modesetting,radeon alternate: fbdev,vesa dri: iris gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: Samsung 0x4e51 built: 2014 res: 1366x768 hz: 60
dpi: 101 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
class-ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:9ca0 class-ID: 0403
API: ALSA v: k6.1.19-1-MANJARO status: kernel-api with: aoss
type: oss-emulator tools: alsamixer,amixer
Server-2: PipeWire v: 0.3.65 status: off tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active tools: pacat,pactl,pavucontrol
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 4000
bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: wl
v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0
chip-ID: 14e4:4365 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
Device-1: Broadcom BCM43142A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 1-4:4 chip-ID: 0a5c:216d class-ID: fe01 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: N/A
Local Storage: total: 931.51 GiB used: 99.82 GiB (10.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVDRW DU8A6SH rev: DH61
dev-links: cdrom
ID-1: / raw-size: 244.14 GiB size: 239.25 GiB (98.00%)
used: 23.95 GiB (10.0%) fs: ext4 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: b2f9208f-a70b-4cf1-b16c-4076ad6e33f0
used: 25.3 MiB (26.4%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: ECF5-B2D8
ID-3: /run/media/nicole/5A78F73B78F7150B raw-size: 686.73 GiB
size: 686.73 GiB (100.00%) used: 75.84 GiB (11.0%) fs: ntfs dev: /dev/sda3
maj-min: 8:3 label: N/A uuid: 5A78F73B78F7150B
ID-4: /run/media/nicole/SQL e PHP raw-size: 61.8 MiB
size: 60.4 MiB (97.77%) used: 60.4 MiB (100.0%) fs: udf block-size: 2048 B
dev: /dev/sr0 maj-min: 11:0 label: SQL e PHP uuid: 0f11202f53514c20
ID-1: /dev/sda2 maj-min: 8:2 size: 16 MiB fs: <superuser required> label: N/A
uuid: N/A
ID-2: /dev/sda4 maj-min: 8:4 size: 542 MiB fs: ntfs label: N/A
uuid: E286ABEE86ABC201
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 11 rev: 2.0
Device-1: 1-3:3 info: Logitech Unifying Receiver type: Mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 98mA chip-ID: 046d:c52f class-ID: 0300
Device-2: 1-4:4 info: Broadcom BCM43142A0 Bluetooth 4.0 type: Bluetooth
driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s chip-ID: 0a5c:216d
Device-3: 1-5:5 info: Chicony HP Truevision HD type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 04f2:b509
class-ID: 0e02
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 51.0 C pch: 44.0 C mobo: N/A
Processes: 241 Uptime: 9h 20m wakeups: 15 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 1263 libs: 361 tools: pamac pm: flatpak pkgs: 0
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.26
lsusb
[nicole@nicole-pc ~]$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 04f2:b509 Chicony Electronics Co., Ltd HP Truevision HD
Bus 001 Device 004: ID 0a5c:216d Broadcom Corp. BCM43142A0 Bluetooth 4.0
Bus 001 Device 003: ID 046d:c52f Logitech, Inc. Unifying Receiver
pamac search broadcom-bt-firmware
[nicole@nicole-pc ~]$ pamac search broadcom-bt-firmware
broadcom-bt-firmware-git 12.0.1.1011_p1.r3.gc0bd928-2 AUR
Broadcom bluetooth firmware.
broadcom-bt-firmware 12.0.1.1105-1 AUR
Firmware for Broadcom Bluetooth devices
Let’s try installing that:
pamac build broadcom-bt-firmware
I’m shooting in the dark here, so I don’t know if it’ll work.
It works now, thank you so much!
You’re welcome!
