$ make build
bash build.sh
=> Workon './src/volantes_cursors' ...
terminate called after throwing an instance of 'Gio::DBus::Error'
xargs: sh: terminated by signal 6
make: *** [Makefile:7: build] Error 125
I could neither makpkg the AUR package, nor perform NO_AT_BRIDGE=1 make build
$ NO_AT_BRIDGE=1 make build
bash build.sh
But if it works for you … then I wonder whats my problem?
Me neither, thats why I’m here. I was willing to accept I touched some config or was missing a package … but it was really only this project giving errors and I couldnt make sense of it.
Doesnt work with a clean plasma profile either.
…but it appears the clean chroot build worked.
Which is nice … but I would really like to figure out whats broken if there is indeed something to fix.
(and then I can move on to adding a few different sizes to this cursor theme)
I imagine DBUS_SESSION_BUS_ADDRESS (or something) is not set (or the given path is unreachable from the chroot), so the problematic part of the code never runs.
I have to add that on my machine I am getting the same crash that was in the issue linked by me previously, so a bit different from your issue.
And it does seem to run fine if I set -P 1 in the xargs command. So presumably it tries to own a dbus name, which fails, hence the exception. It seems g_register_application() fails when it tries to query the primary instance, which will have exited by that point.
