Interesting problem - when I run Timeshift-gtk, I am unable to browse the files.
When I launch in terminal (kdsu timeshift-gtk) and I hit ‘browse’ I see that it’s attempting to open the folder with other applications (easytag first, when I removed that it then started to open folders with filebot).
Now I can’t run settings as root… so how do I set the default file browser for the root user?
then I can try also as su
But still, timeshift tries to open a folder with filebot as root.
❯ su timeshift-gtk
[sudo] password for ben:
App config loaded: /etc/timeshift/timeshift.json
/dev/sdc1 is mounted at: /run/timeshift/backup, options: rw,relatime
No … timeshift … if its a graphical application that not only needs to be opened with su/sudo … and then also calls for a root graphical file manager … then … thats pretty silly.
Not really.
Until proper polkit or gvfs or similar support in dolphin (incoming soon supposedly) is fully functional you should not have any sort of ‘admin dolphin’ and certainly not ‘sudo dolphin’ which is rightly blocked.
Right - so we have a problem, a root application has the option to browse files, but that’s not allowed. Also the Settings is unable to set the default browser being called by timeshift-gtk.
So I start timeshift, enter password, and am now unable to browse files as I previously could. This also means I can’t ‘browse’ the non-root timeshift backups as I could before - it’s a new problem, and hence something which changed possibly when updating this week to plasma 20.x
From a quick look … it also seems you are using the wrong executable … timeshift-launcher apparently does use polkit to validate you first.
…and… it seems that its broken similar to gufw.
$ timeshift-launcher
Unable to init server: Could not connect: Connection refused
(timeshift-gtk:209061): Gtk-WARNING **: 18:43:39.298: cannot open display:
which is equal to:
$ pkexec timeshift-gtk
(timeshift-gtk:209660): Gtk-WARNING **: 18:45:30.599: cannot open display:
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to ‘/tmp/runtime-root’
“Session bus not found\nTo circumvent this problem try the following command (with Linux and bash)\nexport $(dbus-launch)”
yeah … there wouldnt be. its setting an env var.
I kinda more meant include it in the string like above. but it should also now be ative in your current session … so execute the launcher again.
When I hit browse, then I get:
❯ timeshift-launcher
[Warning] Deleted invalid lock
