Cannot chroot into broken installation after failed system update
Hello everyone !
Yesterday i tried to update my system using -Syyu but it seems like GLIBC was removed and so the update process could not finish (see pacman log file below).
I then did a shutdown on my system, fully knowing that I would be facing the “no vmlinuz image” issue.
As this has happened to me many times before, I knew that I would have to boot using a live USB and chroot into my installation and fix the issue by updating.
However, chroot does not seem to work as GLIBC is missing.
I have confirmed that chroot did not succeed using ls commands and mhwd-kernel which returns nothing…
I found this page on archwiki where paragraph 3.5 mentions to manually mount the filesystem and then use the –sysroot argument of pacman…
So what can I do to fix this?
I don’t want to resort to reinstalling the OS as I have a lot of stuff installed and configured.
I am going to give the pacman –sysroot approach a shot, since the normal chroot process does not seem to work…
Any help will be greatly appreciated.
sudo manjaro-chroot -a :
grub-probe: error: cannot find a GRUB drive for /dev/sdc1.  Check your device.map.
==> Mounting (ManjaroLinux) [/dev/sda2]
 --> mount: [/mnt]
 --> mount: [/mnt/boot/efi]
/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /bin/bash)
 --> umount: [/mnt/boot/efi]
 --> umount: [/mnt]
/var/log/pacman.log:
[2023-10-13T21:44:17+0300] [PACMAN] Running 'pacman -Syyu'
[2023-10-13T21:44:17+0300] [PACMAN] synchronizing package lists
[2023-10-13T21:44:26+0300] [ALPM] transaction started
[2023-10-13T21:44:26+0300] [ALPM] upgraded archlinux-keyring (20230821-2 -> 20230918-1)
[2023-10-13T21:44:26+0300] [ALPM-SCRIPTLET] ==> Appending keys from archlinux.gpg...
[2023-10-13T21:44:28+0300] [ALPM-SCRIPTLET] ==> Disabling revoked keys in keyring...
[2023-10-13T21:44:28+0300] [ALPM-SCRIPTLET]   -> Disabled 2 keys.
[2023-10-13T21:44:28+0300] [ALPM-SCRIPTLET] ==> Updating trust database...
[2023-10-13T21:44:28+0300] [ALPM-SCRIPTLET] gpg: key 786C63F330D7CB92: no user ID for key signature packet of class 10
[2023-10-13T21:44:28+0300] [ALPM-SCRIPTLET] gpg: key 1EB2638FF56C0C53: no user ID for key signature packet of class 10
[2023-10-13T21:44:29+0300] [ALPM-SCRIPTLET] gpg: marginals needed: 3  completes needed: 1  trust model: pgp
[2023-10-13T21:44:29+0300] [ALPM-SCRIPTLET] gpg: depth: 0  valid:   1  signed:  27  trust: 0-, 0q, 0n, 0m, 0f, 1u
[2023-10-13T21:44:29+0300] [ALPM-SCRIPTLET] gpg: depth: 1  valid:  27  signed:  99  trust: 2-, 0q, 0n, 25m, 0f, 0u
[2023-10-13T21:44:29+0300] [ALPM-SCRIPTLET] gpg: depth: 2  valid:  72  signed:  27  trust: 72-, 0q, 0n, 0m, 0f, 0u
[2023-10-13T21:44:29+0300] [ALPM-SCRIPTLET] gpg: next trustdb check due at 2023-10-27
[2023-10-13T21:44:29+0300] [ALPM] transaction completed
[2023-10-13T21:44:29+0300] [ALPM] running '30-systemd-daemon-reload.hook'...
[2023-10-13T21:44:29+0300] [ALPM] running '30-systemd-update.hook'...
[2023-10-13T21:44:29+0300] [ALPM] running 'clean_package_cache.hook'...
[2023-10-13T21:44:29+0300] [ALPM-SCRIPTLET] ==> finished: 1 packages removed (disk space saved: 1.14 MiB)
[2023-10-13T21:44:29+0300] [PACMAN] starting full system upgrade
[2023-10-13T22:46:42+0300] [ALPM] running '60-mkinitcpio-remove.hook'...
[2023-10-13T22:46:42+0300] [ALPM] running '71-dkms-remove.hook'...
[2023-10-13T22:46:42+0300] [ALPM] running 'firefox-pre.hook'...
[2023-10-13T22:46:42+0300] [ALPM] running 'kernel-alive-pre.hook'...
[2023-10-13T22:46:44+0300] [ALPM] running 'texinfo-remove.hook'...
[2023-10-13T22:46:44+0300] [ALPM] running 'thunderbird-pre.hook'...
[2023-10-13T22:46:44+0300] [ALPM] transaction started
[2023-10-13T22:46:45+0300] [ALPM] removed networkmanager-qt (5.108.0-1)
[2023-10-13T22:46:45+0300] [ALPM] removed kplotting (5.108.0-1)
[2023-10-13T22:46:45+0300] [ALPM] removed kimageformats (5.108.0-1)
[2023-10-13T22:46:45+0300] [ALPM] removed kdoctools (5.108.0-1)
[2023-10-13T22:46:45+0300] [ALPM] removed kpeople (5.108.0-1)
[2023-10-13T22:46:45+0300] [ALPM] removed prison (5.108.0-1)
[2023-10-13T22:46:45+0300] [ALPM] removed krunner (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed threadweaver (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed plasma-framework (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kwayland (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kholidays (1:5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kunitconversion (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed modemmanager-qt (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kdesu (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kcontacts (1:5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed ktexteditor (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kactivities-stats (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed knotifyconfig (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed purpose (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kquickcharts (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed qqc2-desktop-style (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kactivities (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kcmutils (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed syntax-highlighting (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kdnssd (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed frameworkintegration (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed knewstuff (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed syndication (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kdeclarative (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kpackage (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed bluez-qt (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed baloo (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kidletime (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kfilemetadata (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed attica (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kitemmodels (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kpty (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kparts (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kio (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kded (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed ktextwidgets (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed sonnet (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kcompletion (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kwallet (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kservice (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed knotifications (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kbookmarks (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kxmlgui (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kitemviews (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kiconthemes (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed karchive (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kconfigwidgets (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed ki18n (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kguiaddons (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kcodecs (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kauth (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kglobalaccel (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kcrash (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kwindowsystem (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kconfig (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kdbusaddons (5.108.0-1)
[2023-10-13T22:46:46+0300] [ALPM] removed kjobwidgets (5.108.0-1)
[2023-10-13T22:46:47+0300] [ALPM] removed kwidgetsaddons (5.108.0-1)
[2023-10-13T22:46:47+0300] [ALPM] removed kcoreaddons (5.108.0-1.0)
[2023-10-13T22:46:47+0300] [ALPM] removed solid (5.108.0-1)
[2023-10-13T22:46:47+0300] [ALPM] upgraded iana-etc (20230629-1 -> 20230907-1)
[2023-10-13T22:46:47+0300] [ALPM] warning: /etc/vconsole.conf saved as /etc/vconsole.conf.pacsave
[2023-10-13T22:46:47+0300] [ALPM] warning: /etc/shells installed as /etc/shells.pacnew
[2023-10-13T22:46:47+0300] [ALPM] upgraded filesystem (2023.03.21-1 -> 2023.09.22-1)
[2023-10-13T22:46:47+0300] [ALPM-SCRIPTLET] Note: vconsole.conf is not longer tracked by
[2023-10-13T22:46:47+0300] [ALPM-SCRIPTLET] package management. Restoring /etc/vconsole.conf ...
[2023-10-13T22:46:47+0300] [ALPM] upgraded linux-api-headers (6.3-1 -> 6.4-1)
[2023-10-13T22:46:47+0300] [ALPM] upgraded gcc-libs (13.1.1-2 -> 13.2.1-3)
[2023-10-13T22:46:47+0300] [ALPM] upgraded abseil-cpp (20230125.3-1 -> 20230802.1-1)
[2023-10-13T22:46:47+0300] [ALPM] upgraded alsa-card-profiles (1:0.3.75-2 -> 1:0.3.81-1)
[2023-10-13T22:46:47+0300] [ALPM] upgraded alsa-ucm-conf (1.2.9-1 -> 1.2.10-2)
[2023-10-13T22:46:47+0300] [ALPM] upgraded alsa-lib (1.2.9-1 -> 1.2.10-2)
[2023-10-13T22:46:47+0300] [ALPM] upgraded zlib (1:1.2.13-3 -> 1:1.3-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded openssl (3.1.1-1 -> 3.1.3-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded bashrc-manjaro (5.1.016-2 -> 5.1.016-3)
[2023-10-13T22:46:48+0300] [ALPM] upgraded bash (5.1.016-2 -> 5.1.016-3)
[2023-10-13T22:46:48+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T22:46:48+0300] [ALPM] upgraded xz (5.4.3-1 -> 5.4.4-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded kmod (30-3 -> 31-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded hwdata (0.372-1 -> 0.375-2)
[2023-10-13T22:46:48+0300] [ALPM] upgraded alsa-utils (1.2.9-1 -> 1.2.10-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded amd-ucode (20230724.59fbffa9-1 -> 20230810.7be2766d-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded protobuf (23.4-1 -> 24.3-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded brotli (1.0.9-12 -> 1.1.0-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded libldap (2.6.4-2 -> 2.6.6-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded util-linux-libs (2.39.1-1 -> 2.39.2-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded audit (3.1.1-1 -> 3.1.2-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded libnghttp2 (1.55.1-1 -> 1.56.0-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded gmp (6.2.1-2 -> 6.3.0-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded libtirpc (1.3.3-2 -> 1.3.4-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded pambase (20221020-1 -> 20230918-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded coreutils (9.3-1 -> 9.4-2)
[2023-10-13T22:46:48+0300] [ALPM] upgraded systemd-libs (253.7-1 -> 254.5-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded libp11-kit (0.25.0-1 -> 0.25.0-2)
[2023-10-13T22:46:48+0300] [ALPM] upgraded p11-kit (0.25.0-1 -> 0.25.0-2)
[2023-10-13T22:46:48+0300] [ALPM] upgraded ca-certificates-mozilla (3.91-1 -> 3.94-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded curl (8.2.0-2 -> 8.3.0-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded libelf (0.189-1 -> 0.189-3)
[2023-10-13T22:46:48+0300] [ALPM] upgraded dbus (1.14.8-1 -> 1.14.10-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded kbd (2.6.1-1 -> 2.6.3-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded file (5.44-3 -> 5.45-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded shadow (4.13-2 -> 4.14.0-4)
[2023-10-13T22:46:48+0300] [ALPM] upgraded libutempter (1.2.1-3 -> 1.2.1-4)
[2023-10-13T22:46:48+0300] [ALPM] upgraded util-linux (2.39.1-1 -> 2.39.2-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded device-mapper (2.03.21-1 -> 2.03.22-2)
[2023-10-13T22:46:48+0300] [ALPM] upgraded json-c (0.16-1 -> 0.17-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded libnftnl (1.2.5-1 -> 1.2.6-1)
[2023-10-13T22:46:48+0300] [ALPM] upgraded libnl (3.7.0-3 -> 3.8.0-1)
[2023-10-13T22:46:48+0300] [ALPM] warning: directory permissions differ on /etc/credstore/
filesystem: 0  package: 700
[2023-10-13T22:46:48+0300] [ALPM] warning: directory permissions differ on /etc/credstore.encrypted/
[2023-10-13T22:46:49+0300] [ALPM] upgraded systemd (253.7-1 -> 254.5-1)
[2023-10-13T22:46:49+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T22:46:49+0300] [ALPM] upgraded android-tools (34.0.1-2 -> 34.0.4-2)
[2023-10-13T22:46:49+0300] [ALPM] upgraded aom (3.6.1-1 -> 3.7.0-1)
[2023-10-13T22:46:49+0300] [ALPM] upgraded python (3.11.3-2 -> 3.11.5-2)
[2023-10-13T22:46:49+0300] [ALPM] upgraded apparmor (3.1.6-1 -> 3.1.6-2)
[2023-10-13T22:46:49+0300] [ALPM] upgraded libsysprof-capture (3.48.0-2 -> 3.48.0-4)
[2023-10-13T22:46:49+0300] [ALPM] upgraded glib2 (2.76.4-1 -> 2.78.0-2)
[2023-10-13T22:46:49+0300] [ALPM] upgraded harfbuzz (8.0.1-1 -> 8.2.1-1)
[2023-10-13T22:46:49+0300] [ALPM] upgraded freetype2 (2.13.1-1 -> 2.13.2-1)
[2023-10-13T22:46:50+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T22:46:50+0300] [ALPM] upgraded xcb-proto (1.15.2-3 -> 1.16.0-1)
[2023-10-13T22:46:50+0300] [ALPM] upgraded libxcb (1.15-2 -> 1.16-1)
[2023-10-13T22:46:50+0300] [ALPM] upgraded libx11 (1.8.6-1 -> 1.8.7-1)
[2023-10-13T22:46:50+0300] [ALPM] upgraded cairo (1.17.8-2 -> 1.18.0-1)
[2023-10-13T22:46:50+0300] [ALPM] upgraded libxml2 (2.11.4-1 -> 2.11.5-1)
[2023-10-13T22:46:50+0300] [ALPM] upgraded pango (1:1.50.14-1 -> 1:1.51.1-1)
[2023-10-13T22:46:50+0300] [ALPM] upgraded libjpeg-turbo (2.1.5.1-1 -> 3.0.0-1)
[2023-10-13T22:46:50+0300] [ALPM] upgraded shared-mime-info (2.2+13+ga2ffb28-1 -> 2.3-1)
[2023-10-13T22:46:50+0300] [ALPM] installed jbigkit (2.1-7)
[2023-10-13T22:46:50+0300] [ALPM] upgraded libtiff (4.5.1-1 -> 4.6.0-1)
[2023-10-13T22:46:50+0300] [ALPM] upgraded librsvg (2:2.56.3-1 -> 2:2.57.0-1)
[2023-10-13T22:46:50+0300] [ALPM] upgraded libxmlb (0.3.11-1 -> 0.3.14-1)
[2023-10-13T22:46:50+0300] [ALPM] upgraded appstream (0.16.2-1 -> 0.16.3-1)
[2023-10-13T22:46:50+0300] [ALPM] upgraded libdrm (2.4.115-1 -> 2.4.116-1)
[2023-10-13T22:46:50+0300] [ALPM] upgraded libedit (20221030_3.1-1 -> 20230828_3.1-1)
[2023-10-13T22:46:51+0300] [ALPM] upgraded llvm-libs (15.0.7-3 -> 16.0.6-1)
[2023-10-13T22:46:51+0300] [ALPM] upgraded vulkan-icd-loader (1.3.255-1 -> 1.3.263-1)
[2023-10-13T22:46:52+0300] [ALPM] upgraded mesa (23.0.4-3 -> 1:23.1.9-1)
[2023-10-13T22:46:52+0300] [ALPM] upgraded libwacom (2.7.0-1 -> 2.8.0-1)
[2023-10-13T22:46:52+0300] [ALPM] upgraded libinput (1.23.0-1 -> 1.24.0-1)
[2023-10-13T22:46:52+0300] [ALPM] upgraded xf86-input-libinput (1.3.0-1 -> 1.4.0-1)
[2023-10-13T22:46:52+0300] [ALPM] upgraded libxrandr (1.5.3-1 -> 1.5.4-1)
[2023-10-13T22:46:58+0300] [ALPM] upgraded nvidia-470xx-utils (470.199.02-2 -> 470.199.02-4)
[2023-10-13T22:46:58+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T22:46:58+0300] [ALPM] upgraded libglvnd (1.6.0-1 -> 1.7.0-1)
[2023-10-13T22:46:58+0300] [ALPM] upgraded xdg-utils (1.1.3+25+g8ae0263-1 -> 1.1.3+45+g301a1a4-1)
[2023-10-13T22:46:58+0300] [ALPM] upgraded sqlite (3.42.0-1 -> 3.43.1-1)
[2023-10-13T22:46:58+0300] [ALPM] upgraded libproxy (0.5.3-1 -> 0.5.3-2)
[2023-10-13T22:46:58+0300] [ALPM] upgraded gnutls (3.8.0-1 -> 3.8.1-2)
[2023-10-13T22:46:59+0300] [ALPM] upgraded avahi (1:0.8+r22+gfd482a7-1 -> 1:0.8+r139+ge5b0bad-1)
[2023-10-13T22:46:59+0300] [ALPM] upgraded libcups (1:2.4.6-1 -> 1:2.4.7-2)
[2023-10-13T22:46:59+0300] [ALPM] upgraded qt5-translations (5.15.10-1 -> 5.15.11-1)
[2023-10-13T22:46:59+0300] [ALPM] upgraded qt5-base (5.15.10+kde+r135-1 -> 5.15.11+kde+r134-1)
[2023-10-13T22:46:59+0300] [ALPM] upgraded appstream-qt (0.16.2-1 -> 0.16.3-1)
[2023-10-13T22:46:59+0300] [ALPM] upgraded archlinux-appstream-data (20230715-1 -> 20230827-2)
[2023-10-13T22:47:00+0300] [ALPM] upgraded btrfs-progs (6.3.2-1 -> 6.5.2-2)
[2023-10-13T22:47:00+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T22:47:00+0300] [ALPM] installed libnvme (1.6-1)
[2023-10-13T22:47:00+0300] [ALPM] upgraded nss (3.91-1 -> 3.94-1)
[2023-10-13T22:47:00+0300] [ALPM] upgraded mpfr (4.2.0.p12-1 -> 4.2.1-1)
[2023-10-13T22:47:00+0300] [ALPM] upgraded libsecret (0.20.5-2 -> 0.21.1-1)
[2023-10-13T22:47:00+0300] [ALPM] upgraded pinentry (1.2.1-1 -> 1.2.1-3)
[2023-10-13T22:47:00+0300] [ALPM] upgraded gnupg (2.2.41-1 -> 2.2.41-2)
[2023-10-13T22:47:00+0300] [ALPM] upgraded gpgme (1.21.0-1 -> 1.22.0-1)
[2023-10-13T22:47:00+0300] [ALPM] upgraded libblockdev (2.28-4 -> 3.0.3-4)
[2023-10-13T22:47:00+0300] [ALPM] upgraded thin-provisioning-tools (1.0.4-1 -> 1.0.6-1)
[2023-10-13T22:47:00+0300] [ALPM] upgraded lvm2 (2.03.21-1 -> 2.03.22-2)
[2023-10-13T22:47:00+0300] [ALPM] upgraded polkit (122-1 -> 123-1)
[2023-10-13T22:47:00+0300] [ALPM] upgraded udisks2 (2.9.4-4 -> 2.10.1-2)
[2023-10-13T22:47:00+0300] [ALPM] installed solid5 (5.110.0-1)
[2023-10-13T22:47:00+0300] [ALPM] installed kcoreaddons5 (5.110.0-1)
[2023-10-13T22:47:01+0300] [ALPM] installed kwidgetsaddons5 (5.110.0-1)
[2023-10-13T22:47:01+0300] [ALPM] upgraded qt5-x11extras (5.15.10-1 -> 5.15.11-1)
[2023-10-13T22:47:01+0300] [ALPM] installed kjobwidgets5 (5.110.0-1)
[2023-10-13T22:47:01+0300] [ALPM] installed kdbusaddons5 (5.110.0-1)
[2023-10-13T22:47:01+0300] [ALPM] installed kconfig5 (5.110.0-1)
[2023-10-13T22:47:01+0300] [ALPM] installed kwindowsystem5 (5.110.0-1)
[2023-10-13T22:47:01+0300] [ALPM] installed kcrash5 (5.110.0-1)
[2023-10-13T22:47:01+0300] [ALPM] installed kglobalaccel5 (5.110.0-1)
[2023-10-13T22:47:01+0300] [ALPM] upgraded qt5-svg (5.15.10+kde+r8-1 -> 5.15.11+kde+r6-1)
[2023-10-13T22:47:01+0300] [ALPM] upgraded polkit-qt5 (0.114.0-1 -> 0.114.0-2)
[2023-10-13T22:47:01+0300] [ALPM] installed kauth5 (5.110.0-1)
[2023-10-13T22:47:01+0300] [ALPM] installed kcodecs5 (5.110.0-1)
[2023-10-13T22:47:02+0300] [ALPM] upgraded qt5-declarative (5.15.10+kde+r29-1 -> 5.15.11+kde+r30-1)
[2023-10-13T22:47:02+0300] [ALPM] upgraded qt5-wayland (5.15.10+kde+r52-1 -> 5.15.11+kde+r59-1)
[2023-10-13T22:47:02+0300] [ALPM] installed kguiaddons5 (5.110.0-1)
[2023-10-13T22:47:02+0300] [ALPM] installed ki18n5 (5.110.0-1)
[2023-10-13T22:47:03+0300] [ALPM] installed kconfigwidgets5 (5.110.0-1)
[2023-10-13T22:47:03+0300] [ALPM] installed karchive5 (5.110.0-1)
[2023-10-13T22:47:03+0300] [ALPM] installed kiconthemes5 (5.110.0-1)
[2023-10-13T22:47:03+0300] [ALPM] installed kitemviews5 (5.110.0-1)
[2023-10-13T22:47:03+0300] [ALPM] installed kxmlgui5 (5.110.0-1)
[2023-10-13T22:47:03+0300] [ALPM] installed kbookmarks5 (5.110.0-1)
[2023-10-13T22:47:04+0300] [ALPM] upgraded gstreamer (1.22.5-1 -> 1.22.6-1)
[2023-10-13T22:47:04+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T22:47:04+0300] [ALPM] upgraded gst-plugins-base-libs (1.22.5-1 -> 1.22.6-1)
[2023-10-13T22:47:04+0300] [ALPM] upgraded gst-plugins-base (1.22.5-1 -> 1.22.6-1)
[2023-10-13T22:47:04+0300] [ALPM] upgraded mpg123 (1.31.3-1 -> 1.32.2-1)
[2023-10-13T22:47:04+0300] [ALPM] upgraded libsndfile (1.2.0-1 -> 1.2.2-1)
[2023-10-13T22:47:04+0300] [ALPM] upgraded qt5-multimedia (5.15.10+kde+r3-1 -> 5.15.11+kde+r2-1)
[2023-10-13T22:47:04+0300] [ALPM] upgraded qt5-speech (5.15.10+kde+r1-1 -> 5.15.11+kde+r1-1)
[2023-10-13T22:47:04+0300] [ALPM] upgraded tar (1.34-2 -> 1.35-2)
[2023-10-13T22:47:04+0300] [ALPM] upgraded libtool (2.4.7+4+g1ec8fa28-4 -> 2.4.7+4+g1ec8fa28-6)
[2023-10-13T22:47:04+0300] [ALPM] installed knotifications5 (5.110.0-1)
[2023-10-13T22:47:04+0300] [ALPM] installed kservice5 (5.110.0-1)
[2023-10-13T22:47:04+0300] [ALPM] installed kwallet5 (5.110.0-1)
[2023-10-13T22:47:04+0300] [ALPM] installed kcompletion5 (5.110.0-1)
[2023-10-13T22:47:05+0300] [ALPM] installed sonnet5 (5.110.0-1)
[2023-10-13T22:47:05+0300] [ALPM] installed ktextwidgets5 (5.110.0-1)
[2023-10-13T22:47:05+0300] [ALPM] installed kded5 (5.110.0-2)
[2023-10-13T22:47:06+0300] [ALPM] installed kio5 (5.110.0-2)
[2023-10-13T22:47:06+0300] [ALPM] installed kparts5 (5.110.0-1)
[2023-10-13T22:47:06+0300] [ALPM] installed kpty5 (5.110.0-1)
[2023-10-13T22:47:06+0300] [ALPM] upgraded libarchive (3.7.0-2 -> 3.7.2-1)
[2023-10-13T22:47:06+0300] [ALPM] upgraded libzip (1.10.0-1 -> 1.10.1-1)
[2023-10-13T22:47:06+0300] [ALPM] installed kitemmodels5 (5.110.0-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded ark (23.04.3-1 -> 23.08.1-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded arm-none-eabi-binutils (2.40-1 -> 2.41-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded at-spi2-core (2.48.3-2 -> 2.50.0-1)
[2023-10-13T22:47:07+0300] [ALPM] installed attica5 (5.110.0-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded openjpeg2 (2.5.0-2 -> 2.5.0-3)
[2023-10-13T22:47:07+0300] [ALPM] upgraded poppler (23.07.0-1 -> 23.10.0-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded poppler-qt5 (23.07.0-1 -> 23.10.0-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded dav1d (1.2.1-1 -> 1.3.0-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded gperftools (2.10-3 -> 2.13-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded highway (1.0.5-1 -> 1.0.7-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded imath (3.1.9-1 -> 3.1.9-2)
[2023-10-13T22:47:07+0300] [ALPM] upgraded libdeflate (1.18-1 -> 1.19-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded openexr (3.1.9-1 -> 3.2.1-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded libjxl (0.8.2-1 -> 0.8.2-2)
[2023-10-13T22:47:07+0300] [ALPM] upgraded db5.3 (5.3.28-2 -> 5.3.28-4)
[2023-10-13T22:47:07+0300] [ALPM] upgraded libopenmpt (0.7.2-1 -> 0.7.3-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded libva (2.19.0-1 -> 2.20.0-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded libvdpau (1.5-1 -> 1.5-2)
[2023-10-13T22:47:07+0300] [ALPM] upgraded libvpx (1.13.0-1 -> 1.13.1-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded libwebp (1.3.1-1 -> 1.3.2-1)
[2023-10-13T22:47:07+0300] [ALPM] installed onevpl (2023.3.1-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded hidapi (0.14.0-1 -> 0.14.0-2)
[2023-10-13T22:47:07+0300] [ALPM] upgraded sdl2 (2.28.1-1 -> 2.28.4-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded srt (1.5.2-1 -> 1.5.3-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded svt-av1 (1.6.0-1 -> 1.7.0-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded ffmpeg (2:6.0-8 -> 2:6.0-12)
[2023-10-13T22:47:07+0300] [ALPM] upgraded libtommath (1.2.0-4 -> 1.2.1-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded gettext (0.22-1 -> 0.22.3-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded libinih (56-1 -> 57-1)
[2023-10-13T22:47:07+0300] [ALPM] installed kfilemetadata5 (5.110.0-1)
[2023-10-13T22:47:07+0300] [ALPM] upgraded libxss (1.2.3-4 -> 1.2.4-1)
[2023-10-13T22:47:07+0300] [ALPM] installed kidletime5 (5.110.0-1)
[2023-10-13T22:47:08+0300] [ALPM] installed baloo5 (5.110.0-1)
[2023-10-13T22:47:08+0300] [ALPM] upgraded baloo-widgets (23.04.3-1 -> 23.08.1-1)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl (5.36.1-2 -> 5.38.0-1)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-autovivification (0.18-8 -> 0.18-9)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-business-isbn-data (20230516.001-1 -> 20230516.001-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-business-isbn (3.008-1 -> 3.008-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-tie-cycle (1.227-1 -> 1.227-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-business-ismn (1.203-1 -> 1.203-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-business-issn (1.005-1 -> 1.005-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-class-accessor (0.51-2 -> 0.51-3)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-number-compare (0.03-12 -> 0.03-13)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-text-glob (0.11-9 -> 0.11-10)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-file-find-rule (0.34-9 -> 0.34-10)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-clone (0.46-1 -> 0.46-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-data-compare (1.29-1 -> 1.29-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-data-dump (1.25-3 -> 1.25-4)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-data-uniqid (0.12-10 -> 0.12-11)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-try-tiny (0.31-2 -> 0.31-3)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-module-implementation (0.09-8 -> 0.09-9)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-params-validate (1.31-1 -> 1.31-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-params-util (1.102-3 -> 1.102-4)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-sub-install (0.928-8 -> 0.928-9)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-data-optlist (0.114-1 -> 0.114-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-sub-exporter (0.989-1 -> 0.990-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-sub-exporter-progressive (0.001013-8 -> 0.001013-9)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-variable-magic (0.63-1 -> 0.63-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-b-hooks-endofscope (0.26-1 -> 0.26-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-sub-identify (0.14-10 -> 0.14-11)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-exporter-tiny (1.006002-1 -> 1.006002-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-list-moreutils-xs (0.430-3 -> 0.430-4)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-list-moreutils (0.430-3 -> 0.430-4)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-dist-checkconflicts (0.11-8 -> 0.11-9)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-package-stash-xs (0.30-1 -> 0.30-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-package-stash (0.40-2 -> 0.40-3)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-namespace-clean (0.27-8 -> 0.27-9)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-namespace-autoclean (0.29-4 -> 0.29-5)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-eval-closure (0.14-8 -> 0.14-9)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-role-tiny (2.002004-3 -> 2.002004-4)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-class-data-inheritable (0.09-3 -> 0.09-4)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-devel-stacktrace (2.04-2 -> 2.04-3)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-exception-class (1.45-2 -> 1.45-3)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-params-validationcompiler (0.31-1 -> 0.31-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-class-inspector (1.36-5 -> 1.36-6)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-file-sharedir (1.118-2 -> 1.118-3)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-file-sharedir-install (0.14-1 -> 0.14-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-list-someutils (0.59-1 -> 0.59-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-list-utilsby (0.12-1 -> 0.12-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-list-allutils (0.19-1 -> 0.19-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-test-fatal (0.017-1 -> 0.017-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-class-load (0.25-2 -> 0.25-3)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-class-singleton (1.6-1 -> 1.6-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-mro-compat (0.15-1 -> 0.15-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-datetime (1.59-1 -> 1.59-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-datetime-calendar-julian (0.107-1 -> 0.107-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-package-deprecationmanager (0.18-1 -> 0.18-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-datetime-format-strptime (1.79-1 -> 1.79-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-datetime-format-builder (1:0.83-3 -> 1:0.83-4)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-file-slurper (0.014-1 -> 0.014-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-ipc-run3 (0.048-10 -> 0.048-11)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-lingua-translit (0.29-1 -> 0.29-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-log-log4perl (1.57-1 -> 1.57-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-net-ssleay (1.92-2 -> 1.92-3)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-uri (5.19-1 -> 5.21-1)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-io-socket-ssl (2.083-1 -> 2.083-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-net-http (6.23-1 -> 6.23-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-encode-locale (1.05-10 -> 1.05-11)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-timedate (2.33-4 -> 2.33-5)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-http-date (6.05-6 -> 6.06-1)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-file-listing (6.15-2 -> 6.16-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-html-tagset (3.20-13 -> 3.20-14)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-io-html (1.004-3 -> 1.004-4)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-lwp-mediatypes (6.04-3 -> 6.04-4)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-http-message (6.44-1 -> 6.45-1)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-html-parser (3.81-1 -> 3.81-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-http-cookies (6.10-3 -> 6.10-4)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-http-daemon (6.16-1 -> 6.16-2)
[2023-10-13T22:47:08+0300] [ALPM] installed perl-http-cookiejar (0.014-1)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-http-negotiate (6.01-11 -> 6.01-12)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-www-robotrules (6.02-11 -> 6.02-12)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-libwww (6.67-1 -> 6.72-1)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-lwp-protocol-https (6.10-4 -> 6.11-1)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-mozilla-ca (20221114-1 -> 20230821-1)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-parse-recdescent (1.967015-2 -> 1.967015-3)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-perlio-utf8-strict (0.010-1 -> 0.010-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-regexp-common (2017060201-5 -> 2017060201-6)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-sort-key (1.33-11 -> 1.33-12)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-text-bibtex (0.89-1 -> 0.89-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-text-csv (2.02-1 -> 2.03-1)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-text-roman (3.5-9 -> 3.5-10)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-mime-charset (1.013.1-1 -> 1.013.1-2)
[2023-10-13T22:47:08+0300] [ALPM] upgraded perl-unicode-linebreak (2019.001-5 -> 2019.001-6)
[2023-10-13T22:47:09+0300] [ALPM] upgraded perl-capture-tiny (0.48-6 -> 0.48-7)
[2023-10-13T22:47:09+0300] [ALPM] upgraded perl-ffi-checklib (0.31-2 -> 0.31-3)
[2023-10-13T22:47:09+0300] [ALPM] upgraded perl-file-chdir (0.1011-4 -> 0.1011-5)
[2023-10-13T22:47:09+0300] [ALPM] upgraded perl-file-which (1.27-2 -> 1.27-3)
[2023-10-13T22:47:09+0300] [ALPM] upgraded perl-path-tiny (0.144-1 -> 0.144-2)
[2023-10-13T22:47:09+0300] [ALPM] upgraded perl-alien-build (2.80-1 -> 2.80-2)
[2023-10-13T22:47:09+0300] [ALPM] upgraded perl-alien-libxml2 (0.19-1 -> 0.19-2)
[2023-10-13T22:47:09+0300] [ALPM] upgraded perl-xml-libxml (2.0208-1 -> 2.0209-1)
[2023-10-13T22:47:09+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T22:47:09+0300] [ALPM] upgraded perl-file-slurp-tiny (0.004-8 -> 0.004-9)
[2023-10-13T22:47:09+0300] [ALPM] upgraded perl-xml-libxml-simple (1.01-1 -> 1.01-2)
[2023-10-13T22:47:09+0300] [ALPM] upgraded perl-xml-libxslt (2.002001-1 -> 2.002001-2)
[2023-10-13T22:47:09+0300] [ALPM] upgraded perl-xml-writer (0.900-1 -> 0.900-2)
[2023-10-13T22:47:09+0300] [ALPM] upgraded biber (1:2.19-1 -> 1:2.19-2)
[2023-10-13T22:47:09+0300] [ALPM] upgraded jemalloc (1:5.3.0-2 -> 1:5.3.0-3)
[2023-10-13T22:47:09+0300] [ALPM] upgraded bind (9.18.16-1 -> 9.18.19-1)
[2023-10-13T22:47:09+0300] [ALPM] upgraded binutils (2.40-6 -> 2.41-3)
[2023-10-13T22:47:09+0300] [ALPM] upgraded blas (3.11.0-2 -> 3.11.0-3)
[2023-10-13T22:47:09+0300] [ALPM] warning: directory permissions differ on /etc/bluetooth/
filesystem: 755  package: 555
[2023-10-13T22:47:09+0300] [ALPM] upgraded bluez (5.68-1 -> 5.70-1)
[2023-10-13T22:47:09+0300] [ALPM] installed bluez-qt5 (5.110.0-1)
[2023-10-13T22:47:09+0300] [ALPM] installed kpackage5 (5.110.0-1)
[2023-10-13T22:47:09+0300] [ALPM] installed kdeclarative5 (5.110.0-1)
[2023-10-13T22:47:09+0300] [ALPM] upgraded bluedevil (1:5.27.6-1 -> 1:5.27.8-2)
[2023-10-13T22:47:09+0300] [ALPM] upgraded bluez-libs (5.68-1 -> 5.70-1)
[2023-10-13T22:47:09+0300] [ALPM] upgraded boost-libs (1.81.0-7 -> 1.83.0-2)
[2023-10-13T22:47:09+0300] [ALPM] upgraded noto-fonts (1:23.7.1-1 -> 1:23.10.1-1)
[2023-10-13T22:47:09+0300] [ALPM] upgraded gtk-update-icon-cache (1:4.10.4-1 -> 1:4.12.3-1)
[2023-10-13T22:47:09+0300] [ALPM] upgraded libcloudproviders (0.3.1+r8+g3a229ee-1 -> 0.3.4-1)
[2023-10-13T22:47:09+0300] [ALPM] upgraded json-glib (1.6.6-2 -> 1.8.0-1)
[2023-10-13T22:47:10+0300] [ALPM] upgraded glib-networking (1:2.76.1-1 -> 1:2.78.0-1)
[2023-10-13T22:47:10+0300] [ALPM] upgraded libsoup3 (3.4.2-1 -> 3.4.3-1)
[2023-10-13T22:47:10+0300] [ALPM] upgraded tracker3 (3.5.3-2 -> 3.6.0-1)
[2023-10-13T22:47:10+0300] [ALPM] upgraded brave-browser (1.56.20-1 -> 1.58.137-1)
[2023-10-13T22:47:10+0300] [ALPM] installed syndication5 (5.110.0-1)
[2023-10-13T22:47:11+0300] [ALPM] installed knewstuff5 (5.110.0-1)
[2023-10-13T22:47:11+0300] [ALPM] installed frameworkintegration5 (5.110.0-1)
[2023-10-13T22:47:11+0300] [ALPM] upgraded kdecoration (5.27.6-1 -> 5.27.8-2)
[2023-10-13T22:47:17+0300] [ALPM] upgraded breeze-icons (5.108.0-1 -> 5.110.0-1)
[2023-10-13T22:47:17+0300] [ALPM] upgraded qt5-quickcontrols (5.15.10-1 -> 5.15.11-1)
[2023-10-13T22:47:18+0300] [ALPM] upgraded qt5-quickcontrols2 (5.15.10+kde+r6-1 -> 5.15.11+kde+r5-1)
[2023-10-13T22:47:18+0300] [ALPM] upgraded qt5-graphicaleffects (5.15.10-1 -> 5.15.11-1)
[2023-10-13T22:47:18+0300] [ALPM] upgraded kirigami2 (5.108.0-1 -> 5.110.0-2)
[2023-10-13T22:47:18+0300] [ALPM] upgraded breeze (5.27.6-1 -> 5.27.8-2)
[2023-10-13T22:47:18+0300] [ALPM] upgraded c-ares (1.19.1-1 -> 1.20.1-1)
[2023-10-13T22:47:18+0300] [ALPM] upgraded cairo-perl (1.109-2 -> 1.109-3)
[2023-10-13T22:47:18+0300] [ALPM] upgraded libsigc++ (2.12.0-1 -> 2.12.1-1)
[2023-10-13T22:47:20+0300] [ALPM] upgraded cairomm (1.14.4-1 -> 1.14.5-1)
[2023-10-13T22:47:20+0300] [ALPM] upgraded libsigc++-3.0 (3.4.0-1 -> 3.6.0-1)
[2023-10-13T22:47:20+0300] [ALPM] upgraded cairomm-1.16 (1.16.2-1 -> 1.18.0-1)
[2023-10-13T22:47:20+0300] [ALPM] upgraded cblas (3.11.0-2 -> 3.11.0-3)
[2023-10-13T22:47:20+0300] [ALPM] upgraded cfitsio (1:4.2.0-1 -> 1:4.3.0-1)
[2023-10-13T22:47:20+0300] [ALPM] upgraded minizip (1:1.2.13-3 -> 1:1.3-1)
[2023-10-13T22:47:20+0300] [ALPM] upgraded re2 (1:20230301-1 -> 1:20230901-2)
[2023-10-13T22:47:21+0300] [ALPM] upgraded libavif (0.11.1-1 -> 1.0.1-2)
[2023-10-13T22:47:22+0300] [ALPM] upgraded chromium (115.0.5790.170-1 -> 118.0.5993.54-1)
[2023-10-13T22:47:23+0300] [ALPM] upgraded clamav (1.0.1-1 -> 1.2.0-1)
[2023-10-13T22:47:27+0300] [ALPM] upgraded gcc (13.1.1-2 -> 13.2.1-3)
[2023-10-13T22:47:28+0300] [ALPM] upgraded compiler-rt (15.0.7-2 -> 16.0.6-2)
[2023-10-13T22:47:45+0300] [ALPM] upgraded clang (15.0.7-9 -> 16.0.6-1)
[2023-10-13T22:47:47+0300] [ALPM] upgraded perl-algorithm-diff (1:1.201-3 -> 1:1.201-4)
[2023-10-13T22:47:48+0300] [ALPM] upgraded perl-class-method-modifiers (2.15-1 -> 2.15-2)
[2023-10-13T22:47:48+0300] [ALPM] upgraded perl-devel-globaldestruction (0.14-8 -> 0.14-9)
[2023-10-13T22:47:49+0300] [ALPM] upgraded perl-import-into (1.002005-8 -> 1.002005-9)
[2023-10-13T22:47:49+0300] [ALPM] upgraded perl-sub-quote (1:2.006008-1 -> 1:2.006008-2)
[2023-10-13T22:47:50+0300] [ALPM] upgraded perl-moo (2.005005-1 -> 2.005005-2)
[2023-10-13T22:47:51+0300] [ALPM] upgraded perl-parallel-forkmanager (2.02-4 -> 2.02-5)
[2023-10-13T22:47:51+0300] [ALPM] upgraded cloc (1.96-1 -> 1.98-1)
[2023-10-13T22:48:05+0300] [ALPM] upgraded cmake (3.27.0-1 -> 3.27.7-1)
[2023-10-13T22:48:07+0300] [ALPM] upgraded cpupower (6.3-2 -> 6.5-1)
[2023-10-13T22:48:08+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T22:48:11+0300] [ALPM] upgraded qpdf (11.5.0-1 -> 11.6.2-1)
[2023-10-13T22:48:12+0300] [ALPM] installed libcupsfilters (2.0.0-1)
[2023-10-13T22:48:13+0300] [ALPM] installed libppd (2.0.0-1)
[2023-10-13T22:48:14+0300] [ALPM] upgraded cups-filters (1.28.17-4 -> 2.0.0-1)
[2023-10-13T22:48:21+0300] [ALPM] upgraded cups (1:2.4.6-1 -> 1:2.4.7-2)
[2023-10-13T22:48:21+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T22:48:21+0300] [ALPM] upgraded cython (3.0.0-1 -> 3.0.3-2)
[2023-10-13T22:48:21+0300] [ALPM] upgraded debuginfod (0.189-1 -> 0.189-3)
[2023-10-13T22:48:22+0300] [ALPM] upgraded dhcpcd (10.0.1-1 -> 10.0.2-1)
[2023-10-13T22:48:39+0300] [ALPM] upgraded discord (0.0.28-1 -> 0.0.31-1)
[2023-10-13T22:48:44+0300] [ALPM] upgraded discount (2.2.7.c-1 -> 3.0.0.a-1)
[2023-10-13T22:48:44+0300] [ALPM] installed kdnssd5 (5.110.0-1)
[2023-10-13T22:48:44+0300] [ALPM] upgraded ldb (2:2.7.2-2 -> 2:2.8.0-1)
[2023-10-13T22:48:45+0300] [ALPM] upgraded libwbclient (4.18.5-2 -> 4.19.0-1)
[2023-10-13T22:48:47+0300] [ALPM] upgraded smbclient (4.18.5-2 -> 4.19.0-1)
[2023-10-13T22:48:47+0300] [ALPM] upgraded libkexiv2 (23.04.3-1 -> 23.08.1-1)
[2023-10-13T22:48:47+0300] [ALPM] installed syntax-highlighting5 (5.110.0-1)
[2023-10-13T22:48:51+0300] [ALPM] upgraded kio-extras (23.04.3-1 -> 23.08.1-1)
[2023-10-13T22:48:51+0300] [ALPM] installed kcmutils5 (5.110.0-1)
[2023-10-13T22:48:51+0300] [ALPM] installed kactivities5 (5.110.0-1)
[2023-10-13T22:48:51+0300] [ALPM] upgraded dolphin (23.04.3-1 -> 23.08.1-1)
[2023-10-13T22:48:51+0300] [ALPM] upgraded dolphin-plugins (23.04.3-1 -> 23.08.1-1)
[2023-10-13T22:48:51+0300] [ALPM] upgraded dotnet-host (7.0.9.sdk109-1 -> 7.0.11.sdk111-1)
[2023-10-13T22:48:53+0300] [ALPM] upgraded dotnet-runtime (7.0.9.sdk109-1 -> 7.0.11.sdk111-1)
[2023-10-13T22:48:53+0300] [ALPM] upgraded libxpm (3.5.16-1 -> 3.5.17-1)
[2023-10-13T22:48:55+0300] [ALPM] upgraded libheif (1.16.2-1 -> 1.16.2-2)
[2023-10-13T22:48:56+0300] [ALPM] upgraded gd (2.3.3-6 -> 2.3.3-7)
[2023-10-13T22:48:56+0300] [ALPM] upgraded harfbuzz-icu (8.0.1-1 -> 8.2.1-1)
[2023-10-13T22:48:56+0300] [ALPM] upgraded libsynctex (2023.66984-15 -> 2023.66984-16)
[2023-10-13T22:48:58+0300] [ALPM] upgraded texlive-bin (2023.66984-15 -> 2023.66984-16)
[2023-10-13T22:49:07+0300] [ALPM] upgraded ghostscript (10.01.2-1 -> 10.02.0-1)
[2023-10-13T22:49:08+0300] [ALPM] upgraded dvisvgm (3.1-2 -> 3.1.1-1)
[2023-10-13T22:49:09+0300] [ALPM] upgraded ecryptfs-utils (111-7 -> 111-8)
[2023-10-13T22:49:14+0300] [ALPM] upgraded electron25 (25.3.1-1 -> 25.9.0-2)
[2023-10-13T22:49:22+0300] [ALPM] upgraded elfutils (0.189-1 -> 0.189-3)
[2023-10-13T22:49:23+0300] [ALPM] upgraded enchant (2.3.4-2 -> 2.6.0-1)
[2023-10-13T22:49:23+0300] [ALPM] upgraded libmfx (23.2.2-1 -> 23.2.2-2)
[2023-10-13T22:49:24+0300] [ALPM] upgraded ffmpeg4.4 (4.4.4-1 -> 4.4.4-2)
[2023-10-13T22:49:24+0300] [ALPM] upgraded ffmpegthumbs (23.04.3-1 -> 23.08.1-1)
[2023-10-13T22:49:25+0300] [ALPM] upgraded figlet (2.2.5-4 -> 2.2.5-5)
[2023-10-13T22:49:25+0300] [ALPM] installed qqc2-desktop-style5 (5.110.0-1)
[2023-10-13T22:49:26+0300] [ALPM] installed kquickcharts5 (5.110.0-1)
[2023-10-13T22:49:29+0300] [ALPM] upgraded filelight (23.04.3-1 -> 23.08.1-1)
[2023-10-13T22:49:40+0300] [ALPM] upgraded firefox (116.0-1 -> 118.0.1-1)
[2023-10-13T22:49:41+0300] [ALPM] upgraded libpipewire (1:0.3.75-2 -> 1:0.3.81-1)
[2023-10-13T22:49:41+0300] [ALPM] upgraded fluidsynth (2.3.3-1 -> 2.3.4-1)
[2023-10-13T22:49:42+0300] [ALPM] upgraded fmt (9.1.0-4 -> 10.1.0-1)
[2023-10-13T22:49:47+0300] [ALPM] upgraded foomatic-db (3:20230709-1 -> 3:20230903-1)
[2023-10-13T22:50:02+0300] [ALPM] upgraded foomatic-db-gutenprint-ppds (5.3.4-2 -> 5.3.4-3)
[2023-10-13T22:50:02+0300] [ALPM] upgraded foomatic-db-nonfree (3:20230709-1 -> 3:20230903-1)
[2023-10-13T22:50:03+0300] [ALPM] upgraded foomatic-db-nonfree-ppds (3:20230709-1 -> 3:20230903-1)
[2023-10-13T22:50:25+0300] [ALPM] upgraded foomatic-db-ppds (3:20230709-1 -> 3:20230903-1)
[2023-10-13T22:50:25+0300] [ALPM] upgraded frei0r-plugins (2.3.0-2 -> 2.3.1-1)
[2023-10-13T22:50:25+0300] [ALPM] warning: /etc/fuse.conf installed as /etc/fuse.conf.pacnew
[2023-10-13T22:50:25+0300] [ALPM] upgraded fuse-common (3.15.1-1 -> 3.16.1-1)
[2023-10-13T22:50:25+0300] [ALPM] upgraded fuse3 (3.15.1-1 -> 3.16.1-1)
[2023-10-13T22:50:28+0300] [ALPM] upgraded libmm-glib (1.20.6-1 -> 1.20.6-2)
[2023-10-13T22:50:30+0300] [ALPM] installed passim (0.1.2-1)
[2023-10-13T22:50:32+0300] [ALPM] upgraded protobuf-c (1.4.1-2 -> 1.4.1-4)
[2023-10-13T22:50:43+0300] [ALPM] upgraded fwupd (1.9.3-1 -> 1.9.6-1)
[2023-10-13T22:51:21+0300] [ALPM] upgraded gcc-ada (13.1.1-2 -> 13.2.1-3)
[2023-10-13T22:51:24+0300] [ALPM] upgraded gcc-fortran (13.1.1-2 -> 13.2.1-3)
[2023-10-13T22:51:27+0300] [ALPM] upgraded lensfun (1:0.3.4-2 -> 1:0.3.4-3)
[2023-10-13T22:51:31+0300] [ALPM] upgraded luajit (2.1.0.beta3.r493.g8635cbab-1 -> 2.1.1694285958-1)
[2023-10-13T22:51:37+0300] [ALPM] upgraded poppler-glib (23.07.0-1 -> 23.10.0-1)
[2023-10-13T22:51:38+0300] [ALPM] upgraded lapack (3.11.0-2 -> 3.11.0-3)
[2023-10-13T22:51:50+0300] [ALPM] upgraded suitesparse (7.1.0-2 -> 7.2.0-3)
[2023-10-13T22:51:51+0300] [ALPM] upgraded glu (9.0.2-3 -> 9.0.3-1)
[2023-10-13T22:51:59+0300] [ALPM] upgraded gegl (0.4.46-1 -> 0.4.46-2)
[2023-10-13T22:52:00+0300] [ALPM] upgraded geoclue (2.7.0-1 -> 2.7.1-1)
[2023-10-13T22:52:00+0300] [ALPM] upgraded qt5-webchannel (5.15.10+kde+r3-1 -> 5.15.11+kde+r3-1)
[2023-10-13T22:52:01+0300] [ALPM] upgraded qt5-location (5.15.10+kde+r4-2 -> 5.15.11+kde+r4-1)
[2023-10-13T22:52:43+0300] [ALPM] upgraded qt5-webengine (5.15.14-4 -> 5.15.15-2)
[2023-10-13T22:52:44+0300] [ALPM] upgraded ghostwriter (23.04.3-1 -> 23.08.1-1)
[2023-10-13T22:52:44+0300] [ALPM] upgraded libgexiv2 (0.14.1-1 -> 0.14.2-1)
[2023-10-13T22:53:31+0300] [ALPM] upgraded gimp (2.10.34-2 -> 2.10.34-3)
[2023-10-13T22:53:31+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T22:53:36+0300] [ALPM] upgraded perl-error (0.17029-4 -> 0.17029-5)
[2023-10-13T22:53:37+0300] [ALPM] upgraded perl-mailtools (2.21-6 -> 2.21-7)
[2023-10-13T22:53:48+0300] [ALPM] upgraded git (2.41.0-1 -> 2.42.0-1)
[2023-10-13T22:53:49+0300] [ALPM] upgraded glib-perl (1.329.3-3 -> 1.329.3-4)
[2023-10-13T22:53:50+0300] [ALPM] upgraded glib2-docs (2.76.4-1 -> 2.78.0-2)
[2023-10-13T22:53:56+0300] [ALPM] upgraded glibmm-2.68 (2.76.0-1 -> 2.78.0-1)
[2023-10-13T22:54:05+0300] [ALPM] upgraded glm (0.9.9.8-1 -> 0.9.9.8-2)
[2023-10-13T22:54:12+0300] [ALPM] upgraded glslang (12.2.0-1 -> 13.0.0-1)
[2023-10-13T22:54:14+0300] [ALPM] upgraded libgirepository (1.76.1-3 -> 1.78.1-1)
[2023-10-13T22:54:15+0300] [ALPM] upgraded gobject-introspection-runtime (1.76.1-3 -> 1.78.1-1)
[2023-10-13T22:54:18+0300] [ALPM] upgraded python-markdown (3.4.3-2 -> 3.5-1)
[2023-10-13T22:54:21+0300] [ALPM] upgraded gobject-introspection (1.76.1-3 -> 1.78.1-1)
[2023-10-13T22:54:31+0300] [ALPM] upgraded gopass (1.15.5-1 -> 1.15.8-1)
[2023-10-13T22:54:34+0300] [ALPM] upgraded graphicsmagick (1.3.40-3 -> 1.3.42-1)
[2023-10-13T22:54:40+0300] [ALPM] upgraded netpbm (10.73.43-1 -> 10.73.43-2)
[2023-10-13T22:54:49+0300] [ALPM] upgraded graphviz (8.0.5-2 -> 9.0.0-1)
[2023-10-13T22:54:49+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T22:54:50+0300] [ALPM] upgraded groff (1.23.0-3 -> 1.23.0-5)
[2023-10-13T22:54:50+0300] [ALPM] installed grub-update (2.12rc1.r49.ge58b870ff-1)
[2023-10-13T22:54:50+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T22:55:01+0300] [ALPM] upgraded grub (2.06.r499.ge67a551a4-4 -> 2.12rc1.r49.ge58b870ff-1)
[2023-10-13T22:55:01+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T22:55:03+0300] [ALPM] upgraded gsimplecal (2.4.1-1 -> 2.5.1-1)
[2023-10-13T22:55:10+0300] [ALPM] upgraded gspell (1.12.1-2 -> 1.12.2-1)
[2023-10-13T22:55:13+0300] [ALPM] upgraded gst-libav (1.22.5-1 -> 1.22.6-1)
[2023-10-13T22:55:14+0300] [ALPM] upgraded gupnp (1:1.6.4-1 -> 1:1.6.5-1)
[2023-10-13T22:55:25+0300] [ALPM] upgraded gst-plugins-bad-libs (1.22.5-1 -> 1.22.6-1)
[2023-10-13T22:55:26+0300] [ALPM] upgraded webrtc-audio-processing (0.3.1-3 -> 0.3.1-4)
[2023-10-13T22:55:28+0300] [ALPM] upgraded zvbi (0.2.41-1 -> 0.2.42-1)
[2023-10-13T22:55:29+0300] [ALPM] upgraded pcre (8.45-3 -> 8.45-4)
[2023-10-13T22:55:30+0300] [ALPM] upgraded openpmix (4.2.3-2 -> 4.2.6-1)
[2023-10-13T22:55:36+0300] [ALPM] upgraded openssh (9.3p2-1 -> 9.5p1-1)
[2023-10-13T22:55:41+0300] [ALPM] upgraded openmpi (4.1.5-2 -> 4.1.5-5)
[2023-10-13T22:55:45+0300] [ALPM] upgraded imagemagick (7.1.1.14-1 -> 7.1.1.20-1)
[2023-10-13T22:55:45+0300] [ALPM] upgraded gst-plugins-bad (1.22.5-1 -> 1.22.6-1)
[2023-10-13T22:55:46+0300] [ALPM] upgraded procps-ng (4.0.3-1 -> 4.0.4-2)
[2023-10-13T22:55:46+0300] [ALPM] upgraded imlib2 (1.11.1-1 -> 1.12.1-1)
[2023-10-13T22:55:48+0300] [ALPM] upgraded gst-plugins-good (1.22.5-1 -> 1.22.6-1)
[2023-10-13T22:55:48+0300] [ALPM] upgraded gst-plugins-ugly (1.22.5-1 -> 1.22.6-1)
[2023-10-13T22:55:48+0300] [ALPM] upgraded gtest (1.13.0-1 -> 1.14.0-1)
[2023-10-13T22:55:50+0300] [ALPM] upgraded gtk4 (1:4.10.4-1 -> 1:4.12.3-1)
[2023-10-13T22:55:53+0300] [ALPM] upgraded gtkmm-4.0 (4.10.0-1 -> 4.12.0-1)
[2023-10-13T22:55:59+0300] [ALPM] upgraded gtkmm3 (3.24.7-1 -> 3.24.8-1)
[2023-10-13T22:56:03+0300] [ALPM] upgraded gtkwave (3.3.115-1 -> 3.3.117-1)
[2023-10-13T22:56:22+0300] [ALPM] upgraded gutenprint (5.3.4-2 -> 5.3.4-3)
[2023-10-13T22:56:22+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T22:56:31+0300] [ALPM] upgraded gvfs (1.50.5-1 -> 1.52.0-1)
[2023-10-13T22:56:32+0300] [ALPM] upgraded gvfs-afc (1.50.5-1 -> 1.52.0-1)
[2023-10-13T22:56:33+0300] [ALPM] upgraded libgphoto2 (2.5.30-2 -> 2.5.31-1)
[2023-10-13T22:56:33+0300] [ALPM] upgraded gvfs-gphoto2 (1.50.5-1 -> 1.52.0-1)
[2023-10-13T22:56:33+0300] [ALPM] upgraded gvfs-mtp (1.50.5-1 -> 1.52.0-1)
[2023-10-13T22:56:34+0300] [ALPM] upgraded gvfs-nfs (1.50.5-1 -> 1.52.0-1)
[2023-10-13T22:56:34+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T22:56:34+0300] [ALPM] upgraded gvfs-smb (1.50.5-1 -> 1.52.0-1)
[2023-10-13T22:56:39+0300] [ALPM] upgraded vim-runtime (9.0.1676-1 -> 9.0.2002-1)
[2023-10-13T22:56:48+0300] [ALPM] upgraded gvim (9.0.1676-1 -> 9.0.2002-1)
[2023-10-13T22:56:50+0300] [ALPM] upgraded libkdcraw (23.04.3-1 -> 23.08.1-1)
[2023-10-13T22:56:50+0300] [ALPM] upgraded signon-kwallet-extension (23.04.3-1 -> 23.08.1-1)
[2023-10-13T22:56:53+0300] [ALPM] upgraded kaccounts-integration (23.04.3-1 -> 23.08.1-1)
[2023-10-13T22:56:54+0300] [ALPM] installed purpose5 (5.110.0-1)
[2023-10-13T22:57:05+0300] [ALPM] upgraded gwenview (23.04.3-1 -> 23.08.1-1)
[2023-10-13T22:57:05+0300] [ALPM] upgraded gzip (1.12-2 -> 1.13-2)
[2023-10-13T22:57:05+0300] [ALPM] upgraded heimdall (1.4.2-6 -> 1.4.2-7)
[2023-10-13T22:57:07+0300] [ALPM] upgraded net-snmp (5.9.1-6 -> 5.9.1-8)
[2023-10-13T22:57:08+0300] [ALPM] upgraded python-gobject (3.44.1-4 -> 3.46.0-1)
[2023-10-13T22:57:11+0300] [ALPM] upgraded perl-dbi (1.643-4 -> 1.643-6)
[2023-10-13T22:57:19+0300] [ALPM] upgraded hplip (1:3.23.5-1 -> 1:3.23.8-1)
[2023-10-13T22:57:22+0300] [ALPM] upgraded hugo (0.115.4-1 -> 0.119.0-1)
[2023-10-13T22:57:23+0300] [ALPM] upgraded imagewriter (1.10.1432200249.1d253d9.2.16-1 -> 1.10.1432200249.1d253d9.2.17-1)
[2023-10-13T22:57:26+0300] [ALPM] upgraded inetutils (2.4-1 -> 2.4-2)
[2023-10-13T22:57:26+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T22:57:32+0300] [ALPM] installed gtksourceview4 (4.8.4-1)
[2023-10-13T22:57:32+0300] [ALPM] upgraded python-appdirs (1.4.4-8 -> 1.4.4-9)
[2023-10-13T22:57:34+0300] [ALPM] upgraded python-cairo (1.23.0-6 -> 1.24.0-1)
[2023-10-13T22:57:36+0300] [ALPM] upgraded python-chardet (5.1.0-3 -> 5.2.0-1)
[2023-10-13T22:57:36+0300] [ALPM] installed python-coverage (6.5.0-5)
[2023-10-13T22:57:39+0300] [ALPM] upgraded python-filelock (3.12.0-2 -> 3.12.4-1)
[2023-10-13T22:57:39+0300] [ALPM] installed python-lockfile (0.12.2-12)
[2023-10-13T22:58:03+0300] [ALPM] upgraded python-numpy (1.25.1-1 -> 1.26.0-3)
[2023-10-13T22:58:05+0300] [ALPM] upgraded libimagequant (4.1.1-1 -> 4.2.1-1)
[2023-10-13T22:58:07+0300] [ALPM] upgraded python-pillow (10.0.0-2 -> 10.0.1-1)
[2023-10-13T22:58:08+0300] [ALPM] installed python-pyserial (3.5-5)
[2023-10-13T22:58:08+0300] [ALPM] installed python-zstandard (0.21.0-2)
[2023-10-13T22:58:08+0300] [ALPM] installed scour (0.38.2-3)
[2023-10-13T22:58:09+0300] [ALPM] upgraded python-soupsieve (2.4.1-1 -> 2.5-1)
[2023-10-13T22:58:32+0300] [ALPM] upgraded inkscape (1.2.2-10 -> 1.3-4)
[2023-10-13T22:58:33+0300] [ALPM] upgraded inxi (3.3.28.1-2 -> 3.3.30.1-1)
[2023-10-13T22:58:38+0300] [ALPM] upgraded iproute2 (6.4.0-1 -> 6.5.0-1)
[2023-10-13T22:59:12+0300] [ALPM] upgraded jre-openjdk-headless (20.0.2.u9-3 -> 21.u35-3)
[2023-10-13T22:59:12+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T22:59:12+0300] [ALPM] upgraded jre-openjdk (20.0.2.u9-3 -> 21.u35-3)
[2023-10-13T23:02:20+0300] [ALPM] upgraded jdk-openjdk (20.0.2.u9-3 -> 21.u35-3)
[2023-10-13T23:02:20+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:02:22+0300] [ALPM] upgraded libkcddb (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:02:23+0300] [ALPM] installed knotifyconfig5 (5.110.0-1)
[2023-10-13T23:02:35+0300] [ALPM] upgraded k3b (1:23.04.3-1 -> 1:23.08.1-2)
[2023-10-13T23:02:38+0300] [ALPM] upgraded kaccounts-providers (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:02:41+0300] [ALPM] installed kactivities-stats5 (5.110.0-1)
[2023-10-13T23:02:45+0300] [ALPM] upgraded kactivitymanagerd (5.27.6-1 -> 5.27.8-1)
[2023-10-13T23:02:47+0300] [ALPM] upgraded kamera (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:02:49+0300] [ALPM] installed ktexteditor5 (5.110.0-1)
[2023-10-13T23:02:58+0300] [ALPM] upgraded kate (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:02:58+0300] [ALPM] upgraded kcalc (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:02:58+0300] [ALPM] installed kcontacts5 (5.110.0-2)
[2023-10-13T23:02:59+0300] [ALPM] installed kdesu5 (5.110.0-1)
[2023-10-13T23:03:03+0300] [ALPM] upgraded kde-cli-tools (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:03:05+0300] [ALPM] upgraded kde-gtk-config (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:03:07+0300] [ALPM] upgraded kirigami-addons (0.10.0-1 -> 0.11.0-2)
[2023-10-13T23:03:13+0300] [ALPM] upgraded ppp (2.4.9-3 -> 2.5.0-1)
[2023-10-13T23:03:17+0300] [ALPM] upgraded modemmanager (1.20.6-1 -> 1.20.6-2)
[2023-10-13T23:03:19+0300] [ALPM] installed modemmanager-qt5 (5.110.0-1)
[2023-10-13T23:03:20+0300] [ALPM] installed kpeople5 (5.110.0-1)
[2023-10-13T23:03:25+0300] [ALPM] upgraded kdeconnect (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:03:26+0300] [ALPM] upgraded kdegraphics-mobipocket (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:03:26+0300] [ALPM] upgraded kdegraphics-thumbnailers (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:03:26+0300] [ALPM] installed kunitconversion5 (5.110.0-1)
[2023-10-13T23:03:29+0300] [ALPM] upgraded kemoticons (5.108.0-1 -> 5.110.0-2)
[2023-10-13T23:03:44+0300] [ALPM] upgraded kdelibs4support (5.108.0-1 -> 5.110.0-2)
[2023-10-13T23:03:49+0300] [ALPM] upgraded samba (4.18.5-2 -> 4.19.0-1)
[2023-10-13T23:03:49+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:03:50+0300] [ALPM] upgraded kdenetwork-filesharing (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:04:00+0300] [ALPM] upgraded libksysguard (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:04:00+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:04:01+0300] [ALPM] upgraded ksystemstats (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:04:02+0300] [ALPM] upgraded libqalculate (4.7.0-1 -> 4.8.1-1)
[2023-10-13T23:04:03+0300] [ALPM] installed kholidays5 (1:5.110.0-2)
[2023-10-13T23:04:04+0300] [ALPM] installed kwayland5 (5.110.0-1)
[2023-10-13T23:04:08+0300] [ALPM] installed plasma-framework5 (5.110.0-1)
[2023-10-13T23:04:10+0300] [ALPM] installed threadweaver5 (5.110.0-1)
[2023-10-13T23:04:10+0300] [ALPM] installed krunner5 (5.110.0-2)
[2023-10-13T23:04:12+0300] [ALPM] upgraded milou (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:04:14+0300] [ALPM] installed prison5 (5.110.0-1)
[2023-10-13T23:04:15+0300] [ALPM] upgraded layer-shell-qt (5.27.6-1 -> 5.27.8-1)
[2023-10-13T23:04:16+0300] [ALPM] upgraded libkscreen (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:04:16+0300] [ALPM] upgraded kscreenlocker (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:04:17+0300] [ALPM] upgraded libcamera-ipa (0.0.5-1 -> 0.1.0-2)
[2023-10-13T23:04:17+0300] [ALPM] upgraded libcamera (0.0.5-1 -> 0.1.0-2)
[2023-10-13T23:04:21+0300] [ALPM] upgraded pipewire (1:0.3.75-2 -> 1:0.3.81-1)
[2023-10-13T23:04:21+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:04:30+0300] [ALPM] upgraded kwin (5.27.6-1 -> 5.27.8-4)
[2023-10-13T23:04:30+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:04:31+0300] [ALPM] upgraded plasma-integration (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:04:32+0300] [ALPM] upgraded kpipewire (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:04:35+0300] [ALPM] upgraded kio-fuse (5.0.1-1 -> 5.0.1-2)
[2023-10-13T23:04:48+0300] [ALPM] upgraded qt5-tools (5.15.10+kde+r3-1 -> 5.15.11+kde+r3-1)
[2023-10-13T23:04:48+0300] [ALPM] upgraded oxygen-sounds (5.27.6-1 -> 5.27.8-1)
[2023-10-13T23:05:13+0300] [ALPM] upgraded plasma-workspace (5.27.6-2 -> 5.27.8-2)
[2023-10-13T23:05:24+0300] [ALPM] upgraded kdeplasma-addons (5.27.6-2 -> 5.27.8-2)
[2023-10-13T23:05:28+0300] [ALPM] upgraded kdialog (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:05:34+0300] [ALPM] upgraded kdiff3 (1.10.5-1 -> 1.10.6-1)
[2023-10-13T23:05:35+0300] [ALPM] installed kdoctools5 (5.110.0-1)
[2023-10-13T23:05:36+0300] [ALPM] upgraded keditbookmarks (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:05:40+0300] [ALPM] upgraded kfind (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:05:47+0300] [ALPM] upgraded systemsettings (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:05:51+0300] [ALPM] upgraded kgamma5 (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:05:52+0300] [ALPM] upgraded qgpgme-qt5 (1.21.0-1 -> 1.22.0-1)
[2023-10-13T23:05:54+0300] [ALPM] upgraded kget (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:05:55+0300] [ALPM] upgraded kjs (5.108.0-1 -> 5.110.0-1)
[2023-10-13T23:05:57+0300] [ALPM] upgraded khtml (5.108.0-1 -> 5.110.0-2)
[2023-10-13T23:06:03+0300] [ALPM] upgraded xapian-core (1:1.4.22-1 -> 1:1.4.23-1)
[2023-10-13T23:06:05+0300] [ALPM] upgraded khelpcenter (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:06:06+0300] [ALPM] upgraded khotkeys (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:06:06+0300] [ALPM] installed kimageformats5 (5.110.0-1)
[2023-10-13T23:06:06+0300] [ALPM] upgraded vulkan-tools (1.3.255-1 -> 1.3.263-1)
[2023-10-13T23:06:06+0300] [ALPM] upgraded libdecor (0.1.1-2 -> 0.2.0-1)
[2023-10-13T23:06:06+0300] [ALPM] upgraded mesa-utils (9.0.0-2 -> 9.0.0-3)
[2023-10-13T23:06:15+0300] [ALPM] upgraded kinfocenter (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:06:16+0300] [ALPM] upgraded kinit (5.108.0-1 -> 5.110.0-2)
[2023-10-13T23:06:16+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:06:22+0300] [ALPM] upgraded kmenuedit (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:06:41+0300] [ALPM] upgraded libkdegames (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:06:42+0300] [ALPM] installed kplotting5 (5.110.0-1)
[2023-10-13T23:06:44+0300] [ALPM] upgraded knights (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:06:44+0300] [ALPM] upgraded libkomparediff2 (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:06:46+0300] [ALPM] upgraded kompare (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:06:46+0300] [ALPM] upgraded konsole (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:06:50+0300] [ALPM] upgraded konversation (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:06:53+0300] [ALPM] upgraded smartmontools (7.3-1 -> 7.4-1)
[2023-10-13T23:06:57+0300] [ALPM] upgraded kpmcore (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:07:03+0300] [ALPM] upgraded sane (1.2.1-4 -> 1.2.1-5)
[2023-10-13T23:07:04+0300] [ALPM] upgraded ksanecore (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:07:05+0300] [ALPM] upgraded qt5-sensors (5.15.10-1 -> 5.15.11-1)
[2023-10-13T23:07:05+0300] [ALPM] upgraded kscreen (5.27.6-1 -> 5.27.8-3)
[2023-10-13T23:07:06+0300] [ALPM] upgraded ksshaskpass (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:07:06+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:07:07+0300] [ALPM] upgraded ksysguard (5.22.0-1 -> 5.22.0-2)
[2023-10-13T23:07:10+0300] [ALPM] upgraded ksystemlog (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:07:11+0300] [ALPM] upgraded ktimer (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:07:15+0300] [ALPM] upgraded kubo (0.21.0-1 -> 0.23.0-1)
[2023-10-13T23:07:16+0300] [ALPM] upgraded kwallet-pam (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:07:19+0300] [ALPM] upgraded kwalletmanager (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:07:19+0300] [ALPM] upgraded kwayland-integration (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:07:19+0300] [ALPM] upgraded kwrited (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:07:20+0300] [ALPM] upgraded lapacke (3.11.0-2 -> 3.11.0-3)
[2023-10-13T23:07:20+0300] [ALPM] upgraded less (1:633-1 -> 1:643-1)
[2023-10-13T23:07:44+0300] [ALPM] upgraded lib32-gcc-libs (13.1.1-2 -> 13.2.1-3)
[2023-10-13T23:07:44+0300] [ALPM] upgraded lib32-alsa-lib (1.2.9-1 -> 1.2.10-2)
[2023-10-13T23:07:44+0300] [ALPM] upgraded lib32-xz (5.4.3-1 -> 5.4.4-1)
[2023-10-13T23:07:44+0300] [ALPM] upgraded lib32-openssl (1:3.1.1-1 -> 1:3.1.3-1)
[2023-10-13T23:07:44+0300] [ALPM] upgraded lib32-libldap (2.6.4-1 -> 2.6.6-1)
[2023-10-13T23:07:45+0300] [ALPM] upgraded lib32-systemd (253.7-1 -> 254.5-1)
[2023-10-13T23:07:45+0300] [ALPM] upgraded lib32-dbus (1.14.8-1 -> 1.14.10-1)
[2023-10-13T23:07:45+0300] [ALPM] upgraded lib32-util-linux (2.39.1-1 -> 2.39.2-1)
[2023-10-13T23:07:45+0300] [ALPM] upgraded lib32-zlib (1.2.13-2 -> 1.3-1)
[2023-10-13T23:07:45+0300] [ALPM] upgraded lib32-glib2 (2.76.4-1 -> 2.78.0-2)
[2023-10-13T23:07:45+0300] [ALPM] upgraded lib32-libxcb (1.15-2 -> 1.16-1)
[2023-10-13T23:07:45+0300] [ALPM] upgraded lib32-libx11 (1.8.6-1 -> 1.8.7-1)
[2023-10-13T23:07:45+0300] [ALPM] upgraded lib32-libxml2 (2.11.4-1 -> 2.11.5-1)
[2023-10-13T23:07:45+0300] [ALPM] upgraded lib32-at-spi2-core (2.48.3-1 -> 2.50.0-1)
[2023-10-13T23:07:46+0300] [ALPM] upgraded lib32-harfbuzz (8.0.1-1 -> 8.2.1-1)
[2023-10-13T23:07:46+0300] [ALPM] upgraded lib32-freetype2 (2.13.1-1 -> 2.13.2-1)
[2023-10-13T23:07:46+0300] [ALPM] upgraded lib32-cairo (1.17.8-2 -> 1.18.0-1)
[2023-10-13T23:07:46+0300] [ALPM] upgraded lib32-curl (8.2.0-1 -> 8.3.0-1)
[2023-10-13T23:07:46+0300] [ALPM] upgraded lib32-libdrm (2.4.115-1 -> 2.4.116-1)
[2023-10-13T23:08:15+0300] [ALPM] upgraded lib32-llvm-libs (15.0.7-1 -> 16.0.6-2)
[2023-10-13T23:08:16+0300] [ALPM] upgraded lib32-vulkan-icd-loader (1.3.255-1 -> 1.3.263-1)
[2023-10-13T23:08:34+0300] [ALPM] upgraded lib32-mesa (23.0.4-3 -> 1:23.1.9-1)
[2023-10-13T23:08:36+0300] [ALPM] upgraded lib32-libglvnd (1.6.0-1 -> 1.7.0-1)
[2023-10-13T23:08:39+0300] [ALPM] upgraded lib32-sdl2 (2.28.1-1 -> 2.28.4-1)
[2023-10-13T23:08:40+0300] [ALPM] upgraded lib32-libpipewire (1:0.3.75-1 -> 1:0.3.81-1)
[2023-10-13T23:08:41+0300] [ALPM] upgraded lib32-libsndfile (1.2.0-1 -> 1.2.2-1)
[2023-10-13T23:08:42+0300] [ALPM] upgraded lib32-fluidsynth (2.3.3-1 -> 2.3.4-1)
[2023-10-13T23:08:47+0300] [ALPM] upgraded lib32-gettext (0.21.1-1 -> 0.22.2-1)
[2023-10-13T23:08:48+0300] [ALPM] upgraded lib32-p11-kit (0.25.0-1 -> 0.25.0-2)
[2023-10-13T23:08:49+0300] [ALPM] upgraded lib32-gmp (6.2.1-1 -> 6.3.0-1)
[2023-10-13T23:08:51+0300] [ALPM] upgraded lib32-gnutls (3.8.0-2 -> 3.8.1-1)
[2023-10-13T23:08:51+0300] [ALPM] upgraded lib32-glib-networking (2.76.1-1 -> 1:2.78.0-1)
[2023-10-13T23:08:52+0300] [ALPM] upgraded lib32-glu (9.0.2-3 -> 9.0.3-1)
[2023-10-13T23:08:53+0300] [ALPM] upgraded lib32-libjpeg-turbo (2.1.5.1-1 -> 3.0.0-1)
[2023-10-13T23:08:55+0300] [ALPM] upgraded lib32-libtiff (4.5.1-1 -> 4.6.0-1)
[2023-10-13T23:08:57+0300] [ALPM] upgraded lib32-libcups (2.4.6-1 -> 2.4.7-1)
[2023-10-13T23:08:58+0300] [ALPM] upgraded lib32-pango (1:1.50.14-1 -> 1:1.51.1-1)
[2023-10-13T23:09:02+0300] [ALPM] upgraded lib32-librsvg (2:2.56.3-1 -> 2:2.57.0-1)
[2023-10-13T23:09:03+0300] [ALPM] upgraded lib32-tdb (1.4.8-1 -> 1.4.9-1)
[2023-10-13T23:09:05+0300] [ALPM] upgraded lib32-gstreamer (1.22.5-1 -> 1.22.6-1)
[2023-10-13T23:09:05+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:09:05+0300] [ALPM] upgraded lib32-gst-plugins-base-libs (1.22.5-1 -> 1.22.6-1)
[2023-10-13T23:09:07+0300] [ALPM] upgraded lib32-imlib2 (1.11.1-1 -> 1.12.1-1)
[2023-10-13T23:09:08+0300] [ALPM] upgraded lib32-json-glib (1.6.6-2 -> 1.8.0-1)
[2023-10-13T23:09:08+0300] [ALPM] upgraded lib32-libcurl-compat (8.2.0-1 -> 8.3.0-1)
[2023-10-13T23:09:12+0300] [ALPM] upgraded lib32-libcurl-gnutls (8.2.0-1 -> 8.3.0-1)
[2023-10-13T23:09:14+0300] [ALPM] upgraded lib32-libdecor (0.1.1-1 -> 0.2.0-1)
[2023-10-13T23:09:16+0300] [ALPM] upgraded lib32-libnl (3.7.0-1 -> 3.8.0-1)
[2023-10-13T23:09:17+0300] [ALPM] upgraded lib32-sqlite (3.42.0-1 -> 3.43.1-1)
[2023-10-13T23:09:19+0300] [ALPM] upgraded lib32-nss (3.91-1 -> 3.94-1)
[2023-10-13T23:09:24+0300] [ALPM] upgraded libnm (1.42.6-1 -> 1.44.2-1)
[2023-10-13T23:09:26+0300] [ALPM] upgraded lib32-libnm (1.42.6-1 -> 1.44.2-1)
[2023-10-13T23:09:28+0300] [ALPM] upgraded lib32-libva (2.18.0-1 -> 2.20.0-1)
[2023-10-13T23:09:36+0300] [ALPM] upgraded lib32-libva-mesa-driver (23.0.4-3 -> 1:23.1.9-1)
[2023-10-13T23:09:39+0300] [ALPM] upgraded lib32-libvdpau (1.5-1 -> 1.5-2)
[2023-10-13T23:09:39+0300] [ALPM] upgraded lib32-libwebp (1.3.1-1 -> 1.3.2-1)
[2023-10-13T23:09:39+0300] [ALPM] upgraded lib32-libxss (1.2.3-3 -> 1.2.4-1)
[2023-10-13T23:09:41+0300] [ALPM] upgraded lib32-mpg123 (1.31.3-1 -> 1.32.2-1)
[2023-10-13T23:09:46+0300] [ALPM] upgraded openssl-1.1 (1.1.1.u-1 -> 1.1.1.w-1)
[2023-10-13T23:09:47+0300] [ALPM] upgraded lib32-openssl-1.1 (1.1.1.u-1 -> 1.1.1.w-1)
[2023-10-13T23:09:50+0300] [ALPM] upgraded lib32-pipewire (1:0.3.75-1 -> 1:0.3.81-1)
[2023-10-13T23:09:50+0300] [ALPM] upgraded lib32-polkit (122-1 -> 123-1)
[2023-10-13T23:09:51+0300] [ALPM] upgraded sdl12-compat (1.2.64-1 -> 1.2.68-1)
[2023-10-13T23:09:53+0300] [ALPM] upgraded lib32-sdl12-compat (1.2.64-1 -> 1.2.68-1)
[2023-10-13T23:09:54+0300] [ALPM] upgraded libadwaita (1:1.3.3-1 -> 1:1.4.0-1)
[2023-10-13T23:09:57+0300] [ALPM] upgraded squashfuse (0.2.0-1 -> 0.5.0-1)
[2023-10-13T23:09:58+0300] [ALPM] upgraded libappimage (1.0.4.5-4 -> 1.0.4.5-5)
[2023-10-13T23:09:59+0300] [ALPM] upgraded libdbusmenu-glib (16.04.0.r498-1 -> 16.04.0.r498-2)
[2023-10-13T23:10:00+0300] [ALPM] upgraded libdbusmenu-gtk3 (16.04.0.r498-1 -> 16.04.0.r498-2)
[2023-10-13T23:10:01+0300] [ALPM] upgraded libappindicator-gtk3 (12.10.0.r298-2 -> 12.10.0.r298-3)
[2023-10-13T23:10:05+0300] [ALPM] upgraded libcmis (0.5.2-13 -> 0.5.2-14)
[2023-10-13T23:10:06+0300] [ALPM] upgraded libcpuid (0.6.3-1 -> 0.6.4-1)
[2023-10-13T23:10:06+0300] [ALPM] upgraded libcue (2.2.1-3 -> 2.3.0-0)
[2023-10-13T23:10:06+0300] [ALPM] upgraded libcurl-compat (8.2.0-2 -> 8.3.0-1)
[2023-10-13T23:10:07+0300] [ALPM] upgraded libcurl-gnutls (8.2.0-2 -> 8.3.0-1)
[2023-10-13T23:10:07+0300] [ALPM] upgraded libdbusmenu-gtk2 (16.04.0.r498-1 -> 16.04.0.r498-2)
[2023-10-13T23:10:09+0300] [ALPM] upgraded libdvbpsi (1:1.3.3-2 -> 1:1.3.3-3)
[2023-10-13T23:10:10+0300] [ALPM] upgraded libgit2 (1:1.6.4-1 -> 1:1.7.1-1)
[2023-10-13T23:10:12+0300] [ALPM] upgraded libixion (0.17.0-5 -> 0.19.0-1)
[2023-10-13T23:10:13+0300] [ALPM] upgraded libksane (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:10:14+0300] [ALPM] upgraded libktorrent (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:10:14+0300] [ALPM] upgraded liblouis (3.26.0-1 -> 3.27.0-1)
[2023-10-13T23:10:14+0300] [ALPM] upgraded libnatpmp (20150609-3 -> 20230423-2)
[2023-10-13T23:10:15+0300] [ALPM] upgraded liborcus (0.17.2-5 -> 0.19.0-1)
[2023-10-13T23:10:18+0300] [ALPM] upgraded pacman (6.0.2-13 -> 6.0.2-14)
[2023-10-13T23:10:18+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:10:26+0300] [ALPM] upgraded libpamac (11.5.7-2 -> 11.6.2+6+ge74fe0e-1)
[2023-10-13T23:10:26+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:10:26+0300] [ALPM] upgraded xdg-dbus-proxy (0.1.4-1 -> 0.1.5-1)
[2023-10-13T23:10:27+0300] [ALPM] upgraded xdg-desktop-portal (1.16.0-3 -> 1.18.0-2)
[2023-10-13T23:10:28+0300] [ALPM] upgraded ostree (2023.5-1 -> 2023.6-3)
[2023-10-13T23:10:28+0300] [ALPM] upgraded libpamac-flatpak-plugin (11.5.7-2 -> 11.6.2+6+ge74fe0e-1)
[2023-10-13T23:10:28+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:10:30+0300] [ALPM] upgraded snapd (2.60.1-1 -> 2.60.4-1)
[2023-10-13T23:10:30+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:10:30+0300] [ALPM] upgraded libpamac-snap-plugin (11.5.7-2 -> 11.6.2+6+ge74fe0e-1)
[2023-10-13T23:10:31+0300] [ALPM] upgraded shaderc (2023.3-1 -> 2023.4-2)
[2023-10-13T23:10:31+0300] [ALPM] installed libdovi (3.2.0-2)
[2023-10-13T23:10:31+0300] [ALPM] upgraded libplacebo (5.264.1-1 -> 5.264.1-4)
[2023-10-13T23:13:14+0300] [ALPM] upgraded libreoffice-still (7.4.7-5 -> 7.5.7-3)
[2023-10-13T23:13:15+0300] [ALPM] upgraded libteam (1.31-8 -> 1.32-1)
[2023-10-13T23:13:31+0300] [ALPM] upgraded libtorrent-rasterbar (1:2.0.9-1 -> 1:2.0.9-3)
[2023-10-13T23:13:34+0300] [ALPM] upgraded libupnp (1.14.17-1 -> 1.14.18-1)
[2023-10-13T23:13:42+0300] [ALPM] upgraded libva-mesa-driver (23.0.4-3 -> 1:23.1.9-1)
[2023-10-13T23:13:46+0300] [ALPM] upgraded libva-utils (2.18.2-1 -> 2.20.0-1)
[2023-10-13T23:13:49+0300] [ALPM] upgraded libvips (8.14.2-1 -> 8.14.5-1)
[2023-10-13T23:13:49+0300] [ALPM] upgraded libvterm (0.3.2-1 -> 0.3.3-1)
[2023-10-13T23:13:49+0300] [ALPM] upgraded licenses (20220125-2 -> 20230917-1)
[2023-10-13T23:13:49+0300] [ALPM] upgraded linux-firmware-whence (20230724.59fbffa9-1 -> 20230810.7be2766d-1)
[2023-10-13T23:17:06+0300] [ALPM] upgraded linux-firmware (20230724.59fbffa9-1 -> 20230810.7be2766d-1)
[2023-10-13T23:17:11+0300] [ALPM] upgraded mkinitcpio (36-3 -> 36-6)
[2023-10-13T23:17:11+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:18:14+0300] [ALPM] upgraded linux510 (5.10.187-1 -> 5.10.197-1)
[2023-10-13T23:18:32+0300] [ALPM] upgraded linux510-nvidia-470xx (470.199.02-4 -> 470.199.02-17)
[2023-10-13T23:18:32+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:18:32+0300] [ALPM] upgraded linux510-virtualbox-host-modules (7.0.10-2 -> 7.0.10-15)
[2023-10-13T23:20:55+0300] [ALPM] upgraded linux515 (5.15.122-1 -> 5.15.133-1)
[2023-10-13T23:20:56+0300] [ALPM] upgraded linux515-nvidia-470xx (470.199.02-6 -> 470.199.02-18)
[2023-10-13T23:20:56+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:20:56+0300] [ALPM] upgraded linux515-virtualbox-host-modules (7.0.10-3 -> 7.0.10-15)
[2023-10-13T23:22:06+0300] [ALPM] upgraded linux54 (5.4.250-1 -> 5.4.257-1)
[2023-10-13T23:22:11+0300] [ALPM] upgraded linux54-nvidia-470xx (470.199.02-4 -> 470.199.02-13)
[2023-10-13T23:22:11+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:22:12+0300] [ALPM] upgraded linux54-virtualbox-host-modules (7.0.10-2 -> 7.0.10-11)
[2023-10-13T23:22:12+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:23:54+0300] [ALPM] upgraded linux61 (6.1.41-1 -> 6.1.55-1)
[2023-10-13T23:24:09+0300] [ALPM] upgraded linux61-nvidia-470xx (470.199.02-8 -> 470.199.02-24)
[2023-10-13T23:24:09+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:24:10+0300] [ALPM] upgraded linux61-virtualbox-host-modules (7.0.10-4 -> 7.0.10-20)
[2023-10-13T23:24:10+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:24:25+0300] [ALPM] upgraded llvm (15.0.7-3 -> 16.0.6-1)
[2023-10-13T23:24:26+0300] [ALPM] upgraded lsb-release (2.0.r48.3cf5103-1 -> 2.0.r53.a86f885-1)
[2023-10-13T23:24:27+0300] [ALPM] upgraded lsof (4.98.0-1 -> 4.98.0-2)
[2023-10-13T23:24:29+0300] [ALPM] upgraded lua (5.4.6-1 -> 5.4.6-2)
[2023-10-13T23:24:30+0300] [ALPM] upgraded lua52 (5.2.4-5 -> 5.2.4-6)
[2023-10-13T23:24:31+0300] [ALPM] upgraded lua53 (5.3.6-1 -> 5.3.6-2)
[2023-10-13T23:24:32+0300] [ALPM] upgraded python-pyrate-limiter (2.10.0-1 -> 3.1.0-1)
[2023-10-13T23:24:34+0300] [ALPM] upgraded python-moddb (0.8.1-1 -> 0.9.0-1)
[2023-10-13T23:24:35+0300] [ALPM] upgraded python-yaml (6.0-3 -> 6.0.1-2)
[2023-10-13T23:24:36+0300] [ALPM] upgraded unzip (6.0-19 -> 6.0-20)
[2023-10-13T23:24:45+0300] [ALPM] upgraded webkit2gtk-4.1 (2.40.4-1 -> 2.42.1-1)
[2023-10-13T23:24:46+0300] [ALPM] upgraded xdg-desktop-portal-kde (5.27.6-1 -> 5.27.8-4)
[2023-10-13T23:24:53+0300] [ALPM] upgraded lutris (0.5.13-6 -> 0.5.13-8)
[2023-10-13T23:24:53+0300] [ALPM] upgraded man-db (2.11.2-1 -> 2.12.0-1)
[2023-10-13T23:24:53+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:25:06+0300] [ALPM] upgraded man-pages (6.04-1 -> 6.05.01-1)
[2023-10-13T23:25:06+0300] [ALPM] upgraded pamac-cli (11.0.0-2 -> 11.6.0-2)
[2023-10-13T23:25:07+0300] [ALPM] upgraded pamac-gtk (11.0.1-2 -> 11.6.0-1)
[2023-10-13T23:25:07+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:25:09+0300] [ALPM] upgraded manjaro-application-utility (1.3.3-9 -> 1.3.3-10)
[2023-10-13T23:25:15+0300] [ALPM] upgraded vulkan-headers (1:1.3.257-1 -> 1:1.3.264-2)
[2023-10-13T23:25:17+0300] [ALPM] upgraded qt6-translations (6.5.2-1 -> 6.5.3-1)
[2023-10-13T23:25:41+0300] [ALPM] upgraded qt6-base (6.5.2-1 -> 6.5.3-1)
[2023-10-13T23:25:59+0300] [ALPM] upgraded qt6-declarative (6.5.2-1 -> 6.5.3-1)
[2023-10-13T23:25:59+0300] [ALPM] upgraded shiboken6 (6.5.1.1-4 -> 6.5.3-1)
[2023-10-13T23:26:02+0300] [ALPM] upgraded pyside6 (6.5.1.1-4 -> 6.5.3-1)
[2023-10-13T23:26:02+0300] [ALPM] upgraded mhwd-nvidia (535.86.05-1 -> 535.113.01-2)
[2023-10-13T23:26:03+0300] [ALPM] upgraded mhwd-nvidia-390xx (390.157-7 -> 390.157-8)
[2023-10-13T23:26:04+0300] [ALPM] upgraded mhwd-nvidia-470xx (470.199.02-2 -> 470.199.02-4)
[2023-10-13T23:26:11+0300] [ALPM] upgraded mhwd-db (0.6.5-26 -> 0.6.5-27)
[2023-10-13T23:26:11+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:26:13+0300] [ALPM] upgraded perl-xml-parser (2.46-4 -> 2.46-5)
[2023-10-13T23:26:15+0300] [ALPM] upgraded mhwd (0.6.5-26 -> 0.6.5-27)
[2023-10-13T23:26:15+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:26:16+0300] [ALPM] upgraded python-manjaro-sdk (0.9-2 -> 1:0.1.1-1)
[2023-10-13T23:26:24+0300] [ALPM] upgraded manjaro-hello (0.7.0-6 -> 0.7.1-2)
[2023-10-13T23:26:24+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:26:25+0300] [ALPM] upgraded manjaro-release (23.0.0rc-2 -> 23.0.4-1)
[2023-10-13T23:26:25+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:26:33+0300] [ALPM] upgraded mariadb-libs (11.0.2-2 -> 11.1.2-1)
[2023-10-13T23:26:35+0300] [ALPM] upgraded mariadb-clients (11.0.2-2 -> 11.1.2-1)
[2023-10-13T23:26:50+0300] [ALPM] warning: directory permissions differ on /usr/lib/mysql/plugin/auth_pam_tool_dir/
filesystem: 700  package: 755
[2023-10-13T23:26:57+0300] [ALPM] upgraded mariadb (11.0.2-2 -> 11.1.2-1)
[2023-10-13T23:26:57+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:26:58+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:27:09+0300] [ALPM] upgraded megasync (4.9.5-2 -> 4.9.6-2)
[2023-10-13T23:27:09+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:27:09+0300] [ALPM] upgraded mesa-demos (9.0.0-2 -> 9.0.0-3)
[2023-10-13T23:27:09+0300] [ALPM] upgraded miniupnpc (2.2.4-2 -> 2.2.5-1)
[2023-10-13T23:28:02+0300] [ALPM] upgraded mono (6.12.0.198-1 -> 6.12.0.205-1)
[2023-10-13T23:28:02+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:28:03+0300] [ALPM] upgraded mpd (0.23.13-2 -> 0.23.14-1)
[2023-10-13T23:28:03+0300] [ALPM] upgraded tree-sitter (0.20.10-1 -> 0.20.10-2)
[2023-10-13T23:28:06+0300] [ALPM] upgraded neovim (0.9.1-2 -> 0.9.2-1)
[2023-10-13T23:28:07+0300] [ALPM] upgraded python-cffi (1.15.1-3 -> 1.15.1-4)
[2023-10-13T23:28:08+0300] [ALPM] upgraded python-markdown-it-py (2.2.0-3 -> 3.0.0-1)
[2023-10-13T23:28:14+0300] [ALPM] upgraded python-pygments (2.15.1-1 -> 2.16.1-1)
[2023-10-13T23:28:15+0300] [ALPM] upgraded python-rich (13.4.2-1 -> 13.6.0-1)
[2023-10-13T23:28:18+0300] [ALPM] upgraded netplan (0.106-1 -> 0.107-2)
[2023-10-13T23:28:27+0300] [ALPM] upgraded networkmanager (1.42.6-1 -> 1.44.2-1)
[2023-10-13T23:28:27+0300] [ALPM] upgraded networkmanager-pptp (1.2.12-1 -> 1.2.12-3)
[2023-10-13T23:28:27+0300] [ALPM] installed networkmanager-qt5 (5.110.0-1)
[2023-10-13T23:28:27+0300] [ALPM] upgraded nftables (1:1.0.7-2 -> 1:1.0.8-2)
[2023-10-13T23:28:27+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:28:37+0300] [ALPM] upgraded nmap (7.94-1 -> 7.94-2)
[2023-10-13T23:28:46+0300] [ALPM] upgraded nodejs (20.4.0-1 -> 20.8.0-1)
[2023-10-13T23:31:08+0300] [ALPM] upgraded noto-fonts-cjk (20220126-1 -> 20230817-1)
[2023-10-13T23:31:57+0300] [ALPM] upgraded noto-fonts-extra (1:23.7.1-1 -> 1:23.10.1-1)
[2023-10-13T23:32:00+0300] [ALPM] upgraded semver (7.5.0-1 -> 7.5.1-1)
[2023-10-13T23:32:27+0300] [ALPM] upgraded npm (9.8.1-1 -> 10.2.0-1)
[2023-10-13T23:32:28+0300] [ALPM] upgraded nvm (0.39.4-1 -> 0.39.5-1)
[2023-10-13T23:32:58+0300] [ALPM] upgraded okular (23.04.3-1 -> 23.08.1-2)
[2023-10-13T23:33:02+0300] [ALPM] upgraded onetbb (2021.9.0-1 -> 2021.10.0-1)
[2023-10-13T23:33:07+0300] [ALPM] upgraded opencl-nvidia (535.86.05-1 -> 535.113.01-2)
[2023-10-13T23:33:10+0300] [ALPM] upgraded openmp (15.0.7-1 -> 16.0.6-1)
[2023-10-13T23:33:14+0300] [ALPM] upgraded openvpn (2.6.5-1 -> 2.6.6-1)
[2023-10-13T23:33:14+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:33:16+0300] [ALPM] upgraded opera-ffmpeg-codecs (114.0.5735.199-1 -> 117.0.5938.132-1)
[2023-10-13T23:33:44+0300] [ALPM] upgraded oxygen (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:33:54+0300] [ALPM] upgraded oxygen-icons (1:5.108.0-1 -> 1:5.110.0-1)
[2023-10-13T23:33:55+0300] [ALPM] upgraded pantheon-videos (2.9.1-1 -> 3.0.0-1)
[2023-10-13T23:33:55+0300] [ALPM] upgraded partitionmanager (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:33:55+0300] [ALPM] upgraded pdftk (3.3.3-2 -> 3.3.3-3)
[2023-10-13T23:34:27+0300] [ALPM] upgraded perf (6.3-2 -> 6.5-1)
[2023-10-13T23:34:31+0300] [ALPM] upgraded perl-cairo-gobject (1.005-1 -> 1.005-2)
[2023-10-13T23:34:33+0300] [ALPM] upgraded perl-ipc-system-simple (1.30-4 -> 1.30-5)
[2023-10-13T23:34:36+0300] [ALPM] upgraded perl-file-basedir (0.09-2 -> 0.09-3)
[2023-10-13T23:34:37+0300] [ALPM] upgraded perl-file-desktopentry (0.22-10 -> 0.22-11)
[2023-10-13T23:34:38+0300] [ALPM] upgraded perl-file-mimeinfo (0.33-1 -> 0.33-2)
[2023-10-13T23:34:39+0300] [ALPM] upgraded perl-glib-object-introspection (0.050-2 -> 0.050-3)
[2023-10-13T23:34:39+0300] [ALPM] upgraded perl-gtk3 (0.038-3 -> 0.038-4)
[2023-10-13T23:34:39+0300] [ALPM] upgraded perl-inc-latest (0.500-10 -> 0.500-11)
[2023-10-13T23:34:40+0300] [ALPM] upgraded perl-locale-gettext (1.07-13 -> 1.07-14)
[2023-10-13T23:34:40+0300] [ALPM] upgraded perl-module-build (0.4234-1 -> 0.4234-2)
[2023-10-13T23:34:40+0300] [ALPM] upgraded perl-parse-yapp (1.21-5 -> 1.21-6)
[2023-10-13T23:34:41+0300] [ALPM] upgraded perl-sub-name (0.27-1 -> 0.27-2)
[2023-10-13T23:34:41+0300] [ALPM] warning: /etc/php/php.ini installed as /etc/php/php.ini.pacnew
[2023-10-13T23:34:41+0300] [ALPM] upgraded php (8.2.8-1 -> 8.2.11-1)
[2023-10-13T23:34:42+0300] [ALPM] upgraded php-apache (8.2.8-1 -> 8.2.11-1)
[2023-10-13T23:34:42+0300] [ALPM] upgraded polkit-kde-agent (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:34:42+0300] [ALPM] upgraded powerdevil (5.27.6-3 -> 5.27.8-2)
[2023-10-13T23:35:10+0300] [ALPM] upgraded plasma-desktop (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:35:11+0300] [ALPM] upgraded plasma-nm (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:35:18+0300] [ALPM] upgraded plasma-pa (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:35:30+0300] [ALPM] upgraded plasma-workspace-wallpapers (5.27.6-1 -> 5.27.8-1)
[2023-10-13T23:35:31+0300] [ALPM] upgraded pngquant (3.0.1-3 -> 3.0.1-5)
[2023-10-13T23:35:31+0300] [ALPM] upgraded poppler-qt6 (23.07.0-1 -> 23.10.0-1)
[2023-10-13T23:35:31+0300] [ALPM] upgraded print-manager (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:35:31+0300] [ALPM] upgraded proj (9.2.1-1 -> 9.3.0-1)
[2023-10-13T23:35:32+0300] [ALPM] upgraded python-click (8.1.5-1 -> 8.1.7-1)
[2023-10-13T23:35:33+0300] [ALPM] upgraded python-cryptography (41.0.2-1 -> 41.0.4-1)
[2023-10-13T23:35:33+0300] [ALPM] upgraded python-distlib (0.3.6-3 -> 0.3.7-1)
[2023-10-13T23:35:38+0300] [ALPM] upgraded python-dnspython (1:2.3.0-3 -> 1:2.4.2-1)
[2023-10-13T23:35:39+0300] [ALPM] upgraded python-fastjsonschema (2.18.0-1 -> 2.18.1-1)
[2023-10-13T23:35:45+0300] [ALPM] upgraded python-future (0.18.3-1 -> 0.18.3-2)
[2023-10-13T23:35:45+0300] [ALPM] upgraded python-httpcore (0.17.3-1 -> 0.18.0-1)
[2023-10-13T23:35:45+0300] [ALPM] upgraded python-httpx (0.24.1-1 -> 0.25.0-1)
[2023-10-13T23:35:46+0300] [ALPM] upgraded python-humanfriendly (10.0-5 -> 10.0-6)
[2023-10-13T23:35:47+0300] [ALPM] upgraded python-importlib_resources (5.12.0-2 -> 6.0.1-1)
[2023-10-13T23:35:48+0300] [ALPM] installed python-annotated-types (0.5.0-1)
[2023-10-13T23:35:49+0300] [ALPM] upgraded python-typing_extensions (4.7.1-1 -> 4.8.0-1)
[2023-10-13T23:35:51+0300] [ALPM] installed python-pydantic-core (1:2.6.3-1)
[2023-10-13T23:35:52+0300] [ALPM] upgraded python-pydantic (1.10.9-1 -> 2.3.0-1)
[2023-10-13T23:35:54+0300] [ALPM] upgraded python-inflect (6.1.0-1 -> 7.0.0-2)
[2023-10-13T23:35:55+0300] [ALPM] upgraded python-more-itertools (9.1.1-4 -> 10.1.0-1)
[2023-10-13T23:35:56+0300] [ALPM] upgraded python-jaraco.functools (3.8.0-1 -> 3.9.0-1)
[2023-10-13T23:35:58+0300] [ALPM] upgraded python-pikepdf (8.2.1-1 -> 8.5.0-1)
[2023-10-13T23:36:06+0300] [ALPM] upgraded python-pip (23.1.2-1 -> 23.2.1-1)
[2023-10-13T23:36:06+0300] [ALPM] upgraded python-platformdirs (3.9.1-1 -> 3.10.0-1)
[2023-10-13T23:36:07+0300] [ALPM] upgraded python-pluggy (1.0.0-4 -> 1.3.0-1)
[2023-10-13T23:36:08+0300] [ALPM] upgraded python-pyfiglet (0.8.post1-7 -> 1.0.2-1)
[2023-10-13T23:36:09+0300] [ALPM] upgraded python-pyparsing (3.0.9-3 -> 3.1.1-1)
[2023-10-13T23:36:09+0300] [ALPM] upgraded python-pytz (2023.3-1 -> 2023.3.post1-1)
[2023-10-13T23:36:09+0300] [ALPM] upgraded python-setproctitle (1.3.2-2 -> 1.3.3-1)
[2023-10-13T23:36:09+0300] [ALPM] upgraded python-shiboken2 (5.15.10-1 -> 5.15.11-1)
[2023-10-13T23:36:09+0300] [ALPM] upgraded python-tenacity (8.2.2-3 -> 8.2.3-1)
[2023-10-13T23:36:09+0300] [ALPM] upgraded python-tqdm (4.65.0-3 -> 4.66.1-2)
[2023-10-13T23:36:09+0300] [ALPM] upgraded python-trove-classifiers (2023.7.6-1 -> 2023.9.19-1)
[2023-10-13T23:36:09+0300] [ALPM] upgraded python-tzlocal (1:5.0.1-1 -> 1:5.1-1)
[2023-10-13T23:36:11+0300] [ALPM] upgraded python-virtualenv (20.21.0-1 -> 20.24.5-1)
[2023-10-13T23:36:11+0300] [ALPM] upgraded python-wcwidth (0.2.6-1 -> 0.2.8-1)
[2023-10-13T23:36:38+0300] [ALPM] upgraded python-wxpython (1:4.2.0-4 -> 1:4.2.1-1)
[2023-10-13T23:36:41+0300] [ALPM] upgraded python-xcffib (1.2.0-2 -> 1.4.0-1)
[2023-10-13T23:36:43+0300] [ALPM] upgraded python-zipp (3.16.0-1 -> 3.17.0-1)
[2023-10-13T23:36:47+0300] [ALPM] upgraded qt6-svg (6.5.2-1 -> 6.5.3-1)
[2023-10-13T23:36:53+0300] [ALPM] upgraded qbittorrent (4.5.4-1 -> 4.5.5-1)
[2023-10-13T23:36:53+0300] [ALPM] upgraded qt5-imageformats (5.15.10+kde+r9-1 -> 5.15.11+kde+r12-1)
[2023-10-13T23:36:54+0300] [ALPM] upgraded qt5-script (5.15.14-2 -> 5.15.15-2)
[2023-10-13T23:37:11+0300] [ALPM] upgraded qt5-virtualkeyboard (5.15.10-1 -> 5.15.11-1)
[2023-10-13T23:37:11+0300] [ALPM] upgraded qt6-5compat (6.5.2-1 -> 6.5.3-1)
[2023-10-13T23:37:11+0300] [ALPM] upgraded xxhash (0.8.1-4 -> 0.8.2-1)
[2023-10-13T23:37:11+0300] [ALPM] upgraded rsync (3.2.7-4 -> 3.2.7-6)
[2023-10-13T23:37:12+0300] [ALPM] upgraded ruby-bundler (2.4.13-1 -> 2.4.20-1)
[2023-10-13T23:37:12+0300] [ALPM] upgraded ruby-stdlib (3.0.5-1 -> 3.0.6-1)
[2023-10-13T23:37:12+0300] [ALPM] upgraded ruby-power_assert (2.0.2-1 -> 2.0.3-1)
[2023-10-13T23:37:13+0300] [ALPM] upgraded ruby-rexml (3.2.5-1 -> 3.2.6-1)
[2023-10-13T23:37:32+0300] [ALPM] upgraded ruby-test-unit (3.5.9-1 -> 3.6.1-1)
[2023-10-13T23:37:33+0300] [ALPM] upgraded ruby-bundledgems (3.0.5-1 -> 3.0.6-1)
[2023-10-13T23:37:39+0300] [ALPM] upgraded ruby (3.0.5-1 -> 3.0.6-1)
[2023-10-13T23:37:41+0300] [ALPM] upgraded screen (4.9.0-1 -> 4.9.1-1)
[2023-10-13T23:37:41+0300] [ALPM] upgraded screenfetch (3.9.1-1 -> 3.9.1-3)
[2023-10-13T23:37:49+0300] [ALPM] upgraded sddm (0.20.0-1 -> 0.20.0-2)
[2023-10-13T23:37:49+0300] [ALPM] upgraded sddm-kcm (5.27.6-1 -> 5.27.8-2)
[2023-10-13T23:37:49+0300] [ALPM] upgraded sdl2_mixer (2.6.3-1 -> 2.6.3-2)
[2023-10-13T23:39:23+0300] [ALPM] upgraded signal-desktop (6.26.0-1 -> 6.33.0-1)
[2023-10-13T23:39:36+0300] [ALPM] upgraded skanlite (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:39:43+0300] [ALPM] upgraded sof-firmware (2.2.6-1 -> 2023.09-1)
[2023-10-13T23:39:44+0300] [ALPM] upgraded source-highlight (3.1.9-10 -> 3.1.9-11)
[2023-10-13T23:39:44+0300] [ALPM] upgraded spectacle (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:39:44+0300] [ALPM] upgraded spectre-meltdown-checker (0.46+7+g8ba3751-1 -> 0.46+20+g9b7b09a-1)
[2023-10-13T23:39:44+0300] [ALPM] upgraded splix (2.0.0-19 -> 2.0.0-20)
[2023-10-13T23:39:46+0300] [ALPM] upgraded zenity (3.44.1-1 -> 3.44.2-1)
[2023-10-13T23:39:52+0300] [ALPM] upgraded steam (1.0.0.78-2 -> 1.0.0.78-4)
[2023-10-13T23:39:56+0300] [ALPM] upgraded strawberry (1.0.18-2 -> 1.0.20-1)
[2023-10-13T23:39:56+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:39:57+0300] [ALPM] upgraded sudo (1.9.14.p2-1 -> 1.9.14.p3-1)
[2023-10-13T23:39:57+0300] [ALPM] upgraded syncthing (1.23.6-1 -> 1.25.0-1)
[2023-10-13T23:39:57+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:39:57+0300] [ALPM] upgraded systemd-sysvcompat (253.7-1 -> 254.5-1)
[2023-10-13T23:39:58+0300] [ALPM] upgraded terminus-font (4.49.1-5 -> 4.49.1-6)
[2023-10-13T23:39:58+0300] [ALPM] upgraded tesseract (5.3.2-1 -> 5.3.3-1)
[2023-10-13T23:40:49+0300] [ALPM] upgraded texstudio (4.5.2-3 -> 4.6.3-1)
[2023-10-13T23:41:24+0300] [ALPM] upgraded thunderbird (115.0.1-1 -> 115.3.1-1)
[2023-10-13T23:41:46+0300] [ALPM] upgraded tigervnc (1.13.1-1 -> 1.13.1-2)
[2023-10-13T23:41:47+0300] [ALPM] upgraded vte-common (0.72.2-2 -> 0.74.0-1)
[2023-10-13T23:41:51+0300] [ALPM] upgraded vte3 (0.72.2-2 -> 0.74.0-1)
[2023-10-13T23:42:00+0300] [ALPM] upgraded xapp (2.6.1-1 -> 2.6.1-2)
[2023-10-13T23:42:02+0300] [ALPM] upgraded timeshift (23.07.1-1 -> 23.07.1-2)
[2023-10-13T23:42:02+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:42:16+0300] [ALPM] upgraded tk (8.6.13-1 -> 8.6.13-2)
[2023-10-13T23:42:16+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:42:17+0300] [ALPM] upgraded tlp (1.5.0-6 -> 1.6.1-1)
[2023-10-13T23:42:18+0300] [ALPM] upgraded traceroute (2.1.2-1 -> 2.1.3-1)
[2023-10-13T23:42:26+0300] [ALPM] upgraded transmission-gtk (4.0.3-1 -> 4.0.4-1)
[2023-10-13T23:42:27+0300] [ALPM] upgraded unixodbc (2.3.11-1 -> 2.3.12-1)
[2023-10-13T23:42:42+0300] [ALPM] upgraded vala (0.56.9-1 -> 0.56.13-1)
[2023-10-13T23:42:53+0300] [ALPM] upgraded valgrind (3.21.0-2 -> 3.21.0-4)
[2023-10-13T23:43:09+0300] [ALPM] upgraded ventoy (1.0.94-1 -> 1.0.96-1)
[2023-10-13T23:44:30+0300] [ALPM] upgraded virtualbox (7.0.10-1 -> 7.0.10-2)
[2023-10-13T23:44:37+0300] [ALPM] upgraded virtualbox-guest-utils (7.0.10-1 -> 7.0.10-2)
[2023-10-13T23:45:03+0300] [ALPM] upgraded vlc (3.0.18-13 -> 3.0.18-17)
[2023-10-13T23:45:52+0300] [ALPM] upgraded webkit2gtk (2.40.4-1 -> 2.42.1-1)
[2023-10-13T23:48:43+0300] [ALPM] upgraded wine (8.12-1 -> 8.17-1)
[2023-10-13T23:48:43+0300] [ALPM] upgraded winetricks (20220411-1 -> 20230212-1)
[2023-10-13T23:48:43+0300] [ALPM] upgraded wireless-regdb (2023.05.03-1 -> 2023.09.01-1)
[2023-10-13T23:49:33+0300] [ALPM] upgraded wireshark-cli (4.0.7-1 -> 4.0.10-1)
[2023-10-13T23:49:33+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:49:41+0300] [ALPM] upgraded wireshark-qt (4.0.7-1 -> 4.0.10-1)
[2023-10-13T23:49:44+0300] [ALPM] upgraded xfsprogs (6.3.0-2 -> 6.4.0-1)
[2023-10-13T23:50:03+0300] [ALPM] upgraded xscreensaver (6.06-1 -> 6.07-2)
[2023-10-13T23:50:15+0300] [ALPM] upgraded yakuake (23.04.3-1 -> 23.08.1-1)
[2023-10-13T23:50:25+0300] [ALPM] upgraded yay (12.1.0-1 -> 12.1.3-1)
[2023-10-13T23:50:25+0300] [ALPM] upgraded zita-resampler (1.10.1-1 -> 1.11.2-1)
[2023-10-13T23:50:28+0300] [ALPM] upgraded zsh-completions (0.34.0-4 -> 0.35.0-1)
[2023-10-13T23:50:31+0300] [ALPM] upgraded zsh-history-substring-search (1.0.2-2 -> 1.1.0-1)
[2023-10-13T23:53:38+0300] [ALPM] transaction completed
[2023-10-13T23:53:51+0300] [ALPM] running '20-systemd-sysusers.hook'...
[2023-10-13T23:53:52+0300] [ALPM-SCRIPTLET] /bin/sh: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /bin/sh)
[2023-10-13T23:53:52+0300] [ALPM] running '30-systemd-binfmt.hook'...
[2023-10-13T23:53:52+0300] [ALPM] running '30-systemd-catalog.hook'...
[2023-10-13T23:53:52+0300] [ALPM] running '30-systemd-daemon-reload.hook'...
[2023-10-13T23:53:52+0300] [ALPM] running '30-systemd-hwdb.hook'...
[2023-10-13T23:53:52+0300] [ALPM] running '30-systemd-sysctl.hook'...
[2023-10-13T23:53:52+0300] [ALPM] running '30-systemd-tmpfiles.hook'...
[2023-10-13T23:53:52+0300] [ALPM] running '30-systemd-udev-reload.hook'...
[2023-10-13T23:53:52+0300] [ALPM] running '30-systemd-update.hook'...
[2023-10-13T23:53:52+0300] [ALPM] running '30-update-mime-database.hook'...
[2023-10-13T23:53:53+0300] [ALPM-SCRIPTLET] /usr/bin/env: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/env)
[2023-10-13T23:53:53+0300] [ALPM] running '40-update-ca-trust.hook'...
[2023-10-13T23:53:53+0300] [ALPM-SCRIPTLET] /bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /bin/bash)
[2023-10-13T23:53:53+0300] [ALPM] running '60-depmod.hook'...
[2023-10-13T23:53:53+0300] [ALPM] running '70-dkms-install.hook'...
[2023-10-13T23:53:53+0300] [ALPM] running '72-texlive-fmtutil.hook'...
[2023-10-13T23:53:53+0300] [ALPM] running '73-texlive-updmap.hook'...
[2023-10-13T23:53:54+0300] [ALPM-SCRIPTLET] /bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /bin/bash)
[2023-10-13T23:53:54+0300] [ALPM] running '90-mkinitcpio-install.hook'...
[2023-10-13T23:53:54+0300] [ALPM-SCRIPTLET] /usr/bin/env: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/env)
[2023-10-13T23:53:54+0300] [ALPM] running '90-nvidia-470xx-utils.hook'...
[2023-10-13T23:53:54+0300] [ALPM-SCRIPTLET] /bin/sh: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /bin/sh)
[2023-10-13T23:53:54+0300] [ALPM] running '90-update-appstream-cache.hook'...
[2023-10-13T23:53:55+0300] [ALPM-SCRIPTLET] /usr/bin/appstreamcli: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libglib-2.0.so.0)
[2023-10-13T23:53:55+0300] [ALPM-SCRIPTLET] /usr/bin/appstreamcli: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libgio-2.0.so.0)
[2023-10-13T23:53:55+0300] [ALPM-SCRIPTLET] /usr/bin/appstreamcli: /usr/lib/libm.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libxml2.so.2)
[2023-10-13T23:53:55+0300] [ALPM-SCRIPTLET] /usr/bin/appstreamcli: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libsystemd.so.0)
[2023-10-13T23:53:55+0300] [ALPM-SCRIPTLET] /usr/bin/appstreamcli: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libmount.so.1)
[2023-10-13T23:53:55+0300] [ALPM-SCRIPTLET] /usr/bin/appstreamcli: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libcrypto.so.3)
[2023-10-13T23:53:55+0300] [ALPM-SCRIPTLET] /usr/bin/appstreamcli: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libblkid.so.1)
[2023-10-13T23:53:55+0300] [ALPM-SCRIPTLET] /usr/bin/appstreamcli: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libstdc++.so.6)
[2023-10-13T23:53:55+0300] [ALPM] running '99-grub.hook'...
[2023-10-13T23:53:55+0300] [ALPM-SCRIPTLET] /bin/sh: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /bin/sh)
[2023-10-13T23:53:55+0300] [ALPM] running 'clean_package_cache.hook'...
[2023-10-13T23:53:55+0300] [ALPM-SCRIPTLET] /usr/bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/bin/bash)
[2023-10-13T23:53:55+0300] [ALPM] running 'dbus-reload.hook'...
[2023-10-13T23:53:55+0300] [ALPM] running 'detect-old-perl-modules.hook'...
[2023-10-13T23:53:55+0300] [ALPM-SCRIPTLET] /bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /bin/bash)
[2023-10-13T23:53:55+0300] [ALPM] running 'firefox-post.hook'...
[2023-10-13T23:53:55+0300] [ALPM] running 'fontconfig.hook'...
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /usr/bin/fc-cache: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libharfbuzz.so.0)
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /usr/bin/fc-cache: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libglib-2.0.so.0)
[2023-10-13T23:53:56+0300] [ALPM] running 'fontconfig-32.hook'...
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /usr/bin/fc-cache-32: /usr/lib32/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib32/libharfbuzz.so.0)
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /usr/bin/fc-cache-32: /usr/lib32/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib32/libglib-2.0.so.0)
[2023-10-13T23:53:56+0300] [ALPM] running 'gdk-pixbuf-query-loaders.hook'...
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /usr/bin/gdk-pixbuf-query-loaders: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libglib-2.0.so.0)
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /usr/bin/gdk-pixbuf-query-loaders: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libgio-2.0.so.0)
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /usr/bin/gdk-pixbuf-query-loaders: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libmount.so.1)
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /usr/bin/gdk-pixbuf-query-loaders: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libblkid.so.1)
[2023-10-13T23:53:56+0300] [ALPM] running 'gdk-pixbuf-query-loaders-32.hook'...
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /usr/bin/gdk-pixbuf-query-loaders-32: /usr/lib32/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib32/libglib-2.0.so.0)
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /usr/bin/gdk-pixbuf-query-loaders-32: /usr/lib32/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib32/libgio-2.0.so.0)
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /usr/bin/gdk-pixbuf-query-loaders-32: /usr/lib32/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib32/libmount.so.1)
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /usr/bin/gdk-pixbuf-query-loaders-32: /usr/lib32/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib32/libblkid.so.1)
[2023-10-13T23:53:56+0300] [ALPM] running 'gio-querymodules.hook'...
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /usr/bin/gio-querymodules: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libglib-2.0.so.0)
[2023-10-13T23:53:56+0300] [ALPM] running 'gio-querymodules-32.hook'...
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /usr/bin/gio-querymodules-32: /usr/lib32/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib32/libglib-2.0.so.0)
[2023-10-13T23:53:56+0300] [ALPM] running 'glib-compile-schemas.hook'...
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /usr/bin/glib-compile-schemas: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libgio-2.0.so.0)
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /usr/bin/glib-compile-schemas: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libglib-2.0.so.0)
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /usr/bin/glib-compile-schemas: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libmount.so.1)
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /usr/bin/glib-compile-schemas: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libblkid.so.1)
[2023-10-13T23:53:56+0300] [ALPM] running 'gtk-update-icon-cache.hook'...
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /bin/bash: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /bin/bash)
[2023-10-13T23:53:56+0300] [ALPM] running 'gtk4-querymodules.hook'...
[2023-10-13T23:53:56+0300] [ALPM] running 'gvfsd.hook'...
[2023-10-13T23:53:56+0300] [ALPM-SCRIPTLET] /bin/sh: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /bin/sh)
[2023-10-13T23:53:56+0300] [ALPM] running 'kernel-alive-post.hook'...
[2023-10-13T23:53:56+0300] [ALPM] running 'manjaro-printer.hook'...
[2023-10-13T23:53:56+0300] [ALPM] running 'networkmanager-connectivity.hook'...
[2023-10-13T23:53:56+0300] [ALPM] running 'texinfo-install.hook'...
[2023-10-13T23:53:56+0300] [ALPM] running 'thunderbird-post.hook'...
[2023-10-13T23:53:57+0300] [ALPM] running 'update-desktop-database.hook'...
[2023-10-13T23:53:57+0300] [ALPM-SCRIPTLET] /usr/bin/update-desktop-database: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libglib-2.0.so.0)
[2023-10-13T23:53:57+0300] [ALPM] running 'update-vlc-plugin-cache.hook'...
[2023-10-13T23:53:57+0300] [ALPM-SCRIPTLET] /usr/lib/vlc/vlc-cache-gen: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libvlccore.so.9)
[2023-10-13T23:53:57+0300] [ALPM-SCRIPTLET] /usr/lib/vlc/vlc-cache-gen: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libdbus-1.so.3)
[2023-10-13T23:53:57+0300] [ALPM-SCRIPTLET] /usr/lib/vlc/vlc-cache-gen: /usr/lib/libc.so.6: version `GLIBC_2.38' not found (required by /usr/lib/libsystemd.so.0)
Hi @Zeosleus,
AFAIK, you’ll have to do it all manually:
https://wiki.archlinux.org/title/Pacstrap
And remember to read the update announcement, there was manual intervention neccessary or glibc-locales, which might have had some effect:
Also see:
And:
https://superuser.com/questions/1628582/arch-glibc-2-33-not-found-errors-after-updating-one-package/1628912#1628912
:point_up_2: looks promising indeed…
I used the pacstrap approach and it was successful, so now I should try the classic chroot approach, right?
Small question though, in the answer you linked the root partition was manually mounted using the mount command.
Do I need to unmount it before chrooting?
I think that would be totally pointless, as even manjaro-chroot mounts the partition before doing the chroot…
Yeah, that’s what I thought too…
I fixed it using the chroot approach, but to anyone stumbling onto this in the future, the answer is to first run the pacstrap command from the above superuser link.
Thanks a ton @Mirdarthos !!!
