Hey Guys, I’m a total noob.
This is the first time I’m using linux and I really want to keep using Manjaro. However, I can’t connect to 5Ghz on my laptop. I’ve tried all the internet (and sadly AI) ideas I possibly could.
Here is inxi -zv8 output. (I’m sorry if I’m supposed to format it in a specific way. I couldn’t find anything regarding that)
Kernel: 6.12.44-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=5e053612-9d60-4369-a8bf-450293293607 rw rootflags=subvol=@
quiet splash lockdown=none apparmor=1 security=apparmor
udev.log_priority=3
Desktop: GNOME v: 48.4 tk: GTK v: 3.24.50 wm: gnome-shell
base: Arch Linux
Type: Laptop System: TIMI product: RedmiBook 14-APCS v: N/A
Mobo: TIMI model: TM1931 v: V1.00 serial: <superuser required>
part-nu: TM1931-26420 uuid: <superuser required> UEFI: TIMI v: RMRPC400P0401
date: 10/23/2019
ID-1: BAT0 charge: 35.4 Wh (100%) condition: 35.4/47 Wh (75.3%) volts: 16.81
min: 15.2 model: SUNWODA type: Li-ion serial: <filter> charging:
status: not charging cycles: N/A
System RAM: total: 16 GiB available: 13.58 GiB used: 3.69 GiB (27.2%)
(unregistered) size: 8 GiB speed: spec: 2667 MT/s actual: 2400 MT/s volts:
note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
manufacturer: Samsung part-no: M471A1K43DB1-CTD serial: <filter>
manufacturer: Samsung part-no: M471A1G44AB0-CTD serial: N/A
Info: model: AMD Ryzen 7 3700U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3 note: check
built: 2019 process: GF 12nm family: 0x17 (23) model-id: 0x18 (24)
stepping: 1 microcode: 0x8108109
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2928 min/max: 1400/2300 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 2928 2: 2928 3: 2928
4: 2928 5: 2928 6: 2928 7: 2928 8: 2928 bogomips: 36749
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb lahf_lm lbrv
lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx
nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter
pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni
popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm
svm_lock syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif
vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: Advanced Micro Devices [AMD/ATI] Picasso/Raven 2 [Radeon Vega
Series / Radeon Mobile Series] vendor: Xiaomi driver: amdgpu v: kernel
arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3
speed: 8 GT/s lanes: 16 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 03:00.0 chip-ID: 1002:15d8 class-ID: 0300 temp: 74.0 C
Display: x11 server: X.org v: 1.21.1.18 with: Xwayland v: 24.1.8
compositor: gnome-shell driver: X: loaded: amdgpu
gpu: amdgpu display-ID: :0 note: <missing: xdpyinfo/xrandr>
Monitor-1: eDP-1 model: Najing CEC Panda 0x004a built: 2019 res: 1920x1080
dpi: 163 gamma: 1.2 chroma: red: x: 0.596 y: 0.361 green: x: 0.345 y: 0.557
blue: x: 0.157 y: 0.106 white: x: 0.314 y: 0.329
size: 309x174mm (12.17x6.85") diag: 345mm (13.6") ratio: 16:9
modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720,
1024x768, 800x600, 640x480
device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.1-arch1.4
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 10 Graphics
(radeonsi raven ACO DRM 3.61 6.12.44-3-MANJARO) device-ID: 1002:15d8
memory: 1.95 GiB unified: no
Info: Tools: api: eglinfo,glxinfo x11: xprop
Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio vendor: Xiaomi driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Xiaomi
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Xiaomi driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.44-3-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter
vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 54.0 C
IF-ID-1: ipv6leakintrf0 state: unknown speed: N/A duplex: N/A
mac: <filter>
IP v6: <filter> type: noprefixroute scope: global
IF-ID-2: proton0 state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> type: noprefixroute scope: global
Info: services: iwd, NetworkManager, systemd-timesyncd, wpa_supplicant
Device-1: Lite-On driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-1:2 chip-ID: 04ca:301f class-ID: e001
Local Storage: total: 953.88 GiB used: 355.71 GiB (37.3%)
model: MZVLB512HAJQ-00000 size: 476.94 GiB block-size: physical: 512 B
fw-rev: EXA7301Q temp: 39.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 model: SSD size: 476.94 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 3.1 spd: 10 Gb/s lanes: 1
mode: 3.2 gen-2x1 tech: SSD serial: <filter> scheme: MBR
ID-1: / raw-size: 192.82 GiB size: 192.82 GiB (100.00%)
used: 18.58 GiB (9.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 5e053612-9d60-4369-a8bf-450293293607
used: 632 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: A7F4-4963
ID-3: /home raw-size: 192.82 GiB size: 192.82 GiB (100.00%)
ID-4: /run/media/trojar/Shifaz raw-size: 476.94 GiB
size: 476.94 GiB (100.00%) used: 337.13 GiB (70.7%) fs: exfat dev: /dev/sda1
maj-min: 8:1 label: Shifaz uuid: DCEC-7756
ID-5: /swap raw-size: 192.82 GiB size: 192.82 GiB (100.00%)
ID-6: /var/cache raw-size: 192.82 GiB size: 192.82 GiB (100.00%)
ID-7: /var/log raw-size: 192.82 GiB size: 192.82 GiB (100.00%)
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 283.82 GiB fs: ext4
label: Everything uuid: 0d97a581-8b98-4b67-9a88-0303ed22efdd
Device-1: 1-3:2 info: SHARKOON GmbH [Mediatrack Edge Mini Keyboard]
type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
chip-ID: 1ea7:0066 class-ID: 0301
Device-1: 2-2:2 info: ASMedia ASM1051E SATA 6Gb/s bridge ASM1053E ASM1153
3Gb/s ASM1153E bridge type: mass storage driver: uas interfaces: 1
rev: 3.1 speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1
chip-ID: 174c:55aa class-ID: 0806 serial: <filter>
Device-1: 3-1:2 info: Lite-On type: bluetooth driver: btusb interfaces: 2
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Device-2: 3-2:3 info: CASUE USB KB type: keyboard,HID
chip-ID: 2a7a:939f class-ID: 0300
Hub-4: 4-0:1 info: super-speed hub ports: 1 rev: 3.1
System Temperatures: cpu: 81.5 C mobo: N/A gpu: amdgpu temp: 81.0 C
Fan Speeds (rpm): N/A
Packages: 1421 pm: pacman pkgs: 1409 libs: 370
tools: gnome-software,pamac,yay pm: flatpak pkgs: 12
1: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
2: https://mirror.xeonbd.com/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 383
1: cpu: 200% command: ps pid: 7132 mem: 4.52 MiB (0.0%)
2: cpu: 17.6% command: localsearch-extractor-3 pid: 7114
mem: 36.7 MiB (0.2%)
3: cpu: 16.7% command: kgx pid: 7022 mem: 252.6 MiB (1.8%)
4: cpu: 12.4% command: slack pid: 2507 mem: 535.5 MiB (3.8%)
5: cpu: 9.2% command: chrome pid: 4663 mem: 429.8 MiB (3.0%)
Memory top: 5 of 383
1: mem: 535.5 MiB (3.8%) command: slack pid: 2507 cpu: 12.4%
2: mem: 429.8 MiB (3.0%) command: chrome pid: 4663 cpu: 9.2%
3: mem: 341.5 MiB (2.4%) command: chrome pid: 3213 cpu: 4.5%
4: mem: 296.8 MiB (2.1%) command: gnome-shell pid: 1726 cpu: 8.9%
5: mem: 283.1 MiB (2.0%) command: chrome pid: 3611 cpu: 3.5%
Processes: 383 Power: uptime: 19m states: freeze,mem,disk suspend: s2idle
wakeups: 0 hibernate: shutdown avail: reboot,suspend,test_resume
image: 5.41 GiB services: gsd-power, power-profiles-daemon, upowerd
Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: kgx
inxi: 3.3.39
Here is journalctl -u NetworkManager | grep -i “Shahriar5G” output
Sep 10 19:30:41 trojar-pc NetworkManager[731]: <info> [1757511041.9576] device (wlan0): Activation: starting connection 'Shahriar5G' (bbafe027-53cd-4a2d-89c5-af09bdd9b00b)
Sep 10 20:08:47 trojar-pc NetworkManager[731]: <info> [1757513327.7957] audit: op="connection-activate" uuid="edef9496-2cec-4d40-a84a-f47c800fac8c" name="Shahriar5G 1" pid=1726 uid=1000 result="success"
Sep 10 20:08:48 trojar-pc NetworkManager[731]: <info> [1757513328.1259] device (wlan0): Activation: starting connection 'Shahriar5G 1' (edef9496-2cec-4d40-a84a-f47c800fac8c)
Sep 10 20:08:48 trojar-pc NetworkManager[731]: <warn> [1757513328.1304] device (wlan0): Activation: failed for connection 'Shahriar5G 1'
I can’t possibly remember everything I’ve tried so far…Here’s a somewhat documentation from Claude based on what I’ve shared with it
Firmware and Driver Fixes:
Decompressed firmware files - Your QCA6174 firmware was compressed (.xz files), we decompressed them to .bin files
Fixed firmware permissions - Set correct ownership and permissions on firmware files
Reloaded ath10k driver - Multiple attempts to reload ath10k_pci module
Set WiFi regulatory domain - Tried sudo iw reg set BD (Bangladesh)
Modified NetworkManager connection - Used nmcli con modify “Shahriar5G” 802-11-wireless.band a
Installed ath10k-fixer - AUR package to monitor and reload the driver automatically
Kernel Lockdown Bypass Attempts:
Added kernel parameter - lockdown=none in GRUB configuration (didn’t work)
Stopped AppArmor - Attempted to disable security restrictions
Built firmware into initramfs - Added firmware files to early boot loading via mkinitcpio.conf
Network Management Changes:
Switched to iwd - You mentioned changing from NetworkManager to iwd
Checked for hardware blocks - Used rfkill commands
Diagnostic Commands We Used:
iwlist wlp1s0 freq (consistently showed “no frequency information”)
dmesg | grep ath10k (showed “Operation not permitted” errors)
cat /sys/kernel/security/lockdown (showed persistent integrity restrictions)
PLEASE HELP. SORRY FOR THE LONG LOOONG POST
